What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Aug 23, 2017 at 7:07 PM
    #1531
    Bulldog_tundra
    Bulldog_tundra New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    6 hoop steps came in today
  2. Aug 26, 2017 at 6:00 PM
    #1532
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    GNTundra and Bulldog_tundra like this.
  3. Aug 26, 2017 at 6:37 PM
    #1533
    TheBeast The Beach
    TRD sway bar and good clean up
  4. Aug 27, 2017 at 5:40 PM
    #1534
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Changed the oil for the first time today. What a roller coaster.
    Started off with almost not being able to remove the filler cap since it was torqued on by He-man. :( Then I crawled under and had enough room so I didn't need to jack up the truck. :) Then I noticed that I didn't have to remove the skid plate because I didn't have one. :):(.
    The draining of the pan went well. :) Had a little trouble removing the small cap from the oil filter assembly and a LOT of trouble removing the whole oil filter cap assembly itself. He-man torqued that on with everything he had. :rant: After using a breaker bar and having pieces of plastic breaking off, I was finally able to remove it. :) Now my oil filter wrench was completely stuck to the plastic filter cap assembly.
    :facepalm:
    After using a hammer to remove my wrench, my filter cap assembly completely comes apart (spring,washer,and sleeve tube go flying):mad:.
    I reassemble everything , close it all back up, fill with oil and everything looks good to go. :cool: Then I start the truck and hear something weird. I walk to the front and look underneath and see that I am pressure washing my driveway with oil from the filter cap assembly. :eek::mad:
    I remove the oil filter assembly again and see that the insides have popped free. I put it back together , but for some reason if it got wiggled just a little it would pop apart again.
    :annoyed:
    After a trip to Autozone to purchase a complete new, metal assembly, I put everything back together, torque to the proper specs, refill the oil I lost, and everything seems good.......I hope :D
    duece292 and Les7311 like this.
  5. Aug 27, 2017 at 5:51 PM
    #1535
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    you will need He-Man again when time comes to pull the front differential drain plug. Bring your breaker bar and a great 10mm hex-bit!!!!!
  6. Aug 27, 2017 at 6:01 PM
    #1536
    Tundra Fan
    Toby
    I've never done that before , might leave it up to a professional depending on difficulty rating. I've changed oil tons of times before though and never had an experience like this. There's something to be said for the one piece oil filter cannister.
  7. Aug 27, 2017 at 6:16 PM
    #1537
    Les7311
    It's just as simple as changing the engine oil. They just use more than 40 pounds of torque. More like 180 when I had to pull mine last weekend. No $hit!!
    Then again if you don't have 4x4 then no front dif for you
  8. Aug 27, 2017 at 6:19 PM
    #1538
    Tundra Fan
    Toby
    Wait.......front diff? Mines 2WD.
    Les7311 likes this.
  9. Aug 27, 2017 at 7:10 PM
    #1539
    DalTee
    DalTee New Member
    Dal
    HaHa it's on. I'll post pics tomorrow.
    I just can't sit still.
    GNTundra likes this.
  10. Aug 27, 2017 at 7:22 PM
    #1540
    DalTee
    DalTee New Member
    Dal
    Yoooo - that joker is #Dope
  11. Aug 27, 2017 at 7:26 PM
    #1541
    DalTee
    DalTee New Member
    Dal
    You just want me to spend money -
  12. Aug 27, 2017 at 7:32 PM
    #1542
    DalTee
    DalTee New Member
    Dal
    I got a little tear!
  13. Aug 28, 2017 at 6:07 PM
    #1543
    DalTee
    DalTee New Member
    Dal
    IMG_0512.jpg IMG_0509.jpg IMG_0510.jpg IMG_0506.jpg IMG_0507.jpg BullBar on. Cleaned her up and stopped by the fields this morning before work.
    Les7311, GNTundra and TheBeast like this.
  14. Aug 28, 2017 at 8:30 PM
    #1544
    TRD-ROCKWARRIOR
    TRD-ROCKWARRIOR New Member
    Jerico
    2011 Black Tundra CM 4X4 TRD RockWarrior
    Match Tinted the front driver/passenger windows
    American Flag Tow Hitch Cover and Lock
    a12729743be6fd63c5b071deaa13736b_c3f1b4a07162104ff1561ef5b467a5b02f2d82b9.jpgaad5966276050631c2f97faa499c2ccd_d91ad0fcb1e8ae21a38e9e8b920793888a25b2a3.jpg
    Husky All Weather Floor Mats (Front Driver & Passenger / Rear 1 Piece)
    0a942a90cb86783aa6620e6f8444270f_6c41823ab1ea1bfe63c85cab92b00e47412ef211.jpga54d05249477076c73585929276459ac_38e736e0b3a0162b80aafa2987258f4674cc54c3.jpg
    Tonnosport Roll-Up Cover.
    2011 CM 4X4 TRD RockWarrior
    Mountun Goat and Teriks like this.
  15. Aug 28, 2017 at 8:32 PM
    #1545
    TRD-ROCKWARRIOR
    Jerico
    52f631cc626cb41c8c313834bb522096_2f8d36e8778da363e2065f7d9b0bca55b4e64b1d.jpg500c3e33f6648cac5dd0649114561584_6baffffebaecf40006b6e458e75b6a34c19922e5.jpg
    Line-X and OEM Toyota Bedrails
  16. Aug 28, 2017 at 8:49 PM
    #1546
    TRD-ROCKWARRIOR
    Jerico
    Removed old TRD caps and put on new ones!
  17. Aug 29, 2017 at 2:07 AM
    #1547
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    That is a Sharp looking Tundra!
    DalTee likes this.
  18. Aug 29, 2017 at 2:11 AM
    #1548
    Patriot
    Patriot Member
    Dam sharp looking Tundra there Gino! Well done!
  19. Aug 29, 2017 at 11:02 AM
    #1549
    DalTee
    DalTee New Member
    Dal
    Thanks! I went with the Extang 2.0
    I really like it
  20. Aug 29, 2017 at 7:17 PM
    #1550
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I added Ceramic window tint to my '07, and replaced the wiper blades.
    I'm keeping this one basically stock, but I will be adding a Hellwig to the rear soon.
    GNTundra and DalTee like this.
  21. Sep 1, 2017 at 7:46 PM
    #1551
    Teriks
    Teriks New Member
    Tom
    Front Range, CO
    2008 Toyota Tundra Limited DC 4x4 5.7
    Fixed my aftermarket fog-light mounting issue. They are black-housing HIDs from EleDobleU. Also changed the gear oil in both my differentials and the transfer case. Good amount of gunk on the front diff plug; glad I got it done!
    GNTundra, DalTee and Rex Kramer like this.
  22. Sep 2, 2017 at 9:57 AM
    #1552
    SailorRocco
    SailorRocco New Member
    New York
    2012 Mgm Tundra 5.7 TRD Off Road
    Finally put on the wheels, tires and lift that I picked up on this site. Thanks for the great deal @Kyle100 IMG_3213.jpgIMG_3212.jpg
  23. Sep 2, 2017 at 10:03 AM
    #1553
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    What'd ya go with?
    Silverghost and (deleted member) like this.
  24. Sep 2, 2017 at 10:22 AM
    #1554
    SailorRocco
    New York
    Low range off road 3/1 leveling kit, 20" bmf novakane wheels and 35x12.5 toyo open country tires @zcarpenter92
  25. Sep 2, 2017 at 10:25 AM
    #1555
    Teriks
    Teriks New Member
    Tom
    Front Range, CO
    Rubbing with those tires or did you already cut/chop to avoid that?
  26. Sep 2, 2017 at 10:27 AM
    #1556
    SailorRocco
    New York
    I had to chop the body mount, remove the front mud flaps and bend the skid plate to make them fit. I would have preferred a different lift but it was included with the wheels and tires so I went with it
    GNTundra and Teriks[QUOTED] like this.
  27. Sep 2, 2017 at 11:59 AM
    #1557
    Kyle100
    Kyle100 New Member
    Kyle
    2012 tundra crewmax
    Looks great !!!
    SailorRocco[QUOTED] likes this.
  28. Sep 3, 2017 at 1:41 PM
    #1558
    bobojones
    bobojones New Member
    Randy
    2013 Tundra DC TRD
    I installed my Flowmaster Outlaw Exhaust. for some reason it is not letting me upload the videos but this truck sounds like it it going to eat other trucks now. It is not to loud in the cab at cruising speed (45-50) but dont know about highway. That is coming tomorrow.
    GNTundra and Teriks like this.
  29. Sep 4, 2017 at 1:31 PM
    #1559
    DalTee
    DalTee New Member
    Dal
    Good looking front end there!
  30. Sep 4, 2017 at 3:07 PM
    #1560
    Bulldog_tundra
    USA
    2006 Double Cab
    Finally got a chance to use the new foam cannon . Really impressed, this was the lower setting, didn't figure that out till the end. Highest setting was really thick foam and this was using cheap leftover WalMart brand car soap.
