WHAT HAVE YOU DONE TO YOUR 3RD GEN TUNDRA TODAY?
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Dec 2, 2021.
  1. Jun 10, 2023 at 6:39 PM
    #3481
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    Yeah I ended up buying the matte black one today.
  2. Jun 10, 2023 at 7:40 PM
    #3482
    Jkwolfe09
    Jkwolfe09 New Member
    Jerren
    Took the old tundra out to grab a bite to eat in downtown Austin.
  3. Jun 10, 2023 at 8:23 PM
    #3483
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    The oem valve stem on the inner portion of the wheel has a brass stud where the oem TPMS body screws onto. The stud is flat on one side.
    I can also post an image of the sensor and screw if anyone needs to refer to one.
    Tundrastruck91 and Henry1jg like this.
  4. Jun 10, 2023 at 8:26 PM
    #3484
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Looks great, I also have an SR and I’m completely happy with it. It’s a strong platform which one can build up/customize.
    Are you considering adding any lights? That’s my only legitimate complaint.
    Henry1jg likes this.
  5. Jun 10, 2023 at 8:59 PM
    #3485
    ziznack
    ziznack New Member
    Texas Y'all
    Thanks. So does it make sense that they couldn't use the valve stem from the 1794 wheels on the new one? The 1794 (old) wheels had the original valve stem and sensors. The platinum (new) wheels had the valve stem replaced with ones that couldn't have the sensors on them. They said they can't reuse the valve stem from the old wheels on the new one.
  6. Jun 10, 2023 at 9:08 PM
    #3486
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Maybe they should have transferred the old stems onto the new wheels. However I’m not sure how easily they can be reused.
  7. Jun 10, 2023 at 9:12 PM
    ziznack
    ziznack New Member
    Texas Y'all
    They said once they pull them out they can't. But I feel like maybe I was duped.
  8. Jun 10, 2023 at 11:23 PM
    #3488
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    I remember my tire guy told me that it’s highly recommended to buy new stems from Toyota and he could swap over the sensors without any issues.
    I purchased some from my local dealer for around $53.
    Mlm682577 likes this.
  9. Jun 10, 2023 at 11:27 PM
    #3489
    ziznack
    ziznack New Member
    Texas Y'all
    Ok. Seems like new valves would have been cheaper than new sensors though. They put in new sensors instead of using the old ones. They said they couldn't use the valves in the new wheels. Maybe they didn't have valves? They didn't charge me for the sensors though. But it Sucks they couldn't program.
  10. Jun 11, 2023 at 7:40 AM
    #3490
    T-MAC
    T-MAC New Member
    Westernesse
    2023 Tundra
    Icon stage 7, Dobisons rear springs and track bar, Icon Rebound Pro wheels, MT Baja Legend 40s, JB4, Pedal Commander, AFE intakes and hot pipes
    Love that stance. Glad to see those wheels and tires! Let's see some more pics!
  11. Jun 11, 2023 at 7:49 AM
    #3491
    188Glazier
    188Glazier New Member
    2022 Tundra LTD TRD DC
    Just installed the cbi covert bumper w/ a superwinch sx12k. The vertical fitment of the faceplate pushes the grille/mustache up roughly 1/4” from its factory position. After reading the thread for this install, it appears I’m not the only one.
  12. Jun 11, 2023 at 7:53 AM
    #3492
    188Glazier
    I just had my suspension replaced with the dobinsons ims shocks, and 220lb coils. The dobinsons billet UCA’s should be coming soon(mid June).
    Apica, DMackler and iiawah808 like this.
  13. Jun 11, 2023 at 7:58 AM
    #3493
    188Glazier
    I recently installed the diode dynamics SSC2 pro flush mount reverse lights w/ red backlights. The 7 pin rv piggyback harness was very convenient. Also swapped the rear bumper panels and fender flares for the trd pro’s.
    earlwright239 likes this.
  14. Jun 11, 2023 at 7:59 AM
    #3494
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    how much did this all in you?
  15. Jun 11, 2023 at 9:49 AM
    #3495
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    VERY easy install. Do have to manually tap into one wire and cut another. Other than that, its plug and play. Website says you have to mail back the module but they give you instructions to diy it using idata's weblink. 2hr job, that's taking your time and soldering and buttoning it all up.
    Working great so far, take over is easy and you can just drive off into the sunset without the truck shutting off when you open the door.
    TakiEvo[QUOTED] likes this.
  16. Jun 11, 2023 at 10:42 AM
    #3496
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    Did you do that hood wrap or is that a precut?
  17. Jun 11, 2023 at 11:48 AM
    #3497
    bombsquad85
    bombsquad85 New Member
    David
    2023 Tundra Limited Blueprint
    Cleaned it today. The Blueprint really pops with a good wash! Decided to foam it, clay and maguire spray ceramic wax. I know it's not a real ceramic coating but it's cheaper, faster and looks good lol
  18. Jun 11, 2023 at 2:32 PM
    #3498
    ziznack
    ziznack New Member
    Texas Y'all
    Much better
    Metro14536, dano9258, TFTJ and 8 others like this.
  19. Jun 11, 2023 at 4:15 PM
    #3499
    Harmacist
    Harmacist New Member
    Alex
    NC
    2023 MGM 1794 TRD OR
    that looks nice. You might have just convinced me to get one.
    ziznack[QUOTED] likes this.
  20. Jun 11, 2023 at 4:52 PM
    #3500
    Joemh711
    Joemh711 New Member
    Joe
    2013 Crewmax Texas Edition-Sold, 2015 Red TSS Crewmax-Sold, 2020 TRD Sport Crewmax-Sold, 2023 Tundra TRD Pro
    Anybody have had issues with 35s and balancing . Installed 35x12.5r18 Wildpeaks and have a slight constant bounce /vibration , as if it was balanced right or mud tires .
  21. Jun 11, 2023 at 5:13 PM
    #3501
    ziznack
    ziznack New Member
    Texas Y'all
    Hard stick on.
    Mattedfred[QUOTED] likes this.
  22. Jun 11, 2023 at 5:19 PM
    #3502
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Go back and ask em to rebalance them correctly. I had to go back and have the boys at Discount tire redo the balance. Wildpeaks as well, they aren’t notorious for having balancing issues, I’d say it’s operator error…
  23. Jun 11, 2023 at 5:34 PM
    #3503
    99ways2die
    99ways2die New Member
    NJ
    Coincidentally a recent thread reminded me of these as well, and just received mine (and installed) today.
    When someone else mentioned "glare" from the OEM piece I kinda rolled my eyes when I read it.....that is until I installed this and instantly noticed less glare coming from 'that area.'
    Looks better too; looks more OEM than OEM.
    Someone tell Toyota; maybe they'll change it for MY2042.
    Henry1jg, DexterL and Mattedfred like this.
  24. Jun 11, 2023 at 5:37 PM
    #3504
    ziznack
    ziznack New Member
    Texas Y'all
    Definitely.
  25. Jun 11, 2023 at 8:13 PM
    #3505
    raulz888
    raulz888 New Member
    That looks great! Got a link?
    Thanks!
  26. Jun 11, 2023 at 8:19 PM
    #3506
    ziznack
    ziznack New Member
    Texas Y'all
  27. Jun 12, 2023 at 8:39 AM
    #3507
    Maximus19822
    Maximus19822 New Member
    Jay
    2023 Tundra Capstone
    6 inch lift
    New wheels tires and 6 inch lift to the Capstone
  28. Jun 12, 2023 at 9:02 AM
    #3508
    ArticTundra
    ArticTundra New Member
    Cold
    damn that's a good looking truck. What bedside step is that?
  29. Jun 12, 2023 at 9:04 AM
    #3509
    Maximus19822
    Jay
    6 inch lift
    That’s the stock step
  30. Jun 12, 2023 at 10:29 AM
    #3510
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Looking pretty sharp!
