  1. Jan 13, 2024 at 6:04 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    That looks like your providers ONT (Optical Network Terminal). If you plugged in there you might or might not get an IP, depends on if they provider has that interface turned up. I'd call the ISP and see what they say. I suspect they would turn it up for you if you show them the money.
  2. Jan 13, 2024 at 6:12 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Connect you laptop to it with an Ethernet cable and see if it has internet connectivity. My guess as Moon Pup points out, it won’t be active unless your paying for the second IP address.
    NWPirate likes this.
  3. Jan 13, 2024 at 6:15 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Or it could be open and the ISP is just clueless. I think you pointed out earlier it would be a different network segment and unless you got some mad internet routing skills your clients in your house will not talk to each other, but if they all just need internet it's no big deal.
    I'd stick to the Mesh idea over the one circuit you got.
    https://www.wired.com/story/best-mesh-wifi-routers/
    Good primer to read.
  4. Jan 13, 2024 at 7:12 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Made myself a pair of automatic gates to keep the dogs at home. Still working on creating posts to cover the steel posts and replacing the current fence
  5. Jan 13, 2024 at 7:37 AM
    bfunke
    South Carolina
    Nice looking gates. With that long cantilever how do you keep them from sagging
  6. Jan 13, 2024 at 8:11 AM
    NWPirate
    Zach
    WA
    Thanks for the help guys, I'll try to plug into that port just to see if it's active. That would be cool to get that little freebie :cool:
  7. Jan 13, 2024 at 9:04 AM
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    Love your house, it's really pretty!!
    TaquitoBandito likes this.
  8. Jan 13, 2024 at 10:10 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Keeping the weight down was a foremost consideration. Each gate leaf is 11' 8", 3" thick, 4' tall at the center and just under 6' tall at the post ends. They weigh around 150lbs ea. I used a lamination, "sandwich" type of construction to create overlapping joints that provide the sheer strength to eliminate sag. The curved rails straddle the "pickets" and the 4 vertical stiles to create a sort of semi hollow truss. The bottom rail too is semi hollow. All hollow areas are vented (just an inconspicuous hole drilled) to prevent a pressure build up on hot sunny days.
    Here's a pic of the "sandwich."
  9. Jan 13, 2024 at 10:12 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    THIS would be one reason to run a second router off the modem (at least in my mind). Not only do many IOT devices have lower settings for security, but they also likely only support older/slower WiFi hardware standards. “Dumbing” down the security or available throughput of your main network isn’t ideal.
    Most “consumer” mesh systems are set up to easily provide two networks - a primary and a “guest” network. Inherently, that guest network is blocked from seeing devices on your primary network, so that “guests” can’t access files, servers, printers, etc. that might be hacked. You could set up IOT devices on that network, but that depends on how often you have guests (as the parent of teens/young adults, there is constant activity on my guest network).
    More “pro” grade mesh systems allow for you to create more network IDs, but have more complicated setup. So there’s the trade off of simple setup/use vs more robust function.
    of course, back to the second router - you’re still going to end up with those devices on a separate network that cannot be seen by the main network. As long as all the IOT things are truly accessed via internet and not local network connections, that’s OK.
    TaquitoBandito and NWPirate like this.
  10. Jan 13, 2024 at 10:15 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Nice work.
  11. Jan 13, 2024 at 10:25 AM
    NWPirate
    Zach
    WA
    That would work, I wouldn't mind if the Tesla was the only thing on that network
  12. Jan 13, 2024 at 12:20 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Beautiful work on those gates 831Tun, very nice style :thumbsup:
  13. Jan 14, 2024 at 9:36 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Made the mistake and asked my wife if she wanted me to make this an accent wall in our living room. Of course she said yes so I was busy for a few days.
  14. Jan 14, 2024 at 10:18 AM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    I was digging up my clogged septic field this morning, but now it's raining. Going to have to trench a new field since the old line is bad.
    TaquitoBandito and CodyP like this.
  15. Jan 14, 2024 at 10:49 AM
    Beautiful
  16. Jan 14, 2024 at 10:49 AM
    I swapped out a kitchen canned light that was going on the Fritz.
    CodyP, TaquitoBandito and NWPirate like this.
  17. Jan 14, 2024 at 1:31 PM
    trucksareforgirls2
    Northeast USA
    Good god, that's my worst nightmare for my house!!! Didn't know you could replace your own leach field!! Good luck!
  18. Jan 14, 2024 at 2:15 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Lots of people with frozen furnace drains. IMG_7139.jpg I had a rock on a water diverting plate to keep the wind from blowing it off, I went and checked to see if my furnace drain to the outside was icing up. The water almost completed a frozen path to the pipe. Water was still flowing out a side area. I was gone all day so I was out there at night 14 degrees. Used a rock to knock the ice and remove the frozen rock/diverter. I put some pipe insulation around the drain pipe. Looked ok this morning but will check again today when I get back tonight.
  19. Jan 14, 2024 at 3:18 PM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    HVAC guy for annual check was 'pretty good sized', and broke my attic ladder. Have the new ladder in place (aluminum, rated for 375 lbs!)...just need to adjust the feet, trim any shims needed, a few more lag bolts, and put the molding back on. IMG-20240108-WA0000.jpg IMG-20240113-WA0004.jpg IMG-20240114-WA0000.jpg
  20. Jan 14, 2024 at 6:12 PM
    Half Assed
    Heartland Florida
    Shouldn't be too bad. The ground here in Florida is pretty soft and i only have one bathroom to dig for. Only thing i'm not looking forward to is backfilling the trench with gravel. But if i move a bunch of crap out of the way i think i can get some delivered right next to the hole.
  21. Jan 14, 2024 at 6:44 PM
    shifty` Inside his chest they found ten thousand pencils
    Finally got this done, no time to work on it otherwise. Was stumping over how I was going to rip 1/4" off a 2x4 to fill the void because I couldn't find a cabinet that was 18x24" for the 24.25" tall opening. Then I realized ... duh. The damn waferboard floor is 1/4" thick.
    So circular saw set to shy of 1/4" depth to notch the floor out, then boxed it all in for cabinet support on the sides, on the rear, and for the little overhang of "shelf" on the left I'll do something with later...
    Cabinet slid right in. I rigged up a system to hold the cabinet in place using a 2x6 filler on the left there. and ran a 2x across the top to hold the cabinet down into the slot I built down there. End product, though I'll probably frame out the right-hand side pocket screwing in a 2x2 if I can find a scrap one that's not totally twisted. This isn't pretty by any stretch, but it's tock solid and what I could toss together with scrap wood ... and it serves the purpose.
  22. Jan 14, 2024 at 6:51 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Ohhhhhhh Stainless! o_O
    Looks great/permanent to me:D And that thread identifier, reminded me I need one of those
  23. Jan 14, 2024 at 7:04 PM
    This is basically the one I picked up. I think I may move the damn thing to sit above the drawers, since it's roughly the same width. Quality isn't bad. Is it really worth the $$? I dunno. I'd have been happier paying a little less for Chinesium and I couldn't find vintage American made, but it's done its job a 100x over so ...
    Damn stainless is all I could find! And the price was right, so ... to hell with it. I need to oil it up though, so it doesn't get fingerprints and grease all over it.
  24. Jan 14, 2024 at 7:35 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Right, for what your looking at it seems like they could pump those identifiers out for under $20 all day.
    I joke about my stainless fetish, but Ive just gotten so sick of rusted fasteners/hardware I go for stainless whenever I can. One and Done. That cabinet is really nice:yes:
    BB Stacker likes this.
  25. Jan 14, 2024 at 8:14 PM
    $160 too.
    Looks nice. Metal is a bit thin, middle drawer open/close is really wonky. Slides are a bit cheap. I give 3.75 out of 5 stars. Clearly worth the money to have deep drawer storage. I’d definitely use it for outdoor kitchen/BBQ all day long.
  26. Jan 14, 2024 at 9:23 PM
    RainMan_PNW
    Casey
    Clark County, WA
    They make grey switches, outlets, and covers that would be a pretty close match.
    looks cool though.
  27. Jan 15, 2024 at 11:53 AM
    aelarson
    aelarson New Member
    AZ
    2021 1794 Tundra (Silver Sky Metallic)
    Wife and I just moved to AZ and bought a new house - I tackled the first big project for the living room.
    Framed a bump out, covered in plywood, glued and screwed some acoustic wood slat paneling, installed a fireplace and a big ass TV. Took a couple weekends - well worth the effort!
    IMG_8358.HEIC.jpg IMG_8361.HEIC.jpg IMG_8384.HEIC.jpg IMG_8387.HEIC.jpg IMG_8388.HEIC.jpg
  28. Jan 15, 2024 at 11:55 AM
    This is amazing!!
  29. Jan 15, 2024 at 11:55 AM
    aelarson
    aelarson New Member
    AZ
    Thank you:D
    TaquitoBandito and T-Rex266 like this.
  30. Jan 15, 2024 at 12:14 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    That's a nice outcome man I like it a lot! Just curious on the angle of the photo or maybe you have some tall ass ceilings...why is the TV mounted so low?
