WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Dec 2, 2021.
  1. Jun 17, 2025 at 6:31 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    I don't want the truck to do anything I don't tell it to do. I didn't tell it to turn off. I also don't want to increase my starter use by three, five or more times for what I see as no benefit. I am fairly easy on the brakes but still activate the auto stop a few times per trip, city driving often corner to corner.
    BlackNBlu and LowcountryDave like this.
  2. Jun 17, 2025 at 6:42 PM
    Toklas
    Toklas New Member
    2023 limited TRD OR CM short bed blueprint
    yup found another vendor on etsy that has some more options. already did my wifes suby so wanted some for mine too :)
  3. Jun 17, 2025 at 7:07 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    It has something to do with when you take your seatbelt off relative to when you shift into park. It's really annoying. I didn't want it trying and change my habits to stop it.
  4. Jun 17, 2025 at 7:39 PM
    toyboy1980
    toyboy1980 New Member
    Travis
    2025 Tundra Platinum TRD
    Got rid of the dark chrome and put on my color matched mustache from www.ecoological.com. Very pleased with color match and fitment. Before and after pics attached…
  5. Jun 17, 2025 at 10:12 PM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    I don’t disagree at all. The system is not very intrusive. My only reservation is what happens in the engine with each start cycle. Bearings with zero oil pressure. This happening every time you bring it to a stop? I think it’s better for the engine to keep it running. The only reason for the system is fuel economy. It doesn’t increase the longevity of the engine.
    obgod3[QUOTED] likes this.
  6. Jun 18, 2025 at 4:30 AM
    TFTJ
    TFTJ New Member
    astrength22[QUOTED] likes this.
  7. Jun 18, 2025 at 4:54 AM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    Until I back into my garage or park the truck somewhere and it shuts off then immediately starts back up just in time for me to shut it off again. Sometimes shutting it off just as the high speed starter tried to re start the truck. What an absolutely awful concept this start stop nonsense.
    Retroboy1989 likes this.
  8. Jun 18, 2025 at 4:59 AM
    hudrock
    hudrock New Members only jacket
    So Cal
    25 MGM Limited
    Yeah I have noticed this happening on my truck as well. Is this because I'm pushing the brake harder when parking and activating the auto start/stop? Typically I don't notice the auto start/stop when driving as I'm light on the brakes but I find it very annoying when it occurs during parking.
  9. Jun 18, 2025 at 6:41 AM
    JayDee
    JayDee New Member
    Typically mine would shut off when shifting into park and then immediately re-start. I recently took a long trip (20+ hours of driving) and after several hours of driving the truck shut off in Park and stayed off (for several seconds) while the A/C was still running. I think this is how it's supposed to work and if it did this every time it wouldn't be an issue. Most of the time I'm taking short trips and I suppose the battery doesn't have time to get fully charged. In the normal case the truck shuts off in Park and then realizes the battery is too low to keep the A/C running so it immediately re-starts.
    I recently installed one of those auto disable button pushers and it works flawlessly. You can still turn the feature back on if you like by pushing the button. I'm happy to realize that I've just reduced the number of engine start cycles by at least 50%.
    Mr Rick and bowhuntercoop like this.
  10. Jun 18, 2025 at 6:42 AM
    Retroboy1989
    Northern Utah
    I think the electric parking brake travels the pedal far enough down to activate.
  11. Jun 18, 2025 at 6:48 AM
    Retroboy1989
    Northern Utah
    Engine manufacturers had to revisit bearing materials when start/stop surfaced. The new head of the EPA has called it "a climate participation trophy." I think it's a crock.
    Bulldog6[QUOTED] likes this.
  12. Jun 18, 2025 at 8:18 AM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    ...so do you want your truck to auto-brake it when you mistakenly failed to do so on time hmmm?
    SoCal_Erik likes this.
  13. Jun 18, 2025 at 9:45 AM
    Over the LINE
    New Orleans
    No, I don't want it to autobrake, I don't want it to slow down while I have the cruise control set because the car in front of me is going slower, I don't want it to keep me in my lane, I don't want it to increase brake pressure drastically because it thinks I am in a panic stop situation, I don't want it to give me less throttle because I spun a tire and when I put it in manual shift mode I want my input to be more than a suggestion. This truck specifically, I would like it not to have the scary throtte lag, not turbo lag but intermittent failure to react to pedal input. I'm sure I missed some things but that's a good start.
    kirkb, SoCal_Erik and LowcountryDave like this.
  14. Jun 18, 2025 at 11:20 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    earlwright239 and Toklas like this.
  15. Jun 18, 2025 at 11:25 AM
    Raven67
    Kentucky
    On a good note, after leveling the front of my truck, I didn't like the angles of the upper ball joints, so I fixed it today. Just need to get alignment adjusted. The new UCA's are same length as the steel ones, but the angle of ball joint is slightly different. It was an easy upgrade, 30 min. Drivers side, 20 min pass. Side. 20250613_145421.jpg 20250618_113425.jpg 20250618_123040.jpg
  16. Jun 18, 2025 at 11:49 AM
    CappyKD
    CappyKD Older, grayer member.
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    Where did you get the TRD arms and what did they cost if you don't mind my asking.
    Sisu87TRDOR likes this.
  17. Jun 18, 2025 at 12:06 PM
    bailey bulldog
    bailey bulldog New Member
    Red Faux Pro Project complete!
  18. Jun 18, 2025 at 12:24 PM
    Raven67
    Kentucky
    ToyotaPartsdeal.com. $640 shipped. I found a few places that parts were cheaper, but shipping was way higher.
    Sisu87TRDOR and CappyKD[QUOTED] like this.
  19. Jun 18, 2025 at 12:29 PM
    CappyKD
    Kirk
    Thanks a lot.
  20. Jun 18, 2025 at 12:31 PM
    CappyKD
    Kirk
    You planning to do the red CV's with the lift? I was surprised to see that my 25 ltd with the TRD offroad package already included the red cv axles. Now I feel obligated to lift it.
  21. Jun 18, 2025 at 1:11 PM
    Raven67
    Kentucky
    Maybe sometime in the future, I only leveled it 1.75" so not a real need as I don't do offroading other than a hayfield.
    CappyKD[QUOTED] likes this.
  22. Jun 18, 2025 at 4:45 PM
    Retroboy1989
    Northern Utah
    What's the difference between red and the basic ones?
    Edit: asking about axles
  23. Jun 18, 2025 at 4:47 PM
    CappyKD
    Kirk
    Apparently more articulation. I'm not sure what other differences if any there are.
    Raven67 likes this.
  24. Jun 18, 2025 at 4:58 PM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    It's been posted on this forum that the reds are the same as oem black (ball joint angle included), I wonder which info is correct>
  25. Jun 18, 2025 at 6:04 PM
    Raven67
    Kentucky
    I wish I had gotten a side by side pic. they are the same dimensions, but you can obviously see the ball joint is at a slightly different angle than the black steel one. The red ones are for the factory TRD lift which is only a little over an inch from the standard lift. There IS definitely a difference, & should be perfect for what I have. I will let you know how much they changed alignment when I get it checked in the next few days.
  26. Jun 18, 2025 at 6:48 PM
    Tiger85
    Tiger85 New Member
    2025 Mag Gray Platinum i-Force MAX
    Red axles are from TRD Pro and Offroad. The TRD lift has silver axles.
  27. Jun 18, 2025 at 7:05 PM
    bailey bulldog
    I think they are talking about UCAs.
    Raven67 likes this.
  28. Jun 19, 2025 at 4:34 AM
    MagneticPro
    MagneticPro New Member
    Alabama
    2005 SR5, 2025 Platinum
    Anyone installed a swaybar?
    Sisu87TRDOR and Wraith like this.
  29. Jun 19, 2025 at 6:08 AM
    hudrock
    So Cal
    25 MGM Limited
    Added tailgate lettering (Toyota brand) and ESI tailgate seal
    Sisu87TRDOR, Mr Rick, Miker24 and 2 others like this.
  30. Jun 19, 2025 at 8:11 AM
    Wraith
    Wraith New Member
    '25 Limited Crewmax
    I was wondering the same thing. I have a 2025 limited now but back in the day put a rear red TRD sway bar on my 2012 Limited 5.7.
    MagneticPro[QUOTED] likes this.
