What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Jul 14, 2018 at 10:01 PM
    #2101
    Rica25
    Ricardo
    Tulare
    Installed 1/2 inch toytec lift and new lower control arms
  2. Jul 14, 2018 at 10:22 PM
    #2102
    Aron9000
    Aron9000 New Member
    Aaron
    Washed it. Man that is a fucking task IMO, especially for a short 5'6" man like me, gotta break out that step ladder and washing wand/thingy that is a pole with a sponge on the end of it. 3rd time I've washed it since I owned it back in early May, I know it needs to be cleaned, bug guts taken off the front, at least once a week, but man work has been crazy doing me like 70 hour weeks. When I clean my car, its a process, I really nerd out on it and something the size of the Tundra is like a 1 to 2 hour ordeal to detail it to my standards.
  3. Jul 15, 2018 at 9:09 PM
    #2103
    Punisher17
    Punisher17 New Member
    https://youtu.be/SGYuxelO3u8
  4. Jul 17, 2018 at 4:24 PM
    #2104
    Lars
    Lars Trail Communicatons Expert
    Lars
    Cedar Creek Texas
    2010 Tundra TRD RockWarrior
    I tried to install a set of @RCIoffroad heavy duty steps. unfortunately they don't quite fit my double cab... Rear mount on the step is about a foot too far to the rear compared to the location of the mount on the cab.
    Prostar 190 and Bassmonkey67 like this.
  5. Jul 17, 2018 at 7:18 PM
    #2105
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    Working on TRD brake install. 2nd pic for comparison to non TRD brakes. I'll have the install finished by the weekend.
    Prostar 190 and Trooper2 like this.
  6. Jul 17, 2018 at 7:37 PM
    #2106
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I bet they would fit a crewmax then. ;) They look new - were you shipped the wrong thing?
  7. Jul 17, 2018 at 7:42 PM
    #2107
    Lars
    Lars
    Cedar Creek Texas
    I called, because after ordering I noticed the site says Crew Max only. They said they could make them fit the Double Cab. Unfortunately they don't.
    As for new, they arrived today. I went to install the first one and ran into a snag.
  8. Jul 17, 2018 at 7:45 PM
    #2108
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Bummer!
  9. Jul 17, 2018 at 7:48 PM
    #2109
    Lars
    Lars
    Cedar Creek Texas
    I'll either send them back to RCI (Waiting for a phone call back from them.) Or I'll sell them locally to one of the crewmax guys.
    I ordered a set of Demello Dominator rock sliders.
    landphil[QUOTED] likes this.
  10. Jul 17, 2018 at 8:35 PM
    #2110
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    Did you do a write up? If not could you sum up how much of a pita it was or wasn’t?
  11. Jul 17, 2018 at 8:38 PM
    #2111
    Lars
    Lars
    Cedar Creek Texas
    In this photo, the left side of the triangle coming up from the base, to the top. I cut it out with an angle grinder to clear the headlight adjuster.
    Beyond that it's a tight fit, but it goes in. I also trimmed a couple of plastic bits off the front of the fuse box to increase clearance.
    Doing it again, I would move the whole fuse box to the rear about 1/2" which is how much space it looks like there is. doing that I don't think I'd have to modify the box at all.
    Pale_Horse[QUOTED] likes this.
  12. Jul 17, 2018 at 8:43 PM
    #2112
    Lars
    Lars
    Cedar Creek Texas
    Couple more photos, Sorry I found these after my last post.
  13. Jul 17, 2018 at 9:18 PM
    #2113
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Just got done with
    Cleaning and conditioning the leather seats and Aerospace 303'ing the rest of the interior.
    Washing the exterior, and giving it a coat of Z2 polish followed by Z6. Detailing the rest of the rubber/plastics with either Aerospace 303, Z16, or waxaddict tyre conditioner.
    Hope to get another coat of Z2 on tomorrow and maybe some Butter wet wax.
  14. Jul 19, 2018 at 10:04 PM
    #2114
    Lars
    Lars
    Cedar Creek Texas
    I finally got around to wiring up my relay/switch panel, and re-running the circuit breaker for all the radios after the dual battery install. I'm not happy with the current placement of the switch panel, but it'll work for the trip we're taking this weekend.
    6 Fuse, 6 Relay gang box from Amazon.
    Takes standard automotive fuses and relays which should make repairs on the road easy.
    Current switch panel location.
    Mountun Goat likes this.
  15. Jul 20, 2018 at 8:02 PM
    #2115
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Got some 35x12.5 mounted up today
  16. Jul 21, 2018 at 6:14 AM
    #2116
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Just had my transmission serviced @ Toyota of Elizabeth City, (Drain & Fill) . I had the tech keep the fluid so I could inspect, and WOW! Fluid was still a deep red and no signs of metal shavings. Tundras F$%&ing Rock! :yay: $180.00 out the door.
  17. Jul 22, 2018 at 6:56 PM
    #2117
    Lars
    Lars
    Cedar Creek Texas
    I took mine on an adventure to the Padre Island National Seashore.
    (Including a Donut)
    She has a sexy smile
  18. Jul 22, 2018 at 7:09 PM
    #2118
    Lars
    Lars
    Cedar Creek Texas
    how many miles?
  19. Jul 22, 2018 at 9:23 PM
    #2119
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Dang, I want to go play there!
  20. Jul 22, 2018 at 9:25 PM
    #2120
    Lars
    Lars
    Cedar Creek Texas
    I mean, the speed limit on the beach is 15mph.
    It's pretty awesome to get away though. Once you get past the 15-20 mile mark you'll see people but they're few and far between. We had one neighbor we could see from our camp site. He was probably a mile south of us.
  21. Jul 22, 2018 at 9:30 PM
    #2121
    Taco-Blender
    AZ
    2010 DC 4x4
    So, good to go for camping on the beach then I take it.
    If we ever get near that part of TX, I'm in.
  22. Jul 22, 2018 at 9:31 PM
    #2122
    Lars
    Lars
    Cedar Creek Texas
    You're allowed to camp on the beach for up to 14 consecutive days. Unless you're right at the first mile marker though it'll be primitive camping.
    Taco-Blender[QUOTED] likes this.
  23. Jul 23, 2018 at 2:04 AM
    #2123
    Aron9000
    Aron9000 New Member
    Aaron
    Put a bigger round mirror on the passenger side. I had the smallest size round mirror on the passenger side mirror on my 2011 Tundra. It was maybe okay/alright in the day, but during the night that 2.5" round mirror was just too small.
    Tried like several D shaped convex mirrors, even a rectangular convex mirror. All of them sucked, I put on a bigger perfectly round stick on mirror, right at the bottom right corner on the passenger side mirror. That round stick on mirror gives the best view of my blind spots.
  24. Jul 23, 2018 at 4:39 AM
    #2124
    rons23
    Ron
    Kill Devil Hills
    101k :thumbsup:
  25. Jul 23, 2018 at 6:19 PM
    #2125
    Washed dried and Butter Wet Wax!
  26. Jul 23, 2018 at 9:39 PM
    #2126
    bthompson12
    bthompson12 New Member
    Bruce
    GA
    22’ Blueprint SR5 4x4
    New wheels and tires over the weekend. Looks way more aggressive in person. Nitto ridge graps 295 70 18 with a set of 2018 trd wheels
    Maxi13, JC303, zcarpenter92 and 5 others like this.
  27. Jul 24, 2018 at 4:09 AM
    #2127
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    That looks good! I looked for a set of those wheels for a while for my truck, but never had any in a price range I was willing to pay. Most of what I saw around here was $800+, none of which had the sensors. My truck had the steel wheels so I was having to get sensors. I finally said screw it, and I bought the Vision Warriors from Discount Tire back in February with my Ridge Grapplers for $125 each and $100 for all 4 sensors.
    This site is awesome, looking at all of the different mods people do to their trucks, 1st gen through 3rd gen, and how many good looking trucks are out there!
    Blueknights75 likes this.
  28. Jul 24, 2018 at 4:24 AM
    #2128
    Looking good!
    bthompson12[QUOTED] likes this.
  29. Jul 24, 2018 at 7:17 AM
    #2129
    bthompson12
    Bruce
    GA
    Yeah I got lucky! Found those rims for $350 on Craigslist. Brand new off a 2018 he said maybe 100 miles on them. The dealership was able to switch over my sensors so didn’t have any extra cost there. Next up is some step bars
    Very pleased with how it turned out!
  30. Jul 24, 2018 at 7:31 AM
    #2130
    Sweet rig!
    Where on Padre did you go through?
