What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Apr 8, 2023 at 6:50 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Today, finished hanging the soft topper and gave the Tundra a bathPXL_20230409_014837858.jpg PXL_20230409_014830353.jpg
    D4x4TRD, TheBeast, Filthyphil and 8 others like this.
  2. Apr 9, 2023 at 3:47 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    How many miles did you have when you did spark plugs?
  3. Apr 9, 2023 at 4:06 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    I finally got around to taking off those ugly, factory Toyota running boards. Man, those things are hideous.
    D4x4TRD and Jorgesworld86 like this.
  4. Apr 9, 2023 at 6:47 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    2008 Double Cab 5.7L
    Just bought some aftermarket ones, probably gonna put them on next weekend. Only got them because the truck is a little high for my wife and kid to get in easily though, so I was more after function than looks.
    Tripleconpanna and Retroboy1989 like this.
  5. Apr 9, 2023 at 7:25 PM
    Retroboy1989
    Northern Utah
    I'd love to take mine off, but my wife uses them.
    D4x4TRD and Tripleconpanna like this.
  6. Apr 10, 2023 at 3:30 AM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    This is exactly what I heard from my wife and kids. I guess I will be looking for some aftermarket ones also. Just want something that tucks up closer to the truck. Suggestions?
  7. Apr 10, 2023 at 7:28 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Make em climb!
    My wife is 5'3 and has no issue getting in w/o boards. 2" level with +1" tires.
    My Mom with broken shoulder, she had to bring a collapsible stool.
    Only way I'm adding anything in the area is sliders.
    Sell your wife on sliders. Little grip-tape on the topside... Stilettos at your own risk, but I suppose that always goes without saying
    mayan, Tripleconpanna and 20GR8 Super like this.
  8. Apr 10, 2023 at 10:30 AM
    RJVA
    RJVA Former Lurker
    Richard
    Idaho
    2008 Tundra Silver DC 4.7 4x4
    OEM 18" wheels off a 2.5 gen 275/70/18 Falken Rubitrek A/T FabFour Redsteel front bumper with HF winch. Dobinsons IMS with 2.25" coils (610) JBA UCA's Iron Man +300lb rear leaf packs with Dobinsons IMS shocks ECGS bushing in front diff Black Oak Led Flood Pods. 40watt (x2) Black Oak 20" light bar. 100 watt OEM style rear bumper, black powder coat, added aux reverse leds. Stubby AM/FM antenna Century Camper Shell with Roof rack and bed mat
    I did the plugs shortly after I bought the truck with 150,000. I'm pretty sure they were the original plugs and they looked okay for being that old.
    joseph_womack[QUOTED] likes this.
  9. Apr 10, 2023 at 11:30 AM
    joseph_womack
    Joe
    Louisiana
    What’d you go back with? NGK Iridium?
  10. Apr 10, 2023 at 2:56 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Replaced the cabin filter :rasta:
    Ohannon7, chugs, 20GR8 Super and 3 others like this.
  11. Apr 10, 2023 at 10:19 PM
    joseph_womack
    Joe
    Louisiana
    Throttle body coolant bypass, decided to just replace the hose with some spare at the shop instead of using a plastic vacuum T fitting, routed around upper radiator hose so it wouldn't hit the belt. Also wrapped the hose in plastic conduit where it rubs on metal to keep it from rubbing through. Used rubber caps for carburetor block offs to close off the throttle body nipples.
    Yes I know its dirty... wheeling this weekend so no sense in getting everything clean :crapstorm:
  12. Apr 11, 2023 at 11:37 AM
    Front Runner - Jolo
    Front Runner - Jolo New Member
    Jolo
    Agoura Hills, CA
    2013 Super White Limited Crewmax
    Fuel Wheels, BF Goodrich KO2, spacer lift, shackle flip, air bags, Cab Rack, TRD Pro Grill, Alpharex Headlights
    Update: Got the Front Runner Outfitters Low Profile Slimline II cab rack installed. So far I've remounted my awning to the passenger's side using the Quick Release mounts, and added two rack handles to the driver's side. I switched out the stock wind deflector and replaced it with a full wind fairing. I have also mounted a 42L water tank as well as my Wolf Pack Pro using the new MKII brackets onto the bed rack. Chase and Ditch lights are now wired as well!
  13. Apr 11, 2023 at 12:51 PM
    rdbonds
    rdbonds New Member
    2021 SR5 4x4
    Any chance you have access to a tool (Autoenginuity, etc) that can read the live voltage off the O2 sensor? I ask since my quick search seems to indicate that P0031 can also be low voltage signal from the sensor. That CAN be due to a bad sensor, but can also be a bad wire, or from a simple exhaust leak.
    Here's a screen capture of one of my banks on a Lexus V8. The red line is the first (front) O2 sensor, and the blue is the rear one. The red one oscillates as the engine varies the mixture. Higher voltage is low O2 (rich) and lower voltage is higher O2 (lean). The 2nd one dampens out due to the cat (as the remaining oxygen is consumed in the catalyst). This graph is how it should look, but on my other bank the blue was flatlined low voltage due to a pinhole leak in the exhaust.
    20GR8 Super[QUOTED] likes this.
  14. Apr 11, 2023 at 8:04 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Nope! I was able to source the correct Denso sensor for $100 and will install this weekend to see if it gets rid of the issue.
  15. Apr 12, 2023 at 2:24 AM
    rdbonds
    rdbonds New Member
    2021 SR5 4x4
    Hopefully that solves your issue. If the issue remains, I'd humbly suggest checking the wiring and checking for small exhaust leaks.
    Cheers!
  16. Apr 12, 2023 at 7:20 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    Still waiting on rear bumper for Tundra, it got delayed in shipping.
    I did however pick up a new trail buddy (for my oldest son)…. 2015 jeep grand Cherokee 4x4 overland edition.
    I can push a button and it raises up a couple inches. Underneath is completely covered with shields for driving through brush I assume.
    It’s 4x4 and super nice inside, 137,000 miles, $13,000.
    my tundra is in the pic so hopefully I get a pass
    Edit: I tried to get a comparable Tacoma but they were either junk or $25,000.
  17. Apr 12, 2023 at 9:21 AM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    I put a few more miles on it and yeah, 5W/30 significantly quieted the engine. Do recommend.
    chugs, GSil[QUOTED] and omgboost like this.
  18. Apr 12, 2023 at 7:29 PM
    Retroboy1989
    Northern Utah
    I cannot say that I noticed a huge difference. But I don't regret the switch. I was more interested in the protection during hours of towing at 3000rpm. The owners manual hits at more viscosity for hard use.
    WVI and PhotoNerd[QUOTED] like this.
  19. Apr 12, 2023 at 7:31 PM
    Retroboy1989
    Northern Utah
  20. Apr 12, 2023 at 9:59 PM
    joseph_womack
    Joe
    Louisiana
    I used a red led bar (link attached) on my bedrack for a 3rd brake light, I just tapped into the brake light harness on the driver side taillight
    Nilight - TL-10 2PCS 16” 11 LED... https://www.amazon.com/dp/B07V7BF18S?ref=ppx_pop_mob_ap_share
    Retroboy1989[QUOTED] and Wynnded like this.
  21. Apr 13, 2023 at 11:06 AM
    Yinzer73
    Yinzer73 New Member
    Menifee, Ca
    2011 Tundra 5.7
    None yet but the list is growing
    Installed a new rear bumper as the existing was damaged from previous owner. Did not go with anything fancy yet, as I am still new to this truck. Just wanted to get something nicer than what I had on it. Next is the running boards as they have damage to them as well. I will post pic's soon.
  22. Apr 15, 2023 at 8:10 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Just completed a 1,400mi round trip to the Gulf (IL to FL) with my 2007 DC. 274k miles on the clock. Never missed a beat. Now to see about fixing that cruise control :rofl:
  23. Apr 15, 2023 at 2:10 PM
    PhotoNerd
    Tony
    Waterford, CT
    Installed a gadget to show the front camera automatically after I switch out of reverse:
    Basically you wire it between your cameras and your aftermarket head unit. You run the reversing wire into the gadget, and the gadget sends the reverse signal to the head unit when you select any camera. After switching out of reverse it shows the forward camera for a few seconds.
    Two other cameras can the triggered with 12v. They're designed to be triggered by turn signals but I intend to install a camera on top of my tailgate for when I'm backing up with the tailgate down.
    It has a wireless remote to manually show any of up to 4 cameras. I only have front and rear at the moment. I stuck it on the steering column.
    tyr0981, Mountun Goat, MTRock and 7 others like this.
  24. Apr 15, 2023 at 2:45 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    can you post a photo of your front mounted camera and a photo of the head unit facing forward?
    when you press F, does it automatically override what’s going on on the head unit? Then how do you get rid of it/return your screen to normal.
    I’m so interested in a front facing camera that can be controlled at will.
  25. Apr 15, 2023 at 4:18 PM
    Tripleconpanna
    This is what most of us went with....
    2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
    .... Crap, I just noticed you're running an '07, so you might want to message Lou @TundraTex and see if he has a setup now for the Gen 2s; if he does, his equipment is reliable and customer service is spot on!
    Ohannon7 and 07 Tundie[QUOTED] like this.
  26. Apr 15, 2023 at 4:35 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    I’ve commented on his posts and tagged him asking if he would ever made one for 07-13s and got no reply.
  27. Apr 15, 2023 at 6:19 PM
    Tripleconpanna
    I assume you're meaning in the past; if so, that's weird cuz he's always been responsive w/me... Maybe try sending him a PM :notsure:, but yeah if you've msg'd him in the past and got nothing, I understand blowing my recommendation off. I don't remember seeing anything w/the Gen2s ever coming out, so maybe not...
    Maybe that other set up will prove to be reliable... Seems to be much cheaper as well, but I get a little nervous about quality when the price seems too good.
    Good luck on finding something that works for you though :thumbsup:
  28. Apr 15, 2023 at 6:29 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    Installed 3rd Gen type tail lights the other day.
  29. Apr 15, 2023 at 6:32 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    :monocle: Hmmm, those do not look bad; more info/link?
    TheBeast, aelarson and 20GR8 Super like this.
  30. Apr 15, 2023 at 6:35 PM
    BoysandHisToys
    Central Virginia
    there are a couple “brands” of them on Amazon for around $280. I tried one that was $230. They’re now down to $220. Looked to be identical except it had a little bit better mounting for the hyperflash resistor IMO.
    Shocklight LED Tail Lights Rear Lights For Tundra 2007 - 2013 with Running & Brake & Turn Signal & Reverse Light Replacement Black Housing Smoked Lens https://www.amazon.com/dp/B0BJVH69MZ
    Mountun Goat, kparrow, chugs and 2 others like this.
