What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Jun 20, 2023 at 8:25 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Well crap!
    On the hunt for the OEM part 89413-0C021
  2. Jun 21, 2023 at 8:41 AM
    Tenny
    Tenny New Member
    2012 Silver Tundra
    Looking for any help on this...
    I installed an aftermarket Radio a couple months back. Write up of what I have:
    Let’s see all aftermarket head units installed
    Anyways, about a week ago the rear camera started having issues. Right after turning it on, it worked great. But after a few moments it'd fade to static. I just pulled the radio partially out and was looking to see if I had any loose connections. All connections are good and solid. I checked the ground (gave it another ground) and still static. When I unplug/replug the harness it works for a moment, but then it fades away after about 3 seconds. Anyone have any thoughts / ideas?
  3. Jun 21, 2023 at 12:07 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    R
    Start with replacing the camera
    Musicmasterd12 likes this.
  4. Jun 22, 2023 at 10:20 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Returned from our first road trip with the new-ish rig.
    Betty pulled the TT admirably, especially given the wicked headwinds we encountered on our first day... and above 10k feet as seen in the pictures
    Good Tundra.
  5. Jun 22, 2023 at 12:48 PM
    pyrite808
    pyrite808 Real TRD Pros are built not bought
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    Got my Alcan springs delivered! Went for ultimate beef with 2000lb rating since we recently got a tractor I’m planning on pulling around regularly (TYM 474C)B2D06436-F51D-483B-B888-A8F58421BF93.jpg
  6. Jun 23, 2023 at 6:13 AM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    How much of a lift are those going to create? I’d love to upgrade my OEM leafs but would prefer not lifting up the rear much, if at all.
  7. Jun 23, 2023 at 1:55 PM
    pyrite808
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    I asked for 0" additional lift since I have coachbuilder 3" shackles (1.75" of lift). Because they are custom you tell them what amount of lift/weight you'll be carrying etc. but beware they are pricey.
    They cost more than my falcon shocks but there aren't really any other options out there that would meet my weight needs plus the big names like OME, Ironman, Dobinsons are designed in Australia but made in China. Some will say 'but your bumpers are chinese made', true and they've served their purpose until I get a welder and make my own. Leafs are a much more critical component that will be put to the test regularly so followed the buy once cry once rule and these provide more peace of mind when I'm pulling the tractor or put on the camper shell + load up all of our gear.
    I know you didn't ask for all that but I'm sure some of you were wondering..
  8. Jun 23, 2023 at 3:23 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Why not ditch the shackles and ask for the springs to be +2" in addition to your weight specs?
  9. Jun 23, 2023 at 3:57 PM
    pyrite808
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    Thought about it and went over that with Lew the owner at Alcan, we both agreed I should keep the coachbuilder shackles. They are a quality product, if I were to ditch the ones I have I would just buy another coachbuilder set at 0" lift, and that's just unnecessary spending..
  10. Jun 25, 2023 at 12:23 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Well... Truck started throwing the P0441 and P0455 codes every few days again :mad:
    I had replaced the gas cap and air switch valve less than a year ago when the truck started throwing the same codes. However, at the time, I could not get an OE air switch valve from the dealer. So, I just grabbed one from a local parts store and threw it in. Problem solved, but turns out it would only be for a short while. Now, here we are again... same codes :censored:
    So this time I just ordered a new OE switch valve and a new OE vacuum regulator from a reasonably local dealer. Parts shipped and arrived in only 3 days!!!
    Part Number Part Name Price Quantity Total
    25860-0S020 2007-2020 Toyota Air Switch Valve $73.16 1 $73.16
    25860-0S010 2007-2020 Toyota Vacuum Regulator $39.38 1 $39.38
    Tonight, after finishing up w/my pups for the day, I pulled off the engine cover and performed the 5 minute swap of both parts. Seriously took longer to walk into the garage and find a 10mm and a 12mm wrench than it did install the 2 parts.
    Scan tool showed no pending codes after the install and a short drive, so I'm hoping that resolves the issue. :thumbsup:
    Next step would be the charcoal canister and that's $$$... Pardon the dust; engine bay needs some TLC :cool:
  11. Jun 25, 2023 at 5:08 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Replaced the front rotors and brakes. Also got them bedded in. Had them smoking pretty good. Warped the last set diving down 81 between Winchester and Radford. That stretch of road is hard on brakes. So is 64 between 81 and 295.
  12. Jun 25, 2023 at 6:06 AM
    Krewcial
    Krewcial So good with my rod, I make fish come!
    Don
    2010 DC (3UR-FE) & 2000 AC (2UZ-FE)
    -Kings 2.5’s shocks -JBA UCA -Wheelers front bumpstops -Torque air bags with Daystar air bag cradles -Alcans leaf’s +700 lbs 1” lift -Dobinson grease-able shackles -TRD front and rear sway bars -RCI Engine, Transmission/Transfer Case skid plate -RCI Catalytic Guard -RCI sliders -Magnum ICI RT series bumpers -Auxbeam 72W Amber 4" round spot off road lights -Morimoto XB LED headlights -Level 8 MK6 +12 offset 18" rims wrapped with 285/75/18R Falken AT3’s with TRD centercaps -TRD dual exhaust with black chrome tips -AFE Power Magnum FLOW Pro DRY S Air Filter -TRD air accelerator -WeatherTech floor mats -Aftermarket Sequoia Grill -MAX Modular bed rack with tonneau brackets -Diamondback HD tonneau -James Baroud Grand Raid XXL -OVS 270 awning -11” Alpine iLX-F511 media receiver
    I second Alcans. My situation was slightly different. I had CB +2’s on stock leaf’s. The stock leaf’s were flatten/ W shaped and I was not comfortable having a 35” full size spare that close to my shackles. The CB shackles are beefy and well build as @pyrite808 said.
    I ended up going with Alcan’s with 1” of lift and 700 lbs capacity to support my diamondback, bed rack, RTT, awning, bumper full size spare and all the other crap I take with me. Also I changed my shackles to dobinson’s with no lift but greaseable and added airbags/ daystar cradles.
    I couldn’t be happier with the results. Definitely a buy once cry once situation but the smile when you have no bed bounce on concrete highways and hauling a$$ on unpaved roads without feeling a thing is priceless.
    RJVA, Leek128, B.Ross and 4 others like this.
  13. Jun 25, 2023 at 7:34 AM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Can I ask, what type of pads do you run on? Organics are a pain in the butt for material build up on rotors causing 'warp' symptoms.
  14. Jun 25, 2023 at 3:43 PM
    TheBrit
    Mark
    Has anyone else noticed the large horizontal expanse of their dashboard, immediately below the windshield, flexing up and down when running off road?
  15. Jun 25, 2023 at 4:53 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I replaced a lower ball joint this weekend. The joint wasn't loose, but I pinched the boot and it started leaking grease when I swapped front diffs this spring.
    I'll try to post a how to thread on it elsewhere. O'Reilly's rental tools took everything apart, but I needed a different size sleeve to install the Moog part. HF expansion sleeve kit worked after I cut one of the cups down.
    Mountun Goat and 07 Tundie like this.
  16. Jun 25, 2023 at 5:24 PM
    chrisf111
    chrisf111 New Member
    Bad camera. Replacements are cheap on Amazon
  17. Jun 25, 2023 at 8:02 PM
    joseph_womack
    Joe
    Louisiana
    I beat on mine pretty hard offroad, I don't think I've ever noticed that happening, I'll look out for it next time
  18. Jun 26, 2023 at 4:48 AM
    TheBrit
    Mark
    *Bearing in mind that my 2wd trucks idea of offroad is beating it up a dirt road not rock crawling!
    joseph_womack[QUOTED] likes this.
  19. Jun 26, 2023 at 10:08 AM
    joseph_womack
    Joe
    Louisiana
    Hahaha I still go about 60 on forest service roads
  20. Jun 26, 2023 at 11:23 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I know I know, it's no FG without pictures but I don't care. When I bought my 07 last year, the truck was in great shape except for the carpet where there were multiple cigarette burns esp. on the drivers side. So today I watched a y/t video on how to repair and I gotta say I am very pleased with the outcome. I have multiple burns to do so the process I used seems pretty good going forward. I figure once the burns are covered up, and then a good shampooing and extraction I think they'll look acceptable.
  21. Jun 27, 2023 at 4:53 PM
    chrisf111
    Found some nice(r) running boards today on FB marketplace and swapped out the chrome ones that came with the truck. Pain in the ass to get them to mount on level and there are a few minor chips in the paint, but I think it's a huge upgrade.
  22. Jun 27, 2023 at 6:17 PM
    TheBrit
    Mark
    Speaking of running boards, I reversed mine up over a steep dirt bank today, thought the front bumper would ground out on the track but instead my drivers side grounded out going over the bank and she wouldn't go any further - the running board was buried under three inches of dirt! Surprisingly enough, after loading her up with work tools, she wasn't stuck and drove straight out - gravity probably helped out a lot, quite a lot!
  23. Jun 29, 2023 at 5:55 PM
    surffj62
    surffj62 New Member
    2011 DBL RW
    Loaded to the gills so these two could enjoy camp
  24. Jul 2, 2023 at 2:15 PM
    RJVA
    RJVA Former Lurker
    Richard
    Idaho
    2008 Tundra Silver DC 4.7 4x4
    OEM 18" wheels off a 2.5 gen 275/70/18 Falken Rubitrek A/T FabFour Redsteel front bumper with HF winch. Dobinsons IMS with 2.25" coils (610) JBA UCA's Iron Man +300lb rear leaf packs with Dobinsons IMS shocks ECGS bushing in front diff Black Oak Led Flood Pods. 40watt (x2) Black Oak 20" light bar. 100 watt OEM style rear bumper, black powder coat, added aux reverse leds. Stubby AM/FM antenna Century Camper Shell with Roof rack and bed mat
    I figured out how to load my square stern canoe solo today so I opted to throw the endro on the hitch carrier as well just to make sure there are no surprises when I'm ready to hit the trail. Okay, also I wanted to see how it looked with both on the truck.
  25. Jul 2, 2023 at 2:32 PM
    Shanet421
    San Diego,CA
    Update on this: I was able to locate an OEM sensor but am still waiting for it to arrive. I have in the meantime got an aftermarket sensor overnighted from Amazon and it seems to have cleared the trouble codes. I will be swapping for OEM when it decides to show up.
    Automatic Transmission Speed Sensor Compatible With 13-15 LX570/08-15 Land Cruiser/08-16 Sequoia TundraV85.7L Input Output 89413-0C021/89413-0C020/89413-20010 https://www.amazon.com/dp/B09K5CKCXB
    07 Tundie and joseph_womack like this.
  26. Jul 2, 2023 at 3:07 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
  27. Jul 2, 2023 at 7:09 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Picked up a Super 50 for a little noise. Now to wait for the exhaust shop to reopen after July 4th
  28. Jul 3, 2023 at 11:00 AM
    joseph_womack
    Joe
    Louisiana
    whered you get the white grille emblem? I painted mine black but its started to chip so looking for replacements
    20GR8 Super likes this.
  29. Jul 3, 2023 at 12:37 PM
    BoysandHisToys
    Central Virginia
    Plastidip
  30. Jul 3, 2023 at 5:57 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    I plastidipped mine white too and it’s been holding up.
