WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Dec 2, 2021.
  1. Jan 19, 2023 at 6:00 PM
    #2281
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    Thank you for the update. I’ll be putting the Timbrens on for sure but I hope that little “bump” isn’t a noticeable issue. Keep the updates coming.
  2. Jan 19, 2023 at 6:31 PM
    #2282
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I am sure the little bump wont be noticeable with a bit of weight on the back.
  3. Jan 20, 2023 at 5:41 PM
    #2283
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Part #'s for those who may be interested:
    22-23 Tundra Icon Foam Bump Stop Kit - SKU 56113
    Icon Vehicle Dynamics 2.5 VS Internal Reservoir Coilover Kit - SKU 58670
    Icon Vehicle Dynamics Rear 2.0 VS IR Shock Absorber - SKU 56516
    Toyota TRD UCA's PT985-3431B & PT985-3432B
    Should have posted these a while back, but better late than never. Install was relatively easy with the right tools, but I've done this a few times in the past. I did notch the lower control arms as instructed by Icon for clearance at full droop, then gave the area a couple shots of Rustoleum for good measure. Didn't get any pictures of the notching, unfortunately. Easy work though, just a little tedious if you want to make it look nice. If anyone would like to see that, just mention and I can grab some pictures for you. I think the worst part of the install was it being roughly 10 degrees outside, which meant working with the garage door closed and the heater roaring.. Truck hardly fits, so it was a bit tight, but we managed. Father in law was in town, so two extra hands and some motivation certainly didn't hurt.
    I attached a photo of some measurements I took after install. The coilovers were not adjusted, and these are straight out of the box results. Tried to get as accurate measurements as I could and used my laser tape to measure from the floor, thru centerline of the hub, to the bottom of the fender flare. Keep in mind the coilovers had not settled at this point, so I may adjust them after a few months and re-align. The new upper controls arms added lots of caster, as expected, and have plenty to spare. All around I am very happy with the results. I drove the truck for a few months in stock fashion, then a few months with a 2.25" ReadyLift level kit (above the top hat - no added pre-load) and now with the Icon setup. The truck drives great, is extremely compliant over rough terrain / potholes and the like, and has a more plush/comfortable ride than either the stock setup or the ReadyLift.
    Siblue, dan81, TexasTacoma713 and 3 others like this.
  4. Jan 20, 2023 at 6:03 PM
    #2284
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    Nice to know you can get a dirt bike in the 5.5 bed with the tailgate up.
  5. Jan 20, 2023 at 6:07 PM
    #2285
    SC4333
    SC4333 New Member
    Grant
    ...and to wrap the project up, the Diode Dynamics TRD Pro center grille light bar and replacement fog lights. Both in Amber. These things are BRIGHT. Much brighter than stock, and this is with Amber which is significantly LESS bright than their white counterparts in terms of Lumen output. I hooked them up to my Switch-Pro and will have to make a seperate post about that sometime. Easy peasy, just take your time routing your wire through the engine bay and measure twice, cut once when you mount the panel to your dash.. SDHQ makes a nice 3D printed mount FWIW. I will mention that DD sent an install kit with the wrong sized screws for the grill. Luckily I have a large selection of stainless screws and had exactly what I needed, but I could imagine most people would be high and dry and left pretty upset if they're hardware store was closed or didn't have those screws.. It is also worth noting that DD made right by sending an email out (presumably to everyone who purchased these direct, as I did not reach out to them) offering a replacement hardware kit to anyone who had purchased the center grille light. Anyhow, I'm very pleased with the lights and they do great in the snow / rain / fog
    Last, I had some of the matte black door handles to install. I was on the cuff about installing them or not. Only because I was not excited about removing all the door panels. After some debate, I convinced myself by ordering some sound deadening materials. I went with some generic Amazon branded butyl with aluminum liner, and some closed cell foam on top of that. very impressed with the results and well worth the minimal cost. It's just a somewhat laborious task..
    69370017146__07B28732-D8FE-4FE6-AFA2-E6670197A002.jpg 69370017146__07B28732-D8FE-4FE6-AFA2-E6670197A002.jpg IMG_5688.jpg 69378693319__19A22E1B-CF73-41A9-A197-0278383A42A0.jpg 69380665416__854701CA-DBC8-4B18-807A-2D202DB4398F.jpg 69378700739__BE21E9C9-97F9-426E-A6BA-96D78E32F99E.jpg IMG_5691.jpg
    =JSG=, Twin2turbo, osu1978 and 4 others like this.
  6. Jan 20, 2023 at 8:38 PM
    #2286
    ncart
    ncart New Member
    2022 Lunar Rock TRD Pro
    The racks are great. Yes, they are in the lowest position now and you barely notice them in the rear view mirror. I bought them for carrying kayaks, so I will need to lift them a little when in use. The cross bars are the 68” set.
    eaglebkh[QUOTED] likes this.
  7. Jan 20, 2023 at 8:46 PM
    #2287
    Tom976
    Tom976 New Member
    Tom
    Nice lift... how much were the parts total (if you dont mind me asking)
  8. Jan 20, 2023 at 8:47 PM
    #2288
    ncart
    ncart New Member
    The bed cover is awesome. I had a bakflip on my prior truck and loved it, but wanted the rack combination on this one. I have a camper and kayaks, and while pricey, this gave me the most flexibility and access. The track system is great and makes it really easy to add or remove the racks. The slide is really nice too versus flipping and clipping it. I thought about going with the MX, but the full aluminum is nice and solid. No water gets in at all.
  9. Jan 20, 2023 at 9:02 PM
    #2289
    ncart
    ncart New Member
    I have been considering sound deadening too. How much of an improvement did it make? Did you add a layer inside between the panel too or just on the outer wall? I am going to be putting on some highway miles and would love a little more quiet. How long did it take you to do all four doors?
    SC4333[QUOTED] likes this.
  10. Jan 20, 2023 at 10:24 PM
    #2290
    SC4333
    SC4333 New Member
    Grant
    Thanks! $2267 shipped to my door. Includes a wrench to adjust the coilovers as well. I bought the coilovers and rear shocks from 4WP since they had the best price at the time, and the bump stops were ordered direct from Icon. The Toyota TRD lift kit upper control arms were purchased from Lithia Toyota online and arrived within a week. Somehow I managed to order an extra set of the UCAs and will post them on here for sale at a discount when I have some time. I ordered a set of UCA bolts as well, but they arrived a few weeks late. I'll likely toss this in with the UCAs so they can be put to good use.
  11. Jan 20, 2023 at 10:35 PM
    #2291
    SC4333
    SC4333 New Member
    Grant
    I did the outer panel as well as the inside face of the metal panel closest to the door panels. I only put the foam on the outer panel. I lost track of time but I would give it a solid 4 hrs between taking the panels off, cutting and placing all the material, then putting the panels back on. I took my sweet time so I didn't goof anything up, and it was so damn cold I was a little worried about adheasen, so I made sure everything was very clean and secured well to the metal.
    Here's what I used, and it was almost exactly enough to complete the entire job. Just a few square feet to spare. Alternatively, you could probably skip that inside metal panel and use that material on the rear cab, behind the seats. I did not do that area, although havent heard too much NVH from that area either.
    Siless Liner 157 mil (4 mm) 36 sqft Car Sound Deadening & Heat Insulation Closed Cell Foam - PE Foam Sound Deadener
    Amazon Basics Car Sound Deadener, 9.8? x 15.7? (34-Piece)
    TN Tundra2 likes this.
  12. Jan 21, 2023 at 5:14 AM
    #2292
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    Nice! That was my worry going from my 08 Double Cab to the 23 Crew Max 5.5, Just tried it out myself and happy with it. Plus can still get two in with my bed extender.
  13. Jan 21, 2023 at 2:10 PM
    #2293
    Fireman258
    Fireman258 New Member
    I improved the JBL sound system by unplugging the "subwoofer" behind the back seat.
    The sound before was horrible. It sounded so bad I had the dealer look at it and see if they would replace it. They said it wasn't broken its just a crappy speaker. Nothing they could do about it. Even with the bass turned all the way down in the EQ it still just sounded awful. So I unplugged it to see what it would sound like. MUCH better. The bass in the door speakers is adequate and now the audio sounds more well rounded. It won't blow the windows out, but at least now it sounds balanced and not like a crispy rattle box. I recommend anybody with the JBL system unplug the subwoofer. You won't regret it.
    mayan, SC4333, DimaA and 1 other person like this.
  14. Jan 21, 2023 at 2:19 PM
    #2294
    Tom976
    Tom976 New Member
    Tom
    Disable the subwoofer? How else are you going to rattle those license plates?
    Yaboy likes this.
  15. Jan 21, 2023 at 6:04 PM
    #2295
    jgoliath
    coming from a 5 foot bed Tacoma, this was a great surprise as I didn’t even think about it when I was buying the truck!
    obgod3[QUOTED] likes this.
  16. Jan 21, 2023 at 8:33 PM
    #2296
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    So out of the box did these coilovers lift more or less than the readylift 2.25” spacer lift you had on?
    About to install these exact same coilovers on mine
  17. Jan 21, 2023 at 9:43 PM
    #2297
    Byrdarian
    Byrdarian New Member
    Anthony
    2023 Tundra Limited 4x4 Crewmax 5.5' Midnight Black
    Got the Datin Fab rack today and installed the rack. Ran out of time so I didn't get my awning jack or traction boards on yet. 20230121_213317.jpg
    Tundra Dude 45, Helo and ncart like this.
  18. Jan 21, 2023 at 9:56 PM
    #2298
    Bneff89
    Bneff89 New Member
    2023 SR5 TRD Sport Blueprint
    I wonder how good the light bar included in the full grille kit that Rave OR offers.
  19. Jan 21, 2023 at 10:05 PM
    #2299
    Byrdarian
    Anthony
    I hope to be able to answer this soon. I ordered it and it arrived today but did not have time for the install. I think they had a video on their website. I have a feeling it is not incredibly effective.
    DoMoToyota and Bneff89[QUOTED] like this.
  20. Jan 21, 2023 at 10:11 PM
    #2300
    Bneff89
    Bneff89 New Member
    Yeah I have the same feeling as the price for the light bar alone is only $180. Once it is installed, I'd be curious to know your thoughts.
    DoMoToyota likes this.
  21. Jan 22, 2023 at 5:23 AM
    #2301
    Blistering fish
    Blistering fish New Member
    Blister
    2023 tundra 1794 iForce max TRD OR army green
    Gave it the first oil change at 1087 mi for good measure. Had them lubricqte the driver side door hinge….and delete the fake engine noise. Now I’m loving the truck
    SD.Tundra.858 and 9OH1 like this.
  22. Jan 22, 2023 at 6:46 AM
    #2302
    wedemmoez
    wedemmoez New Member
    2022 Black Tundra TRD Pro
    Bought my TRD Pro yesterday!
  23. Jan 22, 2023 at 3:14 PM
    #2303
    SC4333
    SC4333 New Member
    Grant
    Initially it was almost dead even in height between the two setups. I now have a couple hundred miles on the truck and the front seems to have settled in as much as it will settle. Overall, the front has settled about an inch, maybe a hair more. I like a slight rake so i'll probably leave it as it. Keep in mind I had the TRD OR struts combined with the ready lift so there would be a small difference it height over the sport or SR5 suspension. I would recommend driving the truck for 25-50 miles and see if it's where you want it. Then adjust if needed, and go get it aligned after you have the height dialed in.
  24. Jan 22, 2023 at 4:57 PM
    #2304
    jkwarren88
    jkwarren88 New Member
    James W.
    2022 Tundra SR5 Crew Max
    All windows and windshield tinted, black overlays and inserts. Just ordered the RC 1.75' lift kit, and 18" Fuel Ammo Gunmetal Rims with 295/70/ Nittos, will be installing next week
    It was a very sad day
    Before and after
  25. Jan 22, 2023 at 5:29 PM
    #2305
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Dude…that sucks! Hopefully everyone is OK.
    DoMoToyota, DeafJam, Boerseun and 3 others like this.
  26. Jan 22, 2023 at 6:26 PM
    #2306
    earlwright239
    earlwright239 New Member
    2022 Army Green Tundra SR5 TRD Sport
    That's a lot of paperwork on the front window! Used? Or is that a list of all the added fees/things none of us want?
  27. Jan 22, 2023 at 6:39 PM
    #2307
    jkwarren88
    James W.
    My wife and I are fine, did a full roll, and some side sliding. Some idiot on a cell phone came over and hit the qtr panel, and it just broke loose down an embankment. Neither one of us have a scratch or bruise on us, it happened this past Tuesday. Really need to write a safety review for that thing.
  28. Jan 22, 2023 at 7:10 PM
    #2308
    Tom976
    Tom976 New Member
    Tom
    Wow, hate to see a new truck like that. Glad that it protected the occupants... you are the Ms. are safe and sound.
  29. Jan 23, 2023 at 5:53 AM
    #2309
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    Reihengti likes this.
  30. Jan 23, 2023 at 7:11 AM
    #2310
    erdub54
    erdub54 New Member
    2023 Tundra TRD Pro Solar Octane
    IG: Mallrig.Pro
    Front Coilovers, Upper control arms and rear coils installed this past weekend
    AFB6A974-FD6B-42B7-928A-88104644336D.jpg 9B936D33-4DE6-4845-B1D1-D79554779439.jpg
