WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Dec 2, 2021.
  1. Jan 4, 2024 at 4:34 PM
    #5251
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I would leave it the way it is before trying to patch and paint match. You will never be able to match that paint perfectly and the damage will grow from a dime size to mutch bigger impacted area. Being so low on the bumper you are probably the only one who sees it, unless you point it out to someone. Then eventually you can replace that piece; it is made that way to be easily replaceable instead of a one-piece old style bumper.
  2. Jan 4, 2024 at 5:59 PM
    #5252
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    ^^^^^...What he said.
    boomtime and Mattedfred like this.
  3. Jan 4, 2024 at 8:29 PM
    #5253
    mtntrout14
    mtntrout14 New Member
    Tundra 23’
    2024 Limited TRD off Road
    Method 703 +35 offset
    35x12.5x17 ridge grapplers
    Dobinson MRR front and rear
    Icon Upper control arms + Icon bump stops and sway bar drop kit
  4. Jan 5, 2024 at 5:03 AM
    #5254
    dutch2112
    dutch2112 New Member
    2023 Limited hybrid Trd
    35” Falken Wildpeak AT3, 17x8.5 method 305 nv, trd lift kit, trd pro grill, trd exhaust
    Looks beautiful my man
    mtntrout14[QUOTED] likes this.
  5. Jan 5, 2024 at 11:24 AM
    #5255
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    I got the temp fuel line fix completed this morning. The SA wasn't there when I picked it up, but the fella that was implied the assigned tech would've noted if there was noticeable wear on the line, which he didn't. I stay on pavement 99% of the time, and my 5/23 build has almost 7,500 miles on it. I took it in with a little over 1/4 left of my 32 gallon tank and they didn't have an issue. By 1/4 I'm referencing the dash gauge not reality. Honestly I felt worse driving it into the shop this morning with 3 inches of snow covering it. The work order didn't show labor time, but I can see they pulled it into the shop at 7:40, tested I assume at 9:09, and parked it outside at 10:40. So 3 hours total.
  6. Jan 5, 2024 at 5:51 PM
    #5256
    boomtime
    boomtime New Member
    do you have pictures of the icon sway bar drop bracket installed? i'm thinking to swap out the one from the TRD lift kit to see if it helps alleviate some rubbing.
  7. Jan 5, 2024 at 5:56 PM
    #5257
    Texas Two Step
    Texas Two Step New Member
    2023 Tundra 1794
    I just added a phone mount. I bought a dash mount on Amazon made by a company called Xomzema. It is a total ICS-FAB knock off, but cost less than a fourth of the price.
    $50 Xomzema Dash Mount,Aluminum Alloy Multifunctional Dash Mount Holder Kit Accessory for Phones, Tablets, Dash Cams, CB's, Radios for Toyata Tundra for Sequoia 2022 2023
    https://www.amazon.com/Xomzema-Aluminum-Multifunctional-Accessory-Tablets/dp/B0C5RJFZZQ
    The product is decent but not perfect. I bought some additional fender washers to add support. I then bought a diamond mount 17mm ball to mount my ESR charger to. If you haven't looked into ESR, check them out. The chargers are mag safe compatible. Android users can buy their halolock rings from ESR to make them compatible with mag safe products. It works great on my Samsung.
    https://www.amazon.com/stores/page/C481BD72-9AE2-4927-B290-BC543AD7B0DA
    Here are some pics:
    [​IMG][​IMG][​IMG]
  8. Jan 6, 2024 at 12:12 AM
    #5258
    NHKTundra
    NHKTundra New Member
    2022 Tundra TRD Pro Lunar Rock
    Retrax. Uptop AFS bed rack. Condor XL. Dobinson rear springs. BFG 35/12.5/r18. BD light bar and ditch lights. Prinsu roof rack. Diode dynamics fog upgrade.
    Installed the Alpharex Novas in alpha black with amber DRLs. Photos aren’t great but amber looks great with raptor lights and Baja designs DRLs.
    Install was slightly tricky with extra wires with the pro grill plus other wires from my extra lights, so I modified and was able to install without taking grill completely off.
    Light output is brighter in the hotspots, but not as even as the OEM projectors. But definitely more useful light patterned forward. My fogs (diode dynamics) are excellent so I don’t notice any issue with low/perioheral lighting. Light color is slightly more blue than OEM. Once I aim lights a little better going to be solid. Very happy although cost isn’t cheap.
    RealTruck, ytank1, mikev25 and 4 others like this.
  9. Jan 6, 2024 at 10:45 AM
    #5259
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Picked these up along with new spark plugs
    ryanwgregg, ytank1, =JSG= and 3 others like this.
  10. Jan 6, 2024 at 2:09 PM
    #5260
    mje505
    mje505 New Member
    Mariano
    2023 Tundra TRD Pro
    Do you have the part number? Do you know if these are different geometry than the UCA on 22-23 TRD Pros? Thinking of pairing these with a 3” lift.
  11. Jan 6, 2024 at 2:13 PM
    #5261
    eddiefromcali
    Eddie
    100% Stock
    I dont, sorry
  12. Jan 6, 2024 at 4:22 PM
    #5262
    CMJT
    CMJT New Member
    2024 Tundra SR5
    They are back in stock
  13. Jan 6, 2024 at 5:44 PM
    #5263
    Mykeromachine
    Mykeromachine New Member
    2022 Tundra TRD Offroad
    Any tips and tricks on install? I have the Pro rack sitting in my garage and getting ready to install next weekend. I've watched the install videos and figure I have most of it figured.
    Love the Lunar Rock by the way, that's my colour also.
    Outbound likes this.
  14. Jan 6, 2024 at 5:59 PM
    #5264
    vorkuta775
    vorkuta775 New Member
    Sick! I wanna come play
    TK1979 likes this.
  15. Jan 6, 2024 at 7:12 PM
    #5265
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Is that tire floating or in freefall ?
    Medic343 likes this.
  16. Jan 7, 2024 at 7:42 PM
    #5266
    northernyota
    northernyota New Member
    2024 Tundra Crewmax Limited TRD Offroad
  17. Jan 7, 2024 at 7:48 PM
    #5267
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    What’s with the big red bows?
    northernyota likes this.
  18. Jan 7, 2024 at 7:49 PM
    #5268
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I got one too??!
    RealTruck, Yaboy, Mattedfred and 2 others like this.
  19. Jan 7, 2024 at 8:09 PM
    #5269
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    2023 Limited L TRD OR MBM
  20. Jan 7, 2024 at 9:07 PM
    #5270
    northernyota
    Haha not sure. The wife liked it tho. It’s totally a BC thing :canada:
    Mattedfred and PBNB like this.
  21. Jan 7, 2024 at 9:15 PM
    #5271
    Jalzate44
    Jalzate44 New Member
    San Antonio TX
    2024 Tundra SR5 Crewmax 4x4
    Bought yesterday!
    Acey, RealTruck, ChiefG and 12 others like this.
  22. Jan 8, 2024 at 8:53 AM
    #5272
    worldinchaos
    worldinchaos New Member
    2023 Sequoia TRD Pro
    Interesting. How does ESR's magnetic strength compare to MagSafe? I have a MagSafe in a RAM Mount adapter, and I find it too weak for any sort of larger bumps. I'm not talking about offroading, but even exiting a curb cut onto a road it falls off (Samsung S21 Ultra using metal ring adapter case).
  23. Jan 8, 2024 at 10:04 AM
    #5273
    Texas Two Step
    2023 Tundra 1794
    It's fairly strong. No issues with bumps. I used the halolock ring from ESR with their charger. Just pointing that out in case there are differences in the rings. The connection is solid and does not give any indication of trying to fall off.
    worldinchaos[QUOTED] likes this.
  24. Jan 8, 2024 at 12:45 PM
    #5274
    BordrG
    BordrG New Member
    Just got this Tundra Limited TRD crew max with 6.6 bed about 1 week ago. I love it. here's my first upgrades Leitner rack w/ 2 dbl pods and ikamper 3.0 tent. so far the rack feels extremely solid, love the pods for storage. the tent is way quieter then expected. little dirty at the moment but it is ski season! cameras on the back of the cab work perfect , no obstructions.
    RealTruck, ChiefG, TK1979 and 5 others like this.
  25. Jan 8, 2024 at 12:57 PM
    #5275
    BordrG
    BordrG New Member
    thank u, the bow would of added a few seconds of unwrapping before i could take off!! slowly of course :)
  26. Jan 8, 2024 at 1:28 PM
    #5276
    ChiefG
    ChiefG Limited 4X4 TRD OR
    Burlington Township, NJ
    2022 Tundra Limited Off Road 4X4
    Just minor stuff. For example, Undercover bed cover, Tufskinz custom door sill protectors, and TRD air filters.
    I checked all over and could not find the invoice for that part or the number. Usually I keep everything but that may have accidentally gone out with the box it came in. Sorry.
  27. Jan 8, 2024 at 5:17 PM
    #5277
    northernyota
    Thanks! Loving it so far lol. Day 3 and I have 1450km on the clock.
    Mattedfred[QUOTED] likes this.
  28. Jan 8, 2024 at 7:38 PM
    #5278
    Michael Tregre
    Michael Tregre New Member
    '14 Tundra SR5 CM
    Notta
    Installed Seat Jackers. Fixed all my discomfort issues.
  29. Jan 8, 2024 at 8:14 PM
    #5279
    northernyota
    Washed it
    RealTruck, ChiefG, Yaboy and 5 others like this.
  30. Jan 9, 2024 at 8:24 AM
    #5280
    RallySauce
    RallySauce New Member
    Middle TN
    ‘23 MGM SR // ‘20 T4R ORP
    Saw these were on overstock pricing on Bezos-world ($6), picked one up for the heck of it. Actually really like it lol now have “two” storage spots in that area and dont feel like i have to dig in a hole to get anything out of it.
