What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. May 6, 2024 at 11:12 AM
    FuegoMCS
    FuegoMCS New Member
    East Texas
    2011 Crewmax 2WD
    Thanks for asking about this. I need to replace mine too!
  2. May 6, 2024 at 12:23 PM
    tahoe
    tahoe New Member
    2013 RW, 6112 @1.9” front, 5100 rear
    IMG_0523.jpg IMG_0521.jpg New headlights! Morimoto XB.
  3. May 6, 2024 at 12:50 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Looks 10 years newer.
    Kiddnapped Tundra and Luckster like this.
  4. May 6, 2024 at 4:12 PM
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    Nice! I love mine!
  5. May 6, 2024 at 4:59 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    from what I've seen, 2.5" is enough to do the spacer, I'm running one at 3"
    Optic15[QUOTED] and 07 Tundie like this.
  6. May 6, 2024 at 7:09 PM
    rphass17
    rphass17 New Member
    Greased my u joints today. The rear end of the front driveshaft was a little tricky. Really missing my Tacoma where it was lifted 2.5” and I could easy move around under it.
    Mountun Goat and joseph_womack like this.
  7. May 6, 2024 at 9:40 PM
    08OffroadTN
    08OffroadTN New Member
    East TN
    2008 TRD Offroad
    I've got zero bounce in mine. Everything is attached to a Ram Mount. Picture for reference. Excuse the bunched-up dash mat, it was brand new.
  8. May 7, 2024 at 4:06 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I replaced my right rear passenger tire today following a flat out on the highway yesterday. The tire was too chewed up to salvage, and was unfortunately only about 5 months old. So I ponied up a little over $300.00 for a new tire, and now I'm good as new. Less three hundred but good as new.
  9. May 7, 2024 at 4:52 PM
    tahoe
    tahoe New Member
  10. May 7, 2024 at 6:23 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I'm curious but no road warranty at all? Only 5 months old, unless you trashed a spiked board on the way.
  11. May 7, 2024 at 8:37 PM
    joseph_womack
    Joe
    Louisiana
    Sweet, thank you for the Input
  12. May 8, 2024 at 4:29 PM
    Retroboy1989
    Northern Utah
    No prorated warranty or road hazard replacement?
    dondino[QUOTED] likes this.
  13. May 8, 2024 at 4:34 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Went to visit a friend and show him my new 2010 RCSB and got to compare to his 2020 DC. His is a top line model, leather interior with all the power options. But neat pic to show the design difference side by side. I like the looks of my 2010 better, looks meaner! Not as nose big, square. It his was $40K more expensive than mine, so there is that! Here is it. IMG_1534.jpg
  14. May 8, 2024 at 4:37 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    These are on my buddies 2020 DC. But I’m hoping someone here recognizes the make? They are 74” and have really sturdy well made brackets. I’d like to put a set on my RCSB. So any eagle eyes can let me know manufacturer I’d appreciate it. IMG_1529.jpg IMG_1531.jpg
    ACDC2ZZTop and Mountun Goat like this.
  15. May 8, 2024 at 4:41 PM
    SAGE63
    San Diego County
    Ugh... those are just rails attached to the body. not much protection offroad. you really want rails that mount to the frame
    joseph_womack likes this.
  16. May 8, 2024 at 4:52 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    The Demello variety
  17. May 8, 2024 at 6:10 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I have off road sliders on my Land Cruiser. This truck isn't for off road. Its for farm duties and hauling stuff.
    The old Lady likes it lower and the steps will help. We are both a bit shorter in the leg than most.
    Just to screw with you all, it's getting SOS lowering kit and airbags over the summer. So I can drive
    in winter without usual pick-up instability.
    07 Tundie, SAGE63 and joseph_womack like this.
  18. May 8, 2024 at 7:28 PM
    joseph_womack
    Joe
    Louisiana
    Also, is that the Ram mount flex arm or the iBolt version from Amazon?
  19. May 9, 2024 at 6:55 PM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    Last week I took advantage of a break in bad weather that aligned with a break away from work, and got my winch installed.
    A couple of months ago, I attempted to install the bumper and winch together, when the winch wouldn't clear the heat exchanger water pump for the super charger. I was short on time, so I put the bumper on without the winch.
    Not wanting to be bothered with rerouting the pump plumbing, I opted to mount the winch control box to the side of the winch and mount the pump to the winch frame. Good, bad, who's to say. I drilled and tapped the winch frame and installed two bolts to mount the pump. Worked like a charm!
    Next up was wiring. Before installing anything, I tested the power draw on the winch with it switched off, and found it still draws power. No thanks. I picked up a 500 amp Stinger relay/isolator and wired it to my Auxbeam switch to use as an on/off trigger for the winch.
    Lastly, I switched out the Smittybilt hook for a Factor 55 Ultrahook. Needless to say, my mallcrawler is now able to winch its way out of parking lots and gas stations, if the need were to arise!
  20. May 10, 2024 at 10:26 AM
    Alilogi
    Alilogi New Member
    It was pretty easy install for the most except the 3 clips on each of the front flares that are needed to install. Those took the longest time for me as it needed to be aligned just right. These are Tyger brand from Amazon.
    https://www.amazon.com/dp/B0849JH2ZK?ref=ppx_yo2ov_dt_b_product_details
    ACDC2ZZTop[QUOTED] likes this.
  21. May 10, 2024 at 5:06 PM
    tahoe
    tahoe New Member
    IMG_0545.jpg New grill, shifty knob, rear shocks and CB shackles today. IMG_0547.jpg
  22. May 11, 2024 at 2:17 PM
    08OffroadTN
    East TN
    2008 TRD Offroad
    Ram mount flex arm
    joseph_womack[QUOTED] likes this.
  23. May 11, 2024 at 2:20 PM
    koditten
    Kirk
    Midland of the Mitten
    How difficult is it to manipulate the manual brake slide on the bottom?
  24. May 12, 2024 at 11:45 AM
    joseph_womack
    Joe
    Louisiana
    Installed the ICS dash mount plate today, overall happy with the look, haven’t tested it while driving yet
  25. May 12, 2024 at 6:14 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Over 250k miles and 4wd actuator finally siezed with rust took it out cleaned and lubed and back to 100% operational.
  26. May 15, 2024 at 11:51 PM
    joseph_womack
    Joe
    Louisiana
    Update on mount: Drove on pretty much the bumpiest road in town and can confirm my phone doesn’t bounce up and down and vibrates minimally; definitely worth the upgrade and not hard to install. Only downside is that you have to take everything apart if you need to bolt anything else to it later
  27. May 16, 2024 at 5:52 AM
    MartinBlank
    MartinBlank New Member
    Bruce
    Loveland CO
    2008 Crew Cab Limited
    TRD Sway Bars, TRD CAI, Bilstein 5100's, LED's, plus LED rear Plate backup light, Aluminum oil filter housing, ECGS Needle Bearing upgrade.
    Wasn't today but about a month ago, had to replace the engine on my 2008, let go at 260k. Found a used one with 124k. Fixed all the regular stuff i.e.: timing chain tensioners, chain was fine, timing cover reseal, new water pump, thermostat, checked but no leak on cam towers, front and rear main seals, new oil pan, then added SDHQ battery terminals, Dirty Deeds 10" Exhaust, Overland Taylor Tune. Runs like a champ now.
  28. May 16, 2024 at 5:54 AM
    MartinBlank
    Bruce
    Loveland CO
    Pictures.. sorry
  29. May 16, 2024 at 5:54 AM
    MartinBlank
    Bruce
    Loveland CO
  30. May 16, 2024 at 5:56 AM
    MartinBlank
    Bruce
    Loveland CO
    Please excuse the cobbled together TRD air cleaner, came in pieces with the engine.
    joseph_womack and OldGuy03 like this.
