What have you hauled or towed with your 3rd gen?
Discussion in '3rd Gen Tundras (2022+)' started by Dirtdog, Jul 27, 2024.
  1. Jul 30, 2024 at 4:28 PM
    Dirtdog
    Dirtdog [OP] New Member
    2023 Tundra SR5 TRD off road premium
    That's great milage for pulling a tandem axle with a car.
  2. Jul 30, 2024 at 5:43 PM
    Nitricacid
    Nitricacid New Member
    Jerzey
    22 Tundra Platinum 4x4 Midnight Black
    Had a dump trailer and ended up towing 14k lbs. Dirt weighs a hella lot. Butthole puckered everytime i needed to brake lol
  3. Jul 30, 2024 at 5:54 PM
    Breathing Borla
    AZ
    lol
    1.5 tons per yard3 for soil with clay in it
  4. Jul 30, 2024 at 6:17 PM
    kelbro
    kelbro New Member
    2021 1794 CrewMax 4x4 in Wind Chill Pearl
    2̶0̶2̶2̶ ̶1̶7̶9̶4̶ ̶C̶r̶e̶w̶ ̶M̶a̶x̶ ̶4̶x̶4̶ ̶w̶i̶t̶h̶ ̶A̶d̶v̶a̶n̶c̶e̶d̶ ̶P̶a̶c̶k̶a̶g̶e̶
    ~7500# towed great. Air ride setup was a little stiff coupled with the WDH but no sway and felt very comfortable towing up or down the mountain.
  5. Jul 30, 2024 at 7:59 PM
    HeBeGB501
    HeBeGB501 New Member
    2024 White Tundra Limited, TRD OffRoad
    I have hauled a yard of dirt a few times. The biggest load was a full pallet of sod. I have Air Lift 5000 ultimate bags in the rear, so they helped to level the truck back out. I wouldn't want to haul this much very often. Luckily I am not far from the sod place.IMG_5970.jpg
  6. Jul 31, 2024 at 5:44 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Pulled my 1k pound ZTR back to the garage out of the muck in the neather regions of my property when its drive belt tension spring broke.
    Not that much of a pull weight wise but satisfying.
  7. Jul 31, 2024 at 7:41 AM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Trailer is roughly 7500# loaded. Just did a 1400 mile trip from Nor Cal to Stanley Idaho and back. I've been towing this setup for over two years now. Coming from a '18 Ram 2500 (gas) and a '19 Ram 1500 I can say this truck is my favorite to tow with. The transmission is super smooth, tons of power. I watch the trans gauge and it never budges above 40%. No air bags, just a dialed WDH. I have a 2"/1" (F/B) lift as well.
  8. Jul 31, 2024 at 8:28 AM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    IMG_2999.jpgAbout 100lbs over door rating. Minor squat is about same as my gen2 but I don’t feel the light front end like in the gen2.
  9. Jul 31, 2024 at 8:42 AM
    Breathing Borla
    AZ
    most guys who weigh their gen 3s are fining 200-300 more lbs of actual payload, toyota sandbagged the ratings a touch
    so your likely actually within real payload anyways
    MaineTundy[QUOTED] likes this.
  10. Jul 31, 2024 at 9:12 AM
    MaineTundy
    Yep, I’d be comfy with another 500#s or more.
  11. Jul 31, 2024 at 3:14 PM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Yup. My test drive was to a scale down the road from the dealer. My curb weight was 5560#, with a GVWR of 7210# giving me a payload of 1650#. I think my door sticker says 1350 or something. Crazy low. I've had zero issues towing with this truck. Like I said above, I honestly feel it outperforms the two rams I had prior (and I liked the 1500).
  12. Jul 31, 2024 at 4:52 PM
    buckeyeman11
    buckeyeman11 New Member
    2024 Tundra Limited
    I’m looking to buy a 6500# travel trailer and seeing guys haul theirs gives me more confidence the truck can handle it without an issue.
  13. Jul 31, 2024 at 4:53 PM
    buckeyeman11
    2024 Tundra Limited
    How long is your camper?
  14. Jul 31, 2024 at 6:17 PM
    Dirtdog
    Dang. That's a lot weight and no squat. I'll have to check those air bags out.
  15. Aug 1, 2024 at 6:14 AM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    To be clear, my TT dry weight is listed at 5700# dry. It GVWR is 7600# (which is what I assume it weighs when loaded as we don't go crazy, but I've never taken my setup to the scales to verify). After doing tons of research into all of this, I am a firm believer in keeping the TOTAL weight under 75% of the trucks tow capacity. Payload is where you'll run short first, but the 75% formula seems to keep you in a pretty safe zone. Generally speaking. Personally, I wouldn't want to tow much bigger than what I have with a 1/2 ton truck. The WDH is the key to making it all work.
  16. Aug 1, 2024 at 7:18 AM
    Breathing Borla
    AZ
    thats been the age old super tested conservative way to do it, keep 25% reserve capacity no matter what your doing. follow this and you stay out of trouble for sure:thumbsup:
    Dfrink[QUOTED] likes this.
  17. Aug 1, 2024 at 3:25 PM
    Yotaholic4life
    Yotaholic4life New Member
    24 TRD Limited CM LB, 23 SR5 8ft bed DC
    24 TRD Lift
    I sent the 23 out with the Hydroseeding crew today . They sent me this pic with 800gal tank of water , 400lbs of mix and a 8ft box full . They asked kindly ,, “can we get some air bags because this seems cruel lol “ I said “ it’s a work truck , make it work or die trying “. JK , gonna need some airbags but this is not the trucks job on the daily by any means .
  18. Aug 1, 2024 at 3:27 PM
    Breathing Borla
    AZ
    dude, get a HD truck for that
  19. Aug 1, 2024 at 3:46 PM
    #49
    Yotaholic4life
    24 TRD Lift
    Lmao , we have more appropriate trucks for the job ! Today , they were all busy and the job had to be done . Short haul , no hills to speak of and easy terrain for seeding . It handled the weight and did its job today . I’m proud of her lol
  20. Aug 1, 2024 at 4:00 PM
    #50
    kelbro
    kelbro New Member
    31' overall
  21. Aug 1, 2024 at 4:02 PM
    #51
    kelbro
    kelbro New Member
    The same direction that I take. Feels much safer.
  22. Aug 3, 2024 at 10:33 AM
    #52
    Dirtdog
    I just got this HF bed extender. It's pretty nice. In the lowest setting the horizontal bracket is just flush with the bed. It's about 10' from the front of the bed to the bracket. It makes hauling the long boards a lot easier.PXL_20240803_171111936.jpgPXL_20240803_170853417.jpg
  23. Aug 3, 2024 at 8:41 PM
    #53
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    That a pretty cool, you got it at Harbor Freight you say? I will have to look that one up. I have the 5.5 and man does it suck when I have to haul something long.
  24. Aug 3, 2024 at 9:15 PM
    #54
    GilFavor
    GilFavor New Member
    2023 silver tundra 1794
    Wow, if I ever buy a new truck I will definitely get the air ride…this was only 100 pieces…
    Is aftermarket air ride considered “just as good” better, or worse, I wonder.
    Metro14536 and Malinois38 like this.
  25. Aug 4, 2024 at 6:48 AM
    #55
    JerseyGeorge
    JerseyGeorge New Member
    2024 Platinum
    We towed our Winnebago, #4500 pounds or so, from New Hampshire to Shenandoah park, elevation 3500' range. Did not even know there was a trailer behind us, accelerating or stopping. I used to do that in a 4runner. Huge difference.
  26. Aug 4, 2024 at 7:26 AM
    #56
    Dirtdog
    Yes, it's at Harbor Freight for $60. It's actually very heavy duty. It also gives you two more tie downs on the horizontal bracket. I've got the 5.5" bed and it's about 10' from the front of the bed to the horizontal bracket. You could carry 12' without a problem.
    22whatwedo[QUOTED] likes this.
  27. Aug 4, 2024 at 9:00 AM
    #57
    HeBeGB501
    I don’t have any experience with the factory air ride option but I would assume that it can auto level the truck. With the aftermarket, you have to dial in the pressure to het the truck level. You do have the ability to save presets, if you have a common weight that you haul. My only annoyance with the version I have is that the controller won’t let you go less than 5psi. That 5psi raises the back of the truck about 3/8” with no load.
  28. Aug 4, 2024 at 9:38 AM
    #58
    Breathing Borla
    AZ
    The factory one auto levels , it’s awesome
    Mr Rick, pwpblue and Dirtdog[OP] like this.
  29. Oct 24, 2024 at 4:36 AM
    #59
    Rickoo
    Rickoo New Member
    Trying to decide between a 23 and 25 foot airstream. 23 should be no problem. After doing the math, the tongue weight of the 25 (which we would rather have) seems to be questionable for my capstone.
    I see some tow the 25 with no trouble at all. Any concerns about payload? Not sure I could put anythng in the bed without going over.
  30. Oct 24, 2024 at 9:24 AM
    #60
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I would get the 25 if in doubt. We have a 22 Sport and it is nice for the 2 of us but would like the extra space offered in the 25. With the tongue weight concern, there are things you can do to move weight around to get the tongue weight at around 12% of the Trailer weight. In my case, I actually move more weight forward on the hitch as it lessens the chance of swaying. We run around 12% which is a bit more than the 10% minimum that experts say to stay above.
