WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Dec 2, 2021.
  1. Jul 7, 2025 at 6:52 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Any probs/tips on install ? Like to see final look with the arks installed as well.
  2. Jul 7, 2025 at 7:05 PM
    60centenergy
    60centenergy Mods Member
    Zack
    GVL
    ‘24 Lunar Rock SR5 TRD Sport
    Thanks for the update. I didn't know this! I may need to figure out something else or just stop using Car Care. You would think it would log with Carfax... I do keep another excel sheet with my self records. Definitely don't want to be doing double work if it's not worth it.
    BlackNBlu likes this.
  3. Jul 7, 2025 at 7:54 PM
    hudrock
    hudrock New Members only jacket
    So Cal
    25 MGM Limited
    My 4th of July sale purchase, Diode Dynamics Hitch mount LED Pod. Simple install and so far I like the looks and functionality of it.IMG_1789.jpg IMG_0441.jpg IMG_0442.jpg IMG_0443.jpg
  4. Jul 7, 2025 at 8:11 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Well, isn't that just a kick in the sack?
    So it's just a fancy way to record it for the owner's use/reference and that's it?
    Dumb.
    60centenergy[QUOTED] likes this.
  5. Jul 7, 2025 at 8:12 PM
    60centenergy
    Zack
    GVL
    Programmed the slim key card for my rig. It worked great! Game changer for just having it in the wallet or phone carrier case.
    You can totally do it yourself if you have Techstream. Here's my post if you're interested.
  6. Jul 7, 2025 at 8:16 PM
    60centenergy
    Zack
    GVL
    Totally agree! I'll just be sticking with my detailed sheet I've always had and drop the Car Care app.
  7. Jul 7, 2025 at 9:27 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Maybe there is a way to share your diy records?
    I use a Google sheet myself. Easy to share too.
  8. Jul 8, 2025 at 6:20 AM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Can you post a a image as viewed in the drivers side mirror showing the illumination at night with/without the pod light?
  9. Jul 8, 2025 at 6:25 AM
    Daedalus
    Daedalus New Member
    Drove it and parked it.
  10. Jul 8, 2025 at 7:11 AM
    daverxa
    daverxa New Member
    Dave
    2024 White Tundra Limited TRD Offroad & TRD Lift
    Leer 100xl, ggoffroad DRV camera relocation, Decked drawer system, BF Goodrich TKO3 275/65R20, Diode Dynamics Fog lights, Go Rhino Dominator D6 Running Boards,
    Is that easy to remove? Can you add a locking pin? I'm worried someone would steal it.
    CappyKD likes this.
  11. Jul 8, 2025 at 7:16 AM
    CappyKD
    CappyKD Older, grayer member.
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    Yes, it is very easy to install, and yes you can use a locking pin with it.
    Sean492 and daverxa[QUOTED] like this.
  12. Jul 8, 2025 at 7:48 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    You have the option of keeping it simple and using the push tabs it comes with. If you want to use a locking pin, you knock the tabs off and then you can run the pin through the housing. Instructions tell you to do that.
    I had this pod and it was ok...the baja designs pod is brighter and wider but its also a bit more money and I dont think it has the brake light function.
  13. Jul 8, 2025 at 12:23 PM
    222Tundra
    222Tundra New Member
    Kentucky
    2022 SR5 CrewMax Midnight Black
    Punched a hole in a tire and found out the spare was destroyed during factory installation, so got new tires today. BFG KO3 285/65/18 on stock rims for now.
    Unitdosed, ngoshawk, Miker24 and 4 others like this.
  14. Jul 8, 2025 at 3:42 PM
    hudrock
    So Cal
    25 MGM Limited
    yes to both questions, check out their install videos…. personally I wanted the extra brake light with the flash as it’s my daily and I’m always in heavy traffic with crappy distracted drivers so I figured it might help. Haven’t really used the reverse lights at night yet since install but seems plenty bright for my concrete jungle use.
    CappyKD likes this.
  15. Jul 8, 2025 at 3:44 PM
    Pizzanaut
    Pizzanaut New Member
    Really straight forward, used an adjustable wrench to get the stock ones off, they weren’t very tight to begin with. You’ll have to jack up the truck a little bit to tighten the new bolts that come with the Durobumps up front. Try not to overtighten it, they come with thread locker on the bolts. Didn’t get them for the rear yet they’re a bit pricey and I’m less concerned bottoming out on the rear with the 2” lift on the back end. Definitely much nicer than the stock ones
    I only had time to get the rear flaps on, grabbed a few quick pictures for you.
    The front will take a little more DIY since I pushed the fender well liner back and used the westcott designs clearance brackets to hold the liner back further so the mount locations are slightly different on the inner liner area.
  16. Jul 8, 2025 at 4:22 PM
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Got stuck in a nasty hail storm. Bakflip MX4 needs to be replaced, many dents.
  17. Jul 8, 2025 at 4:38 PM
    60centenergy
    Zack
    GVL
    How did the Tundra handle it? Any dents?
  18. Jul 8, 2025 at 4:42 PM
    lapoolboy
    lapoolboy New Member
    Where?
  19. Jul 8, 2025 at 5:07 PM
    Tundrastruck91
    Thanks and agree ... wanna do all four corners.
    Pizzanaut[QUOTED] likes this.
  20. Jul 8, 2025 at 5:07 PM
    SilveradoSwap
    Not that i seen, will look at in the sun tomorrow. The tonneau has about 30 dents in it.
  21. Jul 8, 2025 at 5:08 PM
    SilveradoSwap
    PA
    We had hail storms here before that destroyed parking lots full of cars. They had to use plows to get the hail off the road. It was big hail, took out businesses and all.
    https://youtu.be/KM_az3IGd5E?si=yXysxCwXGA5A7N8k
  22. Jul 8, 2025 at 6:11 PM
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    Got my registration bill today... $508 for a year :frusty:
    CappyKD likes this.
  23. Jul 8, 2025 at 6:22 PM
    CappyKD
    Kirk
    I feel your pain.
    az 3rdGen likes this.
  24. Jul 8, 2025 at 6:39 PM
    TerraOnMyTundra
    TerraOnMyTundra New Member
    New coilovers / rear springs / shocks came in from the brown truck man today.
    Process for swapping the rear coils out looks... Far too simple lol.
    chrisgibbs707 likes this.
  25. Jul 8, 2025 at 6:44 PM
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Messed around with my compression adjusters on the rear and found my sweet spot for daily driving. +4 in the front and 0 clicks in the rear. Silky smoof.
    SnowToy likes this.
  26. Jul 8, 2025 at 9:27 PM
    Retroboy1989
    Northern Utah
    Anyone else have this crap? Two leaking coolant hoses. Only 5300 miles on the clock.
  27. Jul 8, 2025 at 9:29 PM
    TerraOnMyTundra
    Not that I'm aware, however I keep catching whiffs of coolant after parking.
    I'll have to dig in tomorrow. I'm also around 5k miles.
  28. Jul 8, 2025 at 9:34 PM
    Retroboy1989
    Northern Utah
    Passenger side. Bottom of the radiator. Peek around the skid plate. I also get a whiff of coolant occasionally after parking with a hot engine.
  29. Jul 8, 2025 at 10:47 PM
    G8Santini
    G8Santini New Member
    25 Tundra SR5, 4x4, PremCnv, Perf. Pkg., Blackout, TRD 3”Lift, 20”TRD rims
    Heritage grille, fog lights, 35x12.5x20” Nitto, low profile toolbox, F/R tow hooks
    Nitto 35x12.5x20 on factory TRD 20” rims
  30. Jul 9, 2025 at 5:12 AM
    mach1man001
    mach1man001 New Member
    Rob
    MA
    2024 Limited Crewmax
    Yup. Mine were to the intercooler. Dealer replaced hoses and tank
    Retroboy1989[QUOTED] likes this.
