  1. Oct 28, 2022 at 7:10 PM
    #9601
    Azblue
    The Dirty T ( ^_^)_且
    After I cut it all out, I put a bunch of this down before reinstalling the toilet. Soon after, most of a grape vine that was here when I bought the house 22 years ago died. So, I think I found where the roots came from.
    https://www.acehardware.com/departm...UAkIZImeRbjXBqDeqeMaAtuMEALw_wcB&gclsrc=aw.ds
  2. Oct 28, 2022 at 7:15 PM
    #9602
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I would continue to dose with that stuff then. I think my moms house might have ruts too. Her kitchen sink is slow, I’ve snaked it before
    Azblue[QUOTED] likes this.
  3. Oct 28, 2022 at 7:23 PM
    #9603
    Azblue
    Roots suck. We should like start a foundation or charity to kill all roots. Maybe I'll start a committee to look into getting this going.
    Any thoughts on who should be on the committee?
  4. Oct 28, 2022 at 7:34 PM
    #9604
    Roots in an irrigation line or?
    I’ll be assistant regional manager to the regional manager of the root committee
  5. Oct 28, 2022 at 7:41 PM
    #9605
    Azblue
    Sewer lines. But before we appoint you I need to know if you have the proper qualifications.
    2 questions- Do you have sewer lines/drains and do you hate roots being in them?
  6. Oct 28, 2022 at 7:50 PM
    #9606
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  7. Oct 28, 2022 at 8:13 PM
    #9607
    Yes and maybe
  8. Oct 28, 2022 at 8:16 PM
    #9608
    Azblue
    Hmm, I'm a little hesitant considering your answer to part 2, but you come highly recommended so I will forward your application to the sub-committee the for committee that considers additions to committees,
    T-Rex266[QUOTED] likes this.
  9. Oct 28, 2022 at 8:25 PM
    #9609
    Committe report sent to me
    ignored
    Wait
    what
    Azblue likes this.
  10. Oct 29, 2022 at 6:03 AM
    #9610
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
  11. Oct 29, 2022 at 9:39 AM
    #9611
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Hmmm. I thought I had a can of copper sulphate and it was sold as a wood preservative. I’ll have to check this out..
  12. Oct 29, 2022 at 9:40 AM
    #9612
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    House has already gone into winter mode. My front door is dragging. Its a steel door, so am i going to have to rebuild the frame? Or maybe shave a hinge pocket or two? Didnt do it this bad last year...
  13. Oct 29, 2022 at 10:29 AM
    #9613
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Is the frame steel as well? My only door that doesn't give me hell during weather transitions is my front door that's steel with a steel frame.
    TaquitoBandito and FrenchToasty like this.
  14. Oct 29, 2022 at 10:34 AM
    #9614
    FrenchToasty
    Mo
    Bone stock
    Ours are starting to close normally now that the humidity is gone
  15. Oct 29, 2022 at 10:42 AM
    #9615
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    no, wood frame. I need to do the rear door, too. Might as well build new frames. Not worth having HD frames, cause i have a glass wall, but i'm thinking real hard about I-beaming the back wall for 2 15ft sections of acordian windows with a leg in the centerish.
    back wall could be pushed 12', front could be pushed 6'. That would make the gutters easier. Been wanting gutters since '20.
  16. Oct 29, 2022 at 10:52 AM
    #9616
    Azblue
    Mine are plastic. The roots grow up where the pipe come through the slab, then through the wax ring on the toilet and down the pipe. I guess plumbers call it a horse tail, fairly common.
  17. Oct 29, 2022 at 11:45 AM
    #9617
    Jayprestonky
    Jayprestonky New Member
    Central Kentucky
    2018 Tundra TRD
    Changed out some light switches and outlets.
  18. Oct 29, 2022 at 11:45 AM
    #9618
    FrenchToasty
    Mo
    Bone stock
    Which way did you leave the slots on the screws?
    FirstGenVol, CodyP, shawn3210 and 3 others like this.
  19. Oct 29, 2022 at 11:46 AM
    #9619
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Are all screws' slits lined up vertically?:boink:
    Gort, Prostar 190, shawn3210 and 3 others like this.
  20. Oct 29, 2022 at 11:48 AM
    #9620
    FrenchToasty
    Mo
    Bone stock
    Slit snob
    Gort, CodyP, NWPirate and 3 others like this.
  21. Oct 29, 2022 at 11:49 AM
    #9621
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I'm very picky about the slits I have to look at and handle multiple times a dayo_O
    Prostar 190, NWPirate, Azblue and 2 others like this.
  22. Oct 29, 2022 at 12:43 PM
    #9622
    TaquitoBandito
    Joel (AKA Bif)
    I've had luck with just tightening the screws on some of hinges but I'm thinking you already thought of that one.
    RainMan_PNW, Azblue and FrenchToasty like this.
  23. Oct 29, 2022 at 7:20 PM
    #9623
    RainMan_PNW
    Casey
    Clark County, WA
    You might try some door hinge shims first
    E-Z Shim EZ HS400BP 4" Hinge Shim (15 Pack), 4", 15 Count https://www.amazon.com/dp/B0044V0L8C
    Use them either between the door and the hinge or the hinge and the frame depending on what it looks like you need to correct
  24. Oct 29, 2022 at 7:22 PM
    #9624
    RainMan_PNW
    Casey
    Clark County, WA
    Ok. You guys also have slab on grade construction down there.
    I’m sitting on top of a basement. There’s one bathroom that could potentially do that, but it would have a long ways to grow first
  25. Oct 29, 2022 at 7:30 PM
    #9625
    NWPirate
    Zach
    WA
    I don't think you could find a single story slab on grade house in our neck of the woods if you tried. :D
  26. Oct 29, 2022 at 7:55 PM
    #9626
    RainMan_PNW
    Casey
    Clark County, WA
    There’s one just down the road from us about a mile. And a whole neighborhood in La Center they just built that way. Fuckiest thing I’ve ever seen around here. I get it in AZ, but up in WA, not a good idea
  27. Oct 29, 2022 at 7:58 PM
    #9627
    NWPirate
    Zach
    WA
    Interesting, sounds like a SW builder came up to La Center for a while. Lol
  28. Oct 29, 2022 at 10:46 PM
    #9628
    Azblue
    Maybe not the smartest thing for here either. It's tons of fun when a copper water line burst under the slab in the kitchen. :mad:
    TaquitoBandito likes this.
  29. Oct 29, 2022 at 10:49 PM
    #9629
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Wait, you guys are saying slab on grades are rare in the PNW?????
    Don’t come to Idaho cause I feel like that’s all they know how to do
  30. Oct 30, 2022 at 5:27 AM
    #9630
    NWPirate
    Zach
    WA
    As far as i knew yeah.
    That's interesting, single story homes too?
