  1. May 23, 2020 at 5:55 PM
    #3091
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Those are great. We had one at our old house, my youngest daughter planted it.
    It's like a wall of flowers.
  2. May 23, 2020 at 7:09 PM
    #3092
    TaquitoBandito
    Joel (AKA Bif)
    Thanks - I'm really looking forward to seeing them grow. Was picking up some Chrysler Imperials when I saw these. Very excited.
    JMB[QUOTED] likes this.
  3. May 23, 2020 at 9:31 PM
    #3093
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    The inside span between the outside post is 19’6”.
    Alexstundra[QUOTED] likes this.
  4. May 24, 2020 at 7:07 AM
    #3094
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Nothing spectacular but I’ve put it off way too long.
  5. May 24, 2020 at 7:32 AM
    #3095
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Puttin in work on our new deck and outdoor shower. I'm going on a month on this project.
  6. May 24, 2020 at 9:18 AM
    #3096
    Just build a urinal next to it, and you’ll never have to go back inside :D
  7. May 24, 2020 at 6:21 PM
    #3097
    biebs96
    PA
    Have done several over the past few weekends.
    Raised flower bed
    Went from this..
    To this..
    Made a legitimate trailer parking spot.
    No photo but leveled the ground where my pool will be installed in a few weeks.
  8. May 24, 2020 at 6:29 PM
    #3098
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    He's all ready outside, seems redundant.
  9. May 24, 2020 at 6:45 PM
    #3099
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Installed mini split for our converted 3rd car garage that my wife is using as studio space for now. Just counting down the days until it's my workshop again...
  10. May 24, 2020 at 7:02 PM
    #3100
    toyota tom
    toyota tom New Member
    Jacksonville, FL
    2019 SR5 4x4 CM
    ESP underseat storage Shorter 6” antenna Bilstein 6112 @ 2.5, 6150, +2 CB shackle 275/60/20 ridge grapplers
    Started pressure washing the driveway today but ran out of time. Decided to have a little fun....
    Should I leave this????
    Hahahaha
  11. May 24, 2020 at 7:07 PM
    #3101
    TomC843
    Tom
    Charleston, SC
    How did you hide the line set?
  12. May 24, 2020 at 7:12 PM
    #3102
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The garage walls aren't insulated so I was able to drop everything down through that. There ended up being about a foot of it visible on the other side of the wall and then squeezed it all between the block and foundation over to the outside unit.
    aperezsh and TomC843[QUOTED] like this.
  13. May 24, 2020 at 7:19 PM
    #3103
    TomC843
    Tom
    Charleston, SC
    Was impressed, biggest fault I usually see in self install is not shorting the line set and homeowner coiling it up vertically causing multiple oil traps.
  14. May 24, 2020 at 7:21 PM
    #3104
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    In the process of a fireplace patio geared toward cooking. It will eventually have a roof over it. If we're stuck home and not spending money for a vacation I may as well make the yard better.
    1UPPER, Wallygator, kparrow and 22 others like this.
  15. May 24, 2020 at 7:22 PM
    #3105
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    I will post pics as ot progresses
    NewImprovedRon, saybng and jewsNbrews like this.
  16. May 24, 2020 at 7:30 PM
    #3106
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I got compliments from the HVAC guy that did the flush/vacuum/charge testing on the system. Apparently I paid enough attention when I helped my grandpa at his plumbing shop back in the day! I also got really lucky that the lines that came with were EXACTLY the right length...
  17. May 24, 2020 at 9:17 PM
    #3107
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    That's so awesome!!!
    Njmike13[QUOTED] likes this.
  18. May 24, 2020 at 9:21 PM
    #3108
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    I installed the same Pioneer mini split last weekend for our family room. Worked out real well.
  19. May 24, 2020 at 9:24 PM
    #3109
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That thing is super quiet. I didn't think it was running until I could barely hear the fan running from about 5 feet away.
  20. May 25, 2020 at 12:56 PM
    #3110
    Last night, the kids were upstairs, in the loft watching a movie. I thought to myself, I should add a dimmer switch for the in-ceiling loft lights. So, today I went out and did just that lol.
    1UPPER, JH5370, 1lowlife and 2 others like this.
  21. May 25, 2020 at 2:52 PM
    #3111
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Don't you love it when the wife rearranges a room, wants to move the TV?
    Then she says 'can you move the cable outlet over there to that wall?'.
    'Sure Babe there is nothing more I'd like than to get in the attic, on my bad knees, and fish a cable down a wall.'
    It was a little different this time, the other side of the wall is the master bath.
    Had to do a sh!tload of measuring both walls to make sure I didn't hit any supply lines or drain pipes..
    Ran a picture wire thru the ceiling to mark where I wanted it.
    Go in the attic, find it, had to lay under the furnace to get to it.
    Drill my hole in the stud to run the cable.
    Then I get it all ready, measure, mark, and cut my hole in the wall.
    Then find a hot water supply line and a sink drain pipe very close to where I cut it.
    Sink drain threw me off since it is a double sink, didn't realize that would share a pipe in the wall and go into the foundation in the middle.
    But that all worked out, I took it easy cutting the hole with my OSCILLATING saw..
    Ran the fish tape down the wall, had her grab it, came down, taped it up and pulled it up.
    It all worked out.
    I must have went up and down those attic stairs 12 times today.
    No pics but anyone that has done it can relate.
    I cruse myself every time this happens for not getting the DirectV wireless mini-Genies.
    I've had to this in each of the 4 bedrooms.
  22. May 25, 2020 at 4:53 PM
    #3112
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    Got the chimney on and the stone set on top. Next will be the sitting walls in each side.
  23. May 25, 2020 at 5:34 PM
    #3113
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Do you want to hear they have wireless solutions for this now or should I just keep moving?
  24. May 25, 2020 at 5:35 PM
    #3114
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    :rofl::bananadead:
    Moon Puppy[QUOTED] likes this.
  25. May 25, 2020 at 5:44 PM
    #3115
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    But really though. I hate moving low voltage stuff so much...
  26. May 26, 2020 at 4:47 AM
    #3116
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Did you read the entire post?
    I've had the wired units since before they offered the wireless.
    The last time I inquired about them, DIRECTV wants $400 to swap the wired units to wireless mini-Genies.
    It would also require another 2 year commitment to them.
    I haven't been under contract with them for a few years.
    I'm thinking about ditching them in the near future and don't want to be stuck with them for another 2 years.
    But thank you for your concern, it was very helpful..
  27. May 26, 2020 at 6:50 AM
    #3117
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Yeah I missed that last line sorry.
    Seriously, both Dish and Direct do this crap. Offer all this free stuff to new folks but gouge their loyal existing subscribers. I would contact Dish, get an offer and go back to Direct, tell them to disconnect and see what they do. I dumped Dish a while back in favor of local fiber service and I'm still getting calls from Dish to reconnect with all these offers of free stuff.
    1lowlife[QUOTED] likes this.
  28. May 26, 2020 at 7:08 AM
    #3118
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    When I had DirecTV a few years ago I had this same issue. I wanted to mount a TV on my patio but there wasn't coax anywhere nearby. I ended up finding the wireless bridge and mini-Genie on Amazon for around $100 for both and already had the main Genie system (the remotes, wireless or wired, are shit IMO). I had to call their support to get the bridge and wireless mini activated, but after that I thought I was golden... until I cancelled my contract a year later and they included MY equipment on the return list. Those assholes claimed that the receiver I bought outright, 3rd party from them, belonged to them. I went back and forth with different supervisors and all sorts of shit, but in the end I just sent it back because it wasn't worth the headache.
    Having said that, I have a free DirecTV wireless bridge if anyone wants it...
  29. May 26, 2020 at 7:23 AM
    #3119
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Damn ! That's some plush grass. I could lie down and take a nap :D
  30. May 26, 2020 at 7:35 AM
    #3120
    rons23
    Ron
    Kill Devil Hills
    Been doing some upgrades in/out the house. My buddy finished our handrails and stairs. I did all the beveling and sanding. He did a helluva job, also built us a nice 2 door front gate. Some before/after pics. Also prepped backyard for pool installation. :D
    My buddy said I have a few years left on my deck boards so they will be pressure washed and stained.
    Looking to paint house this fall.
