  1. Aug 27, 2023 at 7:17 PM
    NWPirate
    Zach
    WA
    What a dick head.
  2. Aug 27, 2023 at 7:18 PM
    TaquitoBandito
    Joel (AKA Bif)
    I know, right?! I named him "Adam." :)
  3. Aug 27, 2023 at 7:19 PM
    NWPirate
    Zach
    WA
    Perfect!
    Tripleconpanna and T-Rex266 like this.
  4. Aug 27, 2023 at 7:41 PM
    Soo like this?
    Kung, Moon Puppy, RainMan_PNW and 3 others like this.
  5. Aug 27, 2023 at 8:17 PM
    TaquitoBandito
    Joel (AKA Bif)
  6. Aug 28, 2023 at 9:01 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Finished digging out the residue from the concrete wash that exposed the aggregate. There were spots of the wash that were solid enough that they came out in chuncks 8 x 6 x 10 inches. I moved all the rocks, sand, dirt to a back area of our property where there is a major dip. It will help hold the dirt there in place. I finally managed to get the pipe out and the sand dirt inside the drain pipe came out in clumps about 2 inches thick. The pipe under the front lawn from the T was clear enough that I am not worried about it. The total length of the pipe is about 37 ft. After wasni g out the inside of the pipes, IMG_6267.jpg 71467392667__3E4EE1D2-6EB7-447B-915D-A7CA2C66EFE2.jpg IMG_6260.jpg IMG_6252.jpg IMG_6243.jpg IMG_3760.jpg I added a new sleeve to the drain pipe to keep dirt out. I put some crushed rock on the bottom of the trench to provide a slight slope toward the T. I now need some drain rock to finish that out.
  7. Aug 28, 2023 at 4:13 PM
    Outbound
    Aaron
    Northern Alberta
    I need to turn this section of fence into a gate. It's 7ft 2in between the posts.
    I'm debating between 1 big gate hinged off the left post or splitting it into 2 doors. 2 doors would mean the one on the right would have about an 8" gap due to the slope.
    Both posts are solidly set, and I have six 10" galvanized t-hinges available.
    My biggest concern with the single gate is the amount of weight that would be hanging off the hinges.
    Thoughts?
    Prostar 190 and TaquitoBandito like this.
  8. Aug 28, 2023 at 4:55 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Just me but I think I would make it a double gate. Unless you use some real heavy duty hinges, a single gate will sag over time.
    ATV25 and TaquitoBandito like this.
  9. Aug 28, 2023 at 4:57 PM
    TaquitoBandito
    Joel (AKA Bif)
    I would probably add a post and make a 48 inch gate.
  10. Aug 28, 2023 at 4:58 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Weight is definitely going to be an issue. I wouldn't want that much gap though...
    Have you thought about trying to find a custom aluminum gate?? Probably be a bit more spendy than using existing pieces, but maybe you could achieve better coverage and reduce the weight significantly :notsure:
  11. Aug 28, 2023 at 5:00 PM
    TaquitoBandito
    Joel (AKA Bif)
    Are you wanting to park something back there?
    NewImprovedRon likes this.
  12. Aug 28, 2023 at 5:37 PM
    Outbound
    Aaron
    Northern Alberta
    I want to be able to get my boat trailer in there. That side of the house is all but useless without a gate in there.
    Aluminum would be nice but way too expensive and I don't have a welding machine at the moment.
  13. Aug 28, 2023 at 5:47 PM
    TaquitoBandito
    Joel (AKA Bif)
    What about straightening it out, stair-stepping the pickets over the slope and doing something like this:
  14. Aug 28, 2023 at 6:48 PM
    Outbound
    Aaron
    Northern Alberta
    I still need the gate on the high side to swing, so stepped pickets won't work.
    Leveling the ground would requite 3+ dump truck loads of material and a retaining wall.
  15. Aug 28, 2023 at 6:57 PM
    TaquitoBandito
    Joel (AKA Bif)
    If turn it into a sliding barn door type, you don't need it to swing. I think. I'm just stalling until @RainMan_PNW shows up.
  16. Aug 28, 2023 at 7:04 PM
    Outbound
    Aaron
    Northern Alberta
    I dont have room for it to slide. The post on the left in the pic is the property line. My neighbor's gate is on the far left.
    So I just laid out where the bottom of a straight gate on the uphill side would be. It's about 9.5in above ground level at the highest.
    My thought is I could build a piece that slided up and down to block that gap when the gate is closed.
  17. Aug 28, 2023 at 7:10 PM
    TaquitoBandito
    Joel (AKA Bif)
    Yeah, that might piss them off.
    That could work. Build the piece, slap a hinge it and flip it down. I'd think you'd have to reinforce the hell out of that door with metal to keep it from sagging. It's gonna be a heavy damn door. Too bad you couldn't build something that just flipped down and was sturdy enough that you could drive over it. That'd be cool as hell.
  18. Aug 28, 2023 at 7:10 PM
    AZTundra
    Paul
    Phoenix, AZ
    Would something like this work? Or at least give some ideas...
    Fotnot and TaquitoBandito like this.
  19. Aug 28, 2023 at 7:17 PM
    Tripleconpanna
    What about having it swing up in an arcing motion.. from like 9 oclock to 12 oclock or 3 to 12???
    BlueRibbon4x4 and TaquitoBandito like this.
  20. Aug 28, 2023 at 7:20 PM
    TaquitoBandito
    Joel (AKA Bif)
    He's only about 4ft tall - he'd have to get his daughter to open it for him. :)
    EDIT: I READ THAT WRONG :rofl:
    I guess you need to stick with the one gate but reinforce the hell out of it with something like this:
    https://www.homedepot.com/p/Adjust-...xuC1tg-s8ydonZ3E37UaAl7iEALw_wcB&gclsrc=aw.ds
  21. Aug 28, 2023 at 7:27 PM
    Tripleconpanna
    I don't think they have HDs in Canada; and I doubt they'd let that thing across the border w/o intervention...
  22. Aug 28, 2023 at 7:29 PM
    TaquitoBandito
    Joel (AKA Bif)
    Good point but I bet they have something like it up there. If not, I'm gonna move to Canadia and get rich selling fence gate reinforcement kits.
  23. Aug 28, 2023 at 8:09 PM
    Outbound
    Aaron
    Northern Alberta
    We do have HD in Canada. Lol. That frame is an idea I had too, but they don't stock it here and again...no welding machine.
    I think I'm going to let this marinate for a bit and kick aroubd a bunch of ideas.
  24. Aug 28, 2023 at 8:10 PM
    TaquitoBandito
    Joel (AKA Bif)
    Is moving one of them?
  25. Aug 28, 2023 at 8:35 PM
    Outbound
    Aaron
    Northern Alberta
    I wish. Probably in 8 - 10 years. Gonna be looking at places with more parking and probably a small acreage.
  26. Aug 28, 2023 at 8:41 PM
    TaquitoBandito
    Joel (AKA Bif)
    We lived with in our first house for 11 years. It was a Pulte starter home and I learned how to fix a lot of things because of that house. Also decided I hope to never live in an HOA or 5 ft from the neighbors house ever again.
  27. Aug 28, 2023 at 8:49 PM
    Outbound
    Aaron
    Northern Alberta
    Thankfuly HOA's arent a thing in my town. This is a spec built home and I've had to fix alot of shoddy workmanship. Never by a house built by Dirham Homes.
  28. Aug 28, 2023 at 8:53 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Freakin ceiling tile can suck it.
    biebs96, Prostar 190, CodyP and 4 others like this.
  29. Aug 28, 2023 at 9:02 PM
    TaquitoBandito
    Joel (AKA Bif)
    All tile can suck it. Looks great though!!
  30. Aug 28, 2023 at 9:07 PM
    BlueRibbon4x4
    Geno
    Thanks!
