What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Nov 10, 2022 at 6:01 AM
    zeekevin
    zeekevin New Member
    Looks like all this tech did was just set the toe setting on the tie rods. He didn’t even bother adjusting your cam tabs, I would get a refund
  2. Nov 10, 2022 at 6:09 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I think this was a fluke. At 205k it was still running smooth, holding the same fuel economy as it had at 126k when I bought it and not using oil.
    My best guess, without tearing the engine down, is that the alternator caused a voltage spike when it failed and fried something in the ECM. There were multiple codes for low and hi voltage and for the crankshaft position and camshaft position sensors, but no misfire codes. There were no abnormal sounds or vibrations when it died on the street. It was just suddenly not running anymore and it wouldn't even engage the starter in neutral or park until I turned the headlights off. Then it just sounded like a dead alternator and undercharged battery.
    Maybe it caused an injector to hold open and fill the cylinder with fuel which hydro-locked the cylinder and broke the rod when the engine started. But that's just speculation and I'm not certain that sequence of events is even feasible.
    I recharged the battery and tried starting it when I got it home to troubleshoot the alternator. It turned over really slowly and smelled like hot plastic. I disconnected the alternator power wire and rectifier plug. It turned over normally and started, but idled really slowly and rough with some noise that I thought was the valvetrain. It quickly died, but didn't produce any trouble codes.
    I did a compression test on the front two cylinders to confirm that it hadn't jumped timing. Both were at 180 psi so I didn't pull any other plugs or check any other cylinders.
    I decided that there were two issues and fixing the alternator first would make finding the second easier. Bad weather was on the way so while I was changing the alternator I changed the oil and filter while the ground was dry. The next day I confirmed that it was full of oil on the dipstick then started it. The phrase "there arose such a clatter" seem to best describe what happened next.
    The hole is actually in the upper oil pan just behind the motor mount on the driver side.
    Yeah. It's 7.9 quarts (7.4 liters). I typed the wrong number, but put it the right amount.
    I could change the engine and sort out everything else myself, but I'd have to do it in the driveway and winter weather is coming soon.
    I've got no interest in doing that job in the snow and it doesn't make any sense to pay someone else to do it. I'm cutting my losses and replacing the truck. I'll sell it as-is to someone who can fix it and get another Tundra with fewer miles. I'll just have to pull all of my accessories off before I sell it.
  3. Nov 10, 2022 at 6:22 AM
    careyrob
    Carey
    Massachusetts
    Good alignment shops and mechanics refer to that derisively as a "toe-n-go" alignment. It's a pretty common standard practice at all of the large national/regional tire and alignment shops unless they somehow hire someone with some intelligence and a conscience. Most of the alignment techs out there aren't trained any better than the guy in the grease pit at the lube shop.
    Ohannon7 and joseph_womack like this.
  4. Nov 10, 2022 at 10:46 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    Thx for the confirmation guys, I appreciate it.
    I am in the process of trying to find a shop around me.
    North Tampa area.
    :spending:
  5. Nov 10, 2022 at 11:02 AM
    @TampaRD Pro do you have any shop recommendations?
    Ohannon7[QUOTED] likes this.
  6. Nov 10, 2022 at 11:32 AM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    I purchased the Lifetime Alignment from Firestone out in Brandon for my original alignment after installing the Coachbuilder TRD Pro Kit, just so I could go in and get it checked out occasionally after wheeling. My long time tire/alignment guy is Gene at Weaver's Tire & Automotive on 60 in Brandon, he re-checked it after installing the Toyo 35's and after I had 5000 miles on them for a rotation. He's a good trustworthy merchant, does a lot of lifted trucks and has handled all the tire needs of my various 4WD vehicles for the last 35 years.
    Weaver's Automotive
    310 W Brandon Blvd, Brandon, FL 33511
    (813) 685-2906
  7. Nov 10, 2022 at 11:42 AM
    Thank you! @Ohannon7 here is an option.
    Ohannon7 likes this.
  8. Nov 10, 2022 at 3:05 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    They did what many shops do, set the toe and go! Crazy how many shops cant perform a real alignment these days. Yes, find a font end shop or 4wd shop and they should be able to do it right.
  9. Nov 10, 2022 at 5:25 PM
    Skew12
    Skew12 New Member
    2010 Black Rock Warrior
    what size wheels/offset/tires are you running? Thinking about getting the CB tie rods when I redo my suspension.
  10. Nov 10, 2022 at 5:50 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Well the fight is nearly over finished up the Total Chaos Cam tabs, couldn't get LCA's from Toyota so ended up getting some from O'reillys which got :censored: around on that and they gave me two different ones. One of which looks weird and had to stretch the pocket for sway link to drop in since it was to small. Removing the sway bar to do OEM bushings and links on of the sway bar bolts decided it liked the nut inside frame and broke it loose, so it turned into a frame surgery to get it fixed. I noticed the drivers side tie rod nut to be loose and then working on the passenger side I bumped the rod and it just came apart :censored: Leschwab aligned it before I left on my trip out here from south Oregon to north Washington and I toke my father to Olympia for surgery on the super twisty 101 to think the whole time it was hanging on by two threads. :eek2: But finished up and got everything back together hoping to have a full alignment done tomorrow by Toyota.
    928EBBB1-326D-4492-A31F-2B084DD9E11D.jpg 0ACC068F-27AC-4E69-B8F9-66C183293E4B.jpg
  11. Nov 11, 2022 at 7:46 AM
    BEDINTRUDER
    BEDINTRUDER New Member
    Dom
    OHIO
    2011 Tundra RockWarrior (SOLD) 2018 Tundra Limited
    Nothing special but finally got around to putting the factory tow hooks on. Had them sand blasted and painted. Oil changed, tires rotated, new spare tire mounted and left rear wheel bearing replaced (128k). Ready to go for the weekend trip. (Waiting on someone to run a good BF sale so i can get rid of these shitty fog lights)
  12. Nov 11, 2022 at 7:57 AM
    @memario1214
    joseph_womack likes this.
  13. Nov 11, 2022 at 8:05 AM
    careyrob
    Carey
    Massachusetts
    Yeah. Mine did that too.
    NueveTundra[QUOTED] likes this.
  14. Nov 11, 2022 at 8:05 AM
    Jorgesworld86
    Jorgesworld86 New Member
    Orange County,CA
    2013 Tundra Limited Rock Warrior
    Same here.
    NueveTundra likes this.
  15. Nov 11, 2022 at 8:10 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    6” ProComp lift.
    17x8.5 +10 wheels on 37x13.5.
    Black rhino stadium
    Cooper discovery sst pro tires
    Skew12[QUOTED] likes this.
  16. Nov 11, 2022 at 10:10 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Keep an eye on my postings and/or the Hotshot Offroad website... I'll have something for ya :cool:
    joseph_womack and Tripleconpanna like this.
  17. Nov 11, 2022 at 2:30 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Tundra234[QUOTED] likes this.
  18. Nov 12, 2022 at 4:47 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    I notice you still have your sway bar on.
    I took my swaybar off.
    It seems to drive better but idk
    :anonymous:
  19. Nov 12, 2022 at 8:15 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Took the summer air out of my tires and refilled with winter air.
    In all seriousness, make sure your spare tire is aired up. And that the chain mechanism isn't all rusted.
    WVI, chugs, omgboost and 7 others like this.
  20. Nov 12, 2022 at 11:21 AM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    Rust treatment to prepare for Winter. Last week I powerwashed everything. Today I treated any surface rust with Corroseal. Then I sprayed the frame and any non-exhaust rustable parts with Fluid Film Black (5 cans).
    Up on 4 ramps...
    Before/after of the rear diff (though it's more about protecting the frame):
    The fluid film stops any existing rust and protects the surface from water and salt that would start new rust. You're supposed to re-apply it every year.
    tnbndr, Marcstryd, D4x4TRD and 14 others like this.
  21. Nov 12, 2022 at 6:04 PM
    Skew12
    Skew12 New Member
    Thanks bud.
  22. Nov 13, 2022 at 6:47 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    That sounds about right.
    If you want something done correctly....
    joseph_womack and 07DCLimited like this.
  23. Nov 13, 2022 at 10:52 AM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    Back on the 7th I ordered a reman’d longblock.
    4-8 week lead time.
    joseph_womack, WVI and Tripleconpanna like this.
  24. Nov 13, 2022 at 10:55 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    If you don't mind me asking, just out of curiosity, what did that end up setting you back given our current inflated price trend??
    Filthyphil likes this.
  25. Nov 13, 2022 at 1:03 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    It’s a 4.7L 2UZFE but $4377.67.
  26. Nov 13, 2022 at 5:17 PM
    joseph_womack
    Joe
    Louisiana
    couldn't get your current block resurfaced at a local shop? or didn't want to?
  27. Nov 13, 2022 at 5:31 PM
    Tripleconpanna
    Really doesn't seem that bad given the current market
  28. Nov 13, 2022 at 6:46 PM
    chrisf111
    chrisf111 New Member
    North Tampa checking in. The Toy House on 301 is family owned for generations and always do good for me.
  29. Nov 14, 2022 at 11:50 AM
    careyrob
    Carey
    Massachusetts
    I looked at a few used trucks here in the North East with 100k miles. The rust made me decided to replace my 5.7 that recently threw a rod instead of getting a different truck. I'm keeping my mostly rust-free truck with 205k.
    In a few weeks I'll swap in a used 5.7 with 44k miles. I'll post pictures of the carnage in the old engine after I finish the swap.
    By now I've done so many mods that swapping the engine will likely take less time than moving the mods to a different truck
  30. Nov 14, 2022 at 11:50 AM
    careyrob
    Carey
    Massachusetts
    5.7 with 44k miles: $6,800 :eek2:
