  1. Jul 18, 2020 at 8:30 PM
    #3571
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    my first water feature, this past spring, much smaller lol.
  2. Jul 18, 2020 at 8:34 PM
    #3572
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    Floored the kitchen. Finally.
    100sf took the afternoon due to moving all appliances to floor under them. Last piece of visible flooring that needed to be done. Woot.
  3. Jul 18, 2020 at 9:23 PM
    #3573
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Been real busy with my house chores this Spring/Summer, and love seeing all yours as well. This really made me laugh,...I won't tell you who this is in my family, but i think we all might have one among us...:rofl::rofl::rofl:
    https://youtu.be/CwGrC0KicSo?t=2
    Boosted4runner and jewsNbrews like this.
  4. Jul 18, 2020 at 9:23 PM
    #3574
    Outbound
    Aaron
    Northern Alberta
    I could work off that. That's actually better than alot of prints I deal with at work. At least it has dimensions. something our so-called engineers routinely neglect to include.
  5. Jul 18, 2020 at 10:30 PM
    #3575
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Added something new for the kids in the basement
  6. Jul 18, 2020 at 11:10 PM
    #3576
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    So a few months back I asked for advice on building a retaining wall. For the most part this thing is 6ft tall (except near the ends like in the picture below) and roughly 225 feet long. They built it with a rough rock wall on the backside, concrete with 3 layers of rebar in the center and a finished looking wall for the outside. It's actually taller than 6 feet since about another 2 ft of wall is in the ground. It's pretty stout.
    Anyway, the advice I got was to let someone qualified do the work. And boy, I'm so glad for that advice and that I actually listened... I'll take a photo of the thing after it's completed.
    But I need advice on one more part. My wife has decided she is afraid someone or one of the German Shepherds that we have, could fall off. So I am planning to build a wrought iron fence along the top.
    The picture below is when they first started and has not been capped yet. They will lay about 3 inch flat stone on top with concrete to finish it. The contractor says about every 8 feet he will stick a piece of angle iron in so I can weld my steel posts to the angle iron. I will probably use 1.5 inch square tubing. These pieces of angle will be concreted in 3 inches.
    My question is this, will the angle buried in the concrete 3 inches be strong enough to hold this fence? I'm no expert, but I'm a little concerned about that. The wall does curves several times, so I would imagine this will help with holding it in place. Is there a better way to anchor the fence? I sure don't need any mistakes here.
    Thanks!
    Also, no, I don't own a sparkly purple phone case... It's my wife's! :laugh:
  7. Jul 19, 2020 at 5:57 AM
    #3577
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    Wow, I am jealous you can do all that fixing!! Good for you for knowing how...
    If you found active termites I highly recommend going to doyourownpestcontrol.com and getting some termite bait stations (will be expensive, but worth it) to put around the periphery of your house (about ten feet from the foundation) and also some Taurus SC to spray all the wood with. The new wood can be sprayed with Boracare, I believe they also sell that. I am not sure if you can inject the brick foundation because that is where your major issue is since they can go up from the ground in-between the holes in the brick where you cannot even see them, but if you cannot inject them the baits should work, otherwise they may be back when they find another area of the house that is good eating. (I have learned a lot over the past four years about pest control owning my house in the woods :eek2:). I am just thankful that we don't have the dry wood termites here in the north, in addition to the subterranean!!!
    -T
    Boosted4runner and GODZILLA like this.
  8. Jul 19, 2020 at 8:14 AM
    #3578
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    If you wanting to put a fence above the retaining wall, I would recommend having your main support post anchored behind the wall versus anchored into the wall. When I put fence post on top of or into a wall I make sure I have enough rebar in the concrete footings to reinforce the extra fence post. I have had the concrete cored out for galvanized fence post and I’ve also had steel anchor plates embedded into the concrete. I’m actually doing both of these applications for a horse facility I’m building now. Your wall appears to be only stone, mortar and concrete, so I would not recommend transferring your post into that wall. I could see you having issues with this wall later down the road if you anchor your post into the wall. This would be fine if the stone was secured to a concrete retaining wall with reinforced rebar in it but that is not the case here. At least what I can tell from your photos.
    This photo shows the embedded steel anchor plates. These were set when the concrete was poured with rebar and stirrups in the concrete footings.
    The fencing after the post were welded to the anchor plates.
    These post I had the holes cored into the concrete. Then the galvanized post were set in the concrete footing.
  9. Jul 19, 2020 at 9:34 AM
    #3579
    TruckyTruck
    Gary
    Thanks! Yes, that's how it's built, but does have a bottom, middle and top layer of vertical rebar running the entire length of the wall.
    So securing the fence to the back of the wall.. I wondered if I could put the steel fence posts directly behind the wall 3 foot below and concrete them in with the concrete bonding to the back of the wall.
    Is that what you mean by securing them behind, or something different?
    I really appreciate the advice!
    In these pictures you can see some of the rebar in the concrete between the rough and finished part of the wall.
  10. Jul 19, 2020 at 9:43 AM
    #3580
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Very nice!! Good work!
    1UPPER likes this.
  11. Jul 19, 2020 at 10:17 AM
    #3581
    helloo
    helloo New Member
    Aurora, CO
    2018 Black TRD CM Limited
    At my last house I drilled two holes into a 2700lb rock to make a little water feature out front. Put some lights under it as well.
  12. Jul 19, 2020 at 12:19 PM
    #3582
    Oh I hired someone for this one lol. I think could do it though now that I watched some. I already hired him for the opposite side too. I’m not sure where’s he’s going to draw power from unless he can find a way to run the wiring from One side of the driveway to the opposite side to tie into the transformer. :notsure:
    jewsNbrews likes this.
  13. Jul 19, 2020 at 1:11 PM
    #3583
    1UPPER
    TEXAS
    Flux capacitor!
    Look great! You can buy a simple water tunneling kit from Home Depot or Lowe’s to run the conduit under your driveway. It’s only $5!
  14. Jul 19, 2020 at 1:55 PM
    #3584
    Boosted4runner
    WA
    I use something similar to dig up my sprinkler heads, never seen this! Badass! Thanks for posting!!
    This is def my favorite thread I follow online.
    Always cool shit to learn! :thumbsup:
    jewsNbrews and 1UPPER[QUOTED] like this.
  15. Jul 19, 2020 at 1:56 PM
    #3585
    1UPPER
    TEXAS
    Flux capacitor!
    If I started a thread for cool home improvement ideas you guys wouldn’t ever have time to work on your trucks anymore. Lol
    Skippy, aperezsh, Outbound and 7 others like this.
  16. Jul 19, 2020 at 2:13 PM
    #3586
    I installed the timer for the front garage lights. Works perfect now! Set to custom on / off times
  17. Jul 19, 2020 at 2:22 PM
    #3587
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Well I think you should start one anyways! House mods are just as important as the trucks if not more so.
  18. Jul 19, 2020 at 2:24 PM
    #3588
    RangerBP
    Worth the risk, IMO.
  19. Jul 19, 2020 at 3:56 PM
    #3589
    Boosted4runner
    WA
    Please don’t!!! :rofl:
    If you do, wait a few months so I can get through my already long list
    ETA - what a pain in the ass!!!
    Cutting 6” depth doesn’t sound like much, but I’m on bucket #12 - which I end up shoveling by hand at least half of, because the big ass tractor isn’t precise...and I’m trying not to go back and forth on the grass, which is required if you want a full scoop.
    F’d up the grass - wife was not happy. o_O
    I love the sun, but 88 degrees is a tad too hot for this shit.
  20. Jul 19, 2020 at 4:05 PM
    #3590
    Boosted4runner
    WA
    That is awesome!!! Nice work, and props on drilling yourself! :thumbsup::thumbsup::thumbsup:
    Thankfully I’m not working with a 2700# pc! That’s what all 5 of the rocks I’m using weigh...together! Lol
    That’s a really cool rock.
    Did you use your sprinkler system drip line to fill the reservoir??
    I heard there some type of auto fill plunger system that can be used, but it sure seemed like a lot of unnecessary work and cost.
    Since I already have drip plumbed in this bed like you do, I had planned to drop either a 2 to 4 gallon per hour dripper into the tank. Since I normally only water during the warm summer months, the reservoir would be filled when my plants get watered every day. Of course in the remaining months, it rains around here and I won’t need to fill.
  21. Jul 19, 2020 at 5:35 PM
    #3591
    TruckyTruck
    Gary
    Jeeze!!!! That's impressive!
    1UPPER[QUOTED] likes this.
  22. Jul 19, 2020 at 6:03 PM
    #3592
    1UPPER
    TEXAS
    Flux capacitor!
    Thank you! I guess some photos of my barn project have gone viral now. At least that’s what the owners told me. I don’t do social media.
  23. Jul 19, 2020 at 6:58 PM
    #3593
    Boosted4runner
    WA
    I believe it, and not surprised!
    HGTV needs to pick you up! :cool:
    TruckyTruck, CodyP, GODZILLA and 2 others like this.
  24. Jul 19, 2020 at 7:04 PM
    #3594
    TomC843
    Tom
    Charleston, SC
    Holmes on Homes, Lonestar edition
  25. Jul 20, 2020 at 7:38 AM
    #3595
    18" TRD Off Road Wheels
    What's with you Military women wanting to punch people? @4x4_Angel :monocle:
  26. Jul 20, 2020 at 7:56 AM
    #3596
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Because it solves problems. Only I don't go for the nuts first.... Throat then nuts.:D but in order to get hot in the nuts from me you have to piss me off pretty bad.
  27. Jul 20, 2020 at 7:57 AM
    #3597
    Kung
    KG, VA
    NICE work!
    On a funny side note, the house I owned previous to this one had some likewise riDICulous issues with it. A few months after we purchased it, I asked some of our neighbors (great people, whom we're friends with to this day) if they knew why it was so messed up.
    "Well, the foreman for the house was later arrested for meth usage and distribution...."
    :thumbsup:
    Thankfully, the house itself was pretty sturdy, and nothing 'wrong' with the house that couldn't be fixed - just a LOT of dumb decisions we had to go back and resolve/fix.
  28. Jul 20, 2020 at 7:59 AM
    #3598
    Kung
    KG, VA
    When it comes to houses, I dunno if it's a military *women* thing. I too would have punched the previous owner/builder of our previous house had I the chance.
    There were also some questionable decisions made in our current house. HOWEVER, the guy who built it
    a) lives next door
    b) is super helpful
    c) is Guamanian, bigger than me, and has a large family.
    :D
    GODZILLA[QUOTED] and 4x4_Angel like this.
  29. Jul 20, 2020 at 7:59 AM
    #3599
    Just watch out for cameras. :rofl:
    GODZILLA and 4x4_Angel[QUOTED] like this.
  30. Jul 20, 2020 at 8:01 AM
    #3600
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    On a serious note I've never intentionally nailed a dude in the balls in my entire life. I say intentional because I accidentally elbowed a buddy of mine and just grazed the twins and he hit the deck. Said a light graze is worse than a direct hit I guess? :rofl:
    I'm just saying the prior owner of this place probably needed one good hit though. Place was dirt cheap with lake access though so I can't complain.. Doesn't mean I'm not going to though. :cookiemonster:
