  1. Jul 3, 2022 at 6:53 PM
    #8491
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Sounds like you may need to slow your feed rate a bit - that blade is THICK
  2. Jul 3, 2022 at 7:01 PM
    #8492
    TaquitoBandito
    Joel (AKA Bif)
    Noticed. If the next photo I post is it sticking out of my skull, you need to explain it to Mrs Bandito. :D
  3. Jul 3, 2022 at 7:12 PM
    #8493
    RainMan_PNW
    Casey
    Clark County, WA
    I got your back
    :fistbump:
  4. Jul 3, 2022 at 7:46 PM
    #8494
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Don't come around my place uninvited if you don't want your ankles molested.
    Seriously tho, he'll let you know if someone shows up in plenty of time for me to retrieve something to greet them with.
    WVI, NewImprovedRon, Njmike13 and 4 others like this.
  5. Jul 3, 2022 at 8:53 PM
    #8495
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Every dog has a purpose, and that dog seems serious about his business; nice looking pup!!!!
  6. Jul 4, 2022 at 4:06 PM
    #8496
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Installed a "free" hot tub in the yard. Dry weight is 900lbs moved it with ropes, pulleys and pvc pipes alone. It was a 12 pack kinda job.
    WVI, Bama, NewImprovedRon and 11 others like this.
  7. Jul 4, 2022 at 9:35 PM
    #8497
    EmergencyMaximum
    EmergencyMaximum New Member
    I swear I thought it was a lunch box lol. I scrolled on the phone all the way down before page all loaded and those last 2 pix is what I saw.
    Anyways, buying and assembling a grill, does that count as home improvement?
  8. Jul 5, 2022 at 7:06 AM
    #8498
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    i did the same with a new patio table/chair set. hoping that counts. i used a drill and sweat outside while drinking beer if that helps too. i even put some old spray wax on it after a rain and before another rain ha
  9. Jul 5, 2022 at 7:14 AM
    #8499
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    Rain...nice!
    Over the weekend...spread more mulch, started modifying my old Delta table saw for a new accurate fence...got a project coming up!
  10. Jul 5, 2022 at 2:21 PM
    #8500
    TaquitoBandito
    Joel (AKA Bif)
    "Acquired" like with some bolt cutters after hours at Home Depot?
  11. Jul 5, 2022 at 2:23 PM
    #8501
    EmergencyMaximum
    It was lowe's:sawzall:
  12. Jul 5, 2022 at 2:24 PM
    #8502
    TaquitoBandito
    Joel (AKA Bif)
    I approve :fistbump:
  13. Jul 5, 2022 at 9:27 PM
    #8503
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Threw up some drywall in the bathroom. I’m about a sheet short so I’ll finish it later I guess….but my back hurts
  14. Jul 6, 2022 at 5:28 AM
    #8504
    RainMan_PNW
    Casey
    Clark County, WA
    Looks good
    My only suggestion - check your screw spacing. Should be maximum of 16” the “field” on the walls and 12” on the ceiling. Edges should be 8” on both. That’s to ensure proper support of the panels over time.
    And before you button everything up, think about putting wood blocking anywhere you might want a towel holder or toilet paper holder. Way better than crappy drywall anchors later. I also put blocking behind where the door knob would hit the wall - even with door stops, it’s sometimes possible for a door to flex enough to bump the knob. Solid blocking makes that knob just slightly dent the texture instead of punching a hole in the wall.
  15. Jul 6, 2022 at 9:22 AM
    #8505
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    good to know. Thanks. Thought the screws were close enough but I’ll double check my measurements. I did have the forethought and put blocking for the TP holder and towel hooks though.
  16. Jul 6, 2022 at 3:54 PM
    #8506
    EmergencyMaximum
    Marginally better.:hattip:I never had my anchor go loose. Solid as a bull.:ballchain:
    RainMan_PNW[QUOTED] likes this.
  17. Jul 6, 2022 at 4:09 PM
    #8507
    Did a little backsplash tile work today. I really hate getting different lot number tile packs but sometimes you have to do it. Between three Home Depot’s I was able to get 17. Wife found 6 more at a different location.
    Put up some felt paper and hardy board. Set tile out and cut the outlets.
    0A3706AD-E787-41CE-9119-3FFE59D4CFA9.jpg A2C04245-BFD7-4E03-8C68-9A4D55C2EAEF.jpg
    Ran out of tile for the morning.
    Enjoyed a brunch beer.
    4x4platinum, Njmike13, WVI and 19 others like this.
  18. Jul 6, 2022 at 4:30 PM
    #8508
    Looking solid!
    ColoradoTJ likes this.
  19. Jul 6, 2022 at 8:33 PM
    #8509
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Looks great, when you mix up the different batches together, you won't even notice. :thumbsup:
  20. Jul 6, 2022 at 8:36 PM
    #8510
    EmergencyMaximum
    After a few beers:drunk:
  21. Jul 6, 2022 at 10:05 PM
    #8511
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Thoughts on improving front yard landscaping? Cul-de-sac.
    E642E0BF-E626-4B00-8E03-40E3239419D5.jpg D955DBCD-969B-418E-8D79-66984CA2EC45.jpg
    (pics from early spring before leaves)
    Njmike13 and TaquitoBandito like this.
  22. Jul 6, 2022 at 10:29 PM
    #8512
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Put some holes in the garage ceiling to hang the hardtop. Simple. Cheap. Single man ability removal.
    WVI, WAtundra4x4, AZTundra and 7 others like this.
  23. Jul 6, 2022 at 11:14 PM
    #8513
    What don’t/do you like with the current landscaping Brian?
    TaquitoBandito likes this.
  24. Jul 6, 2022 at 11:35 PM
    #8514
    csuviper
    Broomfield, CO
    Just looks sloppy I guess.
    The main rock base has to stay as it matches the neighbors rocks.
    Grey house, large brown rocks. Thinking of somehow removing and adding in large dark grey granite rocks.
    Thinking an evergreen tree would be good.
    Don't like the black mulch, only black mulch in the neighborhood.
    TaquitoBandito and ColoradoTJ like this.
  25. Jul 7, 2022 at 4:56 AM
    #8515
    Those are some great ideas. I’m not a mulch person since we get some pretty high winds and it just ends up everywhere but where it’s supposed to be (heard the cut up rubber mulch is better).
    T-Rex266 and TaquitoBandito like this.
  26. Jul 7, 2022 at 7:06 AM
    #8516
    I hate mulch. We only have a very very small amount our front around the tree. You’ll need to replace it annually unless U go rubber, which is heavier
  27. Jul 7, 2022 at 7:52 AM
    #8517
    EmergencyMaximum
    How does rubber hold moisture?
  28. Jul 7, 2022 at 10:14 AM
    #8518
    RainMan_PNW
    Casey
    Clark County, WA
    not worth a shit. it does somewhat block evaporation, but doesn't work the same way traditional mulch does - it's more for the visual and coverage of bare dirt. And it'll never break down or turn into anything organic or useful.
  29. Jul 7, 2022 at 10:17 AM
    #8519
    My wife loves cedar mulch to a fault. If our chickens get out, they raise holy hell on our rock gardens. I just hand her a broom…:D
  30. Jul 7, 2022 at 10:19 AM
    #8520
    RainMan_PNW
    Casey
    Clark County, WA
    For mulch, western hemlock is my favorite. It's soft and doesn't have splinters. For wood CHIPS, we use cedar. It lasts forever out here.
