WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Dec 2, 2021.
  1. Jul 10, 2024 at 10:36 AM
    #6751
    SpilledTheSalt
    SpilledTheSalt Fish Lips
    Oregon
    2024 Tundra 4x4 HV Limited TRD
    2" RC Leveling Struts
    Installed a couple catch cans over the weekend. Fumbled around a bit at first with mounting them but overall pretty pleased with how it turned out.
    VCheng and eddiefromcali like this.
  2. Jul 11, 2024 at 10:23 PM
    #6752
    Narco
    Narco New Member
    23 Hybrid Limited Off-road
    "wired" in a slim wireless charger since mine didn't come with the power package stuff... Popped a few pieces of trim off and fished the USB-C plug into the center console. Gets the job done and didn't have to cut anything! (Not counting the mishap where I tried to hard-wire it into a 12v line lol).PXL_20240711_193932726.MP.jpg
    BoomBoomGanoom likes this.
  3. Jul 12, 2024 at 7:12 AM
    #6753
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    I did the most comprehensive oil change that I have ever done in my life on my 24 Tundra at just 350 miles.
    First, I collected a clean sample to send off to Blackstone ......
    ... followed by the oil and oil filter change:
  4. Jul 12, 2024 at 7:22 AM
    #6754
    VCheng
    VCheng New Member
    Upstate NY
    Oil Change CONTD 2
    Then came the oil filter dissection:
    I opened up the pleats and saw a few scattered metal flecks:
    So I decided to open it all up to spread out for a closer look:
    Then I preserved the remains:
    Now I will send off the oil sample for analysis, and then repeat above process at the next oil change.
    Who says owning a Tundra is not fun? :D
  5. Jul 12, 2024 at 7:24 AM
    #6755
    VCheng
    VCheng New Member
    Upstate NY
    A source for the kit / parts used, and how to install would be greatly appreciated. THanks!
  6. Jul 12, 2024 at 8:03 AM
    #6756
    SpilledTheSalt
    Oregon
    Surely. The catch cans I ordered were off Amazon. Search for "Evil Energy baffled oil catch can." (The one without the breather filter on top.) They are $34 a piece. They are actually great quality aluminum, comparable to the ones running an average of $150 to $200 ea. Expect to buy some bulk 5/8 ID vacuum hose from your local auto parts store (I bought 10 feet but used a little over 8.) I didn't use the aluminum mount bracket the cans came with. I bought a generic L bracket with holes from the hardware store and drilled a couple new holes on one side for the screws on the back of the can to fit through. I used one of the pre-made holes on the bottom side of the L bracket side and used a bolt and washer to mount to the far end blank holes on each side of the upper cross member. (I can take more pictures when I get home tonight if you need as well.)
    As for the hose hook up, just pull off the engine cover, disconnect the rubber flex air tubing going from each air filter to the intake tubes, and then pop open the top of the air filter housing so you can flip it up and keep it out of the way. Look for the small U shaped vent hose going from the engine back to the intake tube. Disconnect that on each side, but keep the pinch clamps to re-use. Run one piece of hose on each side from the engine to the inlet port on the cans and then run the outlet on the cans to the intake tubes. I put the pinch clamps back on the engine and intake tube ends of the hoses and used some small band clamps around the hose fittings on the cans.
    VCheng[QUOTED] and BabyMoose like this.
  7. Jul 12, 2024 at 8:16 AM
    #6757
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Why not catch some oil mid stream instead of pumping it out?
  8. Jul 12, 2024 at 8:21 AM
    #6758
    eddiefromcali
    Eddie
    100% Stock
    Would not recommend using heater hose as those are not rated for vacuum and possibly not for oil either. I've seen and it's a very common problem where people use the wrong type of hose, not rated for vacuum, and it collapses.
  9. Jul 12, 2024 at 8:55 AM
    #6759
    SpilledTheSalt
    Oregon
    True, the stuff I bought bulk is a Gates multi use hose including pcv. A little on the spendy side.
    eddiefromcali[QUOTED] likes this.
  10. Jul 12, 2024 at 9:03 AM
    #6760
    VCheng
    VCheng New Member
    Upstate NY
    I wanted to try out the oil extractor, that’s all.
  11. Jul 12, 2024 at 9:26 AM
    #6761
    eddiefromcali
    Eddie
    100% Stock
    Yeah, I used Gates PCV/EEC hose...also a bit spendy but worth it. 4219XL in 5/16"
  12. Jul 12, 2024 at 9:27 AM
    #6762
    VCheng
    VCheng New Member
    Upstate NY
    Thank you so much for the information. Some more photos, when you get a chance, would be awesome.
  13. Jul 12, 2024 at 9:49 AM
    #6763
    SpilledTheSalt
    Oregon
    Yep, same stuff. Mine was 5/8 version #27008, also rated for fuel I believe. I should've just bought 25 ft. off Amazon. Shit was almost $4.50 a foot at the parts store.
  14. Jul 12, 2024 at 9:59 AM
    #6764
    SpilledTheSalt
    Oregon
    Cool, I'll take some more detailed pics after I get home tonight. Also, as @eddiefromcali noted, you do want to get PCV/EEV/Fuel or multipurpose hose also rated for PCV. I should've clarified that originally. Stay away from heater only hose. (Gates #27008, which you can get off Amazon) is what I used for this.
    eddiefromcali and VCheng[QUOTED] like this.
  15. Jul 12, 2024 at 10:05 AM
    #6765
    Yotaholic4life
    Yotaholic4life New Member
    24 TRD Limited CM LB, 23 SR5 8ft bed DC
    24 TRD Lift
    What did I do ? I picked it up from the Dealership today !! Woohoo , finally after months of waiting :)
  16. Jul 12, 2024 at 11:20 AM
    #6766
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Curious how much oil they capture - let us know when you get a few miles. Before install, happen to look down the intake to see if oil coated?
  17. Jul 12, 2024 at 12:04 PM
    #6767
    eddiefromcali
    Eddie
    100% Stock
  18. Jul 12, 2024 at 12:39 PM
    #6768
    Yotaholic4life
    24 TRD Lift
    Has anyone pulled the weird baffles or prefilter bs goin on under the air filters ? I installed some TRD filters today and scratched my head on what the purpose of these are ,, school me plz ?
  19. Jul 12, 2024 at 12:58 PM
    #6769
    eddiefromcali
    Eddie
    100% Stock
    yep...you get more turbo noise. That blanket under the mesh is supposed to catch vapors...meh, I removed and havent noticed a diff
  20. Jul 12, 2024 at 1:11 PM
    #6770
    Yotaholic4life
    24 TRD Lift
    Man , I’ve feed a lot of turbos but I’ve never tried to smother one lol
  21. Jul 12, 2024 at 1:16 PM
    #6771
    SpilledTheSalt
    Oregon
    I glanced in the intake tubes but didn't notice much (I'm only around 2000 miles currently). However, the small U shaped vent hoses I replaced between the engine and intake had a decent amount of oil coating the inside. The cans you can buy that are pre-designed for the 22+ Tundra just use a single can off the PCV in the back of the engine. Not sure how much more or less you get vs. running one off of each intake like I did. I'll probably check it in about 500 miles or so and re-post.
    Yotaholic4life likes this.
  22. Jul 12, 2024 at 3:34 PM
    #6772
    produxnguy
    produxnguy New Member
    vernon
    A note to those seeking front seat spacers. I am a retired Department of Defense hobbyist with a modern machine shop for my hobbies. I have been making Toyota (rear bracket) and Ford (front and rear bracket) spacers for years longer than any of my competitors. I actually made front bracket spacers in 2018 and canned the idea because they did not work for me. Hindsight bit me on that one. My rear Toyota spacers are $20 cheaper, unique and much safer made, than any others in the market. I am now developing a unique safer front spacer for 2022+ Tundra. These, once developed, will be half the price of the main USA manufacturer. I also only make and sell in the USA. I would not copy something already in the market. That is the Chinese way. They copy and undersell to support the communist party. I am seeking someone to assist me in development and then to beta test the 1st set or 2. The 1st couple of pairs will be shipped with fasteners and instructions for around $25 per pair. Just offering if anyone is interested.
    Boomer08 likes this.
  23. Jul 12, 2024 at 6:32 PM
    #6773
    Lambeau
    Lambeau New Member
    2024 Black Tundra 1794 Limited Edition
    285/60/R20 BF Goodrich KO2’s
    Installed my Diamondback HD cover and the Bulletpoint mount with phone charger and radar detector.
    Also installed the Beatsonic amp. So so easy. And it made a huge difference. If you’re on the fence on an audio upgrade, do the Beatsonic amp install for $299!!!
    ChiefG, j-utah, Twin2turbo and 3 others like this.
  24. Jul 12, 2024 at 6:56 PM
    #6774
    SpilledTheSalt
    Oregon
    @VCheng
    Here's a few more pics of the can mounting and hose routing on each side. I noticed my hose is actually stamped Gates #4219XL, but #27008 seems to correlate to the same hose. Either way, that would be what to get.
    eddiefromcali and VCheng like this.
  25. Jul 12, 2024 at 7:12 PM
    #6775
    VCheng
    VCheng New Member
    Upstate NY
    I think I ordered the wrong size hose, but let me wait until the cans get here so that I can see if that fits or not. Many thanks for those photos, they will be very useful to me.
  26. Jul 12, 2024 at 7:24 PM
    #6776
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
  27. Jul 12, 2024 at 7:29 PM
    #6777
    jctmundra
    Northern VT
    Oil in the intake reduces the octane level of the fuel. It will also shorten the cat lifetime if a high zinc oil is used.
  28. Jul 12, 2024 at 10:04 PM
    #6778
    ziznack
    ziznack New Member
    Texas Y'all
    But if the engine is specifically designed to collect the oil vapors, why take them out?
  29. Jul 13, 2024 at 7:07 AM
    #6779
    NashvilleBulldawg
    NashvilleBulldawg New Member
    Looks great. I don’t want to alarm you but it looks like someone has vandalized your rear window. Hopefully you can pull video footage from neighbors to catch this criminal.
  30. Jul 13, 2024 at 8:07 AM
    #6780
    TRD_TUNDRA
    TRD_TUNDRA New Member
    2024 Tundra TRD Off Road and 2024 Sequoia TRD Pro
    Wrapped the dash center bar or whatever you call it with VViViD Stealth Medium Black Camo vinyl. I have a couple other matching pieces I’ve order that are precut for specific interior spots that I’ll install once it arrives to tie it all together.
    j-utah likes this.
