WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Dec 2, 2021.
  1. Nov 19, 2023 at 9:00 PM
    #4861
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I did the same but used the grille covers from chromestoppers. Bought the painted flares from same folks, quality stuff.
  2. Nov 20, 2023 at 5:19 AM
    #4862
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Installed the Beat-Sonic PA2T3K Plug and Play Encore Alpha Power Amplifier for the JBL 12 speaker system. It made a very big difference, IMO. Sounds cleaner and I don't have to jack the volume up to 50 just to hear it.
  3. Nov 20, 2023 at 8:32 AM
    #4863
    Hunter1699
    Hunter1699 New Member
    I have one the amps coming the next couple of days. Just for the heck of it how did you adjust your gains on the amp?
  4. Nov 20, 2023 at 8:33 AM
    #4864
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    Mine is coming today. I talked to beat sonic and they actually suggested wiring it over to the glove box so that you can change the gain if needed.
    Hunter1699 likes this.
  5. Nov 20, 2023 at 8:45 AM
    #4865
    BlueCrushSC16
    Charleston, SC
    Turn both gain adjustment screws/ knobs clockwise until they stop. Then back them off until they are both horizontal (- -). The Youtube video of the Beat Sonic guy showing installation says it toward the end of the video.
    Hunter1699[QUOTED] and ziznack like this.
  6. Nov 20, 2023 at 10:39 AM
    #4866
    22platitundy
    22platitundy New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    how difficult was taking off the grill and putting it back on? how long did it take?
    RickyBobbysTundra likes this.
  7. Nov 20, 2023 at 10:45 AM
    #4867
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Can’t speak for Greg of course, but it’s honestly not a bad install… Looks worse than it is… Took me a few hours but I did it by myself while making a step-by-step guide for my channel… Here’s the video if you want to check it out, hope it helps!
    CBI Covert Bumper, Install/Review on 2022 Toyota Tundra TRD Pro...Paired with Gear America Shackles!
    https://youtu.be/NnTWLDxeSmY
  8. Nov 20, 2023 at 11:35 AM
    #4868
    DIYReid
    DIYReid New Member
    KC
    2024 Ice Cap Tundra Limited
    Found someone local who took off the OEM Predator Tube Running Boards for $200.
  9. Nov 20, 2023 at 12:17 PM
    #4869
    BlueCrushSC16
    Charleston, SC
    That's a good deal considering the dealer charges $1100 for them.
  10. Nov 20, 2023 at 1:48 PM
    #4870
    ziznack
    ziznack New Member
    Texas Y'all
    I just installed my Beat-Sonic PA2T3K. Nothing to it. Easy peazy. Sounds better for sure. I put gain at about 2/3 of the way up. I tested it before I put it back in. It appears that the rear gain control does nothing and the front one controls everything.
    Question. I have a 1794. There was a wire and clip going into the back of the trim piece you take out above the glovebox. It was clipped in to nothing. It is not for the lights or anything, it goes to nothing, just clipped into blank plastic. Anyone know?
    BlueCrushSC16 likes this.
  11. Nov 20, 2023 at 3:11 PM
    #4871
    BlueCrushSC16
    Charleston, SC
    Yup. It's for the Capstone trim. It says "CAPSTONE" on their trim piece and it lights up. So, the connector goes to that LED that none of the other trim levels has.
  12. Nov 20, 2023 at 3:12 PM
    #4872
    ziznack
    ziznack New Member
    Texas Y'all
    Figured as much. Thanks!
  13. Nov 22, 2023 at 12:22 PM
    #4873
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    I'm swapping the pipe back to original. The rubber hangers have stretched allowing the pipe to contact the step resulting in a OCD annoying rattle at idle. I'll update once I modify dual tailpipe by denting or cutting/TIG the contact area. bummer.
  14. Nov 22, 2023 at 2:51 PM
    #4874
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    Installed new Husky X-ACT Contour floor mats. Loving them so far.
  15. Nov 22, 2023 at 3:58 PM
    #4875
    TunderMuffin
    TunderMuffin New Member
    2022 White SR5 Crewmax
    TRD Running Boards PRO Wheels PRO Grille/Marker Lights Rigid Fog Lights DD Light Bar
    I can't tell from your photos, was your tail pipe chrome? I'm looking for the black chrome version.
  16. Nov 22, 2023 at 4:37 PM
    #4876
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    Just did this yesterday, great mats and better than the oem Toyota all weather mats that come standard up here in Canada.
    kirkb[QUOTED] likes this.
  17. Nov 22, 2023 at 5:54 PM
    #4877
    jctmundra
    Northern VT
    chrome tips
  18. Nov 22, 2023 at 6:31 PM
    #4878
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Don't do anything rash,I had the same problem with mine hitting/rubbing against the bed step and it drove me frigging nuts.
    Loosen it just barely enough to twist the pipes to maneuver it,place it to where it needs to be and "overcompinsate" for the rubber hanger to do what it's going to do over time.
  19. Nov 22, 2023 at 6:37 PM
    #4879
    jctmundra
    Northern VT
    Tried that when installing. Will give it a go again over the weekend. May loosen the joint at muffler, throw a worm clamp on the tail hanger rubber to limit movement then bolt it again. Otherwise, out it comes to be welded.
  20. Nov 23, 2023 at 9:38 AM
    #4880
    Slowbuilt
    Slowbuilt New Member
    Oregon Coast
    24 Limited Off Road
  21. Nov 24, 2023 at 6:02 AM
    #4881
    Soedog
    Soedog New Member
    Northeast Ohio
    24’ Limited Crewmax Nightshade
    TRD Sidesteps Gator SRX Roll Up Tonneau Domed Tailgate Letters Bed Step Beat Sonic Mini Amp IGL Professional Ceramic Coat XPEL PPF (Full Front Clip and Mirror Covers) Suntek 20% Window Film (Front Driver & Passenger)
    Good timing for my first fill up. Black Friday gas price deal at $1.00 off per gallon at my local regular station ($1.93 gal)!
    First hand calculation came in at 16.44 MPG so will see how this goes after further break in.
    kirkb, PBNB, Mattedfred and 1 other person like this.
  22. Nov 24, 2023 at 7:42 AM
    #4882
    kirkb
    DFW
    TunderMuffin likes this.
  23. Nov 24, 2023 at 8:48 AM
    #4883
    BMP
    BMP New Member
    2023 Tundra SR5 SX MGM CM 4X4
    Getting 295/70-18 MT Baja Boss AT's fit on a bone stock 2023 SR5 SX +60 18X7.5" wheels at Discount Tire. They said they won't fit. Rolling the dice! LOL
    Brad
    EDIT - They fit!
  24. Nov 24, 2023 at 11:10 AM
    #4884
    Asleepinthecove
    Asleepinthecove New Member
    Louisiana
    2024 Toyota Tundra TRD Pro in Terra color
    Installed my Diamondback HD on my new 2024 Tundra TRD Pro in Terra color
  25. Nov 24, 2023 at 1:14 PM
    #4885
    TundBP
    TundBP New Member
    23 Blueprint Platinum
    BMP likes this.
  26. Nov 24, 2023 at 2:54 PM
    #4886
    TunderMuffin
    I have these as well. Love the non-slip feature and feels.
  27. Nov 24, 2023 at 8:43 PM
    #4887
    whitenoise
    whitenoise New Member
    Greg
    Germantown, TN
    '23 1794 w/TRD package
    CBI Covert Bumper Warn EVO 10S Diamondback HD
    It really was not very difficult. I actually used Patrick's video (right below your question) as a guide. I was by myself taking it off and it probably took me an hour or less to get it off and back on. Getting the winch plate installed and the winch mounted in the right spot took the most time (a few hours). I ended up having to drill extra holes because the holes on the CBI winch plate wouldn't work because of the placement of the fans.
    All in all it really wasn't that bad.
  28. Nov 25, 2023 at 12:03 PM
    #4888
    901tundra
    901tundra New Member
    Memphis, TN
    2023 Magnetic Gray Limited TRD Off-road
    - Color-matched grille and rear bumper insets - 1-inch Cornfed front spaces - TRD grille with light bar and amber marker lights - Debadged
    Installed the Carven catback exhaust. It’s a little louder on start that I’d like but settles in once the engine warms up.
  29. Nov 25, 2023 at 12:52 PM
    #4889
    Logey22
    Logey22 New Member
    2023 Tundra TRD Pro - Solar Octane
    Ive run out of projects for now, and had a set of extra Baja Designs Squadrons in the garage. I finally found some use for them. Also threw some strut and LCA skids on from Victory 4x4
    Now to figure out the next big project...
  30. Nov 26, 2023 at 5:49 PM
    #4890
    socaldad
    socaldad New Member
    23 SR5 crewmax TRD-sport
    IMG_2964.jpg Sorry for dark pic, there was light out when I started . Installed rear cornfed 1” spacer. Fronts already had rough country M1 (at 1.75”) so it was front high
    quick question, I had alignment done when the front m1 was installed last week. Does it need another alignment for rear spacer post install? Thanks
