WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Dec 2, 2021.
  1. Apr 13, 2025 at 4:30 AM
    #9511
    RDW
    RDW New Member
    Rob
    NJ
    2025 Tundra Platinum TRD Off-road
    Heritage Grille w/ TRD Marker Lights, Diode Dynamics Light Bar and OEM TRD Dash Switch, Rigid Yellow Fogs, Diode Dynamics C1 Hitch Pod Light, AMP Powersteps Smart Series, Aftermarket Power Bed Step, Bedbug XLT, Rough Country Neoprene Rear Seat Cover
    I used a 7 to 4 pin adapter and ran power from the trailer harness. No cutting or splicing factory wires.
  2. Apr 13, 2025 at 9:08 AM
    #9512
    Optic15
    Optic15 New Member
    SF Bay Area
    2011 White Tundra SR5
    Level kit Morimoto XB headlights & fog lights LED light bar behind bumper KMC XD wheels 18” 34” Cooper Discoverer tires Pioneer double din head unit 10” subwoofer - x2 Back up camera trunk latch
    Just sold my 2011 crewmax and I’m already missing it lol but I must say I’m loving this 2025. I’m happy I was able to get the limited TRD pro, based on my research that seemed to be the best one for me. Wish it had the sun roof and TRD lift package but I can live with that. Can’t wait to get out and drive today.
  3. Apr 13, 2025 at 9:17 AM
    #9513
    Paul499
    Paul499 Large Member
    Paul
    Sarasota, FL
    2024 Platinum Hybrid
    Weld 20x9, Toyo 285/60, RC N3 level, ceramic tint
    I'm more than a year into mine and I still feel the same way! Sweet truck!
    BlackNBlu likes this.
  4. Apr 13, 2025 at 9:18 AM
    #9514
    Paul499
    Paul
    Sarasota, FL
    Proper wash inside and out today with my little helper who loves the truck just as much as I do.
  5. Apr 13, 2025 at 9:30 AM
    #9515
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    My guy drying the door jams yesterday. He is learning that a nice truck stays nice when it's cared for.
  6. Apr 13, 2025 at 12:33 PM
    #9516
    WindChillYeti75
    WindChillYeti75 New Member
    2025 WCP Limited TRD Off Road iForce Max
    Got some Cali raised step edition sliders put on!
  7. Apr 13, 2025 at 12:45 PM
    #9517
    CappyKD
    CappyKD Older, grayer member.
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    Very nice.
  8. Apr 13, 2025 at 1:27 PM
    #9518
    Crawldad
    Crawldad New Member
    2024 Tundra Limited TRD OR w/3” Lift
    Had LLumar Ceramic CTX 15% tint installed all around with Ceramic Infrared AIR 80 on the windshield.
    Installed a IMG_2467.jpg IMG_2469.jpg IMG_2468.jpg Amazon bed step and TripleAliner bed mat.
    RealTruck, Yaboy, Miker24 and 3 others like this.
  9. Apr 13, 2025 at 1:47 PM
    #9519
    Jigenax
    Jigenax New Member
    Ken
    Idaho
    2022 Blueprint Tundra DC TRD Sport
    What's the weight capacity of that bed step? And nice set up! :thumbsup:
  10. Apr 13, 2025 at 1:56 PM
    #9520
    Crawldad
    Crawldad New Member
  11. Apr 13, 2025 at 3:44 PM
    #9521
    kjinxx2
    kjinxx2 New Member
    Awesome thank you - did you add a fuse between the trailer light circuit and the marker light or did you wire directly & rely on the truck's fuses?
  12. Apr 13, 2025 at 5:33 PM
    #9522
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    Apparently, I like to live dangerously, so I took the Tundra out for a 4100 mile road trip without the engine blowing up.
    Some thoughts, in no particular order or topic:
    1. I averaged around 17 mpg, with a best tankful of 20.5 mpg, and the worst of 14.5 mpg, carrying about 600 lbs of payload, with average speeds of 80-90 mph.
    2. The truck is limited to 108 mph, and it still had plenty of power reserve at that speed. Pity the tires are what limit it.
    3. The engine is a gem of a powerhouse. I do miss the old V8 burble, but its own turbo whooshes and smoothness make up for it in a big way.
    4. Stability is great at high speeds, with no wander or float, and it tracks very well in stiff crosswinds.
    5, The transmission temperature is steady at 194F while cruising, 198F at triple digits, and hit a high of 215F powering up long mountain passes over 11,000 feet.
    6. The maximum fuel flow rate I saw was just shy of 10 gph.
    8. Did I mention that the engine did not blow up? :D
    It is not perfect, however. The truck is still newish at around 14,000 miles, but there is a faint rattle from the right front door or the right side of the dash that I need to chase, and the differential does have a barely perceptible whine at around 80 mph that I will keep an eye on for the duration of the warranty at least.
  13. Apr 13, 2025 at 5:35 PM
    #9523
    CappyKD
    Kirk
  14. Apr 14, 2025 at 4:58 AM
    #9524
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Which mfg. window vents do you have? How do you like them? Front coverage OK where they taper down? It looks like the rears are much longer than they need to be.
  15. Apr 14, 2025 at 6:05 AM
    #9525
    VCheng
    VCheng New Member
    Upstate NY
    These vents are by APILT. I agree they seem to be too long at the rear, but they go to the edge of the rear door, past the window as you observed, and work very well at speed with no added wind noise.
    Over the LINE[QUOTED] likes this.
  16. Apr 14, 2025 at 7:01 AM
    #9526
    CSE2C
    CSE2C New Member
    Des Moines
    FOX 2.0 set with coil over added to front and shocks for rear. Measures at a gain of 2.25" in front without alignment or settling. Measurement show rear is slightly higher but not eye test. With air ride in high position looks better. Have not made adjustments to rear yet. Going to move linkage to highest, if that doesn't help will install Westcott linkage. tundra4.jpg
  17. Apr 14, 2025 at 9:38 AM
    #9527
    theTupper
    theTupper New Member
    Jake
    2024 Limited Crewmax HV, Lunar Rock
    Looking good! :)
    astrength22[QUOTED] likes this.
  18. Apr 14, 2025 at 10:07 AM
    #9528
    6rian
    6rian New Member
    Still a work in progress, but thought I'd share. And yes, we'll be cutting the lower bumper caps to get rid of that ugly overhang. lol
  19. Apr 14, 2025 at 11:41 AM
    #9529
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    gaps arent that bad...any work needed to get them like that? We did a little bit of work on my brother's fiberwerx stuff...not cf though.
    6rian likes this.
  20. Apr 14, 2025 at 11:49 AM
    #9530
    6rian
    6rian New Member
    Some of the pieces weren't bolted down when those photos were taken, so it'll be better in the end. Despite that, the body lines and gaps in the front are perfect imo. The bedsides are a differen't story. Those are a PITA to install and probably won't look as perfect but that doesn't bother me. This isn't a show truck. Expect the same type/amount of work to fit carbon pieces. The difference is if you do it wrong or mess up, it's costing you 100% more than fiberglass. lol
    eddiefromcali[QUOTED] likes this.
  21. Apr 14, 2025 at 11:53 AM
    #9531
    eddiefromcali
    Eddie
    100% Stock
    With that being said...any plans for rock protection? We ended up with these inner fenders at a local shop
    RealTruck likes this.
  22. Apr 14, 2025 at 12:19 PM
    #9532
    6rian
    6rian New Member
    No plans at the moment but I had my fiberglass set sprayed with a bed liner on the underside and that kept it in tact even after being beat from rocks on trails here. I may try using molded abs plastic next.
  23. Apr 14, 2025 at 12:25 PM
    #9533
    eddiefromcali
    Eddie
    100% Stock
    A buddy used big rig mud flaps held on with L brackets...worked good too. Im sure the bed liner will help too
  24. Apr 14, 2025 at 3:02 PM
    #9534
    Zebjones24!
    Zebjones24! New Member
    2024 Red Tundra trd
    You will love the Fox 2.0 ride! It’s pretty amazing what it can do to the ride!
    Tundrastruck91 likes this.
  25. Apr 14, 2025 at 3:39 PM
    #9535
    Breckler23
    Breckler23 New Member
    Georiga
    2025 Limited TRD OR Black
    Do you have them on yours? I had them on my 2018 and loved the ride
  26. Apr 14, 2025 at 7:51 PM
    #9536
    RDW
    RDW New Member
    Rob
    NJ
    Wired directly, i see no need for an additional fuse.
  27. Apr 15, 2025 at 8:42 AM
    #9537
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    That's freakin epic man! Looks like they did a great job!
  28. Apr 15, 2025 at 8:49 AM
    #9538
    eddiefromcali
    Eddie
    100% Stock
    It looked good but the rivets didn't hold up...ended up welding most of it and using SS rivets instead of alum where we needed them for possible access...worlds most priciest inner fenders. lol
    mach1man001 and oddhours like this.
  29. Apr 15, 2025 at 9:58 AM
    #9539
    DubfromGA
    DubfromGA New Member
    Greg
    2025 Tundra 1794 I-FORCE MAX 4WD
    Bought it home.
    Traded in my 2017 Tacoma for a 2025 Tundra.
    Pics of both taken from similar spots…
    Both trucks came home with anemic tires.
    Firestone MT2’s were excellent on the Tacoma. I may go with them again….or possible some Destination XT’s.
  30. Apr 15, 2025 at 10:39 AM
    #9540
    dano9258
    dano9258 New Member
    2024 Limited 4x4 OR Pkg
    MX4 Cover
    Where did you go on this trip? It looks like amazing views! We are doing a 5000 mile trip at the end of May through Oregon, Washington, Canada, and then back down through Montana and can't wait!
    MAC25Tundra and Raven67 like this.
