WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Dec 2, 2021.
  1. Sep 23, 2023 at 12:29 PM
    #4441
    901tundra
    901tundra New Member
    Memphis, TN
    2023 Magnetic Gray Limited TRD Off-road
    - Color-matched grille and rear bumper insets - 1-inch Cornfed front spaces - TRD grille with light bar and amber marker lights - Debadged
    I just installed mine. I dropped the spare and jacked the truck up from the trailer hitch receiver a bit to help it clear the rear axle. Took about 20 minutes start to finish.
  2. Sep 23, 2023 at 1:11 PM
    #4442
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Good news! I'm gonna try it.
    TundBP[QUOTED] likes this.
  3. Sep 23, 2023 at 1:14 PM
    #4443
    bigblue14
    Craig
    Can confirm this works on my 1794.
    TundBP[QUOTED] and gj953 like this.
  4. Sep 23, 2023 at 4:38 PM
    #4444
    Slimwood Shady
    Slimwood Shady New Member
    Linwood
    San Antonio, TX
    ‘23 TRD Pro, 996 Turbo
    I used 5 mil thickness.
    rwsessions[QUOTED] likes this.
  5. Sep 24, 2023 at 12:04 PM
    #4445
    paulphilly
    paulphilly New Member
    Paul
    Upstate NY
    '24 TRD Pro
    Bulletpoint mounting for phones, console tray insert, front grille TRD inserts, and Mickey Thompson Baja boss at 275/60/20.
    jacquesc, Kepaniamekolea, 4mm and 2 others like this.
  6. Sep 24, 2023 at 2:20 PM
    #4446
    NVTundra
    NVTundra New Member
    Northern NV
    2024 Blue Print SR5
    Wheels and tires. For now...
    Man it’s been a hot minute since I’ve been on. Glad to see everyone doing stuff. Finished wiring in my ditch lights today. Running Baja Designs Squadron lights on Rago Fab ditch light brackets and Cali Raised factory switch.
    ChiefG, jacquesc, 4mm and 2 others like this.
  7. Sep 24, 2023 at 6:11 PM
    #4447
    Hunter1699
    Hunter1699 New Member
    Any chance you could share your wiring scheme for the ditch lights to Cali switch? Did you get the switch works with the running lights? I did the the same switch with Lasfit pods. They work but I don't have it wired correctly (so the back light works with running lights). appreciate if you have anything that could help.
  8. Sep 24, 2023 at 6:18 PM
    #4448
    Unitdosed
    Unitdosed New Member
    '22 Celestial Silver SR5, CREW CAB TRD OR 4X4
    None, yet
    Has anyone installed the Toyota OEM dash cam?
  9. Sep 24, 2023 at 6:18 PM
    #4449
    NVTundra
    NVTundra New Member
    Northern NV
    2024 Blue Print SR5
    https://www.tundras.com/threads/cali-raised-led-oem-square-switch.124342/
    I went off the wiring diagram from this thread. I’m not concerned about the backlight for when I have my regular lights on so I didn’t wire it in. From what I figured out, the wire used for the backlight can be tied to the main ground for the switch if not going to be used for that. I figured out my hot wires and my ground and went with it. I did the same thing on my 11 Tundra. I may rewire it to have the back light for when I have my lights on but I doubt it. Honestly I keep it simple so if I decide to get another truck, everything’s easily removed and set back to stock.
  10. Sep 24, 2023 at 6:25 PM
    #4450
    NVTundra
    NVTundra New Member
    Northern NV
    2024 Blue Print SR5
    Sorry that doesn’t really answer your question but that’s all I did.
  11. Sep 24, 2023 at 6:27 PM
    #4451
    Hunter1699
    thanks. that's pretty much where I am at but it is eating at me to get it working. thanks for the response.
  12. Sep 24, 2023 at 7:55 PM
    #4452
    KiloOps
    KiloOps New Member
    Dustin
    2023 Army Green Tundra Limited TRD Off Road
    Purchased the truck on Jun 10, 2023, modifications will be made!
    Got my my Leitner ACS Rack installed tonight, now I can start planing the accessories layout.
  13. Sep 25, 2023 at 8:49 AM
    #4453
    Hunter1699
    So referencing the Ditch Lights wiring questions that I had (above)I finally figured it out this morning:
    I have Lasfit ditch lights and their harness-color schemes on other lights are different color code but should be able to adapt from the below
    Cali Switch wires/Lasfit Harness wires
    Red Yellow
    White Black
    Black Black
    Green Red (fused)
    Yellow Tan wire from unused harness
    The Cali Raised switch diagram on their site is incorrect as someone earlier had reported.
    Works great and hope it helps someone else.
    NVTundra and iiawah808 like this.
  14. Sep 25, 2023 at 11:28 AM
    #4454
    KiloOps
    KiloOps New Member
    Dustin
    For anyone that's curious, here is how the Leitner rack impacts your rearview camera view. Almost doesn't matter in my opinion.
  15. Sep 25, 2023 at 1:42 PM
    #4455
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
  16. Sep 25, 2023 at 4:30 PM
    #4456
    ryanjay11
    ryanjay11 New Member
    I modified an oar holder for my retriever pole.
    It looks like I need to install the tailgate gasket I bought next to keep the dust out.
    FlagstaffTundra likes this.
  17. Sep 25, 2023 at 4:53 PM
    #4457
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Received my color matched lower valance today and couldn't resist to install it when I got home from work.
    Tomorrow getting new sneakers put on...
  18. Sep 25, 2023 at 4:57 PM
    #4458
    TundraTT
    TundraTT Full Send
    17 Pro, 94 70series LC
    Kryptek seat covers
    BeastOfBourbon7, 4mm and KiloOps like this.
  19. Sep 25, 2023 at 7:24 PM
    #4459
    Palma415
    Palma415 New Member
    VHT wheel paint to stock sr5
    TRD center cap
    305/70r18
  20. Sep 25, 2023 at 8:40 PM
    #4460
    rose
    rose New Member
    2022 Tundra Off Road
    cali raised bed rack, tepui rtt
    Yaboy, earlwright239 and KiloOps like this.
  21. Sep 26, 2023 at 3:14 AM
    #4461
    30walshy
    30walshy New Member
    Andrew
    2023 Limited TRD Off Road
    Are you able to provide the part number for the Grill Surround?
    Where did you order from?
    Thanks!
  22. Sep 26, 2023 at 6:11 AM
    #4462
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    Picked up new tundra yesterday. Immediately got rid of chrome. Waiting on colour matched moustache to arrive. 295’s go on this evening. 1” cornfed front levelling kit should be here any day. Shipping to Canada is sloooow!
    ChiefG, Unitdosed, KiloOps and 3 others like this.
  23. Sep 26, 2023 at 7:19 AM
    #4463
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Congrats on the new Rig and I know that feeling about the over kill of chrome :puke:
    Northern Toyota likes this.
  24. Sep 26, 2023 at 8:21 AM
    #4464
    rwsessions
    rwsessions New Member
    Ryan
    2023 Silver SR5
    I know some folks could take it or leave it, but my latest mod was a small and easy one; finally received the TRD Pro Dash trim pieces I ordered a while back. Shipping took a while, but in my opinion, it was worth the wait. I think it makes for a really cool and interesting change to the interior trim. :thumbsup:
    wmsvol88, 24Tundee, RatPanda and 10 others like this.
  25. Sep 26, 2023 at 3:01 PM
    #4465
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Got my new sneakers installed today & man what a difference,first off its much softer & forgiving over bumps and pot holes vs the rubber bands that were on before, unfortunately it no longer feels like it's on rails while cornering in sport+ mode.
    But I will accept that trade off considering these will handle better in the snow,rain and the beach.I ended up getting Yokohama Geolanders M/T G003 @ 285/55R22 OEM were 265/50R22 from 50~55's = 1.22" 265 ~285's = 1.75" is significant.
    It finally looks proportionate.
  26. Sep 26, 2023 at 10:18 PM
    #4466
    24Tundee
    24Tundee New Member
    NorCal
    '24 Tundra Limited TRD OR
    Bought it and then immediately took it to the ORV park to try it out.
    jacquesc, TundBP, KiloOps and 4 others like this.
  27. Sep 26, 2023 at 10:59 PM
    #4467
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    Did you get it painted or does someone sell them paint matched?? I need a new one either way, might as well get a matched one if I can.
  28. Sep 27, 2023 at 1:13 AM
    #4468
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    I got it and had a painter do it for me,honestly it should of came this way along with color matched door handles and bumper, also I think it looks better this way but what do I know...
    If you need a new one it's $239.99 and paint is about $200 maybe you could do better with that cost I dunno.
    I will gladly sell you my OEM one for $100 + shipping, you can pay me after you get it.Mine has 5k miles on it and there is absolutely nothing wrong with it.No scratches,dings cracks nada.
    Shoot me a PM if ya interested.
    az 3rdGen[QUOTED] likes this.
  29. Sep 27, 2023 at 2:08 AM
    #4469
    az 3rdGen
    Arizona
    Thanks! I see your new one has the front license plate mount.. does your original have the wholes in it too? I got my truck from out of state and Arizona doesn’t require front plates. I took the mount off and it left 4 little holes that bug me now lol
    Blufin[QUOTED] likes this.
  30. Sep 27, 2023 at 2:57 AM
    #4470
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Yeah the factory valance has 2 dimples in it not penitrations,so the sales guy put in just 2 screws to mount the bracket.
