  1. Nov 6, 2020 at 5:03 PM
    #4441
    Maybe Hunter makes that brand for Home Depot.
  2. Nov 6, 2020 at 5:04 PM
    #4442
  3. Nov 6, 2020 at 7:55 PM
    #4443
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Decided to change the island wall color and change the base board to match the rest of the first floor.
    Before
    after
  4. Nov 6, 2020 at 7:59 PM
    #4444
    Bigger baseboards do look nicer. I think ours are 3-4”(?). Looks good dude. Good work
    csuviper likes this.
  5. Nov 6, 2020 at 8:00 PM
    #4445
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    The lights and pictures ikea. She found the chairs used ;)
    RainMan_PNW[QUOTED] likes this.
  6. Nov 6, 2020 at 8:03 PM
    #4446
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Sparky came over today and added my 60-amp sub panel in the garage. Air compressor plug cord will run overtop the door along the wall to the plug.
    Next I’ll add a breaker and plug for a 220 welder :)
  7. Nov 6, 2020 at 8:45 PM
    #4447
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Cost for parts and labor? PM if needed. I got a 220 outlet in my garage but I plan on adding A/C to my house eventually and I think I have to upgrade my panel for that. Just trying to get an idea of $$. Thanks.
    Mountun Goat[QUOTED] likes this.
  8. Nov 6, 2020 at 9:50 PM
    #4448
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I got 66’ of panel to panel cable, the 60 amp panel, the two plug ends and conduit. Plus, I got him to add another exterior plug on the corner of the house near our sheds. All installed for $1100 cad :hattip:
    Baja Mike[QUOTED] and DaBoro54 like this.
  9. Nov 7, 2020 at 1:53 PM
    #4449
    :hattip:
    NewImprovedRon likes this.
  10. Nov 8, 2020 at 9:02 AM
    #4450
    I’m not seeing a name anywhere on plain view. Jim may be right
    Jim LE 1301 likes this.
  11. Nov 8, 2020 at 9:16 AM
    #4451
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Upgraded the pepper grinder for max power. The binford5k-Cole&Mason collaboration
  12. Nov 8, 2020 at 10:02 AM
    #4452
    Sean, do you have that little black remote control?
  13. Nov 8, 2020 at 10:22 AM
    #4453
    Yep. I think 3-4 buttons?
  14. Nov 8, 2020 at 10:45 AM
    #4454
    Trooper2
    JR
    Houston, TX (Suburban South)
    Trying to find a water leak that has created a mess in an upstairs vanity cabinet. House plumbing looks fine. Found what looks like the faucet could have been leaking. Thoughts?
  15. Nov 8, 2020 at 10:48 AM
    #4455
    Is it a slow leak and just spreading over to the vanity? How old is the faucet?
    The hard water may have caused a pin hole leak to start over time
  16. Nov 8, 2020 at 10:54 AM
    #4456
    Trooper2
    JR
    Thinking faucet was in bad shape.
  17. Nov 8, 2020 at 10:56 AM
    #4457
    Trooper2
    JR
    Yes, very slow, cabinet with mdf has been soaking it up causing to deform.
    Faucet original Moen builder grade, about 14 years old.
  18. Nov 8, 2020 at 10:58 AM
    #4458
    Ya turn the water off for the faucet until you replace it. Moen is a good brand and what our Lord @1UPPER recommends IIRC. We have all Moen in ours
    TaquitoBandito, 1UPPER and Trooper2 like this.
  19. Nov 8, 2020 at 11:00 AM
    #4459
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Looks like the valve seat on the hot side was leaking by- on that style faucet it would leak down inside and cause exactly what you’re seeing. You don’t notice it because the water doesn’t obviously leak all over the counter top and instead just slowly makes a mess down inside.
    Hot tends to go first because it’s used probably 9x more than the cold valve when you’re washing hands, etc.
  20. Nov 8, 2020 at 11:03 AM
    #4460
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Pretty sure it’s the faucet. You can see the corrosion coming down the copper line. Make sure to change your supply lines also.
  21. Nov 8, 2020 at 11:04 AM
    #4461
    Good call on the supply lines. Cheap and easy
    BlueRibbon4x4[QUOTED] likes this.
  22. Nov 8, 2020 at 11:07 AM
    #4462
    BlueRibbon4x4
    Geno
    Finished up this kitchen install. Complete with fluorescent light box removal and replaced with crown and flush LEDs.
  23. Nov 8, 2020 at 11:09 AM
    #4463
    BlueRibbon4x4
    Geno
    Yep. Honestly I would go the extra mile and do the angle stops while in the cabinet. 14 years is a pretty good amount of time.
  24. Nov 8, 2020 at 11:14 AM
    #4464
    love the ceiling
  25. Nov 8, 2020 at 11:17 AM
    #4465
    Trooper2
    JR
    It has the angled block valves at the wall. Is that what you are referring to?
  26. Nov 8, 2020 at 11:21 AM
    #4466
    RainMan_PNW
    Casey
    Clark County, WA
    Gorgeous :bowdown:
    those can be a bitch to change. Have to shut off house water, drain, etc. a lot depends on the age, quality, and original construction materials of the house. My house is 15yr old and all copper piping and my angle stops all look good as new. But we installed high quality ones when be built it because I didn’t ever want to have to replace them.
  27. Nov 8, 2020 at 11:29 AM
    #4467
    BlueRibbon4x4
    Geno
    Yes that’s correct. Casey is correct, they can be a pain. But if you have some skills, and your sink is already out (from your pic), it’s not crazy. Turning off the water and draining the whole house depending on if you have a two story and the bath is on the bottom floor sucks. But sometimes, after messing with a 14 year old valve (even simply turning on/off) will create it’s own leak. And you won’t know until everything is assembled.
    RainMan_PNW likes this.
  28. Nov 8, 2020 at 11:29 AM
    #4468
    BlueRibbon4x4
    Geno
    Thanks man!
  29. Nov 8, 2020 at 11:43 AM
    #4469
    I would just do the faucet and supply likes and monitor it. Just don’t deal the faucet in with caulking for a bit to watch it.
    BlueRibbon4x4 likes this.
  30. Nov 8, 2020 at 12:02 PM
    #4470
    Mxvet90
    Mxvet90 New Member
    New black gutters and siding
    Wallygator and Fotnot like this.
