  1. Jun 15, 2021 at 9:01 AM
    #6871
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    Solid advice right there. Just went through this exact mess a while back for a new court yard area.
    kparrow and jewsNbrews like this.
  2. Jun 15, 2021 at 9:19 AM
    #6872
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Good point. I assume I could just dig up the root system once the old concrete is busted up?
  3. Jun 15, 2021 at 9:26 AM
    #6873
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Unless you reinforce the hell out of it and make it a structural floating slab. But that ain't cheap!
  4. Jun 15, 2021 at 10:31 AM
    #6874
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    Is that the only crack? Or are they very widely space? Without more pictures, maybe mudjacking could be a temporary fix for a few years. And yeah water getting in that crack only exacerbates the problem. Sonneborn/BASF SL-1 caulk is a great product for sealing cracks on level surfaces (self leveling so it flows).
  5. Jun 15, 2021 at 10:48 AM
    #6875
    Jjclamdips
    Jjclamdips New Member
    Wichita, Ks
    2008 Limited Double Can 2WD
    I am curious please explain the header requirements for your area.
  6. Jun 15, 2021 at 12:51 PM
    #6876
    RainMan_PNW
    Casey
    Clark County, WA
    Not sure he would know, since it's being built by a builder. The one on the end wall (third pic) I can understand being doubled 2x6 because it's not load bearing. The one on the left in that third pic does seem a bit undersized, but it also depends on what the code reviewer and engineer have figured. It's a subdivision home, so I'm sure they have everything approved based on their standard plan sets.
    @WAtundra4x4 - That particular style of header is going to be a bitch for installing any kind of wall-mounted curtains. I'd recommend you sneak in and add blocking in there before they start insulating the walls. Do the same for any spot you think you'll want to hang a towel holder, toilet paper roll, and behind the door knob on any door where it swings open. That will save you a LOT of headaches later as you live in the house...
    TaquitoBandito and jewsNbrews like this.
  7. Jun 15, 2021 at 12:55 PM
    #6877
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I unloaded a pallet of similar bricks and laid them over the course of this past weekend, along with a 1/2 yard of 1/4 down shoveling etc (3500 lbs of bricks, placing, leveling, adjusting, releveling etc).....and I'm still sore a few days later.
    Mine were 2' long, 50lbs each, 70 of them. I don't envy how many you have to do...but I bet they'll look good.
    TaquitoBandito likes this.
  8. Jun 15, 2021 at 12:59 PM
    #6878
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    If you are referring to my driveway discussion, I posted a few pictures. There are many cracks unfortunately.
  9. Jun 15, 2021 at 1:06 PM
    #6879
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    @WAtundra4x4 - That particular style of header is going to be a bitch for installing any kind of wall-mounted curtains. I'd recommend you sneak in and add blocking in there before they start insulating the walls. Do the same for any spot you think you'll want to hang a towel holder, toilet paper roll, and behind the door knob on any door where it swings open. That will save you a LOT of headaches later as you live in the house...[/QUOTE]
    That is exactly what I did when we built a house in IL. Surprisingly took me almost half a day given all the windows we had. Used a couple of the builders "scrap" 2x6's. Also added insulation to the garage walls that were not a shared wall with the main house as most builders will not insulate those. Also had a bunch of coax wire drops for potential future use. Also added an extra attic access door in the garage..builder told me only one in the main house. I framed it in...the finishers figured it was spec'd out so took it from there.
  10. Jun 15, 2021 at 1:07 PM
    #6880
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Yeah that driveway is toast!
  11. Jun 15, 2021 at 4:57 PM
    #6881
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    J
    thanks for the comments. They are in the rough stages off the framing. The photo that you saw I do not believe will be the finished header configuration. Here is another sliding door/window in another part of the house. I’ll check the headers for sure this weekend.
  12. Jun 15, 2021 at 6:07 PM
    #6882
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    Does this count... Since it's a home away from home? Been 5 years because I couldn't figure out where or how. Glad to have it back. In honor and memorial of those who served.
  13. Jun 17, 2021 at 9:18 PM
    #6883
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Some solar lights on the fence, nothing huge. Adds a nice touch
    31DAECA5-87A8-49F3-A9C9-3C24D236838E.jpg 1558257B-9C5B-47A1-946B-29693A4C67F0.jpg 5ACE6998-F4E6-4532-8BEB-0448AD264D26.jpg
  14. Jun 17, 2021 at 9:50 PM
    #6884
    drobb
    Link please?
    kparrow[QUOTED] likes this.
  15. Jun 18, 2021 at 4:42 AM
    #6885
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    MAGGIFT 12 LEDs Solar Fence Lights Wall Mount, 10 Lumen Solar Deck Lights Solar Porch Lights Wall Sconce Warm White Lights for Outdoor, Steps, Yard, Garden, Garage, Patio, Driveway, 4 Pack https://www.amazon.com/dp/B08D9FRD62/ref=cm_sw_r_cp_api_glt_fabc_0EFBVZGFQW8ZJM7M2EC2?_encoding=UTF8
    alee891, drobb[QUOTED] and ColoradoTJ like this.
  16. Jun 18, 2021 at 5:00 AM
    #6886
    Same here.
  17. Jun 18, 2021 at 5:04 AM
    #6887
    Damn Holden, this turned out great.
  18. Jun 18, 2021 at 5:16 AM
    #6888
    You all have been busy and doing a great job. Just catching up on everyone’s projects (over 500 posts).
    As usual, I have a few irons in the fire with some projects. I’ll post some pics when it gets a little closer to being done.
  19. Jun 18, 2021 at 5:47 AM
    #6889
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Gracias compadre!
  20. Jun 18, 2021 at 6:08 PM
    #6890
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    OK I didn't do it, wife hired someone to do it for us but I'm pleased with the results. Pressure washed the new house.
    Before
    ZEmh4h4mLnvvkqHnx64adQYd04pxIKpd0VjHlrME_7c99f43101916fb06309fb0a909da7b7a7336c65.jpg
    After
    siKiq6mwEzl5itK_pnXBJRcR1qt7L-Ysh_NwVkB-_707df8f2b8658ebd32e1e71901f5105891b4ceed.jpg
    Gotta trim the bushes.
  21. Jun 18, 2021 at 6:15 PM
    #6891
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Looks good. Nice lil refresh. Trimming thr bushes will make the house look a lil bigger too
    aelarson, CodyP, jewsNbrews and 4 others like this.
  22. Jun 18, 2021 at 6:16 PM
    #6892
    o_O:fistbump:
  23. Jun 18, 2021 at 6:24 PM
    #6893
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    :fistbump:
    jewsNbrews and Fotnot[QUOTED] like this.
  24. Jun 18, 2021 at 6:55 PM
    #6894
    Blitzhob
    Blitzhob New Member
    Mark
    2020 tundra double cab white
    Finished up flagstone patio and stone planter bed edging. 28EC09D7-58B8-4B1A-896F-021A0428A0C4.jpgB4B1228D-8E8D-4E2F-A17D-6C106B31E7F5.jpg
  25. Jun 18, 2021 at 8:04 PM
    #6895
    More busy than I cared to be lately:
    Wife has been killing it with her project. Over the past couple years I have been hauling rocks (feels like non stop). This is her first landscaping project. It’s not completed yet…
    375B4CCF-2CAE-450E-AA72-5E76A51B4F39.jpg C18E1013-E7D2-4EDE-8F3F-8EE6A5DF2D49.jpg CA96F23A-CEA8-424C-936A-05FF5E52075F.jpg 1364481A-25DD-4E21-A8F9-5DE244D329E7.jpg 7268DA95-E9B7-464F-B8F5-CA0ACB5ED7A5.jpg 97EFA71A-D8AA-4F8A-AAA5-FE4B85901C2D.jpg F9D12907-7DF6-4CD8-8BB7-532F4316F2AB.jpg
    Been doing a Boulder wall this past two weeks. Hauled 140K lbs of boulders down from West of Denver.
    6B51F920-02C6-4853-82FF-8CFD3D775BCE.jpg B16794F3-CC4B-4AC8-82D5-2027729BC899.jpg 3AB775C4-ABC3-4BF6-AD0A-112F20EC91B6.jpg 0C6D6044-3E8C-408A-AC90-29AEF8108A70.jpg
    Today’s load
    Our back patio project should start in a couple weeks.
    81A444AE-5C17-4422-B863-9D32879E73C1.jpg 8E9653B9-05D3-476C-BAEA-16C05613E368.jpg
    4x4platinum, 1UPPER, B.Ross and 13 others like this.
  26. Jun 18, 2021 at 8:30 PM
    #6896
    RainMan_PNW
    Casey
    Clark County, WA
    Looking awesome Chris. I’m jealous of the rock supply, and the means to place them…
  27. Jun 18, 2021 at 10:47 PM
    #6897
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Whoa. It me or are those massive-sized flagstones?!?
    Blitzhob[QUOTED] likes this.
  28. Jun 19, 2021 at 5:43 AM
    #6898
    Well….it took some pre-planning. Most of these boulders are 2-3000 lbs. my tractor can only lift 1100 lbs from the front end loader and the 3 point can do 1900 lbs.
    I would take old plywood, line the bed of the trailer for the boulders to slide on. We would then park the trailer directly over where the wall needs to be and drag them off. We could mover them around a bit…but some were just too heavy.
    RainMan_PNW[QUOTED] likes this.
  29. Jun 19, 2021 at 8:16 AM
    #6899
    RainMan_PNW
    Casey
    Clark County, WA
    I guy that used to work for me built a Japanese garden in his backyard. He moved every one of the big stones from his front curb (where he had them delivered because no equipment could get to his back yard) using two tripod “gantry” devices he built and chain falls, lifting and drifting them through the side yard and to wherever they went in the back. It was sketchy as all hell, and amazing at the same time.
    CodyP likes this.
  30. Jun 19, 2021 at 3:44 PM
    #6900
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Got some window tint film installed on the windows above the kitchen / living room. Should kill the glare from direct sun in the afternoon as that side of the house is the west side
    626B3551-35AD-4DAA-8E0E-7425D9627C5B.jpg A8D74A25-2E80-4F4C-AA55-01FBA183B31F.jpg
