  1. Nov 20, 2021 at 10:19 AM
    #7591
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    This is a DIY project I’ve been meaning to do for a while now. I power washed the concrete entry way and my stairs leading up to our home. I applied a Muriatic Acid solution to the concrete scrub it with a coarse brush and washed it all off. Then I let it dry out for a few days before starting to apply the Granite Grip coating. I did three coats and I used a total of 5 1/2 gallons of the Granite Grip to do my stairs and entry way. The coating has a textured finish that makes it a lot safer when it’s wet.
    I love the way it turned out!
    Before: Entry-way when it was bare concrete.
    After:
    1FF171DA-39B0-48B3-8FA5-69A373465E58.jpg 8C4B87C8-088C-4CB9-9465-101B21E28BEF.jpg 117E3A1E-D580-47CD-B8FF-5823FDE7D93B.jpg
    This is the Granite Grip by Behr sold at Home Depot. You have to use a 1/4” adhesive roller. You can use a brush to cut in around the edges or tight areas.
  2. Nov 20, 2021 at 10:32 AM
    #7592
    RobertD
    Robert
    DFW, Texas
    How is this with dogs? Is it too rough for their paws?
    TaquitoBandito likes this.
  3. Nov 20, 2021 at 10:35 AM
    #7593
    1UPPER
    TEXAS
    Flux capacitor!
    My dogs are great with it. It’s not very coarse or super rough. It’s has a very light texture to it.
  4. Nov 20, 2021 at 10:53 AM
    #7594
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Do they make a clear version of this? My grandparents house has a tiled front entry way that gets really slick when wet. My first thought is some sort of grip tape, but it would be a eyesore.
    Or any other ideas?
  5. Nov 20, 2021 at 11:12 AM
    #7595
    1UPPER
    TEXAS
    Flux capacitor!
    You can look up all the colors they offer online. They do not offer a clear coating that I know of. I know there are different clear products that use sand for a non slip finish. I don’t know if they will bond to the tile though.
  6. Nov 20, 2021 at 2:54 PM
    #7596
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I was told that papaya trees grow super fast. When I planted this one I was counting on that. Turns out they do, but not nearly as fast as cannas or bananas. This one struggled for sunlight this year and developed a hard curve. It leaned to the sun and was rooted pretty shallow as a result of all the torque.
    Ever been drunk enough to look like that?
    So I dug a hole in a better spot with a lot more sunshine (normally) and replanted it. Dropped an 8 ft steak 2 ft in the ground and tied it for support. Poured a lot of compost in the hole too.
  7. Nov 20, 2021 at 4:05 PM
    #7597
    Danimal86
    Daniel
    Sacramento, CA
    Thanks. That's what I was worried about, I don't know what won't peel off tile
    1UPPER[QUOTED] likes this.
  8. Nov 20, 2021 at 5:13 PM
    #7598
    1UPPER
    TEXAS
    Flux capacitor!
    My three car garage has a separate attic space over one of the car stalls. Previously the only way into the attic was a 2x2’ scuttle hole. The attic space had HVAC lines, electrical wires and a water line running all over the open space. I installed a 10’ aluminum pull down stair case, rerouted all the electrical, HVAC, and water lines. I installed 2x6x10’ decking across the attic space. Now I have an additional 4’x10’ storage area. I’m going to use this space to store all the seasonal decorations.
    Attic after I moved the wiring, HVAC and plumbing.
    Attic space after installing 2x6 decking.
  9. Nov 20, 2021 at 6:50 PM
    #7599
    biebs96
    PA
    about how much square footage would you say this is approximately. I have a stamped concreted patio that leads toward my pool and it either needs this grip treatment or hand railings haha
  10. Nov 20, 2021 at 7:04 PM
    #7600
    TaquitoBandito
    Joel (AKA Bif)
    We had that problem at our old house - I was afraid somebody was going to get hurt because it would get so slick. We ended up replacing it with slate tile.
    NewImprovedRon likes this.
  11. Nov 20, 2021 at 7:13 PM
    #7601
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Getting started, covering cushioned vinyl that was not well done before we moved in.
  12. Nov 20, 2021 at 7:41 PM
    #7602
    Danimal86
    Daniel
    Sacramento, CA
    I have a feeling removal would be best, I'm not really sure why they decided their patio
  13. Nov 20, 2021 at 8:03 PM
    #7603
    1UPPER
    TEXAS
    Flux capacitor!
    They Granite Grip says you will get about 50 square feet of coverage per one gallon container. This is based on using two coats. I got probably 35-40 square feet of coverage per gallon since I went over it three times. This product is very thick. It’s not like a typical paint viscosity.
  14. Nov 20, 2021 at 8:07 PM
    #7604
    TaquitoBandito
    Joel (AKA Bif)
    When we did ours, we trusted our tile guy that it wouldn't be slippery. Big mistake.
  15. Nov 21, 2021 at 7:27 AM
    #7605
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Finally changed out the bent frost free hydrant. Also ran water and power over to new greenhouse location. Going geothermal. Still more excavation to do.
  16. Nov 21, 2021 at 6:03 PM
    #7606
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Minor creature comfort upgrades for now... but found a bigger problem...
    I will have to reaearch some of this but found some electrical issues an open neutral and open hot.... will need more equipment or just Homer Simpson my way through this... at least I found what claimed my toaster...
    This one claimed my toaster...
    This one is dead on the top outlet, but correct on the bottom outlet.. Assuming its a locally open...
    TaquitoBandito and Fotnot like this.
  17. Nov 21, 2021 at 6:17 PM
    #7607
    NWPirate
    Zach
    WA
    Probably bad connections on the outlet or wirenuts. Kill the circuit and see what ya got in there.
    Might have to check the other outlets upstream and downstream on that circuit too to find the break.
  18. Nov 22, 2021 at 3:38 PM
    #7608
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Double check that the top outlet isn't tied to a light switch.
    It's common in spec houses to have the outlets "split" and the bottom outlet is fed from the panel while the top one is fed off the light switch.
  19. Nov 22, 2021 at 3:58 PM
    #7609
    blackdemon_tt
    this is a valid point.. There is a skylight type lighting up above a seam that is out and I was sorta troubleshooting, since I replaced both bulbs and got no joy, so I decided to probe outlets and the top one is out, the otherside is fine.. sooo... May have to dig into both switches..
  20. Nov 22, 2021 at 6:24 PM
    #7610
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Got a lil plumbing and steel tied today and late last week.
    20211122_171749.jpg 20211122_171809.jpg 20211122_171852.jpg 20211122_171908.jpg
  21. Nov 22, 2021 at 8:16 PM
    #7611
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Wow, I was amazed how much piping went into the pool and hottub. They are really moving along on the project.
  22. Nov 23, 2021 at 9:18 AM
    #7612
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Yea we kinda laughed and said the same. Not as simple as into filter, into pool, then back out. Lol. And yea, they're moving along fairly quickly right now. Won't happen when I need the plumber tho. They're all backed up around here right now
  23. Nov 27, 2021 at 10:39 PM
    #7613
    WAtundra4x4
    Den
    Wet side WA
    Continuation from 7847. Stopped by on a Saturday where they were working on doing the stone on the front of the house and finishing up the stairs off the back upper deck. They did some outside items, added concrete slab by the side door off the garage, front stairs and pathway. Added concrete barriers by the side so it’s more level for the AC option on the side behind the RV garage. We went over to the home next door and took a few shots from there. Quite a different perspective of the land from before breaking ground. Some concerns regarding water flow due to rain. We’re not near a river valley as we are about 500 ft In Elevation, but with all the the Recent atmospheric rivers we have been having, the French drain routing is getting a test. They have added an additional trench across the back yard that has to be filled in yet. They finished grouting the bathrooms and the back splash in the kitchen. The range hood is installed also. They finished up the sheet rock fixes and that looks good. Plenty of work left to do. Lots of trim work to be completed, as we had options for wood wrapped windows. We were supposed to have a walk through on December 1, but it looks like the new date is 2 weeks later. That will make it 4 months late… we plan to get the Propane tank buried after we move in, for a cleaner appearance. It hey did the next home over’s driveway, but not ours yet. I think they figured they had to get that one done first before doing ours. Lots of schedules conflicting in this era. Maybe the next photos posted will show a completed house (well maybe with some pickups). Good news is that we know how the water will flow in the heavy WA rains….
    4EF724FD-AC7F-49FB-BB9B-D5F9ADC30297.jpg3EFA3DAC-6918-482C-8671-43F45DABA9A4.jpg 43746230-30EF-4E7E-9266-7A65C5DB9BD3.jpg25B6F8F6-6C79-42D9-ADCA-1474EB3077E1.jpg D4464596-5561-4542-A2B9-26B63D1DFE91.jpg4239693D-D568-4B5C-9204-88B951942A33.jpg 6C8CDECA-C70B-414E-880D-BE960B8965ED.jpg
  24. Nov 27, 2021 at 10:44 PM
    #7614
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Love the stove and tile floor. I’m guessing y’all are some serious cooks with hardware like that.
  25. Nov 30, 2021 at 9:18 AM
    #7615
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    Master bath & walk in shower finally complete. Before & After.
  26. Nov 30, 2021 at 10:57 AM
    #7616
    blackdemon_tt
    OOOOOOOH This is nice... I'm bout to steal this idea, LOL...
  27. Nov 30, 2021 at 2:50 PM
    #7617
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    New stuff today. Wife sent me pics at work since she was home. Getting closer....
    Resized_20211130_151607.jpg Resized_20211130_151538.jpg Resized_20211130_151517.jpg
  28. Nov 30, 2021 at 8:08 PM
    #7618
    TomC843
    Tom
    Charleston, SC
    Seems so strange not to see a tree anywhere, was that former farm land or something?
  29. Nov 30, 2021 at 8:13 PM
    #7619
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Exactly. Used to be all rice/crawfish/soybean fields. Planted 6 trees a couple months ago. Kinda sucks not having them, but they're coming lol
  30. Nov 30, 2021 at 8:33 PM
    #7620
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Built a new floor for under the kitchen sink. 33F333CC-F034-4A24-A395-3231AE0BA135.jpg
    caulk and paint will make me the carpenter i aint.
