What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Mar 19, 2022 at 5:32 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
  2. Mar 19, 2022 at 5:36 PM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    Yeah I just picked up one from advanced autoparts
    joseph_womack and NueveTundra like this.
  3. Mar 19, 2022 at 5:39 PM
    NueveTundra
    Planet Earth
    I made the mistake originally of clicking off the 12 point and have both a 6 and 12 :rofl: glad you found one local :)
    joseph_womack and AstroDude like this.
  4. Mar 19, 2022 at 6:18 PM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    Just scrubbed up the all weather mats and gave a good brush, blow, vac, extract on my filthy ass carpet. These black floors hide an amazing amount of crud!!
  5. Mar 19, 2022 at 6:24 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Picked up all of the items to pull apart my hub assembly as well... Then I put them in a drawer, unused for another occasion.
    Physics will mandate some raising of the truck along with the lifting of the LCA, but will not lift the truck off the jack stands when only lifting enough to compress the suspension adequately to decrease the angle of the CV axle.
    Nothing wrong with digging deeper into your truck than necessary... if you put everything back together correctly
  6. Mar 20, 2022 at 5:56 PM
    FredB32
    FredB32 New Member
    2011 TRD RW
    Got around to installing my Alpharex headlights. Now to just figure out the birds nest of the DRL wiring...and the sequential turn signal. I swear I followed the instructions, but when I did it per them, the turn signals in the front didn't work and fast blinked like there was no bulb installed. I'll figure it out this week... Maybe ‍♂️
    D4x4TRD, aelarson, WVI and 6 others like this.
  7. Mar 20, 2022 at 6:17 PM
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
    Took the engine cover off and gave it a good cleaning today!
    D4x4TRD, WVI, omgboost and 6 others like this.
  8. Mar 20, 2022 at 6:31 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    I finally finished the rear heated seats install. This probably looks really easy, but the switches were too deep to fit in that space so I had to make modifications and I broke a switch. And I scratched up the plastic so I covered it in vinyl which was harder than YouTube had led me to believe. Also running the wires under the carpet was a pain and the wires were too short so I had to lengthen them.
    Moved to my next project: replacing the drop-in bed liner with a bed rug. I found about 30 lbs of dirt and rocks, and of course, rust. You probably know exactly where I found it, too.
    So I ground out the rust which left a hole in the bed... Power washed it all today and I'll Corroseal the rust tomorrow.
    Question: Is it bad if I just patch the hole with some duct tape or Dynamat before putting in the bed rug? I'm not planning to haul anything extreme, but I don't want to literally sweep a problem under the rug either. But I also know there's rust I can't reach without removing the entire bed, a task that seems beyond my skill level.
    D4x4TRD, WVI, FredB32 and 5 others like this.
  9. Mar 20, 2022 at 6:58 PM
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Yeah. Took it to another shop, it's in alignment, so not even sure what the tech is saying now. Will deal with next time I'm there.
    joseph_womack[QUOTED] likes this.
  10. Mar 20, 2022 at 9:51 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    have fun on your travels man, latest insta caption is awesome (they all are of course) :fistbump:
  11. Mar 20, 2022 at 10:01 PM
    joseph_womack
    Joe
    Louisiana
    removing the bed isn't actually that difficult, unbolt those 6 bed bolts, and then from there if you just need a little more clearance underneath you could jack the bed up a little bit while watching the filler neck for the gas tank and some misc wires... granted though, actually removing the bed is slightly time consuming (remove filler neck for gas tank and misc wiring)
    if you know how to weld and it were me, I would weld the hole closed (if its just that dime sized hole in the photo) if the hole is any bigger than I would put a patch piece in. however welding rusty metal sucks and tends to burn through very easily... you could try spraying the rusty underside with a rust converter (rustoleum); I've been seeing this rust dissolver from Eastwood that you might want to try out
    PhotoNerd[QUOTED] likes this.
  12. Mar 21, 2022 at 4:48 AM
    iDon’tRead
    iDon’tRead New Member
    Took half the day Doing the front head rests and driver side , front by the knees still ain’t perfect but looks great so far
  13. Mar 21, 2022 at 6:34 AM
    PhotoNerd
    Tony
    Waterford, CT
    Thanks! It didn't occur to me to just raise the bed enough to get some rust converter or dissolver in there. I'll put that on my to-do list.
  14. Mar 21, 2022 at 10:59 AM
    pyrite808
    pyrite808 Real TRD Pros are built not bought
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    Got these nice sidio crates to clean up and organize all the camping gear. Purple one for food supplies will be kept in the house ready to go for a bug out situation.
  15. Mar 21, 2022 at 3:35 PM
    PhotoNerd
    Tony
    Waterford, CT
    I previously had installed LED bed lights, but they operated with a switch and I would always forget to press it so I never used it. Also if I forgot to turn it off it would kill the battery.
    Today I bypassed the switch and attached the negative terminal to a switch that's triggered when I open the tailgate. Now the lights turn on like the refrigerator door.
    This is the switch wired to the negative on the lights. Note that I ran the wire through the wrong hole in this picture:
    This is a screw glued to my finger so I could fish it through the brake light opening into the little whole I drilled. Did I invent this? Can I now put Redneck Engineer on my resume?
    Here it is installed and trimmed to proper length:
    Here are the lights functioning:
    I'm putting a bed rug in soon. Here's where I snaked the positive wire:
    The wire between the left and right lights runs underneath the bed above the spare. It's all accessible by removing the brake lights. There's a shocking amount of room in there.
    wv00097, Jego, BigSkyTaco and 13 others like this.
  16. Mar 21, 2022 at 4:24 PM
    tundratoofun
    Glendale
    Beast
    Hauled a few loads of appliances
    worktruckwhite, D4x4TRD, WVI and 8 others like this.
  17. Mar 21, 2022 at 5:41 PM
    tundratoofun
    Glendale
    Beast
    That's my redneck cargo slide/dinner table/headache rack mod.
    Mountun Goat and joseph_womack like this.
  18. Mar 21, 2022 at 6:02 PM
    PhotoNerd
    Tony
    Waterford, CT
    Ok fine I installed the bed rug. But repainting and installing the tie-downs will have to wait.
    22D7E9C9-961E-46AE-B405-2A8F975C360B.jpg 99743C82-4E8D-4942-B9EC-02FBE5B303C1.jpg
  19. Mar 21, 2022 at 8:34 PM
    worktruckwhite
    Charleston, SC
    2010 White Crewmax
    thanks bro, not to trash the thread up.. but crazy that people actually enjoy what I create. Never would've imagined that, still hard to believe sometimes.
  20. Mar 22, 2022 at 7:00 AM
    WVI
    WVI New Member
    @008 Tundra Limited
    Installed new foglights on Sunday and swapped the wheels so I can paint the steelies....benn on meds since as my back went out while doing it..
    Ordered difii and TC fluids yesterday.
  21. Mar 22, 2022 at 1:03 PM
    KJJ2007
    KJJ2007 New Member
    Kris
    Earth
    2007 Tundra RCSB
    S@B Cold Air Intake, Lowered 8" in the rear, 4" in the front, Tented taillights.
    Installed a new Left front window regulator Sunday. Right side will be sometime this week.
  22. Mar 22, 2022 at 2:43 PM
    NueveTundra
    Planet Earth
    Just did my rear Rotors and Carbon pads from PowerStop my front ones should be here soon today. Also painted my Calipers black with Ceramic Caliper paint also made sure to put some cooper never seize on the hub for the future.
  23. Mar 22, 2022 at 9:34 PM
    iDon’tRead
    Couldn’t wait till the weekend so installed the Morimoto s tonight instead 27BD0313-FAAB-4A4F-95FD-FC600B64CB9D.jpg
  24. Mar 22, 2022 at 10:58 PM
    bdogg76
    bdogg76 New Member
    Brandon
    2008 Slate Tundra Crewmax TRD
    Falken Wildpeak 265/70/18s. Leveling Kit. Bedrug XLT Bed Mat.
    What do you think of them so far?
  25. Mar 23, 2022 at 5:08 AM
    War Machine
    War Machine SSEM # 5 3MW
    I wouldn’t recommend. The tint started peeling on them probably six months in.
    joseph_womack likes this.
  26. Mar 23, 2022 at 6:19 AM
    MPG_LOL
    MPG_LOL New Member
    Paul
    2012 Black Toyota Tundra
    Leveling Kit, 20" Wheels, KO2 Tires
    How you liking the Morimoto's? You should do the fog lights too!! :)
  27. Mar 23, 2022 at 10:35 AM
    iDon’tRead
    Definetly brighter and leveler function I can see the lights adjusting EFF29B35-01EE-4338-8FD3-6BA430448E98.jpg
    Can’t wait to get off work and drive in the dark with them on
    CaliBPGen2, D4x4TRD, MTRock and 5 others like this.
  28. Mar 23, 2022 at 11:42 AM
    Redman333
    Redman333 New Member
    Jared
    Tundra
    Yes
    Nice I like the tailgate switch idea. Where’d you get the switch from. I was going to do this also but to have a dummy light on the dash to let me know the tailgate is open. I’ve driven off several times with the tailgate open and valuables inside. Luckily I haven’t lost anything yet. Though I’d like to tie it to the bed lights also that’s a good idea.
  29. Mar 23, 2022 at 11:44 AM
    Redman333
    Jared
    Tundra
    Yes
    Got the rest of my lift in finally. Will be trying to tuck my 37s under the truck. The wheels and tires came in last week and couldn’t wait so I threw them on to see if they’d fit. They didn’t. Still rubbing a small amount at full lock if I hit a bump.
  30. Mar 23, 2022 at 5:04 PM
    NueveTundra
    Planet Earth
    Got the front Rotors and pads and caliper painting done today, Tomorrow will do the fluid flush and brake in process. :)
    D4x4TRD, COElkHunter, WVI and 3 others like this.
