  1. Jun 3, 2021 at 6:06 PM
    #6811
    Outbound
    Aaron
    Northern Alberta
    Damn. I need me some of that.
  2. Jun 3, 2021 at 6:47 PM
    #6812
    Jonny Rotten
    Jonny Rotten New Member
    Replaced stairs a couple weeks ago adjusted pitch did some reframing.... Today was sheetrock day
  3. Jun 3, 2021 at 7:34 PM
    #6813
    You need wood?o_O
    :p
    ColoradoTJ and CodyP like this.
  4. Jun 3, 2021 at 7:35 PM
    #6814
    Outbound
    Aaron
    Northern Alberta
    I like to have wood. It assists in laying pipe.
  5. Jun 3, 2021 at 7:57 PM
    #6815
    TaquitoBandito
    Joel (AKA Bif)
  6. Jun 4, 2021 at 6:23 PM
    #6816
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    My front door is a nightmare. In 12 years I had refinished it 3 times. It faces southwest and takes a beating in the OK sun. This time I declared war. No more stain and marine spar varnish.
    Stripped down and painted with 2 1/2 coats Sherwin Williams Emerald semi gloss latex urethane after two coats of primer.
    This was a 4 day project. That detailed trim around the windows is a bitch to prepare. Super happy with the end result. This paint sets up like a hard plastic.
    This picture looks blue green but it's a dark gray. Trust me.
  7. Jun 4, 2021 at 8:47 PM
    #6817
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Your front door looks great! Good job. I had the same issue with my front door as you did. I used the SW Emerald rain refresh paint, it does an amazing job!
  8. Jun 5, 2021 at 6:15 AM
    #6818
    Melikeymy beer
    Muscogee Nation
    Thank you. Good to hear the SW is holding up. I'm tired of messing with this door when I could be fishing.
    Tundratoofun and 1UPPER[QUOTED] like this.
  9. Jun 6, 2021 at 3:27 PM
    #6819
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Continuation from 7039. We decided to check out the build today. We have some WALLS! Excuse the wet appearance, it is Washington after all. The tall walls are my RV garage extension, as I will be able to fit my Tundra finally in the Garage without folding the mirrors. This is the current progress, just framing but its starting to look like something livable. It did rain like crazy in this area yesterday. Some image distortion due to lens.
    9D9F985F-A1E0-495D-9530-BBE7D99ADAA4.jpg 189406C2-D2EA-4CCE-BCC3-AEA5F2F653C7.jpg
  10. Jun 6, 2021 at 3:51 PM
    #6820
    degs
    degs New Member
    2020 MGM Crewmax
    Home Depot was blowing out their Jeld Wen windows... got a bunch of them for under $40 each (down from over $250)
    first 2 installed...
  11. Jun 6, 2021 at 4:10 PM
    #6821
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I don’t know about you, but when we were building our house and saw the foundation poured, it seemed SO small. Then the walls go up and it’s like “WOW! Now it’s a house!”
  12. Jun 6, 2021 at 5:47 PM
    #6822
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Dog House / Run….99% done. Interior is done with the exception of foam board insulation on the roof. Exterior dog run is assembled. Dogs have fan and light in the kennel on smart plugs and I put a Wyze cam to monitor them. Have automation to turn fan on with temp outside and light comes on at sunset Will have an external cam to monitor that side of the house and them up shortly. Basically it’s “done” till winter when I’ll swap the fan for a heater and make sure the door opening is sealed up with some weatherstripping. Will probably add a big water bottle on the door that I can fill on the regular. What y’all think?
    95B8D3D3-125C-41D7-ABC8-D084CA9282CE.jpg F13DE2EF-16B3-448E-986A-BF38B7F3041E.jpg
    BigSkyTaco, 1UPPER, scpete24 and 13 others like this.
  13. Jun 6, 2021 at 6:18 PM
    #6823
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    My wife almost lost her mind when she saw it poured and no walls yet. I actually had to go back to the house to get the 100' tape to prove to her it was what we wanted and even mapped out a couple rooms quick. Once the walls went up, she started saying the opposite that we may have gone too big :facepalm:. Its all good though, we're happy with it and it's just where we wanted
  14. Jun 6, 2021 at 6:53 PM
    #6824
    TaquitoBandito
    Joel (AKA Bif)
    Your dogs are housed nicer than I was in 1999-2000 when I living in the barracks at Fort Hood. Nice job.
  15. Jun 6, 2021 at 8:32 PM
    #6825
    Plumpy33
    Plumpy33 New Member
    Mark
    Central PA
    2020 White Double Cab Limited
    Replaced my mailbox and post after the Amazon delivery person knocked it down last week.
    TaquitoBandito and kparrow like this.
  16. Jun 6, 2021 at 9:50 PM
    #6826
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Did you get a new one from Amazon?
    kparrow, TaquitoBandito and MS22 like this.
  17. Jun 6, 2021 at 9:58 PM
    #6827
    MS22
    MS22 New Member
    02 Tundra 4x4
    Did you order a new one from Amazon? :rofl:
  18. Jun 7, 2021 at 11:53 AM
    #6828
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Got the side yard done before leaving for cabo for a week
  19. Jun 7, 2021 at 8:15 PM
    #6829
    WAtundra4x4
    Den
    Wet side WA
    There is also a similar visual change when you go from just framing and getting the Sheetrock installed. The consensus is after the Sheetrock is done the interior looks bigger. My wife and the realtor gal we’re going on (discussing it) about it the other day. Some aspects of this house we have only seen the design on paper and not a finished real detail.
  20. Jun 8, 2021 at 8:35 AM
    #6830
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    Thanks man, its come a long way from where it was when we bought the house! only have one little quarter round planter I need to plant and should be wrapped up.
    Edit - Meant to add, looks very clean compared to the paint on the house which has now been moved up on the timeline because it looks even worse now!
  21. Jun 8, 2021 at 9:19 AM
    #6831
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    What’s going out the giant opening on the back center of house?
  22. Jun 8, 2021 at 9:40 AM
    #6832
    WAtundra4x4
    Den
    Wet side WA
    It will be a pair sliding glass doors, they open at the center. 4 large panes: the 2 sliders in the middle and 2 fixed on the sides.
    NewImprovedRon likes this.
  23. Jun 9, 2021 at 3:38 PM
    #6833
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Just finished hanging my garage cabinet set. Really pleased with the quality and appearance, especially for the price. The company is called New Age Products.
  24. Jun 9, 2021 at 4:59 PM
    #6834
    Jjclamdips
    Jjclamdips New Member
    Wichita, Ks
    2000 Access Cab
    Pullout out an old insert precision fit Pella Double hung window and installed a new Sierra Pacific H3 awning window over the kitchen sink.
  25. Jun 9, 2021 at 5:41 PM
    #6835
    BayRunner
    2017 Tundra Platinum
    Was really looking forward to my next honey-do project. Got the material in for a large patio and garden wall setup when all the sudden I realized that I have a hernia. Now, 12 pallets sitting idle.
  26. Jun 9, 2021 at 6:34 PM
    #6836
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I know a guy who could fix you right up :thumbsup:
    NewImprovedRon and T-Rex266 like this.
  27. Jun 9, 2021 at 7:34 PM
    #6837
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Oh no. Be careful man. Hopefully you get straightened out soon
  28. Jun 9, 2021 at 7:40 PM
    #6838
    BayRunner
    Yea, consultation is set for the end of the month and then schedule surgery.
    jewsNbrews and Fotnot[QUOTED] like this.
  29. Jun 10, 2021 at 5:28 AM
    #6839
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    New project starting that I will have nothing to do with except going to work with wife sending a few pic now and then.
    drobb, jewsNbrews and TaquitoBandito like this.
  30. Jun 10, 2021 at 5:47 AM
    #6840
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    thats a project you want no part of. money well spent letting them do it
    TomC843[QUOTED] likes this.
