What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Sep 27, 2022 at 5:42 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    Washed the truck. Drove home from North Carolina last night. I was up there with my dad doing some maintenance and some modifications to my truck for the past few days.. I'll have to take some photos and make another post tomorrow.
  2. Sep 27, 2022 at 6:04 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Got the drivers side down so I can install the ECGS bushing, as well as R&R the UCA,
    As well, rebuilt the McPherson's,
    KYB Mono Max..
    Hopefully the bushing tomorrow and all the parts put back together, then all to the passenger side Thursday.
    On Edit: Noticed a bad seal on the backside of the hub assembly, and after messing with the hub, I could detect a "click" when I would rotate the lug s....so I ordered new TRQ wheel bearing/hubs.
  3. Sep 28, 2022 at 6:50 AM
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    Replaced and installed a new battery.
    Finally, after 10 years, my stock Toyota 84-month battery took a dirt nap. WOW!
    I have had great results with Duralast Gold batteries in the past, so I went that route. Time will tell.
    O.S.T.
    MTRock, WVI, NueveTundra and 4 others like this.
  4. Sep 28, 2022 at 6:56 AM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    That's great. Toyota batteries get alot of hate on here.
  5. Sep 28, 2022 at 8:49 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I just topped off my 10 year old battery with distilled water. Still getting 13.4v when running. Checking for proper water level in lead/acid batteries as well as keeping terminals clean and tight is key to longevity.
    https://www.usbattery.com/know-batterys-water-fill-level/
    MTRock, WVI, NueveTundra and 2 others like this.
  6. Sep 28, 2022 at 8:59 AM
    0.S.T.
    0.S.T. New Member
    EAST COAST
    Yep, that's the secret for sure. I did the same. (but, got lazy and used tap water, but still...)
    O.S.T.
    NueveTundra likes this.
  7. Sep 28, 2022 at 11:15 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Update on the Weileite window moldings. Free replacements arrived within a couple of days. Fit and finish on this set is 100% better. They fit like OEM did, they are long enough, and the rear rubber on the back windows fits snugly under the trim in the back which it didn’t on the original replacement set. Time will tell how these hold up to the elements but I’m happy with the replacements and they were free due to lifetime warranty on them. If they fail again, I will go OEM Toyota but these should do for at least another year.
    F92C1860-0F3C-4915-9D3E-0791AB1DEB9D.jpg 3F601357-CA54-4890-BC08-60B218AF1BFF.jpg B80E9AE4-4F79-4E20-B80F-307152752891.jpg 5C9F3D8B-E328-4172-9440-9B7623CDCD9F.jpg 91D96515-A434-4635-AEBA-C0195578CA0A.jpg
    ACDC2ZZTop, MTRock, WVI and 5 others like this.
  8. Sep 28, 2022 at 11:27 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Agreed, wouldn't be surprised if they crapped out early. Feel like "cheap" rubber vs the OEM but hey....the replacements were free and of all the parts on our trucks, this is probably the easiest to swap because it requires no tools and takes about 5 minutes for all 4. Time will tell for sure
  9. Sep 28, 2022 at 1:09 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I wonder if I can use some of those back to black or ceramic trim restorer to bring it back to original color and add some UV protection.
  10. Sep 28, 2022 at 1:35 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I'm sure it wouldn't hurt but depends on the product. The OEM was more of a plastic type than the rubber that these are. I replaced them originally because the molded in retainer clips that hold it to the center column broke off and they had at some point been glued by the previous owner. They came loose and so I had to replace the moldings. I replaced them with this "budget" brand and they only lasted a year before warping in the sun but they replaced for free. These are the replacements. I'm not confident they will last as long as OEM did (approx 11yrs) but hope they last longer than a year that the first set did. Will be replacing with Toyota OEM next time around
    NueveTundra and omgboost[QUOTED] like this.
  11. Sep 28, 2022 at 4:38 PM
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    Today I installed my new Supreme Suspensions 1.75” lift shackles and new CB rear leaf spring bushings.
    All went smooth with the torch, sawz-all, and pneumatic chisel. :muscleflexing:
  12. Sep 28, 2022 at 6:15 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    Not today, but this week I went up to my folks place in North Carolina and my dad and I did some stuff to my truck.
    We made our own auxiliary power kit and relay block and mounted it to a sheet of steel. Secured that to my fuse box and did a bunch of wiring.
    Wired up my fog lights (finally), my raptor lights, and a button for my garage door opener with AirOnBoard switches.
    Before wiring up my fogs, we removed the front bumper and installed a CoachBuilder shim kit to push the front bumper forward half an inch. It definitely makes a world of difference with the 2014-2021 bumper installed on an 07-13.
    Replaced my serpentine belt with a Continental one.
    Then we went to install a transmission thermostat, so that I can run lines to an AT cooler, but the first bolt snapped off and we decided it'd probably be best not to proceed while I was 160 miles from home..
    Instead, we decided to replace the CarQuest brake pads (front and rear) that have been on my truck since I bought it 5 years ago with OEM ones.
    I'm going to remove the carbon fiber vinyl in my truck and paint the inside black.
    Got a lot goin on...
    Today, I removed the running boards on my truck and have been prepping them for Raptor liner.
    D4x4TRD, Peeeheeuuu, AZEric and 11 others like this.
  13. Sep 29, 2022 at 12:41 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    Just got done installing some Kicker KSC 2 3/4” tweeters in the dash. I replaced my factory door speakers and head unit back in 2017 and never realized I had dash tweeters.
    At the time, Crutchfield only gave me options for the front and rear doors, and I’d previously removed the middle dash speaker grille to see that there was nothing there.
    Stereo sounds so much better now!
    Then I did the rear diff breather mod and relocated it to behind my taillight. Hopefully with Hurricane Ian making its way towards us I don’t have to test it out!
    Lastly, I changed the diff fluid. It’s been about 35K miles since the last time I did it. Fluid was dark and stinky but not nearly as bad as the last time I did it.
    I used the Valvoline FlexFill bags this time, it was easier that using my cheap bottle pump but I’m not sure if I like it. Each bag still holds a decent amount of fluid and then you have to roll them like a tube of toothpaste to get them to empty.
    D4x4TRD, AZEric, Winning8 and 5 others like this.
  14. Sep 29, 2022 at 4:22 PM
    cougarhound
    cougarhound New Member
    I bought a very expensive diehard battery from Sear's that lasted less than a year. They didn't take it back cause their test said it was still good. I would say never again but I think they are bankrupt.
    Retroboy1989[QUOTED] likes this.
  15. Sep 29, 2022 at 5:40 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Thanks for the update!
  16. Sep 29, 2022 at 5:42 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    It’s nice to see some folks who still have their second gen after all these years!
  17. Sep 29, 2022 at 8:03 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Started early on pulling my rack and pinion and doing sway bar bushings and links plus Total Chaos Uniball UCAs. Turns out my front end issue of violent shake bent a cam tab. (Wasn't bent before). 65F0E512-DEED-43E3-BCD8-2D97CD7934CC.jpg
  18. Sep 29, 2022 at 8:53 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Been running diagnostics on my Tundra, 270k, due to there being an intermittent misfire on Cylinder 1... been on and off with no codes and had bee driving sluggish. Today, I decided to go all in, due to advantageous circumstances since my oil change was due. Started removing spark 1 and spark 3 and swapping them. If there was an issue I would find it once I was done with the oil and take it for a spin.
    Here is spark plug 1 and 2
    swapped them both and the misfire, jumped to Cyl 6. So, now its electrical I thought.
    I did pull both plugs without disconnecting the battery, so I thought, maybe I need to reset the computer, so I disconnected the battery and it felt super light.. kinda threw me off... but I moved. Left it for about 30 minutes, before I needed the truck and I discover a possible culprit to the issue.
    So far she has been alright, no issues that I've noticed.... Took for a spin and seems more responsive and quieter, lol..
    Ohannon7, Winning8, WVI and 5 others like this.
  19. Sep 29, 2022 at 9:28 PM
    Seattle996
    Seattle996 New Member
    LX470.. future Tundra owner
    Bought a '07 Tundra today :) 220k miles on the clock, got her mainly to pull the boat. Time to get her baselined and updated to my aesthetic.. Have a lot to learn and will be on this forum searching..
  20. Sep 29, 2022 at 9:29 PM
    Hotwire
    Hotwire New Member
    Montana
    Ordered the most expensive little pieces of rubber ever!
    AZEric, Ohannon7, 20GR8 Super and 5 others like this.
  21. Sep 29, 2022 at 10:34 PM
    Retroboy1989
    Northern Utah
    Advanced auto carries the diehard name now.
    Ohannon7 and NueveTundra like this.
  22. Sep 30, 2022 at 6:21 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    :thumbsup::fistbump:
    Hotwire and 20GR8 Super like this.
  23. Sep 30, 2022 at 1:34 PM
    Hotwire
    Hotwire New Member
    Montana
    I decided to throw in a carrier bearing drop today.
    wv00097, D4x4TRD, Peeeheeuuu and 7 others like this.
  24. Sep 30, 2022 at 2:30 PM
    Hotwire
    Hotwire New Member
    Montana
    I love it when it turns out to be something simple! Even if it drives you crazy for a while.
  25. Sep 30, 2022 at 6:45 PM
    blackdemon_tt
    Sure did... never noticed it since it was tucked where it was supposed to.. Only when I decided to pull the battery is when I noticed it.
    Hotwire[QUOTED] likes this.
  26. Sep 30, 2022 at 11:06 PM
    NueveTundra
    Planet Earth
    Got the rack and pinion pulled out, needless to say I struggled and made the biggest mess ever. :( I'm now pondering how I will get the other one in. Really don't want to drop the diff nor take apart the new one to slide it in. :oops: Guess I should look through my 12k page manual. :rofl:
  27. Oct 1, 2022 at 5:04 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Might search the forum a bit more.
    I know there is a thread which explains which part can be removed from the steering rack inorder to remove and install without removing the front differential. As I understand, it can not be done with the diff in place, without this method.
    At least you're half way there already!
    ....feeling generous (and the search was easy with google). I hope it helps
    https://www.tundras.com/threads/the...olutions-updated-10-2020-in-first-post.33539/
  28. Oct 1, 2022 at 7:03 AM
    Retroboy1989
    Northern Utah
    I did not know this was even possible without dropping the diff. I just had mine unbolted to replace the bushings and I thought there was no way on earth it was exiting the frame.
    Edit: I think Toyota advises you remove the engine to replace the rack.
    I'd drop the diff.
  29. Oct 1, 2022 at 3:05 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    I upgraded my visors with the lighted double visors from a junked Limited edition.
    Since I had the center console out I added some sound proofing.
    I steamed off the warnings because I hate them.
    I spliced in the power using these gadgets. I have an electronic rearview so I needed power to three separate wires. The light blue wire in the unused harness is switched power and the white with black stripe is negative.
    The original bulbs suck so I upgraded them to LED. Before/after:
    4D66FE13-DFF4-4F3D-B99B-9B3934AC5DD7.jpg 49B2E065-A4D0-47E8-9400-0E87AD4BDA95.jpg
    Visor works two ways now:
    But I lost or moved a grey switch thing inside the driver's center console light so... Two steps
    Forward, one step back.
    D4x4TRD, Peeeheeuuu, Ohannon7 and 7 others like this.
  30. Oct 1, 2022 at 3:30 PM
    Tundra1D6
    What’s the going rate for those sun visors ?
