  1. Mar 23, 2021 at 12:11 PM
    #5821
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Just put in a heated floor and you’ll be good :D
    CodyP[QUOTED] likes this.
  2. Mar 23, 2021 at 12:23 PM
    #5822
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Smart idea, BUT how would the bottom plate of that wall be secured since it would just be foam below it?
    I was going to do that anyways as long as it wouldn’t make the transitions from garage and dining room too different
  3. Mar 23, 2021 at 1:10 PM
    #5823
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Started sanding, scraping and pressure washing the 16x20ft deck for a fresh paint yesterday
    pressure washed vinyl and brick siding to house and garage
    sharpened chain saw and cut up a truck load of 30" oak from a tree felled a couple months back down the street
    TaquitoBandito and Fotnot like this.
  4. Mar 23, 2021 at 1:22 PM
    #5824
    MEWaters
    MEWaters New Member
    Maine
    I enjoy your bird feeder setup
  5. Mar 23, 2021 at 1:45 PM
    #5825
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    There's a long story there involving raccoons. It's an 80 steel cable with ratchet straps providing tension between a utility pole and a 30" maple.
  6. Mar 23, 2021 at 3:02 PM
    #5826
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I bet @1UPPER would have some ideas.
    I bet you are over thinking the coldness issue, not really that much difference than having a tile floor on a slab....
    1UPPER and CodyP[QUOTED] like this.
  7. Mar 23, 2021 at 3:32 PM
    #5827
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Get a few 6x6s for support. Plant them into the ground with some concrete just like you'd hold up a wall.
    Set em, place in the insulation foam, throw on your wood floor base.... Boom.
  8. Mar 23, 2021 at 4:36 PM
    #5828
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    The cold that would transfer from the outside concrete to the inside would be a lot I would think but you could be right....I’d just rather OVER than UNDER think.
  9. Mar 23, 2021 at 4:46 PM
    #5829
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Where can I see your knives?
  10. Mar 23, 2021 at 5:28 PM
    #5830
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I didn’t improve the house, but the kids’ swim team asked for a box for their countdown timer. I don’t see the point in a box on the ground, so I made a frame...
    Baja Mike, RainMan_PNW, drobb and 5 others like this.
  11. Mar 23, 2021 at 6:07 PM
    #5831
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Putting in the wife’s closet system. Still waiting on 10 boxes to show up. image.jpgimage.jpg
    T-Rex266, kparrow, alb1k and 4 others like this.
  12. Mar 23, 2021 at 6:33 PM
    #5832
    alb1k
    Left Coast
    It's good
    Sweet!!!
    ToyoMafia[QUOTED] likes this.
  13. Mar 23, 2021 at 6:44 PM
    #5833
    AZTundra
    Paul
    Phoenix, AZ
    Started draining the pool about 3 hours ago.
    Fotnot, kparrow, drobb and 1 other person like this.
  14. Mar 23, 2021 at 8:09 PM
    #5834
    alb1k
    Left Coast
    It's good
    Is that 3 hours in? I don’t have a pool, gravity feed with a garden hose?
  15. Mar 23, 2021 at 8:34 PM
    #5835
    AZTundra
    Paul
    Phoenix, AZ
    Yeah, that's after draining for 3 hours. There is a submersible pump lowered into the deepest part of the pool which pumps the water out through the hose which runs into our main line cleanout for drainage.
    TaquitoBandito and alb1k[QUOTED] like this.
  16. Mar 23, 2021 at 9:25 PM
    #5836
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I have a few ideas. I would consider doing a insulated floor system over the existing foundation. This is something you would do inside the inclosed air conditioned space. Watch these videos to give you a better idea of what I’m talking about.
    https://m.youtube.com/watch?v=8SSG2AofIe8
    https://m.youtube.com/watch?v=7nBkV4ecWos
  17. Mar 23, 2021 at 9:53 PM
    #5837
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Thank you. You should have a monthly advice fee via PayPal haha
    my hesitation with doing that is then the flooring would be higher than the dining room but maybe a transition piece in the doorway wouldn’t be so bad.
  18. Mar 23, 2021 at 11:18 PM
    #5838
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Elfa is the best!!!!
  19. Mar 24, 2021 at 4:12 AM
    #5839
    mtb-sam
    mtb-sam New Member
    My least favorite thing - cleaning the gutters!
  20. Mar 24, 2021 at 5:54 AM
    #5840
    1UPPER
    TEXAS
    Flux capacitor!
    Agreed, the step up wouldn’t be ideal. A lot of homes will have a monolithic foundation that transitions from an air conditioned space to an outside area. Other parts of your home will still have foundation that is exposed to the cold weather next to an air conditioned space.
    There are other factors to consider as well. Is the attic or roof over this space, insulated already? Do you plan to have this space controlled by your existing HVAC system? Have you talked to different HVAC companies to see what they recommend to make this space air conditioned? Do you have the enough slope on the outside patio concrete for water to stay out of the room?
    TaquitoBandito likes this.
  21. Mar 24, 2021 at 5:58 AM
    #5841
    ToyoMafia
    Magic carpet.
    Stuff is nice. It is a riddle to put together because of all the shipments we received but it’s getting there.
    kparrow[QUOTED] likes this.
  22. Mar 24, 2021 at 6:21 AM
    #5842
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Install some leaf guards. I did last in areas where I have trees. Not hard to do. I used my cordless impact. A magnetic socket would help but I just put some duct tape in the socket. Make sure the guards slope away from the house.
  23. Mar 24, 2021 at 7:43 AM
    #5843
    NoKenDo
    NoKenDo New Member
    Ken
    Grand Rapids MI.
    2018 Platinum 4x4 Mesquite Brown
    TRD Pro Suspension. Moonroof. Front window tint. Compustar Pro T11 remote starter. N-FAB running boards Bedrug Bedmat XLT DiamondBack HD Tonneau Weather Tech Window Visors
    Had a new roof put on. Two layer tear off.
    I have a flat roof over the porch and they had to replace 10 sheets of OSB.
    TaquitoBandito, saybng and Fotnot like this.
  24. Mar 24, 2021 at 8:37 AM
    #5844
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Hmm, for some reason I didn’t think about the hvac stuff but luckily one of the main trunks dead ends under the dining room so that’s accessible. The ceiling isn’t insulated yet but is able to be. The slope would be an issue and I doubt it’s got the right pitch but I will have to check in that. Thank you for all these thoughts! I really appreciate it
    1UPPER[QUOTED] likes this.
  25. Mar 24, 2021 at 8:42 AM
    #5845
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    an option for ac would be to throw in one of those ductless ac units. especially if you can't tie into your existing unit for power/flow reasons. i agree with checking with your ac guys and get some input from them.
  26. Mar 24, 2021 at 8:46 AM
    #5846
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yeah I will get their option before I start anything when the time comes but damn these lumber prices
  27. Mar 24, 2021 at 8:54 AM
    #5847
    Bronco Ken
    Bronco Ken New Member
    Ken
    MGM 1794
    I am painting one of the bedrooms white. My grandson was in that room so it was red & blue. It took me three coats of paint AFTER using Kilz...
  28. Mar 24, 2021 at 10:17 AM
    #5848
    AZTundra
    Paul
    Phoenix, AZ
    Pool was drained completely after about 14hours. Next up will be chipping everything out.
  29. Mar 24, 2021 at 8:57 PM
    #5849
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    What are you doing?
    AZTundra[QUOTED] likes this.
  30. Mar 24, 2021 at 9:17 PM
    #5850
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    What is the height difference? Would Dricore work as a subfloor (only 7/8” thick). That’s what I’m (slowly) putting in my basement over the slab.
