What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Oct 8, 2023 at 10:42 PM
    Magnet18
    Magnet18 New Member
    Rob
    Oregon
    2008 Double Cab SR5 TRD
    joseph_womack likes this.
  2. Oct 8, 2023 at 10:46 PM
    Magnet18
    Magnet18 New Member
    Rob
    Oregon
    And a garage door opener switch!
  3. Oct 8, 2023 at 11:22 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Nice work :thumbsup: Night and day difference between the OE '08 dash lights!!!
    Magnet18[QUOTED] likes this.
  4. Oct 9, 2023 at 10:26 AM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Nothing! I just happened to have a guage setup running while watching trans temps and was amazed at 13 year old technology doing so well with balanced trims. i.e. working as intended too.
    It means both bank 1 and bank 2 are being fueled equally as seen by o2 sensors and its running an AFR of 14.7:1 on both banks. Wear, tear, injectors, blowby are balanced on the little V8 with 111k miles. A good thing.
    joseph_womack and MTRock like this.
  5. Oct 9, 2023 at 7:10 PM
    Cmende
    Cmende New Member
    California
    2013 Rock Warrior
    Dirt King boxed upper and lower control arms. Fox 2.5 shocks front and rear. R1 concepts drilled and slotted rotors. Baja Designs XL80 on the A-pillar and Baja Designs Squadron Pros in the fogs.
    Installed my TRD Pro Sequoia grill.
  6. Oct 10, 2023 at 6:48 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Well, it’s not exactly second gen or even tundra. I did a bunch of pre-season maintenance on the truck plow yesterday. I moved the stand and adjusted some pin points (due to truck lift) so it stands up where it’s supposed to now and I can drive into the plow. Installed a grader edge. Doubled up recoil springs. Fixed broke welds. And replaced a pivot pin that fell out. She’s brand new upgraded now bois ready for winter. :hattip:
  7. Oct 10, 2023 at 2:55 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Pumped all 5 U joints full of new grease. Anyone have a good method for cleaning off the expressed grease? Or do you just let 'er fling?
  8. Oct 10, 2023 at 2:57 PM
    coTony
    Tony
    Montrose, CO
    Shop rag will clean er right up!
  9. Oct 10, 2023 at 2:59 PM
    Retroboy1989
    Northern Utah
    Mostly the nooks and crannies. Especially on the forward 3 joints with limited access.
  10. Oct 10, 2023 at 3:14 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Let ‘er fling!!
    rphass17 and PolishedTRD like this.
  11. Oct 10, 2023 at 5:35 PM
    KeepOnTruckin
    Randy
    I stick a rag in to grab some but mostly it comes out on its own.
    Have you found a good tool to reach the front shaft u-joint at the xfer case? I've been dropping 4 bolts and pry it free every other oil change. But while it was in the air for tranny fluid dump last weekend I did all 5 3000 miles early.
  12. Oct 10, 2023 at 5:37 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    So where are all the lube points on the 2nd gen Tundras?
  13. Oct 10, 2023 at 5:40 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Drive shafts, and that's it.
  14. Oct 10, 2023 at 6:22 PM
    KeepOnTruckin
    Randy
    Before you run to look, picked mine up with 105K and no one ever greased them! The rear shaft has zerks protruding from the caps. All three should be in alignment, just jack it up to spin. The front is a PITA near the x-fer case.
    Tipsovr[QUOTED] likes this.
  15. Oct 10, 2023 at 6:28 PM
    Retroboy1989
    Northern Utah
    I rotated the shaft and found an angle where I could just barley get the normal grease fitting on a hose to slip on from below. I had it at about 4:00 looking from the rear of the truck. It was the hardest one by far.
    5 zerks on the driveline. 3 on the rear, 2 on the front.
    I pump grease until I see old grease on all fours and clean grease coming out on atleast 1.
  16. Oct 11, 2023 at 2:35 AM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Thank you for the replies about the Zerks!
  17. Oct 11, 2023 at 12:27 PM
    coTony
    Tony
    Montrose, CO
    There are zero zerks on my 2018. I looked then had a shop look while they were in there and all sealed up
  18. Oct 11, 2023 at 12:31 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've read that at some point Toyota started doing away with them. Which has me wondering if the 3rd Gen has them. Anyone willing to stop, drop, and roll under one at a traffic light to see? j/k;)
    ACDC2ZZTop and coTony[QUOTED] like this.
  19. Oct 11, 2023 at 4:25 PM
    Retroboy1989
    Northern Utah
    This makes me feel like the need to grease our drivelines isn't very pressing. If newer trucks don't even need new grease, what does the presence of zerks do to reduce U joint grease life?
  20. Oct 11, 2023 at 5:20 PM
    coTony
    Tony
    Montrose, CO
    My whole life was, if you have them grease them and I would each time I changed the oil. Takes no time
    KeepOnTruckin and chugs like this.
  21. Oct 12, 2023 at 4:06 AM
    sctomfar
    sctomfar Chasing 700RWHP
    Tom
    Bluffton, SC
    Supercharged Reg cab
    Harrop 2650 supercharger TRD suspension TRD intake Custom exhaust Dirtydeeds cross pipe Fully built bottom end motor Manly Rods Crowder Pistons ARB Stud Kit National Speed Tuned Redesigned fuel system XAT Fuel Rails Twin Demon Fuel Pumps 83cc Injectors Morimoto Headlights
    New 1000hp capable IPT Transmission installed… I never knew how badly I needed it.
    MTRock and Magnet18 like this.
  22. Oct 12, 2023 at 8:43 AM
    Magnet18
    Magnet18 New Member
    Rob
    Oregon
    Installed my cheap LED light kit from Amazon https://a.co/d/4IFTJ9L
    Happy with how bright everything is, and since I didn't have vanity/footwell/glove box lights I ended up with a bunch of extra LED bulbs
    Also switched the LED in the auto window up/down switch and the one in the glovebox, completing the conversion of every single amber LED and incandescent bulb inside the truck :woot:
  23. Oct 12, 2023 at 8:43 AM
    rphass17
    rphass17 New Member
    Wild turn of events here within the last 5 posts form grease points to installing 1000hp transmissions.
  24. Oct 12, 2023 at 8:52 AM
    coTony
    Tony
    Montrose, CO
    It was hard to tell what you actually get for the $5K+ price tranny except for it is heavy duty
  25. Oct 12, 2023 at 8:53 AM
    Kiddnapped Tundra
    Kiddnapped Tundra New Member
    Grand Island, NY
    2010 Tundra DC
    I had a new/used 2012 motor installed into my 2010 Tundra.
  26. Oct 12, 2023 at 7:02 PM
    KeepOnTruckin
    Randy
    Thanks for this. Made me lol haha!
    On the zerk topic, there are two key ingredients. As machining tolerances improve and material quality improves, wear is reduced, so long as grease stays in and moisture stays out.
    If either of the last two enter the equation, u-joints die. Unlike the trunion Cv-joints with loads of grease everywhere, u-joints have little spare grease and zero circulation.
    Recap: It appears my 2010 lived 11 years without new grease. Compared to 1960 through 1990 where they maybe lived 35/55k that's impressive!!!
    Let's not forget petroleum products are superior to the 70s and 80s.
    JM2C
  27. Oct 12, 2023 at 10:17 PM
    litehedded
    litehedded New Member
    Had mine replaced yesterday.
    Shop charged me 250 installed. Seemed like something worth paying someone to do
    joseph_womack and Tripleconpanna like this.
  28. Oct 13, 2023 at 3:14 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I’m not sure if we’re are talking about the same thing. There’s now way a shop would have charged $250 to do what I did.
  29. Oct 13, 2023 at 3:15 PM
    litehedded
    It depends which one is bad. The center one has to have the whole dash come off
  30. Oct 13, 2023 at 3:19 PM
    Danny3737
    The one I replaced is on the drivers side and has 2 servo motors that controls 5 doors. I was able to do it without having to remove the dash, but it wasn’t easy.
