  1. Apr 25, 2022 at 5:20 AM
    #8161
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Our friend bought one off Greggslist, and had it disassembled and moved to her house and put back together for about 150, im guessing that’s the going rate for someone who knows what they’re doing
  2. Apr 25, 2022 at 5:06 PM
    #8162
    Yzed608
    Yzed608 New Member
    Wisconsin
    Awesome! They're holding up alright then I'm assuming? Do you have any on your house? Don't mind drilling holes in the garage, but house is a little different.
  3. Apr 25, 2022 at 6:21 PM
    #8163
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    Actually going through a reno. So pulled data lines to each corner of the house. Using POE injectors. Out of the weather, I think they will hold up for quite a long time. Even the ones that have been exposed, are holding their own. Right now screwed to the old wooden siding, but most likely will be installed to the soffit for the permanent install. Had an AHA moment. I'll probably install low voltage mounting brackets, like these
    https://www.lowes.com/pd/CANTEX-1-G...ZWZ8rXDqZ7c22S9n9uRoCvT8QAvD_BwE&gclsrc=aw.ds
    And then a blank and put the wires through that. Should be a clean install and allow me to work on it in the future if needed.
  4. Apr 26, 2022 at 2:39 PM
    #8164
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Threw some foam board against a few walls and rim joists. Framing and ductwork soffit are next.
    14FDC201-B120-463C-84AE-64BE99732D63.jpg 915B14C7-7193-489A-B92D-30D82C30712B.jpg 5F1C13CE-E738-4C44-8F71-593A1613AB45.jpg
    i really don’t have the room right now to move everything out so it’s been a bit of a pain working around things.
  5. Apr 26, 2022 at 3:08 PM
    #8165
    “J”
    “J” New Member
    NC
    2021 Tundra SR Barcelona Red
    Microwave arrived Friday, spent this morning installing it with the trim kit. Went fairly easy and turned out pretty good from a distance lol
  6. Apr 27, 2022 at 8:53 PM
    #8166
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Finishing up some odds and ends on my kitchen remodel, tonight's task was under-cabinet LED's. Found this kit at Lowe's and was a little hesitant because of it being Black&Decker, but it turns out to be a really nice kit. 10 different warm light settings, hand motion on/off, and a really easy install. Highly recommend if you're in the market for some lighting.
    IMG_1741.jpg IMG_1742.jpg IMG_1744.jpg IMG_1745.jpg IMG_1732.jpg IMG_1733.jpg IMG_1734.jpg
  7. Apr 29, 2022 at 4:08 PM
    #8167
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Went to HD and picked a bunch of concrete and lumber...
    Carried said concrete from the trailer down the side of the house, around the back of the house, down a flight of stairs to the basement and into an adjacent room to the bathroom where it's gonna be poured. Man that sucked. 22 80lb bags...I'm sore. The picture was on my 'break' halfway through lol
    Then I put up one of the small walls...
    And who said shooting a .22 cal indoors isn't fun haha!
    https://youtube.com/shorts/IKUO2YZtXXw?feature=share
  8. Apr 29, 2022 at 4:45 PM
    #8168
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Those nail guns are fun. I have the kind you have to hit with a hammer to get the .22 shell to go off. Always terrifyingly enjoyable :rofl:
  9. Apr 29, 2022 at 5:36 PM
    #8169
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Yep - I’ve got the hammer strike one too
    TaquitoBandito and Fotnot like this.
  10. Apr 29, 2022 at 8:44 PM
    #8170
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I have one also, from a room build 40 years ago. I still have a couple bags of nails/shell left over. I wonder if they still work. I just saw them yesterday in my toolbox.
    TaquitoBandito likes this.
  11. Apr 29, 2022 at 9:23 PM
    #8171
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    exactly why I spend the extra $10 for the trigger actuated one lol
  12. Apr 30, 2022 at 10:36 PM
    #8172
    RainMan_PNW
    Casey
    Clark County, WA
    Almost finished the shed/greenhouse. Just gotta put the door on.
  13. Apr 30, 2022 at 10:40 PM
    #8173
    FrenchToasty
    Mo
    Bone stock
    Whenever I light my oxy torch in McDowells fixing a fridge, I always get a yelp from a old lady
  14. May 1, 2022 at 2:11 PM
    #8174
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I posted this drill press on Nextdoor for a 12 pack of bud. 4 inquires in 5 minutes. 30 minutes later I'm drinking a bud.
    ColoradoTJ, 1UPPER, B.Ross and 10 others like this.
  15. May 1, 2022 at 7:58 PM
    #8175
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    always pop,pop,pop or black soot. Never perfect.
  16. May 1, 2022 at 8:01 PM
    #8176
    FrenchToasty
    Mo
    Bone stock
    I always try and crack the oxygen so I don’t end up with black floaties all in the air which then usually land on my face. The smell of acid burnouts usually gets some strange faces too
  17. May 1, 2022 at 8:03 PM
    #8177
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    I finally got around to continue with our fixer upper..some tile work...such a slow process since I work on other people's homes.
  18. May 2, 2022 at 11:21 AM
    #8178
    RainMan_PNW
    Casey
    Clark County, WA
    Progress on the shed - 1/2 CY of gravel wheelbarrowed up the hill and spread for the floor with hardware cloth under it. Moved in the gardening stuff.
    Then discovered critters had undermined two of the support blocks under the coop, so had to form and back-pour 400# off concrete
    Then drop a tree that had leaned over in the recent snowstorm and was almost hitting the house
    Then burned a bunch of limbs from the same storm.
    ColoradoTJ, 1UPPER, B.Ross and 5 others like this.
  19. May 2, 2022 at 2:45 PM
    #8179
    TaquitoBandito
    Joel (AKA Bif)
    I've been replacing our self-monitored Nest security system with Ring because of some asswipe from Corpus doing address fraud and getting a drivers license at our home address. So, since I bet on Google, much like in the 80's when I leaned toward Betamax, if I want a monitored security system, I needed to upgrade.:annoyed:
    Did almost everything yesterday and switched out the smart lock today to work with my new system. Of course the new lock is smaller than the old one even though it's the same brand. I guess I'll be breaking out the paint. :mad:
    I was tempted to leave the lock off and just make it a gun port. :infantry:
  20. May 2, 2022 at 7:29 PM
    #8180
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Trying to look less poor.
    IMG_20220502_205716_289.jpg IMG_20220502_205716_419.jpg IMG_20220502_205716_364.jpg
  21. May 4, 2022 at 6:16 PM
    #8181
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    Had a back patio installed. They were shorted a post, so there’s a white temp post in place until it comes in
    CBBDC574-F276-4438-98BD-667209B0C412.jpg 59936C21-1904-4E1A-B17D-BB196789B67D.jpg
  22. May 4, 2022 at 7:38 PM
    #8182
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    That'll be nice entertaining space this summer! Won't help the humidity tho lol.
    Where you at in LA? Trying to figure out how far I gotta drive:D:burnrubber:
  23. May 4, 2022 at 7:40 PM
    #8183
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Threw up some solar powered led lights around the pool on the fence. Just wanted to add a slight ambiance lighting and slightly light up the bottom without having it be a bright light like from the flood lights. It was about 80' of lighting with the lights 2' apart. Has a nice reflection off the pool too.
  24. May 4, 2022 at 7:41 PM
    #8184
    Musicmasterd12
    Southern Louisiana
    Lol, nothing can help with this humidity!! Yea it’s nice to have some shade.
    I’m in Slidell!!
  25. May 4, 2022 at 7:44 PM
    #8185
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Gotcha. Other side of the atchafalaya. I'm near lake charles. So you're about 2-3 hours. And with the price of fuel, I'll stay here lol
  26. May 5, 2022 at 8:52 AM
    #8186
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    Doin a science experiment with tank enzymes. 3 different brands in bottles with tissue to see which is best at breaking it down.
  27. May 5, 2022 at 8:56 AM
    #8187
    TaquitoBandito
    Joel (AKA Bif)
    I read Angelsoft toilet paper is the best at breaking down, be interested to hear your results with the enzymes.
  28. May 5, 2022 at 9:03 AM
    #8188
    tundratoofun
    Glendale
    Beast
    The kirkland or great value is good for rv septics as well, and much cheaper than anything "rv or marine"
  29. May 5, 2022 at 9:06 AM
    #8189
    tundratoofun
    Glendale
    Beast
    The plan is to leave it for 3 days (time it takes my savage fam to fill a tank lol)
    Ill give a small shake every morning to simulate flushing or travel. I am expecting the "rv digest it" to be the best, but tst max and Happy Campers have a decent rep also.
  30. May 6, 2022 at 10:27 AM
    #8190
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Can I run something by you guys? Too bad cause I'm gonna anyways. I'm pulling up my 3/4" hardwood cause it's beat up and I want the same continuous flooring on the main level anyways. I'm replacing with 12mm (.47 inch) LVP and thinking of just throwing down 3/8 (.375) OSB on top of my subfloor (plus I can fix a few squeaks this way) so that all said and done I'm just a pinch (.847 inch) over the original .75 inch flooring. This way I don't have to pull all the door jambs and such.
    Makes sense?
    the OSB will cost me some time and about $1000 but that's cheaper and easier than pulling and plugging 8 doors and 2 closets right?
