What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Dec 10, 2018 at 5:24 PM
    #2641
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Its the whole lower bumper assembly. By Assembly, I mean if you unbolt the six bolts on each side, where the bumper bolts to the frame, and lift it off. I picked up that whole section. It bolts right on. I sprayed it with "Raptor Liner", I owna detailing shop, and that's what we spray. I use different air pressures to give the desired texture the customer is looking for. This is pretty fine, about 80psi, looks identical to Linex.
    The paint is "Raptor" Spray in bedliner.
    I found mine on the 3rd gen "For Sale" section of the forum. A lot of the 3rd gen guys are installing the big bumpers, these usually get tossed aside in their garages. Put a "WTB" (want to buy) out there,see who bites. I picked up the Fog light bezels from IJDMtoy.com and the Lights are AuxBeam, not ridgid, but they do the job.
    Zoren Tundra[QUOTED] likes this.
  2. Dec 10, 2018 at 5:28 PM
    #2642
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    Thank you sir
    On the hunt I go !!
    Zoren Tundra likes this.
  3. Dec 10, 2018 at 5:29 PM
    #2643
    Theyfzman
    Pa
    08 TRD
    Can you post a side pic ?
  4. Dec 11, 2018 at 2:44 PM
    #2644
    Bmxrider1331
    Bmxrider1331 New Member
    Brendan
    NEW JERSEY
    2013 tundra 4x4 4.6....
    3 inch toytec eibach kit on 35s
    Spc going in now
  5. Dec 11, 2018 at 5:35 PM
    #2645
    Bmxrider1331
    Brendan
    NEW JERSEY
  6. Dec 11, 2018 at 5:40 PM
    #2646
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Sick dude. The spc has been awesome for me. Taken a beating so far. Jumped the truck a couple feet and didn’t lose alignment :headbang:
    Zoren Tundra and Prostar 190 like this.
  7. Dec 11, 2018 at 5:47 PM
    #2647
    1BadTundra
    Clinton
    Too Much to List
    How bad was it getting the long bolts out?
    Prostar 190 likes this.
  8. Dec 11, 2018 at 5:52 PM
    #2648
    Bmxrider1331
    Brendan
    NEW JERSEY
    Not bad. Have to loosen these hoses first then comes out fine. The driver side was tighter than the other.
  9. Dec 11, 2018 at 5:53 PM
    #2649
    Bmxrider1331
    Brendan
    NEW JERSEY
    Awesome. I'm gunna go home and crack down the upper nut down more. Seems so weird that it's just movable like that
    Mountun Goat[QUOTED] likes this.
  10. Dec 11, 2018 at 8:13 PM
    #2650
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    Installed a supercharger and recovered the headliner! #murica
  11. Dec 11, 2018 at 8:20 PM
    #2651
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    F'n A........
    BA brotha....sweet SC too!!!
  12. Dec 11, 2018 at 8:45 PM
    #2652
    Bmxrider1331
    Brendan
    NEW JERSEY
    Update. Alignment is BAD
    Prostar 190 and Mountun Goat like this.
  13. Dec 11, 2018 at 9:19 PM
    #2653
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Dude so badass!
    airosey[QUOTED] likes this.
  14. Dec 11, 2018 at 9:20 PM
    #2654
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Ya I thought the same thing when I saw it. So far so good. :fingerscrossed:
  15. Dec 11, 2018 at 9:21 PM
    #2655
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    When I installed mine the tires were squeeling in the way to the alignment shop haha
  16. Dec 11, 2018 at 9:27 PM
    #2656
    Bmxrider1331
    Brendan
    NEW JERSEY
    Idk who to trust to do this alignment.
  17. Dec 11, 2018 at 9:38 PM
    #2657
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I also felt that way too. Small town so not hard to find the guy if he screwed up here tho so that helped
  18. Dec 12, 2018 at 5:53 PM
    #2658
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
  19. Dec 12, 2018 at 5:57 PM
    #2659
    FXFormat
    FXFormat New Member
    ^^^Nice use of anal beads :D
  20. Dec 12, 2018 at 5:59 PM
    #2660
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Yah you would know :rofl:
  21. Dec 12, 2018 at 6:15 PM
    #2661
    Bmxrider1331
    Brendan
    NEW JERSEY
    Honest opinions? Hit me. I didnt think I was gunna like it but I do. Tomorrow tires and rims go on. I'll post another after
  22. Dec 12, 2018 at 6:20 PM
    #2662
    Trooper2
    JR
    Houston, TX (Suburban South)
    :thumbsup:
  23. Dec 13, 2018 at 11:37 AM
    #2663
    Bmxrider1331
    Brendan
    NEW JERSEY
  24. Dec 13, 2018 at 12:46 PM
    #2664
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    :thumbsup::rofl: I just replied on your FB post too
  25. Dec 13, 2018 at 1:42 PM
    #2665
    Looks good.
    Bmxrider1331[QUOTED] likes this.
  26. Dec 13, 2018 at 2:21 PM
    #2666
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    When are these bad boys going on??
    :drool:
  27. Dec 13, 2018 at 4:21 PM
    #2667
    Bmxrider1331
    Brendan
    NEW JERSEY
  28. Dec 13, 2018 at 5:43 PM
    #2668
    FXFormat
    FXFormat New Member
    Installed Sequoia Limited seats into my Tundra SR5 which didn't have power, leather, or heat. Leather seats and power makes a world of difference, i found that perfect comfort spot now. For those that might want to do this, seat bolts right in, just tap a power wire to the connector and ground the negative to one of the seat bolts and it'll work. These seats are very comfy
    Just tap into the blue wire on the connector and ground the white wire and you've got power.
  29. Dec 13, 2018 at 5:55 PM
    #2669
    Bmxrider1331
    Brendan
    NEW JERSEY
    What years your truck
  30. Dec 13, 2018 at 6:00 PM
    #2670
    FXFormat
    FXFormat New Member
    2008, but i'm pretty sure the floor plan is the same for Sequoias 2008-2018 and Tundra 2007-2018. Toyota is lazy, they're not gonna redesign the floor plan and then have to make different seat brackets and so on.
