  1. Jan 6, 2023 at 8:20 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    And there’s the reason they start house fires
  2. Jan 6, 2023 at 8:23 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Yeah - my vent is no more than 2 feet total from back of dryer straight up and then 90 out to the outlet, and I still pull the dryer and clean it out once a year.
  3. Jan 6, 2023 at 8:27 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Replaced the tank fill valve on my powder bath toilet last night because it stopped shutting itself off on Tuesday morning.
    And then just before bed had the slip-joint drain piping from my garbage disposal to the wall connection pop loose and had my dishwasher draining all of it’s water into the cabinet under the sink…
    :annoyed:
    Got everything mopped up, got the drain pipe all reconnected, got a fan drying out the floor (we caught it right away, so not much got under the cabinet).
    WAtundra4x4, saybng, Fotnot and 2 others like this.
  4. Jan 6, 2023 at 8:28 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Messy. That sucks. Hopefully the damage is minimal for you
  5. Jan 6, 2023 at 8:29 AM
    NWPirate
    Zach
    WA
    I was paranoid about that when I built so i planned a straight shot outside from the dryer. 8" of ducting and I still check it
  6. Jan 6, 2023 at 8:30 AM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    so true. I will be cleaning once a year also. I am going to redo the floor in the laundry room soon so I will change out to the mag vent. @RainMan_PNW thanks for all the good info
  7. Jan 6, 2023 at 8:31 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I don’t care who ya’re…8” is still a long pipe
  8. Jan 6, 2023 at 8:36 AM
    NWPirate
    Zach
    WA
    My wife used to shake her head when I would close our main water valve when gone more than one night.
    After hearing stories like this and fridge water lines blowing, she's on board.
    Edit: Glad it wasn't a total mess and ya caught it early Casey!
  9. Jan 6, 2023 at 8:36 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    i built and got about 6-8" of run from back to outside too.
    on yea....freakin huge! most houses can't handle that much pipe too:rolleyes:
  10. Jan 6, 2023 at 8:39 AM
    NWPirate
    Zach
    WA
    Got damn right. :thumbsup:
  11. Jan 6, 2023 at 8:39 AM
    Trentimus
    Trentimus New Member
    Trent
    2019 Tundra Off Road
    Nfab bars, undercover armor cover, hottails
    Your deck color is quite nice
    JohnH[QUOTED] likes this.
  12. Jan 6, 2023 at 9:07 AM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    TWSS
    CodyP[QUOTED] and NWPirate like this.
  13. Jan 6, 2023 at 9:26 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I bet that's exactly what happened. Previous owners had this siding installed in 2015. They did a shitty job on an outside electrical plug too. Also didn't install step flashing around the chimney. What's crazy is that I can see pretty far back in that hole and don't see any vent just laying there disconnected.
    Here are some pictures. The 3' feet of flex dryer vent is an easy fix. I just need to trim it. It dumps into a hole directly behind the dryer. Laundry room on left, pantry is on the right and behind the pantry is the exterior wall.
    Yes.
    I do have attic access but I'm guessing it isn't wise to fight gravity and send the vent up the wall, into the attic, and out?
    I'm honestly wondering if it would be better to relocate the dryer to the basement exterior wall. I really think my wife would hate that. What a cluster F...
  14. Jan 6, 2023 at 9:36 AM
    TaquitoBandito
    Joel (AKA Bif)
    I think it’s fine. This site has a lot of info:
    https://inspectapedia.com/ventilation/Clothes_Dryer_Vent_Installation.php
  15. Jan 6, 2023 at 10:04 AM
    RainMan_PNW
    Casey
    Clark County, WA
    You want your vent line to be as short as possible. Sounds like 10’ to the right in that one picture is the shortest route. If you can get the duct fed in from outside you’re winning because that lets the direction of the fittings with best for the direction of airflow. Fishing an elbow down through the hole to connect into the straight is going to be fun, but not impossible. Might look into using that mag vent as a flange at the floor to anchor things.
    like i said - don’t use screws that will poke inside and trap lint. Keep the inside as smooth as possible. Use heavy duty wide foil duct tape for the joints where you can.
    TaquitoBandito likes this.
  16. Jan 6, 2023 at 10:57 AM
    Azblue
    The Dirty T ( ^_^)_且
    I wish I could vent my dryer outside but the moron who designed my house thought it would be a good idea to have the laundry room on a inside wall in a room that opens into the garage.
    So of course my garage fills up with lint. I just use a leaf blower every now and then to clean up the garage. I sometimes even find some lint on my truck's air filter when I change it because the dryer vent is right in front of the truck.
    FirstGenVol and TaquitoBandito like this.
  17. Jan 6, 2023 at 10:59 AM
    TaquitoBandito
    Joel (AKA Bif)
    Ours goes into our screened in side porch which is also my workout room. I bought this a while back to try to cut back on the lint that I get out there but I have yet to put it on.
    https://www.amazon.com/gp/product/B01LVYZEQZ?ie=UTF8
  18. Jan 6, 2023 at 11:03 AM
    Azblue
  19. Jan 6, 2023 at 11:07 AM
    TaquitoBandito
    Joel (AKA Bif)
    I will but at the rate that I'm piling up projects, I may not get around to installing it until 2026.
  20. Jan 6, 2023 at 11:19 AM
    NWPirate
    Zach
    WA
    Track that guy down and slap him!
  21. Jan 6, 2023 at 12:50 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I would take that over my situation where it's dumping into my floor/basement ceiling. :annoyed:
    RainMan_PNW and Azblue[QUOTED] like this.
  22. Jan 6, 2023 at 2:58 PM
    NWPirate
    Zach
    WA
    Extra insulation? :confused:
    RainMan_PNW likes this.
  23. Jan 7, 2023 at 9:50 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Upstate on my dryer vent situation. I removed the outside cover for a better look. The hole measures exactly 4" but I could make it a little bigger. Anyone got a tool suggestion for that?
    There is no duct at all. If there ever was one, I can't see it. I see a lot of dryer lint resting on my HVAC ductwork. On a positive note, I can't see any mold. Not saying it isn't there but it looks good so far.
    Here is how much I've pulled out of the floor so far. This is getting stranger by the minute. So far I'm unable to pull it completely out. I can feel it's hooked to something inside now. I don't know if I should cut it or not. Really need to see in the hole.
  24. Jan 7, 2023 at 9:54 AM
    DaBoro54
    I use a multi tool with a circular saw attachment for such jobs.
    Wow that’s wild the amount you got out of there. Hopefully you are correct the mold is not in there
  25. Jan 7, 2023 at 10:31 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Confirmed they have it dumping into nothing. Just a piece of duct that went into the floor.
    Unbelievable. People suck. I went outside and had my wife stick a broom down the hole and shine a light. I can't even seen the broom and can barely see the light. It's not even a direct shot to the vent outside so it looks like my idea isn't going to work.
    I know this isn't ideal but I wonder if one of these would work.
    FUNMAS 3-in-1 Indoor Dryer Vent, Stainless Steel Screen Filter, Polyester Filter and Water Drawer System, Upgrade Safety Vent Flap, with 4 Pieces Polyester Filters, For Electric Clothes Dryers https://www.amazon.com/dp/B095KG5FPT
    TaquitoBandito, Fotnot and NWPirate like this.
  26. Jan 7, 2023 at 11:31 AM
    DaBoro54
    @FirstGenVol just a diy guy here too. That is definitely interesting and might we worth a try especially since you can clean it often. My question is where does all the condensation go?
    Maybe that can be a short term solution till you are ready to tackle it all the way
  27. Jan 7, 2023 at 12:54 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    Not my house but my neighbor, 82 years old, had 2 leaks at his toilet vent pipes. I'm not one for heights and his roof has a 6 in 12 pitch. It made fore a stressful Friday evening.
  28. Jan 7, 2023 at 1:51 PM
    RainMan_PNW
    Casey
    Clark County, WA
    My money is they just ran the fucking flex out to your outlet in the wall and it came undone at some point (or got pulled off)
    that is getting weirder by the minute
  29. Jan 7, 2023 at 6:52 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    When it rains it pours... Just discovered a leak on my roof, by the sky light, and another by the boiler exhaust.... what are the odds I need a new roof or should I get patches.. Clay tile roof.. unknown when it was replaced, if ever, 30 year old house...
    Also got a couple emails about needing to grab my ankles because my gas bill bout to double, as well as my electrical cuz they use Natural Gas at night.. so I may really need to look into solar, with a battery reserve in the near future...
  30. Jan 7, 2023 at 8:00 PM
    TaquitoBandito
    Joel (AKA Bif)
    Yeah, you'll be getting a lot of humidity in that little area.
    What about cutting out the flooring in that area, put your vent in properly, then tiling it? Not the cheapest solution at all but if your washer ever leaks, your flooring is gonna be hurting.
    RainMan_PNW and DaBoro54[QUOTED] like this.
