  1. May 11, 2024 at 6:23 PM
    Interesting. I wonder what else it chewed through other than food for it do that
  2. May 11, 2024 at 6:57 PM
    shifty` You can call 1 (800) PP5-1-DooDoo
    It's the major downfall to disposals. We usually need to replace ours every 8-10 years. But usually don't figure that out until it's already leaked and bloated the under-counter boards.
  3. May 11, 2024 at 7:45 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    A utensil in there can do some damage too:anonymous:
    EDIT: I dropped a secondary defense over it (strainer cover) so it only gets fully opened when you need it.
  4. May 11, 2024 at 8:00 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    That's Deadly! What a nice place to hang out. Stone/hardscape is the only way to go. I did it with the cheap 16x16 on my 16'x20' out back, best decision I made. pic 2014
    NG fire pit and grill, the Bose, and some beers haha
  5. May 13, 2024 at 10:47 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    BroHon and Ponderosa_Pine like this.
  6. May 13, 2024 at 6:24 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Your chickens don't seem to appreciate your work. Or, maybe they're just inspecting it from both sides :notsure::thumbsup:
  7. May 14, 2024 at 8:26 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    You guys need to get a leak sensor! Not expensive.
  8. May 14, 2024 at 9:40 AM
    Have one after the first failure. Failed to alert us soon enough, both times, under both sinks in question.
    EDIT: If you have one that's better than the 'frog' thing I got off Woot many moons ago, I'm all ears.
  9. May 14, 2024 at 10:33 AM
    Need a large flat pan that can cover the under sink space and place the moisture sensor in it.
    shifty`[QUOTED] likes this.
  10. May 14, 2024 at 11:13 AM
    coTony
    Tony
    Montrose, CO
    This is what I use and bought from Amazon. The wire has a sensor on the end of it and I have the sensor laying next to the drain under the washer. As soon as water touches it that damn thing is LOUD. I tested with a glass of water poured on the floor and it is pretty quick.
  11. May 14, 2024 at 11:38 AM
    SD Surfer
    Bruce
    So Cal
    Got the patio power washed and re-sealed.
    Paid a guy to do that, but my part (moving all the furniture and crap off the patio) was harder than his part. My wife has WAY too many succulents and potted plants.
    Looks nice again though.
    Ready for summer nights soon.
  12. May 14, 2024 at 11:55 AM
    I have a huge rubber catch mat under there. The 1st time the main sink disposal ate shit, I installed it. The next time we had a massive leak under that sink that really FUBAR'd the base, it's because the hose on the wand was dripping, and started saturating the area behind where the pipes come up from the floor, which is outside the footprint of the rubber catchbasin mat. The mat has saved us once, for sure. But in none of those three incidents did we get an alert. On the sink under our island, it's a similar story, where we can only cover so much because, unfortunately, it's a mid-floor level, so pipes are coming up from the floor of the cabinets.
    This would be an easy solve for me if we had a solid, flat floor, and all drains/incoming were coming out of the wall. It's just not the case. I can take pics if that doesn't make sense.
  13. May 14, 2024 at 4:43 PM
    coTony
    Tony
    Montrose, CO
    Does anyone have experience with removing hard water build up from a water fountain? This thing is beautiful when it is running but the build up is getting bad and taking away from the beauty. I have no clue what kind of stone it is made out of but all 3 pieces are the same stone (base, center stem and the upper ball) and look like the same kind. Any help would be appreciated, I have some time now so looking forward to getting this thing all cleaned up
    Base
    Upper Ball
    Close up of the upper ball
    Close up of base
    TaquitoBandito, BroHon and ATV25 like this.
  14. May 14, 2024 at 4:49 PM
    Really, the only thing that's going to remove buildup like that is probably an acid. Thing about acids is, if you don't know what the base stone is, you may be taking stone along with the acid.
    Maybe don't do something as strong as muriatic or phosphoric acid. I'd probably buy a bottle of CLR, squirt it into a jar, and spot-apply it to some of the taller crust to see if it does anything to the underlying stone. If not, go to town.
    No reason you can't try the same with one of the other two stronger acids, but ... tread lightly, test first. And while you're at it, do something to balance out the water that's in that thing.
    BroHon, Blufin and coTony[QUOTED] like this.
  15. May 14, 2024 at 5:47 PM
    coTony
    Tony
    Montrose, CO
    This is Arizona and I am moving, it will be just fine once I clean it. That is the underlying issue, what kind of stone is it? Well I have time to mess with it I guess and see which of the acids will work. Thanks for the info!
  16. May 14, 2024 at 5:47 PM
    WAtundra4x4
    Den
    Wet side WA
    Our house insurance gave us a 5 % discount if we added sensors for water, with a home system from Hedge. My cost was a couple hundred dollars but I had sensors everywhere. We ended up getting a lot of sensors and it was also phone notifications. I really liked the system but the were no longer supported by our insurance. A long story….. Well, they switched to a Ring system, and they provided a whole home security system, a $600 system, that cost me like $6. Not many leak sensors, 2, one under the kitchen sink and by the fridge. Also motion sensors, camera, and a couple of door sensors, plus a “listener” that goes next to the fire/carbon monoxide. They have several levels of monitoring services, so I get a phone message. If a fire or carbon monoxide it will dispatch fire/police. I have a rubber pan under the sink to catch any drips. We actually had a small leak under the sink as the sink plumbing was not tight(new house construction). We also got one year free service with the system. I’m thinking of cancelling my Xfinity security and just using the ring but I really like the Xfinity notifications when the cameras detect motion people on the drive way and porch. If we get a delivery I’m on it asap.
  17. May 14, 2024 at 5:58 PM
    I'm already running ring doorbell, flood cams, ring alarm w/ring retrofit to adapt our door/window bugs into it, so this may work nicely to round that out. We're all Nest on t-stats and smoke/CO, and Ring on perimeter cams, Unifi on interior LV and cams. House is pretty wired, sadsome water drips screwed me, just about everything else is monitored or on backup.
    WAtundra4x4[QUOTED] and T-Rex266 like this.
  18. May 14, 2024 at 6:11 PM
    Florida AF
    Logan
    North Florida
    Have I mentioned I hate painting?? Hopefully we get a break from the rain so I can focus on my truck and camper tomorrow, we will see.
  19. May 14, 2024 at 10:12 PM
    WAtundra4x4
    Den
    Wet side WA
    Looks like a no brainer to add the sensor. The Ring system looks like a well designed product.
  20. May 15, 2024 at 6:17 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    I'd like yous guys opinion on this.
    My shed needs new siding.
    AP1GczMlVIadVPLmH3L5WufG1sFVj1sGrNJ9VS6p_5272f6deff3e63754df80d0fe7006b4ba983fc68.jpg
    12X10 I'm pretty sure, you can see the panels rotting on the bottom. This was a garage for years, not sure when the previous owners chopped it in half but I see photos from the 80s of it taking up the entire foundation with the open end on the other side. The sides still have clapboard siding under this paneling. Not replacing that.
    AP1GczP1j5Q2gO2oIj-5VK6Wm-_lIfsrjG4ffTwU_8e38fa429baced2ad62034e3fcd5323e68aa7c1a.jpg
    you see what I mean here, the far wall you can see framing has been added and only the back of that paneling. The panel is rotted at the bottom as you can see sunlight coming in.
    so I'm going to remove the rotting siding and replace it with this, I think.
    https://www.lowes.com/pd/Plytanium-...tual-0-578-in-x-47-875-in-x-95-875-in/3010818
    Any thoughts or suggestions? I know this isn't rocket science but just like another set of eyes on it.
    TaquitoBandito likes this.
  21. May 15, 2024 at 6:25 AM
    ebpgh
    ebpgh .
    PA
    2020 Cement Tundra
    Buy something like this to save you hours of time. https://www.amazon.com/gp/product/B09WMLNPR5?ie=UTF8 Just got one and the driveway took an hour instead of all day. Less mess and came out better. I didn't think it would be that great, but it was a game changer. Tried a cheap one from HD, but it wasn't worth it.
  22. May 15, 2024 at 6:29 AM
    Go with Hardie-board, not plywood. Board and batten style is the rage. The Hardie is a fiber cement board, not wood. Won't rot.
    bfunke, shifty`, Fotnot and 1 other person like this.
  23. May 15, 2024 at 9:23 AM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    I’ve got a much simpler version that DeWalt makes but she doesn’t care for it. I’ve used it and it’s fine, I don’t get it but if it’s a backache she wants, then a backache is what she’s going to get! Thanks though.
  24. May 15, 2024 at 9:40 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Goggles and a good coarse nylon brush with muriatic acid mixed wth H2O.
    Simple fix.
    coTony[QUOTED] likes this.
  25. May 15, 2024 at 10:31 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Yup, Hardie board for your shed. I had to rebuild three dormers that were rotting wood and used Hardie plank on those. Still look new after 15 years.
    Moon Puppy and KNABORES like this.
  26. May 15, 2024 at 11:44 AM
    Jckdanls07
    Jckdanls07 We May Not Know Them All, BUT, We Owe Them All !!
    Keith
    Tampa Area
    2015 White Tundra SR5
    When using Hardee Panels... Treat it like drywall.. try no to break the face with the nail/screw head... If so you have to seal it with caulk (which you should do on all fasteners anyways)... Moisture will get in the damaged spot and the Hardee Panel will start to come apart (delaminate) after time...
  27. May 15, 2024 at 4:04 PM
    Florida AF
    Logan
    North Florida
    Rain broke just enough the get these planted finally. BlackBerry row is finally done!
    Or until the wife has more plans.
  28. May 15, 2024 at 4:37 PM
    I've been meaning to do this on my side yard. You go with one of the tribe-named thornless varieties?
  29. May 15, 2024 at 7:22 PM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    You mean like hide the screw head with caulk?
  30. May 15, 2024 at 9:31 PM
    AZTundra
    Paul
    Phoenix, AZ
    Can I ask what they charged you? My stamped concrete needs a good wash and reseal as well.
