  1. May 6, 2022 at 12:57 PM
    #8191
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I haven't known too many people that been able to seamlessly transition from an old floor to a new one like you're saying without a slight difference in heights. Minimal? Yes. I've been in a house that did something like this and they were a good friend so I inquired. It was separated by a threshold and there was I believe he said a 1/16" difference between the two floors different thicknesses because if something similar. He saw the difference when his new floor matched up before the threshold was put down. It wasn't drastic and no one ever tripped, but I felt it (BARELY) and stood back to look at. I was convinced and he confirmed it when asked.
    I only say this because if you're kinda anal about stuff and it doesn't match up, I'd hate for you to have wasted time and money on it. About 13/16" higher is pretty noticeable IMO
    TaquitoBandito and CodyP[QUOTED] like this.
  2. May 6, 2022 at 1:55 PM
    #8192
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Not a fan of OSB for sub floor, even under “floating” floors like LVP - it’s lumpy and can cause anomalies or soft spots. And it has a tendency to off-gas formaldehyde that can be obnoxious. Best thing is to use particle board or MDF in the desired thickness to get a flatter surface underneath the planking. Screw it down judiciously and hold 1/8” gaps at your joints for expansion/contraction
  3. May 6, 2022 at 2:22 PM
    #8193
    DmoHtx15
    DmoHtx15 New Member
    D
    2021 Trd Sport
    Katzkin leather/heated
    Backyard is bare so a process. Layed and stamped concrete. Gonna let it dry and set for a month or so then start getting the covered patio/pergola going
  4. May 6, 2022 at 5:44 PM
    #8194
    Slayer
    Slayer Member
    Slayer
    I wouldn't put OSB on a dog house.
    that stuff is crap... & it's 50 bucks a sheet around here.
    not a fan of particle board or MDF either.. it's just glued saw dust that desinigrates with a low amount of moisture
    a better choice would be a/c plywood..
    you'll likely have to pull some of the door jambs & casings anyway to get the LVP to lock except your starting run.
    remember to leave 1/4" gap at all perimeters on the LVP.
    make sure you run a key or a knife across your LVP selection before you buy. some are not very scratch
    resistant.
    good luck with your project
  5. May 6, 2022 at 5:53 PM
    #8195
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Current hard wood is in the bedrooms, hallway, living, and dining.
    Slate in entryway
    Tile in master bath has a transition piece
    Tile in hall bath is flush with flooring
    kitchen/laundry tile has a transition piece
    New flooring will be:
    carpet in bedrooms
    tile in master bath will stay the same
    tile in hall bath will be replaced with lvp
    lvp in hallway, hall bath, living, entry, dining, kitchen/laundry.
    Should be able to get down to the same layer everywhere except the master bath which will transition to carpet so that shouldn't be an issue.
    Oh I didn't know. I thought OSB was the bee's knees for subfloor. Guess I'll look into particle board then instead. Thanks
  6. May 6, 2022 at 6:15 PM
    #8196
    SouthWestGA
    SouthWestGA New Member
    Did a truck/crew pour that or did you hand mix it yourself?
    I just got quoted $2,800 for a 12x14 concrete patio extension
    But that was just the first guy and I’m still taking bids
  7. May 6, 2022 at 7:44 PM
    #8197
    DmoHtx15
    DmoHtx15 New Member
    D
    2021 Trd Sport
    Had a truck pour for me. Is the quote you got just supplies?
  8. May 6, 2022 at 9:42 PM
    #8198
    4x4platinum
    4x4platinum New Member
    18 platinum
    Had carpet put in 2 spare bedrooms and ripped up the floor in the storage room, and tomorrow will remove the drywall so I can rewire/insulate and figure out what the lasted owner attempted to cover up where the patch is.
  9. May 7, 2022 at 12:57 PM
    #8199
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    When the wife says I sure wish the big heavy as shit concrete hands were out from under the azaleas (where she wanted them last year) you start thinking how nice people have it living in the weekly motel.
  10. May 7, 2022 at 12:58 PM
    #8200
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    At least you’ve got an extra hand to help out…….
    Those look heavy AF!
  11. May 7, 2022 at 2:23 PM
    #8201
    Signed so construction begins for my finished basement :smokertransformer:
  12. May 7, 2022 at 2:53 PM
    #8202
    matt kruckenberg
    matt kruckenberg New Member
    slc ut
    2015 Trd Pro Inferno
  13. May 7, 2022 at 3:48 PM
    #8203
    Solid view too
  14. May 7, 2022 at 6:28 PM
    #8204
    RainMan_PNW
    Casey
    Clark County, WA
    Dig down through 5” of slimy muck/clay/old hay in the chicken run, then laid down hardware cloth and filled it back up with 1-1/2 CY of cedar chips. Between the concrete poured last weekend and the “bathtub floor” of hardware cloth, this should keep rodents from burrowing into the run and should keep things dryer for the birds.
  15. May 8, 2022 at 7:03 AM
    #8205
    TomC843
    Tom
    Charleston, SC
    Done. Angle of pic makes it look a little off, not centered. Will have to break out the bleach and hose.
  16. May 8, 2022 at 8:20 AM
    #8206
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Can you make a separate thread with all the deets?
    Im interested to see the results
  17. May 8, 2022 at 6:07 PM
    #8207
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Finally finished up my little kitchen remodel, think it turned out pretty nice. :) Still waiting on a fridge I ordered a mere 11 Weeks ago, but who's counting. Now onto the the family room. :facepalm:
    IMG_1750.jpg IMG_1751.jpg IMG_1757.jpg IMG_1760.jpg IMG_1761.jpg IMG_1763.jpg
  18. May 10, 2022 at 7:36 PM
    #8208
    TaquitoBandito
    Joel (AKA Bif)
    That looks AMAZING! Great job!
    WVI likes this.
  19. May 10, 2022 at 8:05 PM
    #8209
    TILLY
    Massachusetts
    Thank you Joel, I really appreciate that. :)
  20. May 10, 2022 at 8:32 PM
    #8210
    Getting closer to being completed with the rear patio project. stucco coloring completed with stonework.
    Next is the granite countertops, finish electrical, then landscaping.
    building handrails now to be powder coated.
    BBD18A69-21CF-4CAD-9003-A15BCADE5287.jpg DDB335F6-4956-4842-8D68-B2D109BF870C.jpg E74E6AEF-3E33-49D9-B0A5-F392BB80D061.jpg A81F964E-68C9-4770-897A-56F952D35422.jpg 868C0B64-9274-47D7-B431-1AAB30EA9A4C.jpg F9957412-C62C-4EEC-9AF0-CAE245B84F3E.jpg
  21. May 10, 2022 at 10:56 PM
    #8211
    They did a pretty good job color matching too! Ur backyard is where it’ll be at!
  22. May 11, 2022 at 11:38 AM
    #8212
    TaquitoBandito
    Joel (AKA Bif)
    Nothing interesting here. It's too freaking hot outside to get done what I really need to get done. I replaced a water filter for our bar sink/ice machine. The Woder only lasted about a year and a half so I switched to this FrizzLife filter that has cheap filter replacements (you have to replace the whole Woder). It probably didn't last as long as it should because my neighbor kept asking me for "filtered" water.
    I also replaced our Nest Doorbell with a Ring Pro 2 doorbell. We have some lady trying to establish herself at our address and, since Google dropped support for their alarm system, I switched over to Ring. This one is pretty cool because it'll pick up on people 30 ft away and tracks their movement. Alexa also will answer the door so when my neighbor comes to ask for filtered water, I can let her answer and then pretend it glitched and that I never got the message. ;)
    Oh, I ordered the doorbell and then I ordered a replacement cover to match the house. If you buy one, don't get the replacement cover. After I set it up, it told me it'd email me an offer for a free cover. :mad:
  23. May 11, 2022 at 12:23 PM
    #8213
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    WVI, T-Rex266 and TaquitoBandito like this.
  24. May 11, 2022 at 12:26 PM
    #8214
    TaquitoBandito
    Joel (AKA Bif)
  25. May 11, 2022 at 12:33 PM
    #8215
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I have 2 others. I'll need 2 more to let all the kids duel.
  26. May 11, 2022 at 12:46 PM
    #8216
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Kitchen overhaul in full swing...
    WAtundra4x4, WVI, Kimosabe and 7 others like this.
  27. May 11, 2022 at 12:56 PM
    #8217
    TaquitoBandito
    Joel (AKA Bif)
    RainMan_PNW, WAtundra4x4, WVI and 4 others like this.
  28. May 11, 2022 at 12:58 PM
    #8218
    Danimal86
    Daniel
    Sacramento, CA
    I'm confused on this filtered water business with the neighbors.
    Is this code for something?
  29. May 11, 2022 at 1:03 PM
    #8219
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
  30. May 11, 2022 at 1:03 PM
    #8220
    TaquitoBandito
    Joel (AKA Bif)
    How dare you, sir!
    It literally means he wanted filtered water. When we moved here, we bought a whole-home water filter. Unfortunately, it's only a 95% home water filter, so I had to install one under the sink for our ice maker. Our neighbor doesn't have filtered water, so he hits me up for 5 gallons every now and again. He's going through dialysis and chemo now so I don't really mind. I just like to bitch.
    He's getting his kitchen remodeled. When it's done, I'll probably go over there and put one of these filters under his kitchen sink.
