WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Dec 2, 2021.
  1. Sep 17, 2023 at 11:26 AM
    #4381
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Your not getting anything for Christmas, you have all of the reindeer in your trucks bed…
  2. Sep 17, 2023 at 1:18 PM
    #4382
    223Wylde
    223Wylde New Member
    Jeff
    Cottage Grove, MN
    2023 Tundra TRD Pro MGM
    Added Peragon cover, Predator steps, Bed Slide, and raised tailgate letters.
    LakeLife, Twin2turbo, KiloOps and 3 others like this.
  3. Sep 17, 2023 at 2:19 PM
    #4383
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    Took it on a road trip along the north shore of Lake Superior.
  4. Sep 17, 2023 at 4:11 PM
    #4384
    Black22tundra
    Black22tundra New Member
    2022 black tundra sr5
    6" ready lift 35" tires
    Swapped out my front bumper and headlights
    fab four matrix
    alpharex luxx series
    ChiefG, rwsessions, nodak67 and 4 others like this.
  5. Sep 17, 2023 at 4:55 PM
    #4385
    223Wylde
    223Wylde New Member
    Jeff
    Cottage Grove, MN
    Yes, easy install, they just give you 4 longer stainless bolts that replace factory box bolts, and it comes with brackets that fit perfect. I have the factory bedliner, only had to cut liner around factory bolt heads with utility knife, then they just pop right out. The bed slide is pretty heavy, weighs about 200lbs, so install is not a one man job, but I love the thing, completely eliminates need for climbing up in box and you don't lose much space compared to storage box type setups. Cost was about $1,600, depends on which model you get, I went with the 1000 CL, its really heavy duty, built like a tank!
    batman900[QUOTED] likes this.
  6. Sep 17, 2023 at 4:59 PM
    #4386
    223Wylde
    223Wylde New Member
    Jeff
    Cottage Grove, MN
    Ha thanks, yeah she really turned out nice, yeah not many Tundras around here, took me almost a year to get mine but it was worth the wait! I plan to put a Fab Fours Matrix on next, just like the post after mine!
    ToyotaB[QUOTED] likes this.
  7. Sep 18, 2023 at 9:02 AM
    #4387
    fat_marshmallow
    fat_marshmallow New Member
    i'm from Cottage grove MN, i've seen a good handful of 3rd gens now. there's 3 total just about a block or 2 from me but they are stock though. but not many modified ones i've seen.
  8. Sep 18, 2023 at 9:09 AM
    #4388
    901tundra
    901tundra New Member
    Memphis, TN
    2023 Magnetic Gray Limited TRD Off-road
    - Color-matched grille and rear bumper insets - 1-inch Cornfed front spaces - TRD grille with light bar and amber marker lights - Debadged
    TRD exhaust is on. Sounds better than stock but is waaaay quieter than the TRD on my old 2nd gen Tacoma.
  9. Sep 18, 2023 at 10:04 AM
    #4389
    rwsessions
    rwsessions New Member
    Ryan
    2023 Silver SR5
    Sweet rig man! I love the DRL pattern of the Alpha's. Did you go black or alpha black?
    iiawah808 likes this.
  10. Sep 18, 2023 at 11:29 AM
    #4390
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Little bit of product testing. Air damn delete via JB4
  11. Sep 18, 2023 at 12:08 PM
    #4391
    TundraTT
    TundraTT Full Send
    17 Pro, 94 70series LC
    Rear Dobinsons 2in lift springs, Dr. KDSS track bar correction kit installed. Wow wow wow the handling is night and day better over the oe springs with the westcott puck. The kings came alive too
    CringyDad, Yaboy and KiloOps like this.
  12. Sep 18, 2023 at 12:12 PM
    #4392
    KiloOps
    KiloOps New Member
    Dustin
    2023 Army Green Tundra Limited TRD Off Road
    Purchased the truck on Jun 10, 2023, modifications will be made!
    Do you have the part # on those Dobinsons springs? My setup is almost exactly the same except I went with the Dobinsons adjustable panhard bar and upper trailing arms. I also have those Timbren bump stops because I tow a 23" overland trailer and still don't like the sag that causes.
    I'm pretty sure Dobinson has different spring rates and heights on those rear springs so I'm curious as to the exact ones you got.
  13. Sep 18, 2023 at 12:25 PM
    #4393
    TundraTT
    TundraTT Full Send
    Yup, mine is the C59-841 (2” with 0-110 added weight) I haven’t yet towed with them but I left a rake for that reason. I only have the front coils at around 1.5” lift(10-11 threads)
  14. Sep 18, 2023 at 12:34 PM
    #4394
    KiloOps
    KiloOps New Member
    Dustin
    Cool, thanks. My front coils are at max height based on Kings recommendations and I have the Wescott puck in the back with factory rear springs and with that there is about 1/2 of rake. I assume the rake will be closer to 1.5" with the Dobinsons 2" springs. If that's the case the trailer will basically level it out when I'm towing.
  15. Sep 18, 2023 at 12:43 PM
    #4395
    TundraTT
    TundraTT Full Send
    I’ll have to measure it but I think you’re spot on. The rear definitely lifted up considerably(surprisingly)
    If you’re towing often and want to compromise a little no-load ride quality possibly a higher spring rate? Mine are like pillows compared to stock lol
  16. Sep 18, 2023 at 1:51 PM
    #4396
    golfersa
    golfersa New Member
    Black carbon fibered the mustache, PPF'd the hood, added Ranch Hand grille guard with 2" receiver...
    ChiefG, mayan and batman900 like this.
  17. Sep 18, 2023 at 2:09 PM
    #4397
    SecrITSociety
    SecrITSociety New Member
    Orlando, FL
    2023 Platinum Tundra / Blueprint / 4x4
    Picked up a bolt in the sidewall last week, so new pair of shoes went on this afternoon.
    Before:
    After:
  18. Sep 18, 2023 at 3:29 PM
    #4398
    chance12
    chance12 New Member
    GA
    23 Tundra CM Limited
    looks 100% better. what are the size/brand?
  19. Sep 18, 2023 at 3:35 PM
    #4399
    SecrITSociety
    Orlando, FL
    Nitto Ridge Grapplers 295/65/R20 on stock rims and no lift/level
  20. Sep 18, 2023 at 3:54 PM
    #4400
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Had a flat tire this am (road trip last night home from Ketchum, ID) and took it in to the tire shop. Turns out one of my wheels was broken… back to stock while I wait for a replacement, looks absurd
  21. Sep 18, 2023 at 4:12 PM
    #4401
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Changed the grill to TRD Off Road and added Falcons Garage Front Skid Plate, not pictured added the control know to add MTS/Crawl control, Crawl control doesn’t work, as I don’t have locking diff from my understanding
  22. Sep 18, 2023 at 4:29 PM
    #4402
    golfersa
    golfersa New Member
    Install was straightforward. You can see the opening they left for the camera... they provide a panel to fill the opening, I may look at relocating the camera and filling that. No sag noted.
  23. Sep 18, 2023 at 4:37 PM
    #4403
    machd08
    machd08 New Member
    CLARENCE
    Install wasn't bad, just need patients with the clips (which is one thing I am on short supply of,LoL), had to get a 3d printed bracket, got if from Brian Hall @roboots21, it was $25 for the bracket. No issues with sensor or cameras, just make sure you do reconnect all the sensors, lessons learned from others. From start to finish, taking my time and taking breaks, it was done in about 3 hrs, there are some good YouTube videos on it.
    The skid plate was only about 38 lbs didn't notice any sag, also have access to the filter and there is a hole for getting to the oil
  24. Sep 19, 2023 at 12:45 PM
    #4404
    10 ga Bob
    10 ga Bob New Member
    Bob
    2012 Regular Cab Long Bed 4X4 SR5, 2023 DC TRD 6.5 Ice Cap
    ARE Cap
    Received and installed a set of Wet Okole front seat covers. I had Wet Okoles on my 2012 Tundra and they held up great, are waterproof, were very comfortable and allowed me to wear wet waders in the truck without hurting the original seats. The new set didn't fit quite as well as the ones I got for the 2012 and the arm rest covers were not a good fit at all, due to the design of the consol. Honestly, the seats themselves in my 2012 Tundra were more comfortable than these in my 2023 and the new seat design made it a bit more difficult to install these seat covers. Overall though, I'm glad I got the Wet Okoles. They are a fairly thick neoprene and will add some more cushioning to the seats and are warm in winter and still very comfortable in summer. Mud and water won't hurt them.
    ArticTundra and earlwright239 like this.
  25. Sep 19, 2023 at 2:04 PM
    #4405
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Oem grille, oem marker lights, tuff skinz tri color, dd grille and stealth bar. Surround is off as it goes into the shop to be fixed after someone side swiped me. Excuse to color match and ditch the (dark) chrome!
    49ºNRTH, rwsessions, KiloOps and 2 others like this.
  26. Sep 19, 2023 at 2:27 PM
    #4406
    G3ardnut
    Joe
    Canada
    Even your dog looks impressed by what you did.
    rwsessions likes this.
  27. Sep 19, 2023 at 2:42 PM
    #4407
    Ipaddick
    Ipaddick New Member
    Canada
    More like mad I spent time on the truck rather than taking her out for a run/bike haha
    G3ardnut[QUOTED] likes this.
  28. Sep 19, 2023 at 2:55 PM
    #4408
    Unitdosed
    Unitdosed New Member
    '22 Celestial Silver SR5, CREW CAB TRD OR 4X4
    None, yet
    Any issues with the sensor for cruise assist?
  29. Sep 19, 2023 at 3:07 PM
    #4409
    Unitdosed
    None, yet
    I was able to find someone local who can print this form me. Is the 20oz bottle version also posted?
    Thanks!
  30. Sep 19, 2023 at 3:48 PM
    #4410
    chance12
    chance12 New Member
    GA
    how do you like the DD stealth bar? I have the grille light bar. been debating on the lower stealth light bar
