WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Dec 2, 2021.
  1. Dec 13, 2024 at 10:43 AM
    #8011
    BoomBoomGanoom
    BoomBoomGanoom New Member
    Corey
    Columbus, Ohio
    2023 Tundra Limited off-road
    TRD Pro Heritage grille with marker lights, TRD Pro fender flares, TRD Pro front sway bar and end links, TRD Pro aluminum front upper control arms, Fox Performance 2.0 coil overs and shocks, Alpharex Nova Black headlights w/amber DRL. OEM tonneau cover
    I used the "quote" link, I chose to erase the text so it would not display the quote in the body of the post. Thanks for looking out though!
  2. Dec 13, 2024 at 10:49 AM
    #8012
    BoomBoomGanoom
    Corey
    Columbus, Ohio
    That looks great! Did you modify the OEM Platinum ambient light parts or make your own? It appears much brighter than the door lights that come in the Platinum trims.
  3. Dec 13, 2024 at 1:16 PM
    #8013
    Arthughes1
    Arthughes1 New Member
    Northwest Arkansas
    2025 Limited TRD OR
    Fred Anderson order hit the doorstep 15 minutes ago. Nothing major, but some nice touches to complete the look. Have the tailgate inserts to put on too, but it’s raining.
  4. Dec 13, 2024 at 1:19 PM
    #8014
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Fillder up. 11gal of E, 12.5 of premium
    ziznack likes this.
  5. Dec 13, 2024 at 1:19 PM
    #8015
    lapoolboy
    lapoolboy New Member
    Damn Cali sucks
    On another note, can you share a pic of how/where you have your JB4 installed?
    Woodrow bangs likes this.
  6. Dec 13, 2024 at 1:29 PM
    #8016
    eddiefromcali
    Eddie
    100% Stock
    115° summers and its still stuck on there
    Screenshot_20241213_132803_Gallery.jpg Screenshot_20241213_132829_Gallery.jpg
    Tundrastruck91 likes this.
  7. Dec 13, 2024 at 8:07 PM
    #8017
    Kerktam
    Kerktam Lexus truck wanted
    middle of nowhere, up north
    2023 limited TRD OR, 2024 silverado 5.3
    35 tires, 2 inch level kit
    Mood lightning is PITA
  8. Dec 13, 2024 at 8:46 PM
    #8018
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    Fuse will be in the fuse box under the dash on the passenger side. Pull the cover off the box and it has a graphic on what each fuse is used for. The big panel you have to pull off is a pain in the ass. It is a long panel up by your toes.
    Kerktam likes this.
  9. Dec 14, 2024 at 4:25 AM
    #8019
    Kerktam
    Can't figure out if I destroyed window master switch or if fuse blowed somewhere. No illumination on master switch, lock and power windows on that switch are not working, mirrors still work for adjusting but do not fold.... will connect my scanner tomorrow to see I'd bcm knows what going on, may be it will trow code at me
  10. Dec 14, 2024 at 8:56 AM
    #8020
    Siopao
    Siopao New Member
    Paolo
    2023 Tundra Limited
    Cut and clamp carven exhaust
    Just put a ready lift suspension 3in SST kit and added the ready lift cv axle. Man im so happy with the ride quality and the added height. Special shout out to total off roads for the install!! Amazing work as usual. Definitely took an immediate hit with my mpg. We'll worth the hit. Also added baja legend exp 35x12.5r17 20241212_165527.jpg 20241212_165539.jpg 20241213_084805.jpg
  11. Dec 14, 2024 at 9:02 AM
    #8021
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4
    Had this delivered yesterday. Box arrived all beat up (I assume it happened in NC where it was delayed several days). In inspection, I noticed a crack in the grille :eek: I’ve emailed BAM asking for an exchange or for a small refund of my original purchase price. I don’t mind keeping it if the refund amount is agreeable.
    akira, Reaper1911, BlackNBlu and 2 others like this.
  12. Dec 14, 2024 at 9:04 AM
    #8022
    Paul499
    Paul499 Large Member
    Paul
    Sarasota, FL
    2024 Platinum Hybrid
    Weld 20x9, Toyo 285/60, RC N3 level, ceramic tint
    That looks great. I'm looking at the same 3/2 readylift with CV axle upgrade. Next step is to find the lightest 35/11.5R20...
    Siopao[QUOTED] likes this.
  13. Dec 14, 2024 at 9:08 AM
    #8023
    jachal
    jachal jachallen
    andy
    FLX NY
    2023 Black Platinum Hybrid
    35’s 4evr
    Selene, Narco, Yaboy and 6 others like this.
  14. Dec 14, 2024 at 11:32 AM
    #8024
    BlackNBlu
    BlackNBlu Cranks Nickelback in Target order pickup lane
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Bummer. Hope they do right by you.
    Potential fix? Super glue crack together then a little plastic weld on the back side? Should be nearly invisible when done right.
  15. Dec 14, 2024 at 11:44 AM
    #8025
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Something like that, you could also use a bit of JB weld on the backside so you can't see it.
  16. Dec 14, 2024 at 11:48 AM
    #8026
    bailey bulldog
    bailey bulldog New Member
    You could use a plastic welder on the backside.
    SoCal_Erik and cartage1 like this.
  17. Dec 14, 2024 at 12:29 PM
    #8027
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Got some door lights today, no big deal, but better than what was on there from factory.20241214_132150.jpg
  18. Dec 14, 2024 at 1:25 PM
    #8028
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
    This truck wins. Well done
  19. Dec 14, 2024 at 2:53 PM
    #8029
    BlackNBlu
    Rich
    MN
    NICE! :thumbsup:
    Great minds and all that.
    Also can see the additional blue footwell lighting I added.
  20. Dec 14, 2024 at 5:15 PM
    #8030
    lapoolboy
    Which TRD Off-Road light is that exactly if you don't mind?
    cartage1 and SoCal_Erik like this.
  21. Dec 14, 2024 at 5:46 PM
    #8031
    BlackNBlu
    Rich
    MN
    https://www.mvpautosupplies.com/
    is the website for the manufacturer, but I got them from Etsy, where the seller name is MVPCUSTOMSshop.
    That's assuming my Etsy versions aren't knockoffs, which is possible.
  22. Dec 14, 2024 at 7:11 PM
    #8032
    SoCal_Erik
    2023 SR5 Sport 4x4
    Yup, ans some of you mentioned, I’ll probably use JB Weld on the backside. It’s a fine hairline when pieced together, so shouldn’t be noticeable . I’d hate to exchange it at this point.
    BlackNBlu[QUOTED] likes this.
  23. Dec 14, 2024 at 7:20 PM
    #8033
    Hye_Tundra
    Hye_Tundra Fortune Favors The Bold
    LEV
    Los Angeles, CA
    25’ CSM Limited TRD OR
    All-Pro tailgate panel. Good quality for the price. No more destroyed knees.
    ChiefG, buzzkill42, Siopao and 5 others like this.
  24. Dec 14, 2024 at 8:11 PM
    #8034
    Eznk1
    Eznk1 New Member
    Tony
    2024 Tundra
    I added the OEM dashcam and seatjackers from Desert Does It. I opted to only go with the 3/4” lift on the seatjackers but it makes a world of difference in seat comfort.
    I also pulled out my Bedrug XLT and swapped it for the full Bedrug. It was a wash from a functionality standpoint but I prefer the more finished look.
  25. Dec 14, 2024 at 8:30 PM
    #8035
    Itsbui
    Itsbui New Member
    I installed Tufskin rear tailgate tundra overlay,
    Trd overlay for front grill and door sill overlay
  26. Dec 15, 2024 at 10:11 AM
    #8036
    Raven67
    Kentucky
    Installed 1/2" cornfed rear spacers today to give it just a tad bit of rake.
    The 1.75 front level made it perfectly level front & rear. (About 1/4" higher in rear). So I added the 1/2" spacer, now it's perfect.
    BlackNBlu and jachal like this.
  27. Dec 15, 2024 at 12:37 PM
    #8037
    egreen91
    egreen91 New Member
    Ethan
    2024 tundra sr5
    3 in Eibach lift on 35s
    Did you have the physical metal key inside? I bought my 24 with 5k miles and they don’t have the metal insert key for the second fob and said I should have got it when I bought the truck used
  28. Dec 15, 2024 at 1:35 PM
    #8038
    Frank_TRD23
    Frank_TRD23 New Member
    Farmers Branch , Texas
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    So, are these used lots possibly keeping the second key to give to the bank. You know for those repo days !!!!
  29. Dec 15, 2024 at 1:53 PM
    #8039
    Cmaccullen
    Cmaccullen New Member
    2022 Tundra Limited
    I bought my 2022 tundra used from a dealer. No second key. I called my local Toyota to see if by chance my vin had a second key issued already. He never really answered me but did tell me it would be $400 for another fob and key.
  30. Dec 15, 2024 at 7:09 PM
    #8040
    lapoolboy
    Thanks! Just ordered.
