What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Mar 23, 2023 at 10:04 AM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Last night I was playing with OBD Fusion to try and get TPMS data which was to no avail.
    However, I could read this which I took when the steering wheel was dead nuts level.
    Any thoughts on why truck is not complaining about this? The only way I can imagine it got this far off would be if someone decoupled the shaft at the rack or for some reason had the steering column out.
    When at Zero, we have this...
    And ya, you can look right at the evap thermistor!
    Mountun Goat likes this.
  2. Mar 24, 2023 at 3:22 PM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    it is not fun. there are 4 screws behind the cup holder, which can be removed by pushing the plastic bump stops on the sides of the slide out portion. that will loosen the cup holder trim. to get to those blanks you will need to remove the trim above that too, which requires starting at the drivers door, removing bottom panel below steering wheel, then center panel ashtray and trim piece. Then you can unscrew and pop out that panel you are after. there are hidden screws that hold stuff in place.
    https://youtu.be/oDOz6tVkP88
    KeepOnTruckin[QUOTED] likes this.
  3. Mar 24, 2023 at 4:37 PM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    I like them.
    Yep, the led lights light up either orange OR white depending on how you wire them.
    If you do the ground and use the pretty descent fuse box tap they include AND connect a little wire from 1 side to the other then they are orange. If you don’t, they are white. I actually almost left it white but then went orange. Either looks nice imo.
    it’s a great upgrade for the money bc it makes you forget your truck is getting old lol
    Btw I had the led bulbs turned 180* the wrong way and they work well now. They are not the most amazing in the world but good enough and the right price point for my budget.
  4. Mar 24, 2023 at 8:08 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Installed my Scangauge mount made by Spiker Engineering that I bought from Opt Off-road. Also picked the truck up from the gear shop since we don’t mess with gears at the shop I work at, pinion bearing fixed and truck runs like a top
    Mountun Goat, aelarson, WVI and 4 others like this.
  5. Mar 25, 2023 at 7:22 PM
    Tundrex81
    Tundrex81 New Member
    Las Vegas
    07 Crewmax Black
    Replaced my front wheel bearing hubs. Easy as cake. Its been quite a while since I've had to do any repairs on my truck that were this involved. Man I love my CM!
  6. Mar 25, 2023 at 8:09 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    @Tundrex81 what brand did you go with? Last I looked out of curiosity there wasn't a good complete hub + bearing assembly replacement. But I'm used to using Timken and SKF bearings.
  7. Mar 26, 2023 at 6:57 AM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    Scraped my garage wall. I have to make a very tight and narrow turn to pull into the garage and I decided to take a slightly different approach. I scrape the corner about once per year, but each time I do, it reminds me to diligently check my side mirrors.
    GooGone Latex Paint Cleanup works great. It still needed about 30 minutes of elbow grease but it was impossible without the chemicals.
    Let's hope this is the last time I do this!
    Ohannon7, WVI, joseph_womack and 4 others like this.
  8. Mar 26, 2023 at 7:03 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    Maybe invest in something like this?
    Rubber Bond Wall Corner Guard Edge Protector, 2x2x36 inch Baby Proofing Corner Guards | Self-Adhesive Furniture Edge Strips for Home & Office (5 Pack, Black) https://www.amazon.com/dp/B0BNJTY7XH
    omgboost likes this.
  9. Mar 26, 2023 at 11:52 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
  10. Mar 26, 2023 at 12:13 PM
    Nemesis
    Nemesis New Member
    What the heck?
    Oh, I need to see a vid of this tight/narrow turn. No, not a pic but a vid of you attempting to park the TT.
    Ohannon7 likes this.
  11. Mar 26, 2023 at 12:55 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    Drove it! haha.
    I got back from 3 weeks in Vegas this morning at 3am and she fired right up. It was a relief! 200 miles on the new engine so far.
    Ohannon7, Tripleconpanna, WVI and 2 others like this.
  12. Mar 26, 2023 at 4:46 PM
    joseph_womack
    Joe
    Louisiana
    Don’t snip on both ends of the cotter pin, snip on the side to the truck, the other side wraps up and over the end of the threaded stud
    Wynnded and 07 Tundie like this.
  13. Mar 26, 2023 at 7:04 PM
    chrisf111
    chrisf111 New Member
    Tell me more about the little wire needed to drl orange instead of white. I have some alpharex pros that I would like to have orange instead of white.
  14. Mar 26, 2023 at 9:38 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Did some rendering work added front bumper and rrw wheels.
    Pnoy_toy, D4x4TRD, WVI and 3 others like this.
  15. Mar 26, 2023 at 9:50 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    What front bumper is that?
  16. Mar 26, 2023 at 10:29 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    What front bumper is that?[/QUOTE]
    It's the C4 fab overland bumper.
    joseph_womack likes this.
  17. Mar 27, 2023 at 4:30 AM
    joseph_womack
    Joe
    Louisiana
  18. Mar 27, 2023 at 5:39 AM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Mine is the same way. I discovered it when I replaced my rack bushings and needed to check 0° and not +/- 360° before I reconnected the shaft.
    Edit:
    The sensor is in the column itself, not the rack.
    The only "fix" I could contrive was to disconnect both the wheel and the rack, line it up to 0°, then reassemble, then get an alignment. Chances are good it still wouldn't be dead 0° unless the spline indexing was dead on.
    I decided that it must be normal and left it alone.
  19. Mar 27, 2023 at 7:39 AM
    KeepOnTruckin
    Randy
    Thanks for the reply. I know steering gears and R&Ps need to be centered as the gears are cut to have zero to near zero lash when centered so they drive well and I'm pretty sure my rack is centered.
    It's had two prior owners, the last guy who is a co-worker and he grabbed it with 25k mi and made no mention of rack replacement.
    I suppose someone could have had the dash apart to create this if they dropped the column? wtf knows...
    As stated, the time I see it being an issue is when it matters and your skidding down the road sideways... weeeeeeeeee
  20. Mar 27, 2023 at 11:38 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
    Rendered the sequoia headlight.
  21. Mar 27, 2023 at 1:21 PM
    koday0196
    koday0196 New Member
    I finally got rid of the annoying spare tire brackets on Sunday. I looked through multiple threads related to fitting a larger tire under the truck be in the forum, and it sounded like it is a pain in the ass experience, but it wasn’t bad at all. I spent about an hour drilling through the pivots and they come off pretty easily. I considered sawing the brackets off, but I wasn’t too comfortable with the idea of using the in such a limited space.
  22. Mar 28, 2023 at 4:48 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    hey Chris.
    Alpharex recently posted a really good step by step how-to. The link is below for full pictures but here is the one with that DRL orange you are lookin for…
    https://alpharexusa.com/installatio...quoia-headlights-with-sequential-turn-signal/
  23. Mar 28, 2023 at 12:10 PM
    apwisher
    apwisher New Member
    Everett, WA
    Which is right, the text (wrong descriptions) or the image? which is the vertical adjustment?
  24. Mar 28, 2023 at 1:32 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    If I remember correctly the vertical adjustment is the lower dial
    I recall not getting much if any horizontal adjustments from the other dial
  25. Mar 28, 2023 at 5:06 PM
    joseph_womack
    Joe
    Louisiana
    Lower dial is vertical, a screwdriver can stick through that channel to let you turn the bolt if you can’t get a wrench or ratchet on it… I don’t think there is any horizontal adjustment if I remember right
  26. Mar 28, 2023 at 5:19 PM
    chrisf111
    Both adjusters are present, the horizontal doesn't do much though. The screwdriver tip is key. Lots of people think you have to take the headlight out to access the vertical adjustment, but you can do it with them installed with a long screwdriver.
    joseph_womack[QUOTED] likes this.
  27. Mar 29, 2023 at 4:50 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    Sooooo, JUST the tip?
    :dancingbacon:
    20GR8 Super and joseph_womack like this.
  28. Mar 29, 2023 at 5:37 AM
    joseph_womack
    Joe
    Louisiana
    I actually just took my milwaukee powered ratchet and stuck it down there and held the trigger and I was done in like 2 minutes tops
    Ohannon7 and 20GR8 Super like this.
  29. Mar 29, 2023 at 6:00 AM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Dreaded CEL came on yesterday afternoon throwing P0031 code. I think I have narrowed it down to the A/F sensor (Oxygen sensor), specifically the heating element of it, on the drivers side before the cat. Looks like an extremely straight forward swap for a new one. Anyone got any experience or done one of these? I'm thinking of going with the denso sensor instead of getting it from the stealership and saving $100.
  30. Mar 29, 2023 at 8:20 AM
    joseph_womack
    Joe
    Louisiana
    Denso is good, you’ll need the O2 sensor tool, you can rent it from Autozone or O’Reillys, larger socket with a split in it for the wires on top of the sensor
