  1. Jun 14, 2024 at 7:29 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Well after building my deck the wife said she didn’t want the Griddle or pizza oven on it so I had to build another deck for ‘cooking’. Anyways, my wallet, knees and back hurt but it’s done.
    also, started to redo the garage and built a tote storage system. Takes up less space and uses the space way better.
  2. Jun 14, 2024 at 7:38 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Tell them demo the Sheetrock and plywood for the arch, use same width lumbers for plates and staggered the studs so you have a full width wall. And tell the client it’s better for noise reduction. Make a jamb extension for door. A 2 years apprentice could do better than that.
    BroHon and NWPirate like this.
  3. Jun 14, 2024 at 7:49 PM
    Florida AF
    Logan
    North Florida
    When I get my building next year, I will be doing the same. Already have a stack of empty totes for more aggressive organization and full totes to go through still. Looking forward to getting this all off my patio...
    Speaking of patio, finished coating the roof. Missing cold beverages other than water right now, but it works.
    Before:
    After:
    Spotting is just coating, it actually looks pretty decent this time around. Hoping to call it done, although I will go up and caulk some edges when it isnt 100 degrees outside.
    BroHon, CodyP[QUOTED] and WAtundra4x4 like this.
  4. Jun 15, 2024 at 5:10 AM
    daveeasa
    David
    I like the tote storage. Might attempt that myself if I can find time. I’ve been using $200 Whalen industrial racks for now, gets the job done and super stable. Some of my bins are pretty heavy. But that cubby approach is more compact, 5 high in about what I’m using for 4 and flexible width which would help me for some specific spots.
    one thing I decided long ago, despite the cost penalty, clear bins only. So nice to see what’s inside vs having labels. More expensive though.
    Did you anchor to the floor or are these freestanding? Toenail or build the studs on the ground as prefab walls?
    Wish someone sold a kit for this out of steel.
    CodyP[QUOTED] likes this.
  5. Jun 15, 2024 at 5:57 AM
    Every bit of this has to go. Structural or not, it’s very poor craftsmanship. I wouldn’t let that pass in a garden shed remodel. It certainly isn’t close to meeting code requirements for that door framing, where’s the header supported by jackstuds to keep the house from settling and pinching your door closed?!! Looks like the home improvement version of “this just rolled in” when there’s spray foam and baling wire along with drywall screws holding a car together. If I was the contractor I would be embarrassed. If I was the framer I would look for a new line of work.
    BroHon and NewImprovedRon like this.
  6. Jun 15, 2024 at 8:56 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    NWPirate likes this.
  7. Jun 15, 2024 at 10:47 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Got my sprinklers going after being in my house for a year. We got a ton of rain last year, so i didn’t even bother turning them on. It’s been way drier this year so after a little troubleshooting and replacing heads, we’re good to go!
  8. Jun 15, 2024 at 10:55 AM
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    Based on my previous post I’m sick of hiring help right now. I have a few that need replaced. In a DIY scale how hard is it?
    NWPirate and BreyTundy[QUOTED] like this.
  9. Jun 15, 2024 at 11:00 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Not bad at all! Especially if you're just replacing heads, it'll take you longer to drive to Home Depot and buy the heads than it will to actually replace them. Just remove one of the broken heads and bring that with you so you can match up thread patterns. I think total I'm out less than $65 for five heads and some small spare fittings.
  10. Jun 16, 2024 at 9:15 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    It is straight forward. You might as well get used to fixing the sprinkler system now as you will have experience for future repairs. I have lots of spare parts to be ready for a repair when needed. I’ve become comfortable with adding bubblers and added sprinkler heads. Water requirements change as the landscaping matures. Plants die off or are replaced over time.
  11. Jun 16, 2024 at 10:33 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Buy a whole bunch of different lengths fittings and return the wrong ones afterward.
    BreyTundy and daveeasa like this.
  12. Jun 16, 2024 at 11:38 AM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    Took down some trees and bushes in prep for a ground mount solar system. Gotta get a skid steer in here to grade it. Unfortunately those two oaks will be felled soon. Had to stop work as a doe decided to temporarily take up residence to give birth.
  13. Jun 16, 2024 at 11:42 AM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    Have a tankless on propane and considering adding another smaller tankless under the kitchen (furthest fixture) so I can shut off the recirc and only run it when i need tonuse it. Waste of propane.
    daveeasa[QUOTED] likes this.
  14. Jun 16, 2024 at 12:41 PM
    Outbound
    Aaron
    Northern Alberta
    Step 1: Fire the framer.
    Step 2: Tear out that abomination.
    Step 3: Do literally anything else and have it turn out better.
    BroHon, NewImprovedRon, Kung and 2 others like this.
  15. Jun 16, 2024 at 1:04 PM
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    I literally could have done that. Even my wife asked first thing, “aren’t they supposed to cut out that drywall to attach it”
  16. Jun 16, 2024 at 1:27 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Not really home improvement, but home building, haha. But the heck with it on this Fathers Day and I am getting some couch time for the first time in months. We are building and I am doing the work myself. Got a Bobcat e60 for the weekend. Dug the main power line (130 feet) and dug the sewer line out (200 feet). Also dug out where the 1,000 gallon under ground propane tank will go. Also tour out a bunch of waste concrete in the driveway when we poured the footers, foundation walls, and basement slab.
    IMG_0971.jpg IMG_0970.jpg IMG_0972.jpg IMG_0974.jpg IMG_0975.jpg IMG_0980.jpg IMG_0979.jpg
    BroHon, B.Ross, Florida AF and 6 others like this.
  17. Jun 16, 2024 at 1:30 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    Anytime spent operating some heavy equipment is enjoyable.
    T-Rex266 likes this.
  18. Jun 16, 2024 at 2:53 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    That's why best practice for recirc with a tankless is to run the loop downstream of the heater with a small (like 2-5 gallon) tank heater.
    JCBerb[QUOTED] likes this.
  19. Jun 17, 2024 at 6:23 PM
    Florida AF
    Logan
    North Florida
    Went and purchased a new property toy. Then I mowed the yard.
  20. Jun 17, 2024 at 6:54 PM
    Nice. They originally built those about an hour from where I live. Headquarters is still there I think. Batesville, AR
    Florida AF[QUOTED] likes this.
  21. Jun 17, 2024 at 7:02 PM
    Florida AF
    Logan
    North Florida
    Yeah, he got big and made some moves for sure. Owner has a house down this way too. I was torn on a couple different factors, but I am happy with my decision. At least, for now lol
  22. Jun 17, 2024 at 7:16 PM
    There's the dog....haha. :thumbsup:
  23. Jun 17, 2024 at 8:29 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Siding is now fitted and the gutter downspout is routed. I had to use some flashing material to make a “custom” chute for the water to follow under the downspout and keep it away from the ledger board and get the exit down to the concrete foundation. Probably totally unnecessary but I couldn’t leave it alone.
    Still waiting for the electrician to install outlets and wiring for sconce lights, and post cap lights.
    I’m also informed that a motorized roof mounted 16’X12’ awning is next. So I guess the sparky can install a box and switch for that too.
    Pretty soon I’m going to be into this for $30K.
    BroHon, TreeCat, RainMan_PNW and 3 others like this.
  24. Jun 17, 2024 at 8:37 PM
    Coal Dragger
    Kung Fu Dick
    Nice!
    I bought a new mower too. Just much smaller.
    22” deck EGO with their aluminum deck so it can run 3350 RPM, I guess blade speeds that high aren’t legal with composite mower decks.
    The old Husqvarna is going to storage, if we buy a rental I’ll let the tenants use it.
    BroHon and Florida AF[QUOTED] like this.
  25. Jun 18, 2024 at 1:10 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Well this has turned into an absolute nightmare…..we went with a big East coast company because of their reputation and reviews. Paid more than we should but wanted the peace of mind that they knew what they were doing. The county inspector has come three times and failed them…..for the past nine days absolutely no work has been done (on a job that the contract says would take 3-5 days to complete). I have called the office manager twice with no response to get an update on why they haven’t shown up and what’s going on. I am trying to be patient and understanding but the lack of communication is unacceptable to me. Running a business that way is beyond my comprehension and I have no patience for it, especially after they have $25k of my money. Next course of action is to get a lawyer involved but I want to try to play nice as they still have a ton of work to do and I don’t want them to just slap it together. Kind of at a loss here………I have considered calling the inspector to see what’s going on as well.
    BroHon likes this.
  26. Jun 18, 2024 at 4:01 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Step one would be to withhold any further payment if you haven't already. A delay longer than the duration of the schedule is absolutely unacceptable without a viable reason (natural disaster or equivalent). If their office is located locally, I'd just show up and ask WTF is going on, that's a classic one. They can't ignore you if you're standing at the front desk lol. The fact that they would fail inspection three times on a non load bearing structure is pretty fishy as well. I'm sure there's strict requirements for hurricane ties to fight uplift and things like that, but if they charge that much money, I would at least expect them to be fluent with the local codes. I wouldn't shy away from calling your local building inspector and explaining the situation. If you're working with a larger contractor then they likely have some experience with them and might be able to help. That's a bummer that you're in that situation, it seems that the days of builders and contractors doing the right thing have all since past. Best of luck and keep up posted as things progress.
  27. Jun 18, 2024 at 4:48 AM
    Kung
    KG, VA
    All of this. Bluntly put, I know we all want to be nice, and being respectful is always a good thing...but a contract is a two-way street and you and I both know there's no way in HELL they would fail to enforce said contract if you fell short on your part (e.g., didn't make payments or the like).
    One thing I did learn when having work done - I never go with a company based on reviews alone. I check reviews and the like and THEN I specifically ask the elderly people where I live who *THEY* would go with for two reasons:
    1. They've been around a while and know things.
    2. They won't hesitate to get crochety on you, so if THEY are happy that means something. :rofl:
    BroHon and BreyTundy[QUOTED] like this.
  28. Jun 18, 2024 at 5:27 AM
    Florida AF
    Logan
    North Florida
    Yes sir, he is still being a PITA and not losing his trauma..... but he is still here near me at all times. He did not like the mower and followed me around for the first hour or so before he went a dug a hole to hide in.
    Nice! And you spent a lot less, who is the real winner here LOL. Good luck with the new setup, everyone I know with those love them and hope the same for you!
    I will not like this.... good luck getting this resolved!
  29. Jun 18, 2024 at 5:38 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Found the contractor he’s working with
  30. Jun 18, 2024 at 6:32 AM
    It's nice to see that you kept him and are working with him. You have had him long enough that he is attached to his pet parent. :thumbsup:
