WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Dec 2, 2021.
  1. May 25, 2025 at 6:28 PM
    MagneticPro
    MagneticPro New Member
    Alabama
    2005 SR5, 2025 Platinum
    Console tray, bed mat, Pedal Commander, some play toys under back seat in case of zombie apocalypse.
    Miker24, BdBoyitz and oddhours like this.
  2. May 25, 2025 at 7:13 PM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    I put a layer of sound deadener on the bottom of the sliding console tray to make it feel less cheap.
    ScottieBones, ElJefe77 and Raven67 like this.
  3. May 26, 2025 at 1:40 PM
    51TRDPRO
    51TRDPRO New Member
    Mark
    Henderson, NV
    "Poseidon" 2025 TRD Pro Tundra
    Stock "for now"
    we all use our trucks in different ways.
    I do a lot of back country hunting, getting to these areas will require as much ground clearance as possible.
    Raven67[QUOTED] likes this.
  4. May 26, 2025 at 1:55 PM
    SnowToy
    SnowToy New Member
    2023 Tundra TRD Pro - build in the works...
    295/70/18 Duratracs - more mods being researched...
    Any feedback on how it sounds or if the Nytop drones or reverberates at all ? Debating this as a mod to do......
  5. May 26, 2025 at 2:02 PM
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    Love this look, curious how it sounds.
    51TRDPRO[QUOTED] likes this.
  6. May 26, 2025 at 2:19 PM
    51TRDPRO
    51TRDPRO New Member
    Mark
    Henderson, NV
    Stock "for now"
    Add
    Sounds similar to the stock TRD pro exhaust, I really didn’t notice a change in sound tbh.
    ARCOVT23[QUOTED] likes this.
  7. May 26, 2025 at 2:21 PM
    51TRDPRO
    51TRDPRO New Member
    Mark
    Henderson, NV
    Stock "for now"
    To me no change at all in sound. I haven’t really got on it yet, but start up and normal driving sounds like it did before. No obvious drone at all
    ARCOVT23 likes this.
  8. May 26, 2025 at 5:24 PM
    northtundra
    northtundra New Member
    2024 Tundra TRD OR
    just added a canopy yesterday. Anyone have suggestions on brake light wiring? Apparently using the taillight is not an option because the turn signal will make the 3rd brake light flash.
  9. May 26, 2025 at 5:53 PM
    mach1man001
    mach1man001 New Member
    Rob
    2024 Limited Crewmax
    Look into tapping in your trailer wiring. There's separate wires for brake and turns.
  10. May 26, 2025 at 6:25 PM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    Tinted the fronts.
    First time try. Driver side has a spot I’m not happy with, but passenger side is good. I will try again.
    CappyKD, Volator and BdBoyitz like this.
  11. May 26, 2025 at 7:40 PM
    MAC25Tundra
    MAC25Tundra New Member
    2025 Limited Crew Max 4x4
    I recently replaced my stock limited exhaust with the NYTop dump tip and can confirm zero drone or resonance at freeways speeds. No real sound difference on startup either.
    SnowToy[QUOTED], Volator and Daedalus like this.
  12. May 27, 2025 at 7:53 AM
    Volator
    Volator New Member
    Vassalboro, Maine
    2025 Tundra CrewMax TRD - MGM
    Alu-Cab Contour with Crossbars Decked Drawers - Gen 2 Rough Country HD2 Steps Custom 2nd row platform for Dog Kennels Bullet Point Rubigrid Weathertech HP Matts Ceramic Coated Chrome Delete (Vinyl wrapped) Spigen Tempered Glass Screen Protector JDMCAR Central Control Gear Shift Panel Trim Cover Cornfed 2nd Gen 1.5" Front Lift Cooper Discoverer Stronghold AT 295-70/r18 Toyota TRD Exhaust Tip Rok Block tailgate gap seal GG Offroad Camera Relocation kit GG Offroad brake light cable GG Offroad Camera Suction Cup Mounts
    GG Offroad has a camera relocation kit and also a separate brake light / inside cap light wire.
    There's also a T connector that E-Trailer has that will let you install a 4 prong off of the 7 prong taillight connector. Then you could just run your brake and ground up.
    https://www.etrailer.com/Custom-Fit...Tundra/2025/C55384.html?VehicleID=20251176923
  13. May 27, 2025 at 8:50 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Picked up a Sealskin brand cover for the Tundra. Even though it stays in garage, it gets covered with dust & pollen especially this time of year. I always have shop doors open when I'm out working. Hopefully this will help a little.20250527_114710.jpg 20250527_114733.jpg
  14. May 27, 2025 at 9:50 AM
    lapoolboy
    lapoolboy New Member
    Is it lined with anything? Or single-layer nylon?
  15. May 27, 2025 at 10:41 AM
    Raven67
    Kentucky
    Its lined on inside, & pretty soft. Not high end, but I just wanted to keep dust off. It is waterproof however.
  16. May 27, 2025 at 12:14 PM
    JollyRogers
    JollyRogers New Member
    South Louisiana
    2025 Lunar Rock Tundra 1794 TRD
  17. May 27, 2025 at 1:05 PM
    Volator
    Volator New Member
    Vassalboro, Maine
    Dust is an issue where I travel... Added some Rok Block to cover up the tailgate gap.
    And added some seals along the vertical tailgate sections. I was concerned it would hinder the auto tailgate but no issues...
  18. May 27, 2025 at 2:14 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Have you used the Rok Block before? Does it hold up? I've got a camper shell on the way and weatherstripping the tailgate is something I learned to do a few trucks back. In the past I have just used the same gap filler for the sides and gap.
    Bulldog6 likes this.
  19. May 27, 2025 at 2:18 PM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    I’m curious about this as well. I run a lot of dusty roads…
  20. May 27, 2025 at 2:34 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Who does the rok block hold up in the winter? I have a bed rug that I had to cut as it would freeze up when folded.
  21. May 27, 2025 at 2:52 PM
    Volator
    Volator New Member
    Vassalboro, Maine
    I'll find out if this happens to me... I'm in Maine so I'll put it to the test in about 9 months.
  22. May 27, 2025 at 2:54 PM
    Volator
    Volator New Member
    Vassalboro, Maine
    I've never tried it before. I did have some weather stripping previously. This looked like maybe a better option... Time, and dust, will tell. I'll be up in North Maine Woods in July.
    Over the LINE[QUOTED] likes this.
  23. May 27, 2025 at 3:05 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Body shop finally ordered parts, other than light bars. Still on track for mid June completion. My insurance is being difficult with the light bars for some reason
    kirkb and sandiegosteve like this.
  24. May 27, 2025 at 7:07 PM
    Frank_TRD23
    Frank_TRD23 New Member
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    I made the Tundra turn 22,000 miles today.
    BdBoyitz and ToyoJon like this.
  25. May 27, 2025 at 7:07 PM
    Frank_TRD23
  26. May 28, 2025 at 10:48 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Same here only swap Maine for Minnesota.
    I've only had the RokBlok in for a couple months, so no freezing temps for me either.
    I notice that I do get water sitting in there after a car wash.
    Might have to seal the gate to bed cover gap a little better to minimize that.
  27. May 28, 2025 at 10:52 AM
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    Why would my distance to empty with a full tank be lower than it used to be? It used to be at 410ish and now it's like 370.
  28. May 28, 2025 at 10:53 AM
    Frank_TRD23
    Do you have any side picture of the mud flap?
    Just ordered a set and hoping it will fit with the 37s I have.
  29. May 28, 2025 at 10:55 AM
    BlackNBlu
    Rich
    MN
    Frank, was that meant for one of the guys I quoted?
    (I don't have anything special for mud flaps...yet.)
    *edit*
    Yeah...now I get it. RokBlock...we were talking about the rubber strip that goes between the bed and tailgate and blocks the gap.
    The mud flaps are called Rok Blokz.
    And I AM getting a set of those now that I have 35's and some poke.
  30. May 28, 2025 at 11:01 AM
    Frank_TRD23
    Fool me once.....
