  1. Apr 27, 2021 at 8:46 PM
    #6271
    TaquitoBandito
    Joel (AKA Bif)
    He may be in Ohio. That state is all sorts of messed up.
    CodyP likes this.
  2. Apr 27, 2021 at 8:46 PM
    #6272
    TaquitoBandito
    Joel (AKA Bif)
    We used blinds.com a few years back and I was very happy with them.
    AZTundra and mofferman[QUOTED] like this.
  3. Apr 27, 2021 at 8:49 PM
    #6273
    TaquitoBandito
    Joel (AKA Bif)
    I caught a rat in my live trap. Little bastard kept trying to attack my wife while it was in the cage. Wife didn't want me to kill it so it now lives in a field on the other side of the river.
    AZTundra likes this.
  4. Apr 27, 2021 at 8:54 PM
    #6274
    I know what you mean. That is the exact color combo I have in my garage. :rofl:
    Baja Mike[QUOTED], AZTundra and CodyP like this.
  5. Apr 27, 2021 at 9:16 PM
    #6275
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Thanks Casey! So I've abandoned the idea for now about putting in a sink, that picture is the sink was just for reference of what another neighbor had done, and how they got the water supply.
    There isn't any freeze issues here. It might get below 32 outside for an hour or two during the coldest part of winter, but never that cold inside the garage.
    I've sweat pipes before, but would rather not have to deal with it if I don't have to. That valve seems like it would make it easy to slap a t there and call it a day.
    So I need a 3/4 male 3/4 female 1/2 female Tee
    https://smile.amazon.com/Anderson-M...=3/4"+tee&qid=1619582460&s=industrial&sr=1-19
    Then a 3/4 double male...is that flex pipe flared or will any double male work?
    Then a 1/2 to pex barbed
    https://smile.amazon.com/Tailonz-Pn...+pex&qid=1619582970&s=industrial&sr=1-27&th=1
    Then get it down to the 1/4 inch that comes out of the fridge
    https://smile.amazon.com/SharkBite-...x=1/2"+pex+to+ice,industrial,254&sr=8-24&th=1
  6. Apr 27, 2021 at 9:46 PM
    #6276
    point08
    point08 New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    What the hell. Why does no one carry shower sweeps or door stops any more? Lowes? Yes (but actually nope because they have no idea what they have in stock or where they are) Home Depot? Nope, order online! Call local shops and it's "if we didn't install your shower, we can't help you". I just want to buy a new 1/4 shower sweep and 3/8 shower stop so I can hopefully fix the shower "leak". :mad:
  7. Apr 27, 2021 at 9:49 PM
    #6277
    point08
    point08 New Member
    Kyle
    His wife is going to be pissed when he doesn't come back with dinner!
  8. Apr 27, 2021 at 10:24 PM
    #6278
    Yzed608
    Yzed608 New Member
    Wisconsin
    Thanks for the info guys. The wind thing is a really good point, never thought about that.
  9. Apr 28, 2021 at 5:58 AM
    #6279
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    If ONLY hooking up the ice maker, then I would reduce the tee down to 1/4 on the branch and run it in 1/4” pex ice maker tubing the whole way.
    when I get to work, I can pull you a list of parts.
    and yes, the WH flex has a gasket on the inside and is meant to tread directly onto the tapered male pipe threads.
    TaquitoBandito likes this.
  10. Apr 28, 2021 at 6:38 AM
    #6280
    Danimal86
    Daniel
    Sacramento, CA
    I'd appreciate that! Yeah, i'm going to just hook up the ice maker for now....
  11. Apr 28, 2021 at 7:00 AM
    #6281
    NoKenDo
    NoKenDo New Member
    Ken
    Grand Rapids MI.
    2018 Platinum 4x4 Mesquite Brown
    TRD Pro Suspension. Moonroof. Front window tint. Compustar Pro T11 remote starter. N-FAB running boards Bedrug Bedmat XLT DiamondBack HD Tonneau Weather Tech Window Visors
    Changed the John Deere from snowblower duty back to mower duty.
  12. Apr 28, 2021 at 8:24 AM
    #6282
    RainMan_PNW
    Casey
    Clark County, WA
    You COULD just go with one of these kits. I'm always leery of these sort of tap-in valves, but you do have the shut-off valve there that you could use to isolate if this ever developed a leak, and it is probably the easiest and least expensive option.
    https://www.lowes.com/pd/EASTMAN-25...tlet-Polyethylene-Ice-Maker-Connector/3196985
    Otherwise, you could go this route:
    3/4" tee threaded onto the end of the male thread adapter (I'm not finding a 3/4 x 1/2 tee on the Lowes site)
    https://www.lowes.com/pd/B-K-3-4-in-Threaded-Tee-Fitting/1000505761
    In the outlet (run) of that tee, use a 3/4" shoulder nipple and thread the flex back onto that nipple
    https://www.lowes.com/pd/B-K-3-4-in-Threaded-Male-Adapter-Nipple-Fitting/1000505665
    If you don't find a 3/4 x 1/2 tee and use the 3/4 tee linked, then you'll need a 3/4 x 1/2 bushing in the branch
    https://www.lowes.com/pd/B-K-3-4-in-Threaded-Male-Adapter-Bushing-Fitting/1000505553
    Out of that bushing, use a 1/2 MPT x 1/4 OD Compression adaper
    https://www.lowes.com/pd/B-K-1-4-in-Compression-x-MIP-Adapter-Coupling-Fitting/1000505245
    Then get this kit for the icemaker tubing (the push-lock fitting will replace the brass nut on the compression adapter)
    https://www.lowes.com/pd/EASTMAN-25...Outlet-Pex-Ice-Maker-Connector-Kit/1002940588
    Make sure you get LEAD FREE brass fittings. I'm always leery of buying threaded pipe fittings online because there's a lot of really shitty cheap crap on Amazon and I just don't trust it. If you have a decent local plumbing supply (i.e. not big box store), you might go in there and see they've got.
    TaquitoBandito and AZTundra like this.
  13. Apr 28, 2021 at 9:01 AM
    #6283
    Danimal86
    Daniel
    Sacramento, CA
    Thanks Casey! I've got a True Value Standard thats my go to for different pipe fittings, i'll bring this list and see if they have everything, if not, then there's a lowes and home depot on the way home. Thanks for your helps with these parts, i'll keep ya updated!
  14. Apr 28, 2021 at 11:39 AM
    #6284
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    The epoxy itself is not UV resistant, its the flakes that you put over the epoxy that prevents the flooring from yellowing. I admit it is a bit more difficult to to find nuts and bolts but I would rather than than the floor start to yellow near the door. I guess you could go with a solid flake color if you can find it, but you need the vinyl chips for the UV protection.
  15. Apr 28, 2021 at 1:08 PM
    #6285
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    I had luck with Bali Blinds through Costco. Prices were decent, everything custom to measurements you provide.
  16. Apr 28, 2021 at 4:41 PM
    #6286
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    nice! what did that end up costing ? looking to get mine done and I have a 3 car. im also looking for a quad what year are yours ?
  17. Apr 28, 2021 at 5:10 PM
    #6287
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    Both of our quads are a 2004 Honda 400EX. I want to say the epoxy floor was around $1600. 2 car garage, but it’s extra deep. Hope that helps.
    2010bigdog[QUOTED] likes this.
  18. Apr 28, 2021 at 7:28 PM
    #6288
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I’ve been remodeling this lakehouse property for some clients of mine since last year. Now you can see all the beautiful new hardwood floors, stairs, hand railing and kitchen cabinets. This house has some very cool features to it and some amazing views over looking the lake.
    58DC5D88-284B-4B7D-9636-FC6AA6710378.jpg DA6D89F2-0A61-4128-A2A5-FA83C686EA4D.jpg 742F415A-079B-43C1-A295-94FCFE42B950.jpg
  19. Apr 28, 2021 at 7:30 PM
    #6289
    RainMan_PNW
    Casey
    Clark County, WA
    I just want to be the bastard step children one of your clients pays to keep quiet
  20. Apr 28, 2021 at 7:50 PM
    #6290
    TaquitoBandito
    Joel (AKA Bif)
    Yes, yes. This will do nicely. Remind me again, when is the move-in date?
  21. Apr 28, 2021 at 8:00 PM
    #6291
    come re-build mine- after you make my garage even better
    1UPPER[QUOTED] likes this.
  22. Apr 28, 2021 at 8:03 PM
    #6292
    1UPPER
    TEXAS
    Flux capacitor!
  23. Apr 29, 2021 at 6:27 PM
    #6293
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Hauled a bunch of tiles yesterday... tub is in today, one wall is in, 2 more to go tomorrow. Then thinset.
  24. Apr 29, 2021 at 6:36 PM
    #6294
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    Looks like my crawl space
    CodyP[QUOTED] likes this.
  25. Apr 29, 2021 at 6:56 PM
    #6295
    1UPPER
    TEXAS
    Flux capacitor!
    Installed these 6”x8” wood mantels and corbels on the two fireplaces on the second floor. My painters are going to stain and seal them to match the timber trusses.
    Before:
    After.
  26. Apr 29, 2021 at 7:16 PM
    #6296
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Hopefully you bought the ultralite mortar, that last load will be half as heavy. And your tile guys back will thank you with those maximos :rofl:
  27. Apr 29, 2021 at 7:17 PM
    #6297
    Simply amazing.
  28. Apr 29, 2021 at 8:00 PM
    #6298
    1UPPER
    TEXAS
    Flux capacitor!
    :hattip:
  29. Apr 30, 2021 at 9:10 AM
    #6299
    Taco-Spike
    Two Trucks
    Got a question.
    I want to paint one of my living room walls black. Then dark stain (to match the wood floors) 1'' X 6'' wood slats and bolt to the studs in the wall.
    My question is, would I be okay just using wood screws or should I drill a small pilot hole first? Kind of like when you wall mount a TV bracket. Would that be best to not split the wood?
    Below is a rough rendering I modeled up in Solid Works.
    Front View
    Isometric View
  30. Apr 30, 2021 at 9:18 AM
    #6300
    Taco-Spike
    Two Trucks
    Will do. Thank you!
