What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Jan 13, 2023 at 11:58 PM
    Nemesis
    Nemesis New Member
    Installed dual USB ports and replaced cig port with Dual USB + PD charger (w/manual on/off sensor).
  2. Jan 14, 2023 at 12:19 AM
    Nemesis
    Nemesis New Member
    Boo! They don't make them for the 2nd Gens.
  3. Jan 14, 2023 at 12:59 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
  4. Jan 14, 2023 at 3:16 AM
    CMikeB
    CMikeB New Member
    I started the wrap with a spot of Super Glue Gel on the underside of the grab handles and ended the wrap the same way. They've held up for several years.Resized_20230114_060555.jpg Resized_20230114_060608.jpg Resized_20230114_060634.jpg
    B.Ross, MTRock, Mountun Goat and 4 others like this.
  5. Jan 14, 2023 at 6:48 AM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    There is a simple warp method out there that locks the ends. I think there might even be a diy on this site. 99% reversible. The 1% is because of the color transfer the paracord leaves behind.
    TheBrit likes this.
  6. Jan 14, 2023 at 7:25 AM
    Retroboy1989
    Northern Utah
    Drove it on a few trips throughout the day. Definitely still burping some air as the level dropped in the reservoir. I really need to invest in one of those burping funnel deals.
    I did realize that I forgot to drain the transmission warmer. I guess this is why the coolant change interval drops to 5 years after the original fill, no way to get it all.
  7. Jan 14, 2023 at 7:49 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I used a method which is easily and quickly removed for use as needed. I have since shortened the tails, but they have been a nice little upgrade.
    Also looks nice and produces a nice ridge for added comfort and grip.
    https://youtu.be/9aprLqv2GqQ
  8. Jan 14, 2023 at 1:41 PM
    Retroboy1989
    Northern Utah
    Sam's club has a deal running on M1 5w30. Got enough to do both of these oil hogs.
    Also jumping to to 5w30. Going against spec for the first time in my life.
    Edit: What is up with my truck? It took almost 9 quarts to bring up to the full line on the dipstick. 8 quarts only got it half way between full and add.
    Prostar 190, B.Ross, dondino and 5 others like this.
  9. Jan 14, 2023 at 4:53 PM
    ToolCat
    ToolCat New Member
    Greg
    I've always used 5W-30!
    The 0W-20 is to maximize fuel economy, for what, a 0.2 mpg increase?
    In my opinion, for an engine with a lot of miles (and thus likely wear between moving parts), a slightly thicker oil makes sense, as the film strength is stronger to fill larger gaps.
    Now if you live in upper Alaska or similar, might want to stick with the 0W....
    ToolCat
    CMikeB and Danny3737 like this.
  10. Jan 14, 2023 at 7:26 PM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    While fuel economy and emissions might figure highly into Toyota's recommendations for a 20 weight oil does it not give you any concern that one reason they don't recommend a 30 weight oil is because it might be too viscous to properly service some of those hard to reach spots that modern engines are littered with?
    I'm all for jacking with the winter grades but if oil companies were concerned about using lower viscosity oil in older engines then it strikes me as odd that they'd bother making 20 weight oils specifically for older high mileage engines.
    I don't know what the previous owner used but since the 80k when I bought her, mine's had nothing but 0w-20 long life oil and she's rapidly approaching 250k with no smoking, oil usage or grumbling guts, make of that what you will.
  11. Jan 14, 2023 at 8:00 PM
    Tundra1D6
    Just changed my 08’s oils and filter today. She took the required 7.5 quarts.
    From what I gather 07-09’s take 7.5 and 10-13’s onto 2.5gens(14-21) take more. Things get strange with these mid year refreshes.
    Running for the first time 5w30. We shall see but so far the timing chains are a lot quieter.
    TRD oil filter with Amsoil signature series fully synthetic. Lots of $ every 5k. But still less expensive than an engine!
    CMikeB and Retroboy1989[QUOTED] like this.
  12. Jan 14, 2023 at 9:48 PM
    13BrownTundra
    13BrownTundra New Member
    2021 SR Double Cab
    Added new AGP rims. The old rims were missing all of the hub covers since the tire shop broke three out of four of them…
    B.Ross, Filthyphil, Dreyg and 5 others like this.
  13. Jan 15, 2023 at 2:47 PM
    Retroboy1989
    Northern Utah
    My reasons are my own.
    Kidding, here is what it came down to, after stressing about it myself.
    - This bit in the owner's manual. I tow in the summer. I started worrying about how well that w20 was holding up as the hours went by at 3000rpm.
    - It is well documented on this site that this engine is only spec'd for 0w20 in the good ole USofA. Probably Canada?
    - Antidotal evidence of a quieter valvetrain. If these engines have a weak spot, which is relative, it's the valvetrain. Again, all relative.
    I still question all of it just it a bit, however.
    ToolCat and TheBrit[QUOTED] like this.
  14. Jan 15, 2023 at 7:50 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Pulled a nice old lady with a disabled vehicle out of a turn lane, on a fairly major parkway, just under a mile to her house and made $50 in the process :yes:. Told her I didn't want or need her money then I found it in the back of my truck when I got home and was packing up my rope.
    B.Ross, Ricos, joseph_womack and 2 others like this.
  15. Jan 16, 2023 at 12:38 AM
    Chrslefty
    Chrslefty New Member
    08 dubble cab
  16. Jan 16, 2023 at 10:26 AM
    Retroboy1989
    Northern Utah
  17. Jan 16, 2023 at 11:44 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I put a new battery in my key fob. Can't believe I had the right size laying around in the junk drawer.
  18. Jan 16, 2023 at 3:18 PM
    Chrslefty
    08 dubble cab
    Thats weird it's from their official site.
  19. Jan 19, 2023 at 5:34 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Gave her a bath in the rain, then drove back up the mountain to find mud the consistency you would see from a freshman who ate $30 worth of Taco Bell and drank a case of Miller Lite.
    dondino, Mountun Goat, WVI and 6 others like this.
  20. Jan 19, 2023 at 5:37 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    Lubricated the tailgate hinges because it almost wouldn't open... There might be a better way to do this but I sprayed the parts I couldn't reach with garage door lubricant and covered everything I could reach with white lithium grease. At least for the time being the tailgate latch opens easily and reliably.
    E1C4AEFC-3896-4D20-86F8-7BDFAA804638.jpg 3444D481-2A6B-405C-A85B-B23DC12BE323.jpg
    chugs, dondino, Mountun Goat and 6 others like this.
  21. Jan 19, 2023 at 6:14 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    0W20 oil change and remounted my rear sway bar... Been 3 months since I removed it, due to my accident
    dondino, WVI and omgboost like this.
  22. Jan 19, 2023 at 6:38 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    HighwayProducts bedslide showed up. Easy install.
    3/4 pull/1200lbs
    more bed porn to come.....
    chugs, MTRock, Pnoy_toy and 9 others like this.
  23. Jan 21, 2023 at 9:43 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Got it appraised at Carmax. Gonna let it go.
  24. Jan 22, 2023 at 3:52 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Don’t sell it to Carmax, you’ll make up to $6K more selling it on your own.
    chugs likes this.
  25. Jan 22, 2023 at 5:50 AM
    LuvBigBluz
    LuvBigBluz New Member
    Tina
    Long Beach, CA
    2008 Blue Sequoia
    18 x 9.5 Black Rhino Oceano wheels 285/65/18 Falken Wildpeak tires 2.5" Dobinsons springs - front & rear Bilstein 5100 shocks all around
    Does anyone know if I can fit an OEM Tundra front bumper on a 2nd gen Sequoia? I like the look of the Tundra bumper better. Just not sure if I can get it to fit properly. Thanks!
  26. Jan 22, 2023 at 6:59 AM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    What are you getting offered for a platinum? im a little curious myself.
  27. Jan 22, 2023 at 7:38 AM
    zeekevin
    zeekevin New Member
    the bumper will fit. But you will need to get the tundra grill also
    chugs likes this.
  28. Jan 22, 2023 at 8:05 PM
    Tundra Fan
    Toby
    Yeah, thats about what I figure too, but I'm really not feeling messing with it. I am gonna pull off the Snugtop and sell that on my own though.
    They offered me 21,500. Got dinged on my cracked windshield and tear in headliner. They didn't care about the broken driver mirror or the exhaust mount which makes an obnoxious rattle at idle.
    chugs, omgboost and Blang805[QUOTED] like this.
  29. Jan 22, 2023 at 8:13 PM
    Tundra Fan
    Toby
    Might have been a little higher if it was 4WD, but if it was, I probably wouldn't be getting rid of it.
  30. Jan 22, 2023 at 8:20 PM
    Blang805
    Blang805 New Member
    Build in Signature
    True. Ive been tossing the idea around of ditching the CM and getting a DCLB 4x4 for the bed space and ability to sleep two in the back comfortably.
    TG705 likes this.
