What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. May 10, 2022 at 2:03 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    Installed these VLAND license plate lights which are crazy bright!
    671E0885-F0AF-4CB3-BBD1-94FF6E9EEC4A.jpg 34FFBB04-CE86-4743-966B-EBA858D5C8E1.jpg
    Unfortunately they interfered with my backup camera image in reverse
    So then I found out about the DIR (disable wile in reverse) harness which was available for gen 1 and 2.5 tundras. Was able to work with @daveeasa to get a harness made that works with 2nd gens.
    So I got that installed and it’s much better now that the license plates turn off while in reverse
    F627FDA9-621A-42FE-8239-F2B954542E11.jpg 43F68190-F186-41D6-8796-583E35B362F6.jpg
    omgboost, AZEric, D4x4TRD and 12 others like this.
  2. May 12, 2022 at 2:58 PM
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    Today I swung by the tire shop and picked up a used full size spare to replace my dry-rotted factory one.
    At 295/70-18 I needed to remove these brackets to get the spare into the factory location.
    Prostar 190, omgboost, MTRock and 6 others like this.
  3. May 12, 2022 at 5:01 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    What shackles are you running currently?
  4. May 12, 2022 at 5:44 PM
    Hotwire
    Hotwire New Member
    Montana
    They are stock. I’ll make my final decision on rear suspension after I level the front.
  5. May 12, 2022 at 7:47 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    I installed a new tailgate handle assembly. Works great.
  6. May 13, 2022 at 4:13 PM
    surffj62
    surffj62 New Member
    2011 DBL RW
    How hard is it to get those brackets out for spare?
  7. May 13, 2022 at 5:13 PM
    Jorgesworld86
    Jorgesworld86 New Member
    Orange County,CA
    2013 Tundra Limited Rock Warrior
    New TRD sway bar and RCI skid plate
  8. May 15, 2022 at 12:53 PM
    azimuth
    azimuth New Member
    2010 double cab SR5
    Got a coil pack code last Tuesday. #5 was failing. I learned from my 1st gen Tundra not to replace them as they go out and not to replace them with other than OEM Denso. I had a couple of coil packs I bought in advance. My truck is at 220,000 miles and that's about when my 1st gen packs began to die. So I installed one of the packs from my stock and ordered the other six from a trusted source. Installed the remaining seven packs today. Pretty easy on the driver's side. Had to take the airbox out to access the #2 cylinder pack. The remaining went it easy.
    The bummer of waiting until they go out to replace is that until they all die and get replaced, you can be almost anywhere when one dies. then it's limp home or worse. Even after you have them all replaced, they are staggered and will die that way when the time comes. It just delivers a more reliable vehicle to swap them all at once. Also, if you buy them from Vatozone or the like, you will likely be getting a Chinese copy. I did that with one on my 1st gen. It died at 20,000 miles. Yeah.
  9. May 15, 2022 at 1:10 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I got mine in as well; yesterday. Afterward I did some preventative maintenance on a small trailer that I picked up thirdhand. By the time that I left work where I did the install I had pretty much completely forgotten about having installed the sway bar. Not 50 yards down the road on the first 15 mph corner I could tell that it was different from the Sequioa bar that I had just removed. I dropped the trailer at home and headed to the grocer. The first curve on the interstate was better as well. The initial turn-in seems like a smidge more effort is needed to initiate and the vehicle feels flatter throughout the maneuver. We have a ton of roundabouts locally and there's slightly less body roll there as well. The rear TRD sway bar offers the greatest improvement, the front Sequoia bar a bit of additional improvement over the stock front bar, and the TRD a slight improvement over the Sequoia bar, from my perspective. YMMV. :hattip:
  10. May 15, 2022 at 1:16 PM
    jgutierrez89
    jgutierrez89 New Member
    Jose
    San Diego
    2021 White Crewmax TRD Sport
    7ED6AF59-E546-47D7-8849-DB19760CEC70.jpg DDED6FB3-E0C9-43E1-BBBE-259E9E19015F.jpg
    Installed Fox 2.5 c/o w/ Dirt King Uca’s.
    Waiting on the 2.0s for the rear to come in the mail. Then plan on adding amp steps and 295/70/17 Nitto Trail grapplers w/ 17x9 Summit wheels.
    wv00097, omgboost, MTRock and 2 others like this.
  11. May 15, 2022 at 1:21 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Almost sad the remote resi w/ fox logo will be covered with tire... Almost.
    Looking sweet already!
    joseph_womack likes this.
  12. May 15, 2022 at 1:46 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Pretty similar setup to what I have. You’re going to love it.
    P.S. You are always welcome to hang out in the coolest thread ever, especially since you have the fastest color, but here is the one for all the 2.5gens.
    https://www.tundras.com/threads/what-have-you-done-to-your-2-5-gen-tundra-today.713/page-2409
    joseph_womack and Mountun Goat like this.
  13. May 15, 2022 at 4:50 PM
    Jorgesworld86
    Orange County,CA
    Yeah it’s nice having the whole package now front and rear. I can feel it handles a bit better and a bit less body roll. Worth the money imo
  14. May 15, 2022 at 4:58 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Fixed up my driver side front tire, that had a small Brad nail stuck causing me to lose psi every week.
    Jr. And I fixed it up using a $2 tire plug kit. 1st time doing it, was fun figuring it out. Jr and I had fun. :)
  15. May 15, 2022 at 8:49 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    the 4 tire guards/guides?
  16. May 16, 2022 at 8:12 AM
    surffj62
    surffj62 New Member
    2011 DBL RW
    Yes - the spare tire guides.
    Grind them or air chisel?
  17. May 16, 2022 at 9:10 AM
    joseph_womack
    Joe
    Louisiana
    If you are trying to remove them, I think most guys just take an angle grinder with a cut off wheel and cut them off as close as possible, then you can take a flap disk and grind it smooth and flush with the support (then hit it with some paint and you’re done)
    TheBeast and surffj62[QUOTED] like this.
  18. May 16, 2022 at 1:33 PM
    Kerplunk
    Kerplunk New Member
    Got a BlueDriver OBD-II reader. 2012 Tundra, 126k miles: no codes. Handy device. Exceeds expectations. I should plug it in to a BMW or Chevrolet to give it a real work out.
    Mountun Goat, TheBeast, WVI and 2 others like this.
  19. May 16, 2022 at 5:47 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Installed new plugs...
    They looked ok.
    I did find oil in a couple of the plug tubes, one had a good amount.
    I ordered a FelPro valve cover gasket set that will have new seas in it. As well, I ordered a sparkplug "boot kit" because I lost one of the coil seals. I looked for over an hour for it.
    I also did the last test I could find for checking the front wheel bears, trying to run down the loud "humming/howling" at 45-50 mph. Front wheel bearing seem to be in order, nor to check the rears.
    wv00097, MTRock, Filthyphil and 4 others like this.
  20. May 17, 2022 at 8:22 AM
    chrisf111
    chrisf111 New Member
    Found the squeek. Anti rattle clip had come loose and was slowly carving away at the inside of my rock warrior rims. :eek2:
    Little bit of bending and had it figured out.
    wv00097, D4x4TRD, Pistol0528 and 11 others like this.
  21. May 17, 2022 at 9:00 AM
    COTundie
    Trey
    Pretty things
    Well... at least it was wearing away your wheel evenly!
    Glad you corrected it
    MTRock, WVI and Mountun Goat like this.
  22. May 17, 2022 at 5:55 PM
    Tundra3k
    Tundra3k New Member
    Kansas
    2018 Crew Max
    Cleaned off about a million of dead bugs from my front bumper today :mad:
    wv00097, truckguy84, D4x4TRD and 10 others like this.
  23. May 17, 2022 at 6:16 PM
    joseph_womack
    Joe
    Louisiana
    Anyone here installed cruise control on a 07 that’s not pre-wired for it?
  24. May 17, 2022 at 11:01 PM
    Underdogg
    Underdogg New Member
    07 Crewmax 5.7L
    Man I want new suspension set up too but I'm broke right now haha
    Silverghost2 likes this.
  25. May 17, 2022 at 11:02 PM
    Underdogg
    07 Crewmax 5.7L
    Ayyy, I love the dechromed look on all the gens. Smart man
    aelarson[QUOTED] likes this.
  26. May 18, 2022 at 11:41 AM
    Hotwire
    Hotwire New Member
    Montana
    Yay......................maintenance o_O
  27. May 18, 2022 at 6:58 PM
    joseph_womack
    Joe
    Louisiana
    how much did each plug cost?
  28. May 18, 2022 at 9:53 PM
    Hotwire
    Hotwire New Member
    Montana
    $31.99/8
    OEM Iridiums
  29. May 19, 2022 at 8:35 AM
    joseph_womack
    Joe
    Louisiana
    Bought them online? Dealer in town wanted me to pay $12/1
  30. May 19, 2022 at 9:25 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Be careful buying plugs online, there are a lot of counterfeits that look just like the real thing.
