What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Feb 16, 2025 at 7:02 PM
    FREEK
    FREEK New Member
    Darren
    Olathe, KS
    2019 Tundra Limited Crewmax 4X4
    That is SCHWEEEET! Careful with the magnets…
    I heard the bullets always hit Due North.
    07 Tundie[QUOTED] likes this.
  2. Feb 21, 2025 at 2:50 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Tested Ali Express. 9 days later and a decent Chinese carbon fiber shift knob showed up.
  3. Feb 23, 2025 at 4:09 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    I've done too much over the last week..
  4. Feb 25, 2025 at 9:40 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    since i sold the 4Runner, i finally had money and time to pick up parts for my tundra and am finding some time to work on it. added a rear sway bar last weekend and did an oil change with a new cabin air filter. the old one was black and full of leaves.
    she threw a P2440 code last week - "secondary air injection system switching valve stuck open (bank 1)." 4LO was flashing, CEL came on, VSC was blinking, stability control was off, the xmas tree of FVCK. it put her in to limp mode while i was driving my kid to school. A very expensive fix, or a $450 bypass kit. i ordered the bypass kit and am installing it this weekend. it's "plug & play" but i am nervous.
    also got a new damper servo to hopefully fix my AC blend door issues & give me back my AC (and save myself ~$2000), a new clock spring to hopefully fix my cruise control & turn off my airbag light, spark plugs, new weather strips for the windows, new front sway bar end links and new lower control arms. got my work cut out for me for the next few weekends.
  5. Feb 25, 2025 at 3:23 PM
    koditten
    Kirk
    Midland of the Mitten
    This seems odd. The coincidence bothers me.
    You installed a handling bar and you get an ass load of lights?
    Are you sure you did not sever the speed sensors/wires going to the rear brakes as well as issues with AIP pumps ( I know that phrase is redundant)? Speed sensors always give you those lights you listed.
    OldGuy03 likes this.
  6. Feb 25, 2025 at 4:26 PM
    VTTundy
    VTTundy New Member
    let us know how it goes
  7. Feb 25, 2025 at 5:56 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    It would throw a abs code if he broke a wire
    OldGuy03 and koditten[QUOTED] like this.
  8. Feb 25, 2025 at 9:14 PM
    Tundra1D6
    How’s this look?
  9. Feb 25, 2025 at 9:23 PM
    joseph_womack
    Joe
    Louisiana
    looks pretty good to me but im not an alignment tech lol
    07 Tundie and OldGuy03 like this.
  10. Feb 26, 2025 at 10:59 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    sorry, those were out of order. i got the code before installing the sway bar
  11. Feb 27, 2025 at 2:48 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    Also not an alignment tech or Pro Auto Mechanic, but I've personally never had an all green print-out after an alignment. I do feel like your Caster is higher than mine normally is but maybe I'm misremembering.
  12. Feb 27, 2025 at 4:15 PM
    Tundra1D6
    I’m 50/50 on the specs. Personally I’d like more negative camber as these trucks tend to eat the outside edge of tires.
    If it’s green it goes :)
  13. Mar 1, 2025 at 9:17 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    installed a hewitt tech gen II bypass kit and replaced my clock spring. and got new windshield wipers. feeling accomplished.
  14. Mar 2, 2025 at 3:43 PM
    TexasGuyTX
    TexasGuyTX New Member
    Ryan
    2007 SR5 Super White
    PRO BOX w/ RF Mono Amp Limited 20" Wheels HID's on Low Beams Tip Delete Before Axle
    Before/After, Leather/Vinyl Flexable Adhesive + Leather Filler + Leather dye sprayed with mini hvlp.... 2007 SR5 134k Personal work truck (fathers in 08 to me in 21)..
  15. Mar 2, 2025 at 4:03 PM
    VTTundy
    VTTundy New Member
    Amazing!
    TexasGuyTX[QUOTED] likes this.
  16. Mar 2, 2025 at 5:03 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Great work.
  17. Mar 5, 2025 at 7:09 AM
    mbgls63amg
    mbgls63amg New Member
    Joshua
    2010 Toyota Tundra SR5
    Today I’m getting my upper control arms replaced. Bought a gently used pair, off a 2015 Tundra, on eBay. Around $130 for the pair. Both were in great condition with no rust. Got all the necessary hardware to go with them. Also getting my tire rods (inner and outer) replaced and an alignment done.
    Sean492 and SAGE63 like this.
  18. Mar 5, 2025 at 11:40 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    nice. i ddid that with my UCAs. got some OEM takeoffs from a suspension shop
    07 Tundie and mbgls63amg like this.
  19. Mar 5, 2025 at 12:27 PM
    mbgls63amg
    Joshua
    Nice as well. Good used ones are the best way to go. Brand new upper control arms are over $300 a piece nowadays. Not including new hardware or labor if you choose to have a shop install them.
  20. Mar 5, 2025 at 2:08 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    i tried to find low-mileage OEM takeoff LCAs but people don't swap those out as much. happy i have a connection in a local toyota dealership parts dept
  21. Mar 5, 2025 at 5:10 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    What are you paying to get the inner and outer tie rods installed? And how many miles are you at?
  22. Mar 5, 2025 at 5:37 PM
    mbgls63amg
    Joshua
    It was about $736. That includes parts and labor. I’m at just over 198k miles.
  23. Mar 5, 2025 at 8:01 PM
    ZPhilip
    Philip
    West Chester, PA
    That’s not bad. I’m only at 92k miles and I have one side seized up. Oxy acetylene torch didn’t even loosen it up.
  24. Mar 5, 2025 at 8:39 PM
    mbgls63amg
    Joshua
    Thanks. It was a good price. I got them changed out mainly for peace of mind. Especially with the salt and rust here in the northeast, age of the truck.
    Funny thing is that the shop I took my Tundra to had said before that the ends were frozen like one of yours. Would need to be changed out for a proper alignment. Took my Tundra to the dealer to get my rims swapped out, they recommended an alignment, claimed they had no issue performing it. lol
  25. Mar 5, 2025 at 11:06 PM
    j_supra
    j_supra Dreamin about boooost!
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub,
    Maybe you have already but in case you have not, check your lower ball joints too. If your uppers and tie rods need replacement then I'd say your lowers aren't far behind. My 08 needed lowers at around 200k. Before it needed tie rods or uppers.
    HulkSmurf14 and 07 Tundie like this.
  26. Mar 6, 2025 at 5:03 AM
    mbgls63amg
    Joshua
    Thanks for the input. To be honest, I mainly got my upper control arms and tie rod ends replaced out of an abundance of caution. Not because they were failing. And in the case of my upper control arms, I stumbled across a good deal. I owe nothing on my Tundra, so I don’t mind spending a few thousand bringing things up to current. I did find a brand new OEM lower control arm set for under $700 on eBay, from a reputable seller. Something I’ll think about.
    grave likes this.
  27. Mar 6, 2025 at 3:19 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    you can find LCAs on most toyota dealership parts websites in the sub-$350 range, it's the shipping that'll get ya
  28. Mar 6, 2025 at 3:29 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Free shipping may apply here
    HulkSmurf14, mbgls63amg and The Dude like this.
  29. Mar 6, 2025 at 3:47 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    goddamnit, man... I've trying to pay down debt and you post these things!
    joseph_womack and mbgls63amg like this.
  30. Mar 6, 2025 at 4:43 PM
    Shanet421
    San Diego,CA
    Your welcome
    :spending:
    OldGuy03 and mbgls63amg like this.
