WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Dec 2, 2021.
  1. Jan 19, 2024 at 1:09 PM
    #5371
    JP_Trex
    JP_Trex New Member
    Got my wheels and tires mounted today in preparation for a 2/1 lift.
    Here's a little sneak peek.. or poke?
  2. Jan 19, 2024 at 5:00 PM
    #5372
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    After 2 years of ownership. I decided to get TRD running boards cause she likes to use the seat panel like a slide getting out. So hope this helps.
  3. Jan 20, 2024 at 4:56 PM
    #5373
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Is that a little icicle? Sort of like you truck shedding a frozen tear after smashing into all those trees!
    Mattedfred likes this.
  4. Jan 20, 2024 at 5:58 PM
    #5374
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    Better drain that hose so it’s good to go next time
  5. Jan 20, 2024 at 6:00 PM
    #5375
    TK1979
    TK1979 New Member
    TK
    Youngsville, NC
    2018 DC Limited
    Dual Exhaust and Side Steps
    Nice haul!
  6. Jan 20, 2024 at 7:21 PM
    #5376
    lapoolboy
    lapoolboy New Member
    Peeled the shitty 2-day-old tint job off so I can have it done somewhere else. Had them redo it twice and there's still hair and trash behind it. I'm a perfectionist so it just isn't acceptable.
    j-utah and Mattedfred like this.
  7. Jan 21, 2024 at 12:23 AM
    #5377
    TheCrazyludwig
    TheCrazyludwig New Member
    Got my Wildpeak 285/75/R18 on.
    ytank1, pwpblue, jachal and 2 others like this.
  8. Jan 21, 2024 at 8:48 AM
    #5378
    jachal
    jachal jachallen
    andy
    FLX NY
    2023 Black Platinum Hybrid
    dealer installed trd lift w
    2” rear coil springs
    35x12.5r18 firestone destination xt’s
    on kmc impact +18
    Hye_Tundra, ytank1, JP_Trex and 14 others like this.
  9. Jan 21, 2024 at 8:53 AM
    #5379
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Looks great all de-chromed! Did you paint the moustache or cover it with vinyl or similar?
    jachal likes this.
  10. Jan 21, 2024 at 8:57 AM
    #5380
    jachal
    jachal jachallen
    andy
    FLX NY
    actually neither, it’s a genuine toyota/lexus part that’s unpainted, but comes gloss black. it’s not ‘midnite black metallic’ but u can’t tell unless u hold a very bright led light up close.
    PBNB[QUOTED] likes this.
  11. Jan 21, 2024 at 9:18 AM
    #5381
    Bier_Me_1
    Bier_Me_1 New Member
    Shane B.
    2022 Tundra SR5
    How did you do the debadging? I’ve heard multiple routes. Some day use heat some say do it cold.
  12. Jan 21, 2024 at 12:03 PM
    #5382
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    2024 Tundra Hybrid Platinum
    I would definitely use heat to soften that adhesive. I used a heat gun when I removed the tailgate letters on my taco and some floss. Most recently, when I got my tundra PPF'ed, my installer also used a heat gun to remove the door trim molding.
    Bier_Me_1[QUOTED] likes this.
  13. Jan 21, 2024 at 2:06 PM
    #5383
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    1200 miles and I, too, was a victim of the volume knob. I guess only option is to part out.
    Acey, iScramble, j-utah and 4 others like this.
  14. Jan 21, 2024 at 6:00 PM
    #5384
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Did some plowing.
    Had to order a longer adapter to put the batt box farther away from the tail gate as I had a 1/2 inch.
    Tundrastruck91 likes this.
  15. Jan 21, 2024 at 6:01 PM
    #5385
    j-utah
    j-utah Aiming in the dark member
    Utah
    Fortress of Solitude, CO
    2024 Tundra SR5
    Dice valve stem caps (black)
    It was warm enough today, washed off the snow and grime then finally installed mud flaps. They are OK, meh. I like the Rockblokz material and finish better, have those on my Tacoma, but even the small ones they make are huge. Not a fancy wheel build for this truck so these will do I guess…. sigh
    :playball:
    I still like this type of mudflap over the stiff stock ones. The flex helps if you break through and drop down on a frozen puddle.
    Mattedfred and pwpblue like this.
  16. Jan 21, 2024 at 10:20 PM
    #5386
    DeepH2O
    DeepH2O New Member
    Ryan
    Mississippi
    2023 Tundra Platinum
    6” RC lift 37x12.50x20 Tires 20x10 Fuel Wheels BakFlip MX4 bed cover Westin Outlaw Steps JB4 Tuner TRD Shift Knob
    IMG_5786.jpg Tinted the windows! Makes it a completely different truck, inside and out!
    Yaboy, Blufin, j-utah and 4 others like this.
  17. Jan 22, 2024 at 1:41 PM
    #5387
    MaxPayne3
    MaxPayne3 New Member
    2024 Lunar Rock SR5 Crew Cab
    Just starting out but never will be done
    Finally got all my new switches in the switch panel. Rock and Ditch lights on the way. Installed the OEM metal pedal and cover for brake. Ordered the amber marker lights for the grill from Toyota but was told Friday they are on backorder because they are being "redisgned" so ordered a set of lights from Amazon but there was no mounting bracket so I had to make my own.
    in_the_mud, pwpblue and jachal like this.
  18. Jan 22, 2024 at 1:51 PM
    #5388
    lapoolboy
    Had the windows retinted (much better) and installed the fogs that came in today.
    I like your steps...which ones are they?
    Also, did you get a windshield strip at the top? If so, do you have the factory dash cam? I want a strip on top of mine but the tint guy said he had to cut off the camera to tint and then retape it. I didn't want to do that. Thinking maybe he can just tint up to the edge of it? Wouldn't look bad from inside but from outside it might look like there are gaps in the tint.
  19. Jan 22, 2024 at 1:56 PM
    #5389
    jdietrich
    jdietrich New Member
    Kansas City, Mo
    2023 Platinum Wind Chill Pearl
    TRD Pro Grille, Diodedynamics light bar & fog lights, Talon Cat guard, RCI Skid, Suntek Paint Protection, Century Topper, Paint match mustache, GG Off-road Re-Locator
    Any chance you have a link to pedal covers?
  20. Jan 22, 2024 at 2:01 PM
    #5390
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    MaxPayne3 likes this.
  21. Jan 22, 2024 at 2:10 PM
    #5391
    jdietrich
    Kansas City, Mo
  22. Jan 22, 2024 at 2:48 PM
    #5392
    MaxPayne3
    78110-0C050 - Accelerator
    47121-34010 – Brake
    jdietrich[QUOTED] likes this.
  23. Jan 22, 2024 at 3:00 PM
    #5393
    MaxPayne3
    The gas pedal is the whole assembly, which is crazy because it's literally a pedal cover with folded metal tabs over the original assembly. It's actually the easier of the two to to replace, just a few bolts, unplug and install new one and plug it it in. The brake pedal cover is a PITA. The rubber surround is super stiff and is formed to wrap around the metal part of the pedal with little tolerance. I used some PB 100% silicone spray around the rubber and you have to work the rubber around to get it to clear the metal pedal. I used a small flathead and a combination of 90 degree pick tools to work it over the pedal. Start with seating the right side of the pedal first so that you end up with the last corner on the left (closest to the driver door), the last corner will be a bish to get seated. You can use the pick tool to pry out on the rubber lip then use the small flat head screwdriver to slide between the lip and the pedal as you are working it over the lip. Took me nearly an hour just to get that pedal on :frusty:
  24. Jan 22, 2024 at 3:30 PM
    #5394
    tlh1005
    tlh1005 New Member
    Today, Backflip MX4 and M1 leveling struts adjusted to 1.5”.
    surfmc, jachal, FlyinBrian and 2 others like this.
  25. Jan 22, 2024 at 3:54 PM
    #5395
    Hank Hill
    Hank Hill New Member
    If youre cold, theyre cold, i am glad youre bringing them inside..
    :anonymous:
    Acey, FlyinBrian and earlwright239 like this.
  26. Jan 22, 2024 at 4:21 PM
    #5396
    Outbound
    Aaron
    Northern Alberta
    I tried to intimidate a first gen. We're calling this a draw.
  27. Jan 22, 2024 at 4:42 PM
    #5397
    Magnetic1
    Magnetic1 New Member
    Looks good, M1 leveling struts?? What size tire are you running? thanks :)
  28. Jan 22, 2024 at 4:49 PM
    #5398
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    I hear nothing but superb things about that tire.. on my list for sure
  29. Jan 22, 2024 at 6:10 PM
    #5399
    alkalinedevin
    alkalinedevin New Member
    2023 TRD Pro
    Decided on the 35" Wildpeak RT01's in load range C. Can't wait to mount these up!
    ytank1 and TK1979 like this.
  30. Jan 22, 2024 at 6:32 PM
    #5400
    tlh1005
    tlh1005 New Member
    https://www.roughcountry.com/product/m1-tundra-leveling-struts-502148
    They come set at 2" but after some discussions with folks here and researching other posts I decided to have them adjusted to 1.5". Every truck seems to be slightly different and honestly I was happy with mine from the factory once it was delivered but I had already purchased the struts and it turns out the place that installed the running boards also did suspension work and sold bed covers. So far I am very happy with it!
    The tires are Wildpeak AT3 and the size is 275 60 R20
