What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Feb 11, 2017 at 7:53 PM
    #1171
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
    It's the Fortin Evo. It's awesome. Uses my Factory fob so I don't have an additional fob to carry around, and was moderately easy to install. One harness plug, 8 wire connections, and a 5-step programming process. Lock 3x starts the truck, it's runs for 15 mins. Cool feature is if I pull up somewhere just to hop out real quick, I can hit the lock button three times, and take the key out and the truck will stay running. Also, it doesn't shut off when you unlock, I can throw the key, turn to on, and drive away. I'm really happy with it, and for $200 I don't think it honestly gets any better.
  2. Feb 11, 2017 at 8:29 PM
    #1172
    TheBeast The Beach
    installed Toyota hitch cover...
  3. Feb 11, 2017 at 9:12 PM
    #1173
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  4. Feb 11, 2017 at 9:14 PM
    #1174
    SlickRick2013Tundra
    SlickRick2013Tundra #10
    Rick
    Mandeville, LA
    13 TRD CM MGM 4x4
    Toytech Boss 3in Lift kit Iron Cross side step TRD Sway Bar TRD Cold Air Intake Blacked out Badges Blacked out front and rear bumpers
    Let's see a picture
    TheBeast[QUOTED] likes this.
  5. Feb 12, 2017 at 9:01 AM
    #1175
    Dgoll75
    Dgoll75 New Member
    New steering wheel. When I bought my truck the I found the prior owner had handicapped aids on it at one time. No big deal except the steering wheel was crushed and split where his spinner had been. Found this MIT steering wheel on eBay. I was a bit reluctant but figured for $200 I would give it a shot. Well after a week, I feel it's very comfortable, well made, and definitely unique. Install was easy. Took 30 minutes. IMG_6982.jpg
    Tor, DalTee, Wynnded and 1 other person like this.
  6. Feb 12, 2017 at 10:29 AM
    #1176
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Touched up my wheels, needed a fresh coat. Dropped off my Rhino step tubes to be Bullet Lined. Thinking of leaving grill chrome. What you guys think? Syke. Prepping for grill and surround to get bullet lined .20170212_114122.jpg20170212_114109.jpg
  7. Feb 15, 2017 at 6:34 PM
    #1177
    digdug
    digdug New Member
    Doug
    2008 Crewmax
    5" BDS Fox 2.5 BDS UCA TRD stabilizer Airlift wireless one 35x12.5 Venom Power Terra Hunter XT 20" Hard Rock Indestructible
    Looks great!
  8. Feb 15, 2017 at 6:41 PM
    #1178
    digdug
    digdug New Member
    Doug
    2008 Crewmax
    Installed a Aries Bull bar
    Installed led footwell lights
    Installed new Kenwood DNX893S but don't have any pictures yet.
    Exhaust coming next week and I have a RW grill I am color matching and will then install
    LED light bar coming on Friday to install on the new bull bar
    And then ... I need to stop for awhile or my wife will have me sleeping in it .... lol
    ~dig
    NewImprovedRon and TheBeast like this.
  9. Feb 15, 2017 at 8:09 PM
    #1179
    TheBeast The Beach
    looks good. RW grille will change the front end for sure. Love mine. Hated the chrome.
  10. Feb 16, 2017 at 8:00 AM
    #1180
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    Finished installing Coachbuilder shims on top of Bilstein 6112s at top setting, Dakar rear springs, Coachbuilder +1 shackles, Bilstein 5160 rear shocks.
  11. Feb 16, 2017 at 11:23 AM
    #1181
    rons23
    Ron
    Kill Devil Hills
    Did you install the shims to compensate the lower driver side. Was just curious because I was told that installing the 6112's alone@ top setting would rectify that. Would like to know if I need to purchase shims as well. Thanks Tundra looks awesome!
    scotch[QUOTED] likes this.
  12. Feb 16, 2017 at 11:30 AM
    #1182
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    I installed the 6112's on the top setting with no spacers and had the driver's side 1/2" lower than the passenger side (which caused the passenger rear to raise up as well). Used one coachbuilder shim on the driver's side to raise it level to the passenger side. Used an additional shim on each side to raise both side's up another 1/2" over the top setting on the 6112. So 2 shims on the driver's side, one on the passenger side.
    Ground to fender measurements: LF 41", RF 41", LR 42.75", RR 43"
    side view:
  13. Feb 16, 2017 at 11:36 AM
    #1183
    rons23
    Ron
    Kill Devil Hills
    Thanks good to know
  14. Feb 16, 2017 at 4:28 PM
    #1184
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Truck looks great scotch! I've got the 6112's on the top setting on my truck to. I've had the three shims from coach to do the same as you. Kinda leary about the alignment without ucas. Did yours align ok? Did you have to pull everything apart to get the shims in Or were you able to just drop the coilovers down and slip them in.
    scotch likes this.
  15. Feb 16, 2017 at 4:30 PM
    #1185
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Moved mine from one side of the driveway to the other. That's all I had time for
    digdug likes this.
  16. Feb 16, 2017 at 4:56 PM
    #1186
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    I have SPC/LR upper control arms that I installed with my previous suspension setup. The shims, I just dropped them down and slid them in. They sit on top of the upper spring mount.
    Driver's side, 2 shims. 1 for driver's side lean 0.5", 1 for an additional 0.5" for a total of 1" over 6112 top position = 41" from ground to fender
    Passenger side, 1 shim for +0.5" over 6112 top position = 41" from ground to fender
    Silverghost likes this.
  17. Feb 16, 2017 at 5:58 PM
    #1187
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The shadows in your first picture makes it look like the UCA is cracked and broken.
    TheBeast likes this.
  18. Feb 16, 2017 at 6:09 PM
    #1188
    rons23
    Ron
    Kill Devil Hills
    It was, I can see the weld repair. Mig it is.
    TheBeast and Wynnded[QUOTED] like this.
  19. Feb 16, 2017 at 6:19 PM
    #1189
    rons23
    Ron
    Kill Devil Hills
    To be honest scotch, don't know who did the welding, but it needs reinforcement. I can see the edges on both sides. Needs a cap bead or 2 to bring it out just above flush. Your asking for trouble with that arm. Potential for a crack is a good possibility.
    NewImprovedRon and Wynnded like this.
  20. Feb 16, 2017 at 6:29 PM
    #1190
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Been hearing some bad things about spc's. That's no bueno, don't think I would keep driving on those. Or even try to weld them.
  21. Feb 16, 2017 at 6:30 PM
    #1191
    650h1
    650h1 New Member
    Will running stock ucas with 3" of lift fuck your tires up?
  22. Feb 16, 2017 at 6:49 PM
    #1192
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    Yikes! Nothing has been done to them, I bought them new from toytec about two years ago. I'll check them more closely tomorrow in the day time.
  23. Feb 16, 2017 at 6:50 PM
    #1193
    rons23
    Ron
    Kill Devil Hills
    I could be wrong, but sure looks like weld to me. Try getting a better pic.
  24. Feb 16, 2017 at 7:02 PM
    #1194
    rons23
    Ron
    Kill Devil Hills
    I'm not a suspension expert, but I believe the control arm is machined out of a piece of metal, whatever there using (mild, high tensile, iron, etc. I for 1 second wouldn't think Toytec would sell you a repaired control arm. Very interested in this.
  25. Feb 16, 2017 at 7:08 PM
    #1195
    TheBeast The Beach
  26. Feb 16, 2017 at 7:15 PM
    #1196
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The second picture of the other side looks better. It could just be the light angle. The only machined UCAs that come to my mind are the Icons. Everything else I've noticed are welded.
  27. Feb 16, 2017 at 7:45 PM
    #1197
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Installed OEM style fender flares to tone down the prod from the 20 x 35' tires. Sweeettt!!!
  28. Feb 18, 2017 at 12:35 PM
    #1198
    rons23
    Ron
    Kill Devil Hills
    Got my step tubes Bullet Lined. I like it. Also vinyl wrapped the tips of my horns. I think they look better than dipped completely red. Planned on bullet lining my grill and surround, but ran into trouble trying to remove factory grill. All of the nuts stripped on me. Toyota poor design or should I say going cheap route. I wonder . Anyway I got friends in low places, haha. Getting another grill to replace. Also installed my AJT DESIGN Custom Battery Bracket. :cool: 20170218_125917.jpg20170218_134811.jpg20170218_125928.jpg20170218_132556.jpg20170218_145049.jpg
  29. Feb 18, 2017 at 1:19 PM
    #1199
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Bet it took hours....:rofl::rofl: Just kidding :thumbsup:
  30. Feb 19, 2017 at 3:54 PM
    #1200
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Installed my new shift knob
    joonbug, Black Wolf, digdug and 2 others like this.
