WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Dec 2, 2021.
  1. Sep 27, 2024 at 5:54 AM
    #7321
    Foster1
    Foster1 New Member
    2023 TRD Off Road
    Those are the new G3's right?
    Got any more pictures? I'm looking to purchase the same size but debating between these, the Recon's, and the Ridge Grapplers.
  2. Sep 27, 2024 at 6:35 AM
    #7322
    freaksavior
    freaksavior Did you call tech support
    Richmond, Tx
    '22 AG 1794
    Dechromed
    old tires had 20,200 on them.
    Yessir. Debated on the ko3s and the falken wild peaks but I don’t plan to go off roading more than 2-3 times a year and these are more road focused from what I understand. They weren’t really noisy but you could hear a low hum.
    What are you looking for? I can go take some more photos.
    Nope. 323 for the alignment, mount, balance, disposal, and they even charged me for the part they broke.
    I admit I should have looked it over before I swiped the cc but hindsight is 20/20.
  3. Sep 27, 2024 at 6:51 AM
    #7323
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    I mean, they didn’t charge him to put the wheel lock key back in the truck. Pretty big perk right there. :-|
    I’d say they used an impact wrench… which any shop should realize is not suggested.
    They probably got annoyed key wasn’t in right place to begin with ‘I’ll fix him’.
    Tundrastruck91 and freaksavior like this.
  4. Sep 27, 2024 at 7:47 AM
    #7324
    freaksavior
    Richmond, Tx
    '22 AG 1794
    Dechromed
    And the kicker was that it was in the stock location from factory. In the bag behind the right passenger seat.
    I’m about to go back up there and see what they’ll do.
    I’d like the wheel fixed/replaced but I think at the very least they should refund the lugs they damaged which I seemed to have paid for and refund me enough to go buy four more.
    MaineTundy[QUOTED] likes this.
  5. Sep 27, 2024 at 8:26 AM
    #7325
    6rian
    6rian New Member
    I have the same kit but ended up moving my switch panel to the center console with a 3D printed flush mount. Curious, if you've noticed a faint rapid ticking noise coming from your switch panel when it's awake but not connected to bluetooth. Doesn't matter if the truck is on or off. It's very faint and any ambient noise would wash it out. Mine does and I have to turn my ear towards it to hear it in a quiet environment. Worked with sPOD/BD about it and they've acknowledged it after listening to recordings I sent them, but there's no known cause for it. They sent me new cables, circuit board, and two different switch panels, and the ticking persists after each individual change. Tried connecting a touchscreen switch panel and it also ticks. I don't notice it anymore but I gave up trying to find the cause.
    az 3rdGen likes this.
  6. Sep 27, 2024 at 10:36 AM
    #7326
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Started to rip mine apart for new headlights to go in finally. Also took off the front air damn since some road debris snapped the spoiler in two.
    going to take several hours to clean up the clusterF of wiring that alpharex has but hopefully all goes well
  7. Sep 27, 2024 at 11:25 AM
    #7327
    daverxa
    daverxa New Member
    Dave
    2024 White Tundra Limited TRD Offroad & TRD Lift
    Leer 100xl, ggoffroad DRV camera relocation, Decked drawer system, BF Goodrich TKO3 275/65R20, Diode Dynamics Fog lights, Go Rhino Dominator D6 Running Boards,
    tundznoff and Kerktam like this.
  8. Sep 27, 2024 at 11:36 AM
    #7328
    packfan
    packfan New Member
    2021 Tundra Crewmax 4x4 1794
    Kept mine in the garage because of Hurricane Helene. I vacuumed her out real well.
    Raven67 and Yotaholic4life like this.
  9. Sep 27, 2024 at 12:14 PM
    #7329
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
    Got the Kicker powered sub installed by shop today. It sounds good. Adds thump and what is missing from the JBL stereo. The shop did a great install and part of the process was removing the 3 ANC mics so they would not fight the new noise. All in all I would recommend. Keeps factory controls.
  10. Sep 27, 2024 at 12:16 PM
    #7330
    Prescott87
    Prescott87 New Member
    Jonah
    Brentwood, Ca
    2022 Supersonic Red Limited
    TRD Filters, De-Badged, TRD Pro Grille
    Finally color matched the from grille trim and the rear bumper. I got the parts from OEM painted parts. This is my second time ordering from them the color is damn near perfect.
    Cbrash, akira, Yaboy and 2 others like this.
  11. Sep 27, 2024 at 9:11 PM
    #7331
    Hye_Tundra
    Hye_Tundra Fortune Favors The Bold
    LEV
    Los Angeles, CA
    25’ CSM Limited TRD OR
    Interesting. This is my third sPod on a truck build and I never noticed any sound. I will check it out though and let you know if I have similar ticking sound. Cheers
    6rian[QUOTED] likes this.
  12. Sep 27, 2024 at 11:06 PM
    #7332
    6rian
    6rian New Member
    Sounds good. sPOD/BD says they've never come across this before, so it's likely an isolated issue. Just doesn't make sense after troubleshooting with all new components. Every switch panel I plug in ticks. When I connect to bluetooth, it stops ticking and turns into a faint hum.
  13. Sep 28, 2024 at 12:11 AM
    #7333
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    So you couldn’t gut the factory sub and put it in the factory location?
  14. Sep 28, 2024 at 6:30 AM
    #7334
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Built a “shelf” under my Xtrusion Overland XTR3 for my camping tables. Came out perfect. Pic is when I tested it out, it’s currently off truck getting painted black to blend in better. Best part is I can still use my slide out, no interference at all.
  15. Sep 28, 2024 at 6:57 AM
    #7335
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Diff service
    tundznoff, mayan and Tundrastruck91 like this.
  16. Sep 28, 2024 at 7:30 AM
    #7336
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    You got any pictures of that center console mount? I don't think I've seen any like that.. I've seen the overhead and the driver side trim mount above the other buttons.
  17. Sep 28, 2024 at 9:07 AM
    #7337
    6rian
    6rian New Member
    Don't have a great photo but just snapped this to get a driver view.
    =JSG=, az 3rdGen[QUOTED] and matth66 like this.
  18. Sep 28, 2024 at 10:31 AM
    #7338
    GAMark
    GAMark New Member
    Can you tell me where you got the piece that is in your cup holder?
  19. Sep 28, 2024 at 12:28 PM
    #7339
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    https://cupgrip.com/
    edit...great product and no affiliation. Rarely even use but have moreso for passengers and tbh makes the holders 'look' better.
    GAMark[QUOTED] likes this.
  20. Sep 28, 2024 at 12:43 PM
    #7340
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    The Cupgrip is awesome for big tumblers like Stanley or Yeti.
  21. Sep 28, 2024 at 12:46 PM
    #7341
    GAMark
    GAMark New Member
    Ordered, thank you.
    Tundrastruck91 likes this.
  22. Sep 28, 2024 at 12:48 PM
    #7342
    GAMark
    GAMark New Member
    What is the metal?
  23. Sep 28, 2024 at 7:56 PM
    #7343
    eddiefromcali
    Eddie
    100% Stock
    Machining debris. Nothing out of the ordinary, imo
  24. Sep 28, 2024 at 8:02 PM
    #7344
    6rian
    6rian New Member
    Yup, normal for break in and nothing worrysome. Here's what came out of my rear diff at 4,300 miles. Shavings are fine. Chunks are bad.
    eddiefromcali and H20-bar like this.
  25. Sep 28, 2024 at 10:05 PM
    #7345
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    Bought this Platinum. Traded my 4Runner. I really like this truck. I’m not going to mod this truck but really have to fill these wheel wells and will be looking at you’ll trucks for ideas.
  26. Sep 28, 2024 at 10:26 PM
    #7346
    Kerktam
    Kerktam Lexus truck wanted
    middle of nowhere, up north
    2023 limited TRD OR, 2024 silverado 5.3
    35 tires, 2 inch level kit
    installed Rockville subwoofer under rear seat. its okey, will install different one, its barely noticeable
    SoCal_Erik likes this.
  27. Sep 29, 2024 at 2:59 AM
    #7347
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    I briefly thought about it but the labor needed didn’t really make enough sense. I still have too much storage area and won’t miss losing behind seat. Plus this has little modification impact in case it’s ever sold. Just drive 500 miles and I really do like it. And I’m a guy who had a “system” in all my other vehicles. The factory sub is still on and working. It’s like having an extra tweeter lol
  28. Sep 29, 2024 at 3:03 AM
    #7348
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    Is “Rockville” Temu’s “Rockford”?
    Kerktam[QUOTED] likes this.
  29. Sep 29, 2024 at 4:25 AM
    #7349
    jaxadam
    jaxadam New Member
    What did you use?
  30. Sep 29, 2024 at 12:31 PM
    #7350
    christopherdada2
    christopherdada2 New Member
    2024 white Tundra Limited Trd Off Road
    Hi, where can I buy this bracket for the rear dash camera? Thanks.
    machd08 likes this.
