  1. Aug 22, 2022 at 1:26 PM
    #8971
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    Can you just remove the drywall on one side all together?(from countertop down) Let the rest sit on top of the counter?
    TaquitoBandito likes this.
  2. Aug 22, 2022 at 1:37 PM
    #8972
    TaquitoBandito
    Joel (AKA Bif)
    :sawzall:
  3. Aug 22, 2022 at 1:43 PM
    #8973
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    We started two bathroom overhauls today. By we I mean the contractor I hired. He cut the counter top in one of them.
  4. Aug 22, 2022 at 1:43 PM
    #8974
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    Removing the sheetrock, you'd need to redo the corner, too. See if there's one you like that's a 1/4" narrower?
    If it's a non-standard width, may have to get a countertop cut, then a vanity base narrower, that you can do a fill piece on the side (there's a term for that, but I don't remember what it is) to fill up the alcove?
  5. Aug 22, 2022 at 1:49 PM
    #8975
    PXL_20220822_172652053.jpg PXL_20220822_184025819.jpg PXL_20220822_201015902.jpgRouter table in place, did a test bead on a scrap. Then, ran a plank of birdseye maple through the table saw clamped to a straightedge, to get a straight board. Did two beads, ripped the birdseye to 3"x 1/4", and glued and clamped the beads to it, to make a contrast molding (like you see in a lot of 30s-50s veneered furniture)...
  6. Aug 22, 2022 at 1:51 PM
    #8976
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Man you guys are quick to respond. Thanks so much.
    I wondered that. That’s better than replacing the drywall to me.
    The stupid top is glued down from factory but I guess I could separate it and hope not to Break anything. Not sure where I would take it to get cut though.
    It’s a 48” vanity but the top is wider. Bunch of liars. The back corner would be hidden and then above the vanity would be a backsplash so is there any reason I couldn’t just leave it at the studs?
    JMB[QUOTED] likes this.
  7. Aug 22, 2022 at 2:47 PM
    #8977
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Scribe the top, less an 1/8 and silicone in.
  8. Aug 22, 2022 at 3:18 PM
    #8978
    JMB
    Chesapeake, VA
    I wasn't here when the guy cut the vanity top. My project manager said she thought he used a circular saw. She made a 3 inch circle with her hands. Depending on the overhang you might be able to trim it on the left side.
  9. Aug 22, 2022 at 3:32 PM
    #8979
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    I like the angle of the bike rack. What kind did you use?
  10. Aug 22, 2022 at 5:41 PM
    #8980
    OV-1794
    OV-1794 New Member
    get a grinder with a diamond blade and trim a 1/4 inch off the left side door of the counter. You’ll caulk the wall so you’ll never see it.
  11. Aug 22, 2022 at 5:43 PM
    #8981
    :thumbsup:
  12. Aug 22, 2022 at 5:54 PM
    #8982
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    It's a Steady Rack. They're great since they can swing out in either direction and is really easy to use and get the bikes on. You don't have to fiddle with the bike trying to slot it into a hook and it won't damage your rim. It's also easy for my spouse to use who has limited upper body strength to lift bikes up on a rack. They're pricey but if she likes it and easy for her to use then it's worth it.
    https://www.steadyrack.com/
    aRabidLunatic[QUOTED] likes this.
  13. Aug 25, 2022 at 9:30 AM
    #8983
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Tried my hand at woodworking. This shit is tough to get precise. Especially once youre halfway through and realize your miter saw is off by a degree lol...46 and 44 degrees makes a 90 right?
    Needless to say I've spent over $300 the past two days on machinist measuring tools and woodworking stuff...hooked me.
  14. Aug 25, 2022 at 10:34 AM
    #8984
    I know, I justify so many tools by, "I can do it cheaper than hiring somebody or buying one, and I'll still have the tools!"
  15. Aug 25, 2022 at 11:09 AM
    #8985
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Cant count how many times ive used this and the best part is its always true!
    TaquitoBandito and Ckatz53 like this.
  16. Aug 25, 2022 at 12:01 PM
    #8986
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    @1UPPER
    What goes into installing an elevator? Anything crazy, or just pre-fab unit that you slide in and wire up?
    TaquitoBandito, ColoradoTJ and 1UPPER like this.
  17. Aug 25, 2022 at 12:24 PM
    #8987
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    I used to install residential elevators in college. They are pretty straightforward but more involved than just slide in and place. I could elaborate but it would be a lot to type and it’s been a while since I put one in.
    I’m interested to see what @1UPPER says.
  18. Aug 25, 2022 at 12:32 PM
    #8988
    Ckatz53
    Ckatz53 Newish
    MD
    Finished this up and starting on a pinewood fence for the 1/4" trim router.
  19. Aug 25, 2022 at 3:12 PM
    #8989
    snoope
    snoope The Old Man
    Trane has been installed :cool: Large unit outside and the the 3 mini-splits in the home...:thumbsup: Definitely worth the 4 month wait :eek::eek::eek::eek:
    2nd pic is the unit out in the "To be finished Florida Room" o_O , again waiting on supplies :rolleyes::rolleyes: and permitting :(
    This weekend or next the 3 old units will travel to my son's home including those ugly a$$ metal boxes...
  20. Aug 25, 2022 at 3:23 PM
    #8990
    Ckatz53
    Ckatz53 Newish
    MD
    Fence with vacuum exhaust port and storage for router bits/attachments made. I may end up capping them off with a hinge to make mini cabinets...we will see how well the shop vac keeps sawdust at bay. Side walls keep it center but just have to clamp it down when in use.
  21. Aug 25, 2022 at 8:44 PM
    #8991
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    To be honest I’ve not installed an elevator just yet but I’m doing a bunch of research and talking to several companies and other builders I know. The most common elevator I’ve been told about is an in line gear drive system. It’s more cost affective and straight forward for an install but it’s more noticeable for noise levels. You can also do a hydraulic elevator lift but it’s more expensive, requires yearly inspections but its very quiet. The other option I looked into was a lift driven elevators.
    I will have to make sure my walls and elevator chase have framed with blocking per the specs. I will need to have a 8”-12” deep pit sunken into my foundation slab with a drain pipe built in the slab and drained to the outside. The interior finishes on the elevator and having glass doors will definitely add more cost to the whole budget. Still working out those details now.
    TaquitoBandito and ColoradoTJ like this.
  22. Aug 25, 2022 at 8:51 PM
    #8992
    Money....lots of money.
  23. Aug 25, 2022 at 9:37 PM
    #8993
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Just had this conversation at work
  24. Aug 25, 2022 at 9:38 PM
    #8994
    RainMan_PNW
    Casey
    Clark County, WA
    Friend if my wife’s is doing one in her parents new house. It’s pretty involved…from the little bit I’ve been following it.
  25. Aug 26, 2022 at 3:21 PM
    #8995
    Ckatz53
    Ckatz53 Newish
    MD
    Think I'm done. It isn't perfect but the majority of it minus the fence and base are made from cheap common wood so....curvy. And my freehand routing needs some work with the hinge inlays for the mini cabinets but, it's functional and ready to build stuff. Inlay front fence made. The locks are threaded inserts in a ripped and planed common board, 5/16 bolts, some spacers, a wing nut welded to the top, and the tension comes from a rubber shower head grommet that has a gap that compresses with pressure and locks the board down. Works perfectly and zeroed it earlier. Removable with a spare insert made to make it a flat table again when needed.
  26. Aug 26, 2022 at 3:22 PM
    #8996
    I’m going to take on painting our garage walls. Anything special need to be done for the drywall on this?
  27. Aug 26, 2022 at 3:22 PM
    #8997
    MadMaxCanon
    Textured already?
  28. Aug 26, 2022 at 3:29 PM
    #8998
    No. Just going to do most of it all white and one wall red
    MadMaxCanon[QUOTED] likes this.
  29. Aug 26, 2022 at 3:42 PM
    #8999
    Ckatz53
    Ckatz53 Newish
    MD
    Has the garage been used as a garage? As in like mine, I'm constantly welding/grinding so shit is everywhere and I'm constantly cleaning the walls.
    If it's relatively clean, just wipe it off of dust and paint with industrial wall paint. Get a sprayer if you can much easier.
    If it's like my garage, get a drywall sanding pole and some 80 or 100 grit paper, scuff the walls up, wipe down, and paint. I need to repaint my garage but the amount if sanding I'd need to do would be stupid. I'm probably going to just gut the drywall and reinsulate
    Satin is the way to go for garage with good lighting. If lighting is just okay, semi gloss will be fine. Anything glossier will show imperfections more.
  30. Aug 26, 2022 at 3:43 PM
    #9000
    Nope. Just crap hanging on walls and such.
    TaquitoBandito, ColoradoTJ and Fotnot like this.
