What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Aug 28, 2021 at 7:03 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I bet it was pretty filthy
    TundraTRD08[QUOTED] and Rica25 like this.
  2. Aug 29, 2021 at 5:14 AM
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    Washed & waxed 1/2 of my fleet yesterday including the 2007 Limited Crewmax 4x4 Tundra, 2006 Lexus GX470 and the 2001 Ford 7.3 Liter Diesel Super Duty E350 Van.
    O.S.T.
  3. Aug 29, 2021 at 5:32 AM
    TundraTRD08
    TundraTRD08 Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    Oh you can bet it was.
    Rica25 likes this.
  4. Aug 29, 2021 at 9:41 AM
    McYoda
    McYoda H4x0r
    Brady
    Oregon
    2010 “Grade”
    They look great! How long did it take?
  5. Aug 29, 2021 at 11:54 AM
    0.S.T.
    0.S.T. New Member
    EAST COAST
    Thank you for the kind words. About 5 hours.
    Thank goodness, I started while my big tree was blocking the blazing sunshine in the driveway.
    O.S.T.
  6. Aug 29, 2021 at 1:30 PM
    Rozr1
    Rozr1 New Member
    2008 SR5 DC
    I believe they are some older spider taillights. I got the tundra with them already on. Fitment and output are OK but they have some leds burned out. I'm going to go with the alpahrex taillights most likely come this black friday.
  7. Aug 29, 2021 at 1:36 PM
    Rozr1
    Rozr1 New Member
    2008 SR5 DC
    Nice, my tundra came with an old alarm that has 3 damn annoying beeps and also can't unlock all doors with my keyfob. Only unlocks driver door, might have to look into this.
    Rica25 likes this.
  8. Aug 29, 2021 at 7:21 PM
    ATUTundra
    ATUTundra New Member
    Installed Iron Bull front and rear bumpers. I traded my stock bumpers for these bumpers. Found a guy on FB Marketplace wanting stock. I traded straight up. FREE! $3,000 worth of bumpers. They are heavy but they will do for FREE :)
  9. Aug 30, 2021 at 3:49 PM
    Rozr1
    Rozr1 New Member
    2008 SR5 DC
    Had a left turn signal bulb go bad on an replaced it with an amber bulb, think it looks better then the off white bulb that on there before. Also replaced fogfights recently to some leds from Amazon.
  10. Aug 30, 2021 at 5:02 PM
    Wangofree
    Wangofree New Member
    Midwest
    07 Tundra Double Cab 5.7L
    That was one filthy throttle body!!
  11. Aug 31, 2021 at 1:50 PM
    TundraMax12
    TundraMax12 New Member
    Dom
    2013 TSS Crewmax
    I am about to cross 100k miles and this did not occur to me to be an item to address. Were there certain signs that made you believe this needed to be cleaned? Was the truck performing oddly? Can you explain how you cleaned these two things and anything to look out for or avoid?
    Rica25 likes this.
  12. Aug 31, 2021 at 2:38 PM
    Shanet421
    San Diego,CA
    It’s a pretty straightforward job. I pulled the intake lid and intake tubes. From there it’s 1 electrical connection and 2 Phillips head screws to remove the MAF sensor. I would only use MAF specific cleaner on it. (Do not drop it)
    Throttle body is 1 electrical connection and 4 10mm bolts. I just left the coolant lines connected to the TB. There is plenty of slack on those lines to lift the TB and put rags down over the engine. I used a whole can of TB plate cleaner and a rag to wipe inside clean. Reinstall and you can be sure you will see your idle RPMs go from 600 - 1,000 just until the truck’s computer relearns idle. (Couple days)
    There was nothing wrong with the truck that made me do this just trying to keep things clean and running well. It’s one of those things I hope to not put off this long next time. I would recommend every other year cleanings max.
    Wangofree and raymond_hb like this.
  13. Aug 31, 2021 at 2:48 PM
    raymond_hb
    raymond_hb New Member
    Oakland, CA
    07 Tundra Limited 2WD
    For me the only way to explain it, the truck felt like it was gasping for air while switching gears. When I first bought the truck from the beginning I felt it that way I thought “ well it is my first pickup maybe this is how it feels” when I finally found the forum and read a lot of guys doing mods I decided to put my hands under the hood and clean the throttle body. It was filthy, at least Shane was able to see copper color on the back mine was pitch black, there were bits of gunk falling off of it. After cleaning it the truck felt like it was breathing much better of course after that I added the TRD Airflow Accelerator and the aFe Dry Pro filter so so so so much better
    Shanet421 likes this.
  14. Aug 31, 2021 at 2:52 PM
    Shanet421
    San Diego,CA
    I did feel that same change you speak of. For me it was when I smoothed out the tubes on the way to the TB.
  15. Aug 31, 2021 at 3:00 PM
    raymond_hb
    Oakland, CA
    That’s very creative. With the mod did you notice anything different? Maybe MPG gains or maybe a little louder under the hood? I’ve got the 8” exhaust system from DD and I’m loving the sound so I’m looking for anything that’ll make it stand out without breaking bank
    Shanet421[QUOTED] likes this.
  16. Aug 31, 2021 at 3:08 PM
    Shanet421
    San Diego,CA
    I definitely noticed more of a grunt under the hood. The air is less confused feeling it’s not bouncing around inside the resonator. I also did the TRD accelerator at the same time.
    As far as MPGs I really don’t think so. I did see an increase in gas mileage after I swapped the diff and trans fluids. Guess less friction down there.
    I think I have a caliper dragging a bit in the rear now. I’m chasing a squeal at low RPMs. It’s sure to hurt MPGs
    That being said my commute is 90 miles a day with mostly freeway miles. Computer says 13.9 MPG with 295/70/18 load E rubber
    raymond_hb[QUOTED] likes this.
  17. Aug 31, 2021 at 4:06 PM
    raymond_hb
    Oakland, CA
    As promised the report:
    it’s been well over a month now and my report for the MPG’s are mix. Before the swap I was getting 14.0 now my area is all city I live in the Bay Area so there is a BUNCH of traffic not LA traffic but still enough. There are a few hills here and there and very high winds. I do hike and I’m always up and down the mountains so yes I believe the 14.0 reading seemed accurate
    After the install I went to Lake Tahoe and in those hills I can tell you it felt HORRIBLE. That pedal made my truck feel like it had no power at all. With the old pedal those hills were a breeze. While in the Tahoe/Reno area my MPG went up by 0.3 which is my typical gain after a long trip and it remained like that while in the area. I also noticed the more I drove around the better. That pedal break in process was a bit long but those hills and open highways really helped me out.
    After I returned I kept an eye on the reader and it stayed the same for about a week or so. After it dropped down to 14.2 which I wasn’t expecting in all honesty I was expecting to drop down to my usual 14 as it always does after a trip but nope. Now I know I said on the hills it sucked because at the beginning it really did I mean I had the pedal on the floor and no budge but most recently I went to Stanislaus National Forest/Mono Lake area for some easy off roading and the pedal performed great. Of course I’ve had some time from July 19 to now to really test the pedal up and down hills and mountains and I’ve got it exactly where I want it. All control to me the pedal reacts exactly when I want it to react like it did originally, no more mountain/hill driving problems and definitely no dirt problems.
    I’ve recently purchased a DD system and I can tell you I have been rough riding that thing like no tomorrow. MPGs have stayed the same and I cannot be happier with that pedal on because the old one would’ve had me bouncing around with the added power.
    I hope my report helps you in some way and I do apologize for the long report lol
  18. Aug 31, 2021 at 4:12 PM
    raymond_hb
    Oakland, CA
    I like that, that’s exactly what I want to continue doing. Like I said before, what I’ve gotten out of this truck is a feeling of not enough air flow I might be way off but I’m looking for anything that’ll let her breath better and better.
    All things considering, I think I might do the same mod to the tube as I am already thinking of doing the throttle body bypass and I’m glad you mentioned the diff and trans fluid change because that’s also on my list to cross off seems like it worked really well for you. And with the size tire and commute distance yes I think the tube and the fluid changes will definitely help me out. Thank you sir do you have the link to the mod by any chance?
  19. Aug 31, 2021 at 4:15 PM
    Shanet421
    San Diego,CA
    I hope this helps you out making the decision.
    https://www.tundras.com/threads/air-intake-tube-alternative.84222/
  20. Sep 1, 2021 at 6:03 PM
    Rozr1
    Rozr1 New Member
    2008 SR5 DC
    Finally installed the door light led and interior leds from kit I got on Amazon. Looks modern but the interior dome leds a little to bright for my liking. Easy cheap upgrade though.
    Mountun Goat, WVI, D4x4TRD and 5 others like this.
  21. Sep 2, 2021 at 1:52 PM
    zachzap361
    zachzap361 MEAN GREEN MACHINE
    Zach
    San Antonio
    2010 Green Tundra CrewMax
    Toytec Aluma 2.5 Coilovers and Toytec rear shocks, Method NV 17", Nitto Ridge Grappler 35", RCI Skid Plate, Dirtydeeds Dual Dumped Exhaust, Volant Cold Air Intake and Throttle Body Spacer, SDHQ Ditch Mount Brackets, Rigid Blackout Spot Lights, Stampede Fender Flares, N-Fab Nerf Bars, Morimoto Fog Lights, 55 watt HID's, AJT Design Climate Knobs, Ellis Precision Shift Knob, Coverking Seat Covers, Husky Floor Liner's,Demello Off-road Bumper, Rigid and Baja Designs Lights, Jomax ABS Sensor covers
    What I did today was just spend more money on some Jomax sway bar links and purchased the Powertrax grip pro and gotta get the Nitro 5.29’s next
    raymond_hb and omgboost like this.
  22. Sep 2, 2021 at 8:03 PM
    raymond_hb
    Oakland, CA
    So if I read correctly the Powertrax grip pro works with the stock LSD to improve it right? I’m assuming this would help a whole bunch more with off roads in some, not all, but some areas where 4x4 would be ideal. I’d love to hear feedback on this from you and what areas you’ve used it in
    zachzap361[QUOTED] likes this.
  23. Sep 3, 2021 at 6:36 AM
    zachzap361
    Zach
    San Antonio
    Well reason behind me buying the LSD and the new gears is cause I am running 35's and have lost A LOT of mpg since my lift and adding additional weight from the tires and the bumper so I would like to get a little better mpg and also not dump so much gas into engine when my foot is half way down on the throttle
  24. Sep 3, 2021 at 12:34 PM
    Shanet421
    San Diego,CA
    Put the GTR carbide 2 bulbs inside the interior from @Blang805
    3D04214D-072D-44AA-A12A-FC1F3065B542.jpg EAC292AC-4149-4D2B-839B-05B1A1469783.jpg
  25. Sep 3, 2021 at 12:48 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    My Tundra Build is finally done … I think lol
  26. Sep 3, 2021 at 12:53 PM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    glad to see you got those all set up. Enjoy!
    @Shanet421
  27. Sep 3, 2021 at 4:39 PM
    raymond_hb
    Oakland, CA
    Ah okay yes that makes more sense. Hopefully it helps you out thank you for letting me know. Good luck!
  28. Sep 3, 2021 at 7:39 PM
    Limited-07
    Limited-07 New Member
    2007 MGM limited crewmax
    Canopy, nothing crazy.
    Watched it click over to 320,000kms
    Added the cooper At3 XLT tires and bonus pictures from this last winter 899BA626-4AD5-45C0-B773-6BECC89E4AB4.jpg F5358ED6-FDBC-4D61-B640-9E2E346F3CF5.jpg 0009C61F-7305-4D2E-BE97-04465D566149.jpg
  29. Sep 5, 2021 at 8:32 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Finally got tired of the raw exhaust pipe on the side exit I had done. $30 for this Rough Country bolt on tip. That’ll do! Helps finish it off I think.
    368130E8-78D8-4BD7-8CC6-C5FCA7403516.jpg 6DD099E6-9099-47E7-9ACA-7E50A9C9A555.jpg 6FCAD277-55EB-4D8B-A4AF-5721D6F43C3F.jpg BBC1506C-826D-485B-B370-7CC689DEC544.jpg
  30. Sep 5, 2021 at 12:06 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    New TRD Faux Grill and VLED interior footwell lights (front and rear). To hell with the Gen 4 :image.jpg image.jpgD13F3202-F3DD-4E6B-B5CC-1C1F7B317BD9.jpg
