  1. Jan 17, 2025 at 6:50 PM
    Florida AF
    Logan
    North Florida
    Havent gotten around to before and after pics, so for those who know....
    I am more sore today than ever before...
    Took out both trees back to the tree line and leveled the barn area some more... worked the lot for several hours and really learned to appreciate my help who wasnt there today... enough on and off tractor time to drive a man insane..
  2. Jan 17, 2025 at 7:10 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Not surprised
    I don’t know many people that have had much success in switching over in s house originally piped/set up for a tank heater.
    if I was close I’d come help wrestle it in
  3. Jan 17, 2025 at 7:12 PM
    Florida AF
    Logan
    North Florida
    Facts! Have you installed one before? you are far enough way that I will curse a lot, but close enough that if you need help we can figure it out.
    OldGuy03 and TaquitoBandito like this.
  4. Jan 17, 2025 at 7:12 PM
    RainMan_PNW
    Casey
    Clark County, WA
    24” DIA is gonna take a LOT of pieces to print.
  5. Jan 17, 2025 at 7:15 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Just pulled the trigger on a whole house softener/filter system for lime and arsenic. After 19 years the well has moved above safe limits and I have to start treating. That bill is gonna hurt for a while.
  6. Jan 17, 2025 at 7:18 PM
    Florida AF
    Logan
    North Florida
    I am not far behind you. We purchased a super expensive put in and now I am pretty sure I need a softener on top of it... so I am holding some emotions back. But yeah... right there with you
  7. Jan 17, 2025 at 7:26 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Yars I had to replace an entire well system last January and writing that check hurt me physically. New well pump (200ft), booster, 500g tank, whole house filters that back wash themselves, etc. but then no water bills so guess all good haha.
    TaquitoBandito, woods and Florida AF like this.
  8. Jan 17, 2025 at 7:28 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah
    My well is 427 ft deep and rated for 25gpm. I haven’t had to do any maintenance with it for almost 20 years. Thankful I don’t have to do a storage tank and all that crap.
  9. Jan 17, 2025 at 7:31 PM
    Florida AF
    Logan
    North Florida
    Im 30' deep... but yeah, just replaced a shit ton of things because they ran unfiltered high iron into the house for over a year untreated..... so I dont know what half of what you just said is... but I understand the pain.
    TaquitoBandito likes this.
  10. Jan 17, 2025 at 7:40 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Have them add a prefilter (20” is pretty normal) before the big house filters, you swap the filters every 3-4 months but cost a dollar and catch 99% of the stuff to save the rest of system from wear and tear. Surprisingly large fragments of metal make it into this filter.
  11. Jan 17, 2025 at 8:22 PM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    Jinxed myself. Realized the condenser fan had been running nonstop. Defrost board relay tested bad now. Chasing my tail.
  12. Jan 18, 2025 at 3:30 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I recently stopped using those plastic wrenches, and sprung for the metal versions. Game changer!
    https://www.aquapurefilters.com/col...-pure-steel-filter-housing-wrench-ap801-ap802
  13. Jan 18, 2025 at 6:52 AM
    shifty` Inside his chest they found ten thousand pencils
    Ha! Appreciate the offer.
    I should maybe clarify in case it was missed. “Laying some rod” or “laying some pipe” in my youth was a euphemism for sex.
  14. Jan 18, 2025 at 7:29 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    3 new gfci breakers for out standalone hot tub. Bubbler, heater and jets. Poor panel is overloaded for sure but we never use the heavy stuff at the same time (ev charger and tub)
  15. Jan 18, 2025 at 9:29 PM
    eddiefromcali
    Eddie
    100% Stock
    Forgot about this one too. The above drop in tub requires a fixed drain in the slab. Guess i missed the mark so i had to use a flex pipe
  16. Jan 18, 2025 at 11:40 PM
    Blue By U
    Blue By U New Member
    The tub has no overflow? Fixed drain in the slab does not mean surrounded by concrete. I should have a box-out to allow for P-trap swing so it will line up.
    TaquitoBandito and shifty` like this.
  17. Jan 19, 2025 at 12:33 AM
    eddiefromcali
    Eddie
    100% Stock
    Does have an overflow, built in like a sink. P trap was in place and the drain kit was installed like in the video. Either the tub specs were off or I screwed up by like half an inch. But I don't have enough wiggle room between the wall and the shower glass to just drop it in at that spot. Either way, it's in and working. Drains just fine and allows for some movement now, in case we bump it.
    The way this kit works, everything is installed and your placement better be on point cuz there's no box like in a traditional tub drain on slab. The original tub did have a box, but it was up against the wall on the left...I moved it all to the center of the area since the tub is a center drain now. Had to cut/break concrete, extend the plumbing and put in a new trap.
  18. Jan 19, 2025 at 1:57 AM
    Blue By U
    Best laid plans. I would have been chipping concrete. Anything non serviceable has to be glued or soldered, no mechanical joints.
  19. Jan 19, 2025 at 8:47 AM
    eddiefromcali
    Eddie
    100% Stock
    Agreed but I'm not redoing it all for that 5in piece of flex pipe. We've had that in other homes under a sink (Previous owner installed) and it was fine. Tub is light enough that if it ever needs servicing, it's not hard at all. Picture might make it seem longer but that's because I was lifting the tub from one side about 6in to get up in there.
  20. Jan 19, 2025 at 11:09 AM
    blackoutt
    NWA
    OEM+
    Reddit lied to me. The relay is actually normally closed so it's good. I found the only thing that could shut my heat pump fan AND compressor off from running constantly was to pull the thermostat off the wall. Even commanding it off from the thermostat wouldn't shut it off.
    Scored a pallet sale replacement for $35 on FB marketplace this morning! Did a pin to pin continuity check on both thermostats and the old one has a short between two pins while new one doesn't. Installed and testing new stat but not going to call it a win just yet. Something had to short all this stuff out originally so it's back to wire inspection for rubs in the outdoor unit.
  21. Jan 19, 2025 at 8:14 PM
    Blue By U
    Thats what she said!
    eddiefromcali[QUOTED] likes this.
  22. Jan 19, 2025 at 11:11 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Replaced the rollers in one of my garage bays and used silicone spray all over. Didn’t know this was even a thing until I saw a video on it. Was surprised the rollers are about 25-30$ a set for 10 or 12. Took all of 25 mins to replace 10 and spray. Took a before and after and wow the door is silent, now the chain/opener is the noisiest thing. The annoying screech sound is all gone which I had assumed was just part of garage door life haha.
  23. Jan 19, 2025 at 11:18 PM
    NWPirate
    Zach
    WA
    Awesome!
    Where did you get the poly rollers?
    :spending:
  24. Jan 20, 2025 at 12:25 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    These guys over on Amazon, can’t vouch for them long term but the ones I took out were from 1995 and never had a bearings to begin with haha. Definitely measure your pin length and count them as it appears to vary alot.
    The easiest method to replace them is to remove the track bar on one side and do the bottom rollers then the top roller usually can be unbolted by itself. No bending or removing the “red” bolts.
  25. Jan 20, 2025 at 1:00 AM
    NWPirate
    Zach
    WA
    :fistbump:
    TaquitoBandito and FrenchToasty like this.
  26. Jan 20, 2025 at 7:16 AM
    I use those rollers as it’s quieter over the standard ones
  27. Jan 20, 2025 at 4:58 PM
    Out with the old, in with the new. Had to call a plumber friend over to help stuff this cumbersome thing into place and do the copper. I’m inept, and cannot sweat copper proper. I was also out of romex so I couldn’t route that power line better. HVAC dude wrapped it around the back of the water heater.
    Florida AF, woods, Fotnot and 4 others like this.
  28. Jan 20, 2025 at 6:24 PM
    Mine had these cheesy mounts and I replaced them with these.
  29. Jan 21, 2025 at 4:03 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    The govee? I just installed those before Christmas. Kept the cheesy mounts, where did you get those nice ones?
  30. Jan 21, 2025 at 4:22 AM
    Kattshop3DPrinting on Etsy. Yes, mine are the Govee Outdoor Permanent lights Elite which is the same as the Outdoor Permanent Lights 2.
    woods[QUOTED] likes this.
